- Aug 30, 2002
- Southern USA
- Thread Starter
- #21
HiProfile said:Lemme get this straight, dpapag, you have a 120mm@69cfm pulling air out the front and 2 80mm@31cfm each pulling air out the back (PLUS the PSU's fan pulling air out)...I'm guessing you like negative pressure?
Maybe you should try flipping the 80mm exaust fans around until you make the heatercore use external air instead of internal air. If you do have the fans setup like I think, that 120mm is flowing well below the cfm its rated for.
That is correct, but your forgetting about the fan on the side (not pictured) of the case thats blowing air from the outside into the case. Let me make some changes and see what happens.
