- Aug 30, 2002
- Southern USA
I measured the temp of the water at the bottom of the T line. The T line is just after the outlet barb on the core. Temp of DI water in a cup at room temp was 23.6 C Temp of DI water in the T line while system was at full load was 30.6 C Temp of water after comp set for 1 hour after complete shut down was 26 C.
MBM 5 reports 45 C full load, 41 C idle. This is at 13 x 166 at vcore of 1.70. I'm waiting on a probe so I can stick it near the CPU core and get an actual temp reading at full load. My system has only 1 panaflo fan and a shroud. I don't think that the fan is spinning at a high RPM because it is very quiet. Everything else has been hooked up properly. Are my water temps too high? Given that my water temps are at 30.6 C, is there a way to estimate for now what the temp of the CPU on die is? MBM 5 only reports the area below the core.
