OC Noob said:
There are already a ton of pics and screen shots and it take a bit of time to open the htread. You may want to cut some of the less important images out so 56kers can view it.
That rad is killer. Great job!
Current rads are lacking. I'm glad to see someone with the tools and know-how is working on a better rad. Rads just aren't pretty like poly top blocks and don't get the attention they deserve.
Most rads can keep water temp down at okay levels, but they are pretty limited in the ammount of heat they can remove. Sure with lower voltages they are fine, but maintaining decent water temps with extreme voltages and multiple blocks isn't the easiest thing to do. Your rad should allow people to crank the voltages to levels current rads just can't handle. Great job!
oo bad it is limited by ambient temps. I'd like to see how it performs at 80 degrees F with a more mainstream pump.
Hopefully it works as planned. Keep us posted.
That good that you understood so that the radiators and systems are destined that I manufacture, they were projected to break barriers from where you can go using wc, as the ones that I broke with him.
He works with rest where the best systems already built of wc they saturate and they elevate the landing than he can get with watercooling for close to many active systems as vapos and chillers, I work with 2700 mhz 2,1v without any saturation sign, the limit of the system this a lot besides the heat that I get to generate, it was made for that,
I would like to change the people's concept of what it is a watercooling and the one that he can do in extreme systems, F2 exalts will be permitted that.
It would be a tremendous waste not to take advantage of the exelentes waterblocks that we have today and your potential in poor systems
I am always the disposition and I will continue here, now returning to the members of that forum a knowledge little bit of how much was reviewed me in the past.
with relationship to the tests, I have here some prototypes of smaller radiators using the same technology but with cheaper components than has exelent perfomance, when it is opportune I will publish for you them results
thank you very much for everything and be happy
Ivo Guihon ( Copyman )
