- Apr 16, 2009
- Prince George, B.C.
so i just installed HFM (had forgotten to do it for almost a week) and for the first time in my 5 years of folding i have to deal with failed WU's. Since its the first time I've dealt with failed WU's i don't know what to look for in the log(posted below).
The clocks i'm running have never given me this issue in the past and im running the same voltages as always which have been stable at 24 hours of IBT. 4.5ghz cpu at 1.32V, gpu's are 1ghz each at the locked 1.2V
thoughts?
thoughts?
*********************** Log Started 2013-06-20T17:45:43Z ***********************
17:45:43:************************* Folding@home Client *************************
17:45:43: Website: http://folding.stanford.edu/
17:45:43: Copyright: (c) 2009-2013 Stanford University
17:45:43: Author: Joseph Coffland <[email protected]>
17:45:43: Args:
17:45:43: Config: C:/Users/Brad/AppData/Roaming/FAHClient/config.xml
17:45:43:******************************** Build ********************************
17:45:43: Version: 7.3.6
17:45:43: Date: Feb 18 2013
17:45:43: Time: 15:25:17
17:45:43: SVN Rev: 3923
17:45:43: Branch: fah/trunk/client
17:45:43: Compiler: Intel(R) C++ MSVC 1500 mode 1200
17:45:43: Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
17:45:43: /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
17:45:43: Platform: win32 XP
17:45:43: Bits: 32
17:45:43: Mode: Release
17:45:43:******************************* System ********************************
17:45:43: CPU: Intel(R) Core(TM) i7-2700K CPU @ 3.50GHz
17:45:43: CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
17:45:43: CPUs: 8
17:45:43: Memory: 15.95GiB
17:45:43: Free Memory: 14.63GiB
17:45:43: Threads: WINDOWS_THREADS
17:45:43: Has Battery: false
17:45:43: On Battery: false
17:45:43: UTC offset: -7
17:45:43: PID: 2208
17:45:43: CWD: C:/Users/Brad/AppData/Roaming/FAHClient
17:45:43: OS: Windows 7 Ultimate
17:45:43: OS Arch: AMD64
17:45:43: GPUs: 2
17:45:43: GPU 0: ATI:4 Barts XT [ATI Radeon HD 6800 Series]
17:45:43: GPU 1: ATI:4 Barts XT [ATI Radeon HD 6800 Series]
17:45:43: CUDA: Not detected
17:45:43:Win32 Service: false
17:45:43:***********************************************************************
17:45:43:<config>
17:45:43: <!-- Folding Slot Configuration -->
17:45:43: <power v='full'/>
17:45:43:
17:45:43: <!-- Network -->
17:45:43: <proxy v=':8080'/>
17:45:43:
17:45:43: <!-- User Information -->
17:45:43: <passkey v='********************************'/>
17:45:43: <team v='32'/>
17:45:43: <user v='Rustyfender'/>
17:45:43:
17:45:43: <!-- Folding Slots -->
17:45:43: <slot id='2' type='CPU'>
17:45:43: <cpus v='7'/>
17:45:43: </slot>
17:45:43: <slot id='0' type='GPU'>
17:45:43: <client-type v='beta'/>
17:45:43: </slot>
17:45:43: <slot id='1' type='GPU'>
17:45:43: </slot>
17:45:43:</config>
17:45:43:Trying to access database...
17:45:43:Successfully acquired database lock
17:45:43:Enabled folding slot 02: READY cpu:7
17:45:43:Enabled folding slot 00: READY gpu:0:Barts XT [ATI Radeon HD 6800 Series]
17:45:43:Enabled folding slot 01: READY gpu:1:Barts XT [ATI Radeon HD 6800 Series]
17:45:43:WU00:FS01:Starting
17:45:43:WU00:FS01:Running FahCore: \"C:\\Program Files (x86)\\FAHClient/FAHCoreWrapper.exe\" C:/Users/Brad/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/beta/Core_17.fah/FahCore_17.exe -dir 00 -suffix 01 -version 703 -lifeline 2208 -checkpoint 15 -gpu 1 -gpu-vendor ati
17:45:43:WU00:FS01:Started FahCore on PID 3596
17:45:43:WU00:FS01:Core PID:3636
17:45:43:WU00:FS01:FahCore 0x17 started
17:45:43:WU03:FS02:Starting
17:45:43:WU03:FS02:Running FahCore: \"C:\\Program Files (x86)\\FAHClient/FAHCoreWrapper.exe\" C:/Users/Brad/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 03 -suffix 01 -version 703 -lifeline 2208 -checkpoint 15 -np 7
17:45:43:WU03:FS02:Started FahCore on PID 3644
17:45:43:WU03:FS02:Core PID:3656
17:45:43:WU03:FS02:FahCore 0xa4 started
17:45:43:WU01:FS00:Starting
17:45:43:WU01:FS00:Running FahCore: \"C:\\Program Files (x86)\\FAHClient/FAHCoreWrapper.exe\" C:/Users/Brad/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/beta/Core_17.fah/FahCore_17.exe -dir 01 -suffix 01 -version 703 -lifeline 2208 -checkpoint 15 -gpu 0 -gpu-vendor ati
17:45:43:WU01:FS00:Started FahCore on PID 3668
17:45:43:WU01:FS00:Core PID:3680
17:45:43:WU01:FS00:FahCore 0x17 started
17:45:44:WU03:FS02:0xa4:
17:45:44:WU03:FS02:0xa4:*------------------------------*
17:45:44:WU03:FS02:0xa4:Folding@Home Gromacs GB Core
17:45:44:WU03:FS02:0xa4:Version 2.27 (Dec. 15, 2010)
reparing to commence simulation
17:45:44:WU03:FS02:0xa4:- Ensuring status. Please wait.
17:45:44:WU01:FS00:0x17:*********************** Log Started 2013-06-20T17:45:44Z ***********************
roject: 8900 (Run 226, Clone 0, Gen 33)
17:45:44:WU01:FS00:0x17:Unit: 0x0000002a028c126651a658cbd81d452c
17:45:44:WU01:FS00:0x17:CPU: 0x00000000000000000000000000000000
17:45:44:WU01:FS00:0x17:Machine: 0
igital signatures verified
17:45:44:WU00:FS01:0x17:*********************** Log Started 2013-06-20T17:45:44Z ***********************
roject: 8900 (Run 407, Clone 1, Gen 26)
17:45:44:WU00:FS01:0x17:Unit: 0x0000001b028c126651a68124a879bd5a
17:45:44:WU00:FS01:0x17:CPU: 0x00000000000000000000000000000000
17:45:44:WU00:FS01:0x17:Machine: 1
17:45:45:WU00:FS01:0x17: Found a checkpoint file
17:45:45:WU01:FS00:0x17: Found a checkpoint file
17:45:53:WU03:FS02:0xa4:- Looking at optimizations...
17:45:53:WU03:FS02:0xa4:- Working with standard loops on this execution.
17:45:53:WU03:FS02:0xa4:- Previous termination of core was improper.
17:45:53:WU03:FS02:0xa4:- Files status OK
17:45:53:WU03:FS02:0xa4:- Expanded 2079299 -> 5386224 (decompressed 259.0 percent)
17:45:53:WU03:FS02:0xa4:Called DecompressByteArray: compressed_data_size=2079299 data_size=5386224, decompressed_data_size=5386224 diff=0
17:45:53:WU03:FS02:0xa4:- Digital signature verified
roject: 7809 (Run 4, Clone 175, Gen 39)
17:45:53:WU03:FS02:0xa4:Entering M.D.
17:45:59:WU03:FS02:0xa4:Using Gromacs checkpoints
17:46:00:WU03:FS02:0xa4:Mapping NT from 7 to 7
17:48:07:WU03:FS02:0xa4:Resuming from checkpoint
17:48:07:WU03:FS02:0xa4:Verified 03/wudata_01.log
17:48:07:WU03:FS02:0xa4:Verified 03/wudata_01.trr
17:48:07:WU03:FS02:0xa4:Verified 03/wudata_01.xtc
17:48:07:WU03:FS02:0xa4:Verified 03/wudata_01.edr
17:48:07:WU03:FS02:0xa4:Completed 76390 out of 1500000 steps (5%)
17:48:08:WARNING:WU03:FS02
etected clock skew (2 mins 15 secs), adjusting time estimates
17:48:33:WU01:FS00:0x17:Completed 1650000 out of 2500000 steps (66%)
17:48:43:WU00:FS01:0x17:Completed 1400000 out of 2500000 steps (56%)
17:56:06:WU03:FS02:0xa4:Completed 90000 out of 1500000 steps (6%)
18:04:17:WU03:FS02:0xa4:Completed 105000 out of 1500000 steps (7%)
18:05:15:WU00:FS01:0x17:Completed 1425000 out of 2500000 steps (57%)
18:05:22:WU01:FS00:0x17:Completed 1675000 out of 2500000 steps (67%)
18:12:30:WU03:FS02:0xa4:Completed 120000 out of 1500000 steps (8%)
18:20:41:WU03:FS02:0xa4:Completed 135000 out of 1500000 steps (9%)
18:21:18:WU00:FS01:0x17:Completed 1450000 out of 2500000 steps (58%)
18:21:28:WU01:FS00:0x17:Completed 1700000 out of 2500000 steps (68%)
18:28:58:WU03:FS02:0xa4:Completed 150000 out of 1500000 steps (10%)
18:37:14:WU03:FS02:0xa4:Completed 165000 out of 1500000 steps (11%)
18:37:49:WU00:FS01:0x17:Completed 1475000 out of 2500000 steps (59%)
18:37:58:WU01:FS00:0x17:Completed 1725000 out of 2500000 steps (69%)
18:45:27:WU03:FS02:0xa4:Completed 180000 out of 1500000 steps (12%)
18:53:39:WU03:FS02:0xa4:Completed 195000 out of 1500000 steps (13%)
18:53:52:WU00:FS01:0x17:Completed 1500000 out of 2500000 steps (60%)
18:54:04:WU01:FS00:0x17:Completed 1750000 out of 2500000 steps (70%)
19:01:54:WU03:FS02:0xa4:Completed 210000 out of 1500000 steps (14%)
19:10:08:WU03:FS02:0xa4:Completed 225000 out of 1500000 steps (15%)
19:10:22:WU00:FS01:0x17:Completed 1525000 out of 2500000 steps (61%)
19:10:33:WU01:FS00:0x17:Completed 1775000 out of 2500000 steps (71%)
19:18:21:WU03:FS02:0xa4:Completed 240000 out of 1500000 steps (16%)
19:26:25:WU00:FS01:0x17:Completed 1550000 out of 2500000 steps (62%)
19:26:36:WU03:FS02:0xa4:Completed 255000 out of 1500000 steps (17%)
19:26:40:WU01:FS00:0x17:Completed 1800000 out of 2500000 steps (72%)
19:34:46:WU03:FS02:0xa4:Completed 270000 out of 1500000 steps (18%)
19:42:54:WU00:FS01:0x17:Completed 1575000 out of 2500000 steps (63%)
19:42:56:WU03:FS02:0xa4:Completed 285000 out of 1500000 steps (19%)
19:43:09:WU01:FS00:0x17:Completed 1825000 out of 2500000 steps (73%)
19:51:09:WU03:FS02:0xa4:Completed 300000 out of 1500000 steps (20%)
19:58:54:WU00:FS01:0x17:Completed 1600000 out of 2500000 steps (64%)
19:59:12:WU01:FS00:0x17:Completed 1850000 out of 2500000 steps (74%)
19:59:20:WU03:FS02:0xa4:Completed 315000 out of 1500000 steps (21%)
20:07:34:WU03:FS02:0xa4:Completed 330000 out of 1500000 steps (22%)
20:15:17:WU00:FS01:0x17:Completed 1625000 out of 2500000 steps (65%)
20:15:34:WU01:FS00:0x17:Completed 1875000 out of 2500000 steps (75%)
20:15:48:WU03:FS02:0xa4:Completed 345000 out of 1500000 steps (23%)
20:24:04:WU03:FS02:0xa4:Completed 360000 out of 1500000 steps (24%)
20:31:18:WU00:FS01:0x17:Completed 1650000 out of 2500000 steps (66%)
20:31:39:WU01:FS00:0x17:Completed 1900000 out of 2500000 steps (76%)
20:32:22:WU03:FS02:0xa4:Completed 375000 out of 1500000 steps (25%)
20:40:32:WU03:FS02:0xa4:Completed 390000 out of 1500000 steps (26%)
20:47:43:WU00:FS01:0x17:Completed 1675000 out of 2500000 steps (67%)
20:48:03:WU01:FS00:0x17:Completed 1925000 out of 2500000 steps (77%)
20:48:47:WU03:FS02:0xa4:Completed 405000 out of 1500000 steps (27%)
20:56:56:WU03:FS02:0xa4:Completed 420000 out of 1500000 steps (28%)
21:03:48:WU00:FS01:0x17:Completed 1700000 out of 2500000 steps (68%)
21:04:11:WU01:FS00:0x17:Completed 1950000 out of 2500000 steps (78%)
21:05:11:WU03:FS02:0xa4:Completed 435000 out of 1500000 steps (29%)
21:13:24:WU03:FS02:0xa4:Completed 450000 out of 1500000 steps (30%)
21:20:14:WU00:FS01:0x17:Completed 1725000 out of 2500000 steps (69%)
21:20:36:WU01:FS00:0x17:Completed 1975000 out of 2500000 steps (79%)
21:21:48:WU03:FS02:0xa4:Completed 465000 out of 1500000 steps (31%)
21:30:01:WU03:FS02:0xa4:Completed 480000 out of 1500000 steps (32%)
21:36:18:WU00:FS01:0x17:Completed 1750000 out of 2500000 steps (70%)
21:36:43:WU01:FS00:0x17:Completed 2000000 out of 2500000 steps (80%)
21:38:18:WU03:FS02:0xa4:Completed 495000 out of 1500000 steps (33%)
21:46:33:WU03:FS02:0xa4:Completed 510000 out of 1500000 steps (34%)
21:52:41:WU00:FS01:0x17:Completed 1775000 out of 2500000 steps (71%)
21:53:03:WU01:FS00:0x17:Completed 2025000 out of 2500000 steps (81%)
21:54:48:WU03:FS02:0xa4:Completed 525000 out of 1500000 steps (35%)
22:03:03:WU03:FS02:0xa4:Completed 540000 out of 1500000 steps (36%)
22:08:43:WU00:FS01:0x17:Completed 1800000 out of 2500000 steps (72%)
22:09:08:WU01:FS00:0x17:Completed 2050000 out of 2500000 steps (82%)
22:11:21:WU03:FS02:0xa4:Completed 555000 out of 1500000 steps (37%)
22:19:32:WU03:FS02:0xa4:Completed 570000 out of 1500000 steps (38%)
22:25:06:WU00:FS01:0x17:Completed 1825000 out of 2500000 steps (73%)
22:25:29:WU01:FS00:0x17:Completed 2075000 out of 2500000 steps (83%)
22:27:46:WU03:FS02:0xa4:Completed 585000 out of 1500000 steps (39%)
22:35:59:WU03:FS02:0xa4:Completed 600000 out of 1500000 steps (40%)
22:41:10:WU00:FS01:0x17:Completed 1850000 out of 2500000 steps (74%)
22:41:34:WU01:FS00:0x17:Completed 2100000 out of 2500000 steps (84%)
22:44:13:WU03:FS02:0xa4:Completed 615000 out of 1500000 steps (41%)
22:52:26:WU03:FS02:0xa4:Completed 630000 out of 1500000 steps (42%)
22:57:35:WU00:FS01:0x17:Completed 1875000 out of 2500000 steps (75%)
22:57:57:WU01:FS00:0x17:Completed 2125000 out of 2500000 steps (85%)
23:00:38:WU03:FS02:0xa4:Completed 645000 out of 1500000 steps (43%)
23:08:53:WU03:FS02:0xa4:Completed 660000 out of 1500000 steps (44%)
23:13:39:WU00:FS01:0x17:Completed 1900000 out of 2500000 steps (76%)
23:14:04:WU01:FS00:0x17:Completed 2150000 out of 2500000 steps (86%)
23:17:05:WU03:FS02:0xa4:Completed 675000 out of 1500000 steps (45%)
23:25:18:WU03:FS02:0xa4:Completed 690000 out of 1500000 steps (46%)
23:30:04:WU00:FS01:0x17:Completed 1925000 out of 2500000 steps (77%)
23:30:29:WU01:FS00:0x17:Completed 2175000 out of 2500000 steps (87%)
23:33:32:WU03:FS02:0xa4:Completed 705000 out of 1500000 steps (47%)
23:41:40:WU03:FS02:0xa4:Completed 720000 out of 1500000 steps (48%)
******************************* Date: 2013-06-20 *******************************
23:46:08:WU00:FS01:0x17:Completed 1950000 out of 2500000 steps (78%)
23:46:36:WU01:FS00:0x17:Completed 2200000 out of 2500000 steps (88%)
23:49:52:WU03:FS02:0xa4:Completed 735000 out of 1500000 steps (49%)
23:58:03:WU03:FS02:0xa4:Completed 750000 out of 1500000 steps (50%)
00:02:31:WU00:FS01:0x17:Completed 1975000 out of 2500000 steps (79%)
00:02:58:WU01:FS00:0x17:Completed 2225000 out of 2500000 steps (89%)
00:06:17:WU03:FS02:0xa4:Completed 765000 out of 1500000 steps (51%)
00:14:32:WU03:FS02:0xa4:Completed 780000 out of 1500000 steps (52%)
00:18:34:WU00:FS01:0x17:Completed 2000000 out of 2500000 steps (80%)
00:19:02:WU01:FS00:0x17:Completed 2250000 out of 2500000 steps (90%)
00:22:50:WU03:FS02:0xa4:Completed 795000 out of 1500000 steps (53%)
00:31:03:WU03:FS02:0xa4:Completed 810000 out of 1500000 steps (54%)
00:34:59:WU00:FS01:0x17:Completed 2025000 out of 2500000 steps (81%)
00:35:26:WU01:FS00:0x17:Completed 2275000 out of 2500000 steps (91%)
00:39:17:WU03:FS02:0xa4:Completed 825000 out of 1500000 steps (55%)
00:47:31:WU03:FS02:0xa4:Completed 840000 out of 1500000 steps (56%)
00:51:02:WU00:FS01:0x17:Completed 2050000 out of 2500000 steps (82%)
00:51:30:WU01:FS00:0x17:Completed 2300000 out of 2500000 steps (92%)
00:55:44:WU03:FS02:0xa4:Completed 855000 out of 1500000 steps (57%)
01:03:58:WU03:FS02:0xa4:Completed 870000 out of 1500000 steps (58%)
01:07:27:WU00:FS01:0x17:Completed 2075000 out of 2500000 steps (83%)
01:07:53:WU01:FS00:0x17:Completed 2325000 out of 2500000 steps (93%)
01:12:12:WU03:FS02:0xa4:Completed 885000 out of 1500000 steps (59%)
01:20:27:WU03:FS02:0xa4:Completed 900000 out of 1500000 steps (60%)
01:23:30:WU00:FS01:0x17:Completed 2100000 out of 2500000 steps (84%)
01:23:59:WU01:FS00:0x17:Completed 2350000 out of 2500000 steps (94%)
01:28:40:WU03:FS02:0xa4:Completed 915000 out of 1500000 steps (61%)
01:36:57:WU03:FS02:0xa4:Completed 930000 out of 1500000 steps (62%)
01:39:56:WU00:FS01:0x17:Completed 2125000 out of 2500000 steps (85%)
01:40:22:WU01:FS00:0x17:Completed 2375000 out of 2500000 steps (95%)
01:45:08:WU03:FS02:0xa4:Completed 945000 out of 1500000 steps (63%)
01:53:21:WU03:FS02:0xa4:Completed 960000 out of 1500000 steps (64%)
01:56:00:WU00:FS01:0x17:Completed 2150000 out of 2500000 steps (86%)
01:56:29:WU01:FS00:0x17:Completed 2400000 out of 2500000 steps (96%)
02:01:36:WU03:FS02:0xa4:Completed 975000 out of 1500000 steps (65%)
02:09:47:WU03:FS02:0xa4:Completed 990000 out of 1500000 steps (66%)
02:12:23:WU00:FS01:0x17:Completed 2175000 out of 2500000 steps (87%)
02:12:51:WU01:FS00:0x17:Completed 2425000 out of 2500000 steps (97%)
02:18:00:WU03:FS02:0xa4:Completed 1005000 out of 1500000 steps (67%)
02:26:13:WU03:FS02:0xa4:Completed 1020000 out of 1500000 steps (68%)
02:28:26:WU00:FS01:0x17:Completed 2200000 out of 2500000 steps (88%)
02:28:56:WU01:FS00:0x17:Completed 2450000 out of 2500000 steps (98%)
02:28:57:WU02:FS00:Connecting to assign-GPU.stanford.edu:80
02:28:57:WU02:FS00:News: Welcome to Folding@Home
02:28:57:WU02:FS00:Assigned to work server 171.64.65.69
02:28:57:WU02:FS00:Requesting new work unit for slot 00: RUNNING gpu:0:Barts XT [ATI Radeon HD 6800 Series] from 171.64.65.69
02:28:57:WU02:FS00:Connecting to 171.64.65.69:8080
02:28:57:WU02:FS00
ownloading 4.18MiB
02:29:00:WU02:FS00
ownload complete
02:29:00:WU02:FS00:Received Unit: id:02 state
OWNLOAD error:NO_ERROR project:8900 run:749 clone:1 gen:9 core:0x17 unit:0x0000000d028c126651a6cd406ad018d7
02:34:32:WU03:FS02:0xa4:Completed 1035000 out of 1500000 steps (69%)
02:42:45:WU03:FS02:0xa4:Completed 1050000 out of 1500000 steps (70%)
02:44:49:WU00:FS01:0x17:Completed 2225000 out of 2500000 steps (89%)
02:45:17:WU01:FS00:0x17:Completed 2475000 out of 2500000 steps (99%)
02:50:58:WU03:FS02:0xa4:Completed 1065000 out of 1500000 steps (71%)
02:59:11:WU03:FS02:0xa4:Completed 1080000 out of 1500000 steps (72%)
03:00:52:WU00:FS01:0x17:Completed 2250000 out of 2500000 steps (90%)
03:01:22:WU01:FS00:0x17:Completed 2500000 out of 2500000 steps (100%)
03:01:40:WU01:FS00:0x17:Saving result file logfile_01.txt
03:01:40:WU01:FS00:0x17:Saving result file checkpointState.xml
03:01:42:WU01:FS00:0x17:Saving result file checkpt.crc
03:01:42:WU01:FS00:0x17:Saving result file log.txt
03:01:42:WU01:FS00:0x17:Saving result file positions.xtc
03:01:45:WU01:FS00:0x17:Folding@home Core Shutdown: FINISHED_UNIT
03:01:46:WU01:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
03:01:46:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:8900 run:226 clone:0 gen:33 core:0x17 unit:0x0000002a028c126651a658cbd81d452c
03:01:46:WU01:FS00:Uploading 12.96MiB to 171.64.65.69
03:01:46:WU01:FS00:Connecting to 171.64.65.69:8080
03:01:46:WU02:FS00:Starting
03:01:46:WU02:FS00:Running FahCore: \"C:\\Program Files (x86)\\FAHClient/FAHCoreWrapper.exe\" C:/Users/Brad/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/beta/Core_17.fah/FahCore_17.exe -dir 02 -suffix 01 -version 703 -lifeline 2208 -checkpoint 15 -gpu 0 -gpu-vendor ati
03:01:46:WU02:FS00:Started FahCore on PID 5664
03:01:46:WU02:FS00:Core PID:4660
03:01:46:WU02:FS00:FahCore 0x17 started
03:01:46:WU02:FS00:0x17:*********************** Log Started 2013-06-21T03:01:46Z ***********************
roject: 8900 (Run 749, Clone 1, Gen 9)
03:01:46:WU02:FS00:0x17:Unit: 0x0000000d028c126651a6cd406ad018d7
03:01:46:WU02:FS00:0x17:CPU: 0x00000000000000000000000000000000
03:01:46:WU02:FS00:0x17:Machine: 0
03:01:46:WU02:FS00:0x17:Reading tar file state.xml
03:01:46:WU02:FS00:0x17:Reading tar file system.xml
03:01:47:WU02:FS00:0x17:Reading tar file integrator.xml
03:01:47:WU02:FS00:0x17:Reading tar file core.xml
03:01:52:WU01:FS00:Upload 6.27%
03:01:58:WU01:FS00:Upload 12.06%
03:02:04:WU01:FS00:Upload 17.36%
03:02:10:WU01:FS00:Upload 22.67%
03:02:16:WU01:FS00:Upload 27.97%
03:02:22:WU01:FS00:Upload 33.27%
03:02:28:WU01:FS00:Upload 38.58%
03:02:34:WU01:FS00:Upload 43.88%
03:02:40:WU01:FS00:Upload 49.67%
03:02:46:WU01:FS00:Upload 54.97%
03:02:52:WU01:FS00:Upload 60.28%
03:02:58:WU01:FS00:Upload 65.58%
03:03:04:WU01:FS00:Upload 70.89%
03:03:10:WU01:FS00:Upload 76.19%
03:03:16:WU01:FS00:Upload 81.50%
03:03:22:WU01:FS00:Upload 87.28%
03:03:28:WU01:FS00:Upload 92.59%
03:03:34:WU01:FS00:Upload 97.89%
03:03:44:WU01:FS00:Upload complete
03:03:44:WU01:FS00:Server responded WORK_ACK (400)
03:03:44:WU01:FS00:Final credit estimate, 11961.00 points
03:03:44:WU01:FS00:Cleaning up
03:04:30:WU02:FS00:0x17:Completed 0 out of 2500000 steps (0%)
03:07:35:WU03:FS02:0xa4:Completed 1095000 out of 1500000 steps (73%)
03:15:57:WU03:FS02:0xa4:Completed 1110000 out of 1500000 steps (74%)
03:17:36:WU00:FS01:0x17:Completed 2275000 out of 2500000 steps (91%)
03:17:40:FS00
aused
03:17:40:FS00:Shutting core down
03:17:41:WU02:FS00:0x17:WARNING:Console control signal 1 on PID 4660
03:17:41:WU02:FS00:0x17:Exiting, please wait. . .
03:17:41:WU02:FS00:0x17:Lost lifeline PID 5664, exiting
03:17:41:WU02:FS00:0x17:ERROR:103: Lost client lifeline
03:17:41:WU02:FS00:0x17:Folding@home Core Shutdown: CLIENT_DIED
03:17:42:WU02:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
03:24:28:WU03:FS02:0xa4:Completed 1125000 out of 1500000 steps (75%)
03:26:05:FS02
aused
03:26:05:FS02:Shutting core down
03:26:09:WU03:FS02:0xa4:Client no longer detected. Shutting down core
03:26:09:WU03:FS02:0xa4:Folding@home Core Shutdown: CLIENT_DIED
03:26:09:WU03:FS02:FahCore returned: INTERRUPTED (102 = 0x66)
03:26:17:FS02:Unpaused
03:26:17:WU03:FS02:Starting
03:26:17:WU03:FS02:Running FahCore: \"C:\\Program Files (x86)\\FAHClient/FAHCoreWrapper.exe\" C:/Users/Brad/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 03 -suffix 01 -version 703 -lifeline 2208 -checkpoint 15 -np 7
03:26:17:WU03:FS02:Started FahCore on PID 4432
03:26:17:WU03:FS02:Core PID:2560
03:26:17:WU03:FS02:FahCore 0xa4 started
03:26:18:WU03:FS02:0xa4:
03:26:18:WU03:FS02:0xa4:*------------------------------*
03:26:18:WU03:FS02:0xa4:Folding@Home Gromacs GB Core
03:26:18:WU03:FS02:0xa4:Version 2.27 (Dec. 15, 2010)
03:26:18:WU03:FS02:0xa4:- Looking at optimizations...
03:26:18:WU03:FS02:0xa4:- Files status OK
03:26:18:WU03:FS02:0xa4:- Expanded 2079299 -> 5386224 (decompressed 259.0 percent)
03:26:18:WU03:FS02:0xa4:Called DecompressByteArray: compressed_data_size=2079299 data_size=5386224, decompressed_data_size=5386224 diff=0
03:26:18:WU03:FS02:0xa4:- Digital signature verified
03:26:18:WU03:FS02:0xa4:Assembly optimizations on if available.
03:26:18:WU03:FS02:0xa4:Entering M.D.
03:26:24:WU03:FS02:0xa4:Using Gromacs checkpoints
03:26:24:WU03:FS02:0xa4:Mapping NT from 7 to 7
03:26:24:WU03:FS02:0xa4:Resuming from checkpoint
03:26:24:WU03:FS02:0xa4:Verified 03/wudata_01.log
03:26:24:WU03:FS02:0xa4:Verified 03/wudata_01.trr
03:26:24:WU03:FS02:0xa4:Verified 03/wudata_01.xtc
03:26:24:WU03:FS02:0xa4:Verified 03/wudata_01.edr
03:26:24:WU03:FS02:0xa4:Completed 1113590 out of 1500000 steps (74%)
03:28:48:FS02
aused
03:28:48:FS02:Shutting core down
03:28:48:WU03:FS02:FahCore returned: INTERRUPTED (102 = 0x66)
03:29:16:FS01:Shutting core down
03:29:16:WU00:FS01:0x17:WARNING:Console control signal 1 on PID 3636
03:29:16:WU00:FS01:0x17:Exiting, please wait. . .
03:29:16:WU00:FS01:0x17:Lost lifeline PID 3596, exiting
03:29:16:WU00:FS01:0x17:ERROR:103: Lost client lifeline
03:29:16:WU00:FS01:0x17:Folding@home Core Shutdown: CLIENT_DIED
03:29:16:WU00:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
03:30:19:Removing old file 'configs/config-20130618-030054.xml'
03:30:19:Saving configuration to config.xml
03:30:19:<config>
03:30:19: <!-- Folding Slot Configuration -->
03:30:19: <power v='off'/>
03:30:19:
03:30:19: <!-- Network -->
03:30:19: <proxy v=':8080'/>
03:30:19:
03:30:19: <!-- User Information -->
03:30:19: <passkey v='********************************'/>
03:30:19: <team v='32'/>
03:30:19: <user v='Rustyfender'/>
03:30:19:
03:30:19: <!-- Folding Slots -->
03:30:19: <slot id='2' type='CPU'>
03:30:19: <cpus v='7'/>
03:30:19: </slot>
03:30:19: <slot id='0' type='GPU'>
03:30:19: <client-type v='beta'/>
03:30:19: </slot>
03:30:19: <slot id='1' type='GPU'>
03:30:19: </slot>
03:30:19:</config>
******************************* Date: 2013-06-21 *******************************
14:05:51:WU00:FS01:Starting
14:05:51:WU00:FS01:Running FahCore: \"C:\\Program Files (x86)\\FAHClient/FAHCoreWrapper.exe\" C:/Users/Brad/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/beta/Core_17.fah/FahCore_17.exe -dir 00 -suffix 01 -version 703 -lifeline 2208 -checkpoint 15 -gpu 1 -gpu-vendor ati
14:05:51:WU00:FS01:Started FahCore on PID 3840
14:05:51:WU00:FS01:Core PID:4792
14:05:51:WU00:FS01:FahCore 0x17 started
14:05:52:WU00:FS01:0x17:*********************** Log Started 2013-06-21T14:05:51Z ***********************
14:05:52:WU00:FS01:0x17:Unit: 0x0000001b028c126651a68124a879bd5a
14:05:52:WU00:FS01:0x17:CPU: 0x00000000000000000000000000000000
14:05:52:WU00:FS01:0x17:Machine: 1
14:05:52:WU00:FS01:0x17: Found a checkpoint file
14:06:52:Removing old file 'configs/config-20130618-030202.xml'
14:06:52:Saving configuration to config.xml
14:06:52:<config>
14:06:52: <!-- Folding Slot Configuration -->
14:06:52: <power v='full'/>
14:06:52:
14:06:52: <!-- Network -->
14:06:52: <proxy v=':8080'/>
14:06:52:
14:06:52: <!-- User Information -->
14:06:52: <passkey v='********************************'/>
14:06:52: <team v='32'/>
14:06:52: <user v='Rustyfender'/>
14:06:52:
14:06:52: <!-- Folding Slots -->
14:06:52: <slot id='2' type='CPU'>
14:06:52: <cpus v='7'/>
14:06:52: </slot>
14:06:52: <slot id='0' type='GPU'>
14:06:52: <client-type v='beta'/>
14:06:52: </slot>
14:06:52: <slot id='1' type='GPU'>
14:06:52: </slot>
14:06:52:</config>
14:07:39:WU00:FS01:0x17:Completed 2250000 out of 2500000 steps (90%)
14:23:49:WU00:FS01:0x17:Completed 2275000 out of 2500000 steps (91%)
14:39:47:WU00:FS01:0x17:Completed 2300000 out of 2500000 steps (92%)
14:55:59:WU00:FS01:0x17:Completed 2325000 out of 2500000 steps (93%)
15:11:58:WU00:FS01:0x17:Completed 2350000 out of 2500000 steps (94%)
15:28:12:WU00:FS01:0x17:Completed 2375000 out of 2500000 steps (95%)
15:44:13:WU00:FS01:0x17:Completed 2400000 out of 2500000 steps (96%)
16:00:24:WU00:FS01:0x17:Completed 2425000 out of 2500000 steps (97%)
16:16:24:WU00:FS01:0x17:Completed 2450000 out of 2500000 steps (98%)
16:16:25:WU01:FS01:Connecting to assign-GPU.stanford.edu:80
16:16:25:WU01:FS01:News: Welcome to Folding@Home
16:16:25:WU01:FS01:Assigned to work server 171.64.65.69
16:16:25:WU01:FS01:Requesting new work unit for slot 01: RUNNING gpu:1:Barts XT [ATI Radeon HD 6800 Series] from 171.64.65.69
16:16:25:WU01:FS01:Connecting to 171.64.65.69:8080
16:16:25:WU01:FS01
ownloading 4.17MiB
16:16:28:WU01:FS01
ownload complete
16:16:28:WU01:FS01:Received Unit: id:01 state
OWNLOAD error:NO_ERROR project:8900 run:359 clone:1 gen:21 core:0x17 unit:0x00000018028c126651a6767321c7a4b2
16:32:34:WU00:FS01:0x17:Completed 2475000 out of 2500000 steps (99%)
16:48:33:WU00:FS01:0x17:Completed 2500000 out of 2500000 steps (100%)
16:48:46:WU00:FS01:0x17:Saving result file logfile_01.txt
16:48:46:WU00:FS01:0x17:Saving result file checkpointState.xml
16:48:47:WU00:FS01:0x17:Saving result file checkpt.crc
16:48:47:WU00:FS01:0x17:Saving result file log.txt
16:48:47:WU00:FS01:0x17:Saving result file positions.xtc
16:48:48:WU00:FS01:0x17:Folding@home Core Shutdown: FINISHED_UNIT
16:48:49:WU00:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
16:48:49:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:8900 run:407 clone:1 gen:26 core:0x17 unit:0x0000001b028c126651a68124a879bd5a
16:48:49:WU00:FS01:Uploading 12.96MiB to 171.64.65.69
16:48:49:WU00:FS01:Connecting to 171.64.65.69:8080
16:48:49:WU01:FS01:Starting
16:48:49:WU01:FS01:Running FahCore: \"C:\\Program Files (x86)\\FAHClient/FAHCoreWrapper.exe\" C:/Users/Brad/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/beta/Core_17.fah/FahCore_17.exe -dir 01 -suffix 01 -version 703 -lifeline 2208 -checkpoint 15 -gpu 1 -gpu-vendor ati
16:48:49:WU01:FS01:Started FahCore on PID 3676
16:48:49:WU01:FS01:Core PID:5884
16:48:49:WU01:FS01:FahCore 0x17 started
16:48:49:WU01:FS01:0x17:*********************** Log Started 2013-06-21T16:48:49Z ***********************
roject: 8900 (Run 359, Clone 1, Gen 21)
16:48:49:WU01:FS01:0x17:Unit: 0x00000018028c126651a6767321c7a4b2
16:48:49:WU01:FS01:0x17:CPU: 0x00000000000000000000000000000000
16:48:49:WU01:FS01:0x17:Machine: 1
16:48:49:WU01:FS01:0x17:Reading tar file state.xml
16:48:50:WU01:FS01:0x17:Reading tar file system.xml
16:48:50:WU01:FS01:0x17:Reading tar file integrator.xml
16:48:50:WU01:FS01:0x17:Reading tar file core.xml
16:48:55:WU00:FS01:Upload 6.27%
16:49:01:WU00:FS01:Upload 11.09%
16:49:08:WU00:FS01:Upload 15.43%
16:49:14:WU00:FS01:Upload 19.77%
16:49:20:WU00:FS01:Upload 25.08%
16:49:26:WU00:FS01:Upload 30.38%
16:49:32:WU00:FS01:Upload 35.69%
16:49:38:WU00:FS01:Upload 40.99%
16:49:44:WU00:FS01:Upload 46.30%
16:49:50:WU00:FS01:Upload 51.60%
16:49:56:WU00:FS01:Upload 56.91%
16:50:02:WU00:FS01:Upload 62.70%
16:50:08:WU00:FS01:Upload 67.52%
16:50:14:WU00:FS01:Upload 72.82%
16:50:20:WU00:FS01:Upload 78.61%
16:50:26:WU00:FS01:Upload 83.92%
16:50:32:WU00:FS01:Upload 89.22%
16:50:37:WU01:FS01:0x17:Completed 0 out of 2500000 steps (0%)
16:50:38:WU00:FS01:Upload 94.53%
16:50:44:WU00:FS01:Upload 99.83%
16:50:52:WU00:FS01:Upload complete
16:50:53:WU00:FS01:Server responded WORK_ACK (400)
16:50:53:WU00:FS01:Final credit estimate, 10422.00 points
16:50:53:WU00:FS01:Cleaning up
17:06:47:WU01:FS01:0x17:Completed 25000 out of 2500000 steps (1%)
17:22:46:WU01:FS01:0x17:Completed 50000 out of 2500000 steps (2%)
17:38:59:WU01:FS01:0x17:Completed 75000 out of 2500000 steps (3%)
17:54:59:WU01:FS01:0x17:Completed 100000 out of 2500000 steps (4%)
18:11:11:WU01:FS01:0x17:Completed 125000 out of 2500000 steps (5%)
18:27:12:WU01:FS01:0x17:Completed 150000 out of 2500000 steps (6%)
18:43:24:WU01:FS01:0x17:Completed 175000 out of 2500000 steps (7%)
18:59:23:WU01:FS01:0x17:Completed 200000 out of 2500000 steps (8%)
19:15:35:WU01:FS01:0x17:Completed 225000 out of 2500000 steps (9%)
19:20:00:FS00:Unpaused
19:20:00:WU02:FS00:Starting
19:20:00:WU02:FS00:Running FahCore: \"C:\\Program Files (x86)\\FAHClient/FAHCoreWrapper.exe\" C:/Users/Brad/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/beta/Core_17.fah/FahCore_17.exe -dir 02 -suffix 01 -version 703 -lifeline 2208 -checkpoint 15 -gpu 0 -gpu-vendor ati
19:20:00:WU02:FS00:Started FahCore on PID 2632
19:20:00:WU02:FS00:Core PID:2368
19:20:00:WU02:FS00:FahCore 0x17 started
19:20:01:WU02:FS00:0x17:*********************** Log Started 2013-06-21T19:20:00Z ***********************
19:20:01:WU02:FS00:0x17:Unit: 0x0000000d028c126651a6cd406ad018d7
19:20:01:WU02:FS00:0x17:CPU: 0x00000000000000000000000000000000
19:20:01:WU02:FS00:0x17:Machine: 0
19:20:02:FS02:Unpaused
19:20:02:WU03:FS02:Starting
19:20:02:WU03:FS02:Running FahCore: \"C:\\Program Files (x86)\\FAHClient/FAHCoreWrapper.exe\" C:/Users/Brad/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 03 -suffix 01 -version 703 -lifeline 2208 -checkpoint 15 -np 7
19:20:02:WU03:FS02:Started FahCore on PID 4128
19:20:02:WU03:FS02:Core PID:2108
19:20:02:WU03:FS02:FahCore 0xa4 started
19:20:03:WU03:FS02:0xa4:
19:20:03:WU03:FS02:0xa4:*------------------------------*
19:20:03:WU03:FS02:0xa4:Folding@Home Gromacs GB Core
19:20:03:WU03:FS02:0xa4:Version 2.27 (Dec. 15, 2010)
19:20:03:WU03:FS02:0xa4:- Looking at optimizations...
19:20:03:WU03:FS02:0xa4:- Files status OK
19:20:03:WU03:FS02:0xa4:- Expanded 2079299 -> 5386224 (decompressed 259.0 percent)
19:20:03:WU03:FS02:0xa4:Called DecompressByteArray: compressed_data_size=2079299 data_size=5386224, decompressed_data_size=5386224 diff=0
19:20:03:WU03:FS02:0xa4:- Digital signature verified
19:20:03:WU03:FS02:0xa4:Assembly optimizations on if available.
19:20:03:WU03:FS02:0xa4:Entering M.D.
19:20:09:WU03:FS02:0xa4:Using Gromacs checkpoints
19:20:09:WU03:FS02:0xa4:Mapping NT from 7 to 7
19:20:09:WU03:FS02:0xa4:Resuming from checkpoint
19:20:09:WU03:FS02:0xa4:Verified 03/wudata_01.log
19:20:09:WU03:FS02:0xa4:Verified 03/wudata_01.trr
19:20:09:WU03:FS02:0xa4:Verified 03/wudata_01.xtc
19:20:09:WU03:FS02:0xa4:Verified 03/wudata_01.edr
19:20:09:WU03:FS02:0xa4:Completed 1113590 out of 1500000 steps (74%)
19:22:39:WU02:FS00:0x17:Completed 0 out of 2500000 steps (0%)
19:26:40:WU03:FS02:0xa4:Completed 1125000 out of 1500000 steps (75%)
19:31:49:WU01:FS01:0x17:Completed 250000 out of 2500000 steps (10%)
19:35:07:WU03:FS02:0xa4:Completed 1140000 out of 1500000 steps (76%)
19:39:00:WU02:FS00:0x17:Completed 25000 out of 2500000 steps (1%)
19:43:32:WU03:FS02:0xa4:Completed 1155000 out of 1500000 steps (77%)
19:48:11:WU01:FS01:0x17:Completed 275000 out of 2500000 steps (11%)
19:51:58:WU03:FS02:0xa4:Completed 1170000 out of 1500000 steps (78%)
19:55:02:WU02:FS00:0x17:Completed 50000 out of 2500000 steps (2%)
20:00:26:WU03:FS02:0xa4:Completed 1185000 out of 1500000 steps (79%)
20:04:17:WU01:FS01:0x17:Completed 300000 out of 2500000 steps (12%)
20:08:53:WU03:FS02:0xa4:Completed 1200000 out of 1500000 steps (80%)
20:11:26:WU02:FS00:0x17:Completed 75000 out of 2500000 steps (3%)
20:17:14:WU03:FS02:0xa4:Completed 1215000 out of 1500000 steps (81%)
20:20:41:WU01:FS01:0x17:Completed 325000 out of 2500000 steps (13%)
20:25:37:WU03:FS02:0xa4:Completed 1230000 out of 1500000 steps (82%)
20:27:30:WU02:FS00:0x17:Completed 100000 out of 2500000 steps (4%)
20:34:06:WU03:FS02:0xa4:Completed 1245000 out of 1500000 steps (83%)
20:36:46:WU01:FS01:0x17:Completed 350000 out of 2500000 steps (14%)
20:42:25:WU03:FS02:0xa4:Completed 1260000 out of 1500000 steps (84%)
20:43:54:WU02:FS00:0x17:Completed 125000 out of 2500000 steps (5%)
20:50:42:WU03:FS02:0xa4:Completed 1275000 out of 1500000 steps (85%)
20:53:06:WU01:FS01:0x17:Completed 375000 out of 2500000 steps (15%)
20:59:10:WU03:FS02:0xa4:Completed 1290000 out of 1500000 steps (86%)
20:59:58:WU02:FS00:0x17:Completed 150000 out of 2500000 steps (6%)
21:07:39:WU03:FS02:0xa4:Completed 1305000 out of 1500000 steps (87%)
21:09:09:WU01:FS01:0x17:Completed 400000 out of 2500000 steps (16%)
21:16:02:WU03:FS02:0xa4:Completed 1320000 out of 1500000 steps (88%)
21:16:20:WU02:FS00:0x17:Completed 175000 out of 2500000 steps (7%)
21:24:24:WU03:FS02:0xa4:Completed 1335000 out of 1500000 steps (89%)
21:25:30:WU01:FS01:0x17:Completed 425000 out of 2500000 steps (17%)
21:32:22:WU02:FS00:0x17:Completed 200000 out of 2500000 steps (8%)
21:32:48:WU03:FS02:0xa4:Completed 1350000 out of 1500000 steps (90%)
21:41:16:WU03:FS02:0xa4:Completed 1365000 out of 1500000 steps (91%)
21:41:33:WU01:FS01:0x17:Completed 450000 out of 2500000 steps (18%)
21:48:44:WU02:FS00:0x17:Completed 225000 out of 2500000 steps (9%)
21:49:44:WU03:FS02:0xa4:Completed 1380000 out of 1500000 steps (92%)
21:57:54:WU01:FS01:0x17:Completed 475000 out of 2500000 steps (19%)
21:58:09:WU03:FS02:0xa4:Completed 1395000 out of 1500000 steps (93%)
22:04:47:WU02:FS00:0x17:Completed 250000 out of 2500000 steps (10%)
22:06:37:WU03:FS02:0xa4:Completed 1410000 out of 1500000 steps (94%)
22:13:59:WU01:FS01:0x17:Completed 500000 out of 2500000 steps (20%)
22:15:03:WU03:FS02:0xa4:Completed 1425000 out of 1500000 steps (95%)
22:21:10:WU02:FS00:0x17:Completed 275000 out of 2500000 steps (11%)
22:23:30:WU03:FS02:0xa4:Completed 1440000 out of 1500000 steps (96%)
22:30:21:WU01:FS01:0x17:Completed 525000 out of 2500000 steps (21%)
22:31:55:WU03:FS02:0xa4:Completed 1455000 out of 1500000 steps (97%)
22:37:15:WU02:FS00:0x17:Completed 300000 out of 2500000 steps (12%)
22:40:17:WU03:FS02:0xa4:Completed 1470000 out of 1500000 steps (98%)
22:40:17:WU00:FS02:Connecting to assign3.stanford.edu:8080
22:40:17:WU00:FS02:News: Welcome to Folding@Home
22:40:17:WU00:FS02:Assigned to work server 171.67.108.35
22:40:17:WU00:FS02:Requesting new work unit for slot 02: RUNNING cpu:7 from 171.67.108.35
22:40:17:WU00:FS02:Connecting to 171.67.108.35:8080
22:40:17:ERROR:WU00:FS02:Exception: Server did not assign work unit
22:40:18:WU00:FS02:Connecting to assign3.stanford.edu:8080
22:40:18:WU00:FS02:News: Welcome to Folding@Home
22:40:18:WU00:FS02:Assigned to work server 171.67.108.35
22:40:18:WU00:FS02:Requesting new work unit for slot 02: RUNNING cpu:7 from 171.67.108.35
22:40:18:WU00:FS02:Connecting to 171.67.108.35:8080
22:40:18:ERROR:WU00:FS02:Exception: Server did not assign work unit
22:41:18:WU00:FS02:Connecting to assign3.stanford.edu:8080
22:41:18:WU00:FS02:News: Welcome to Folding@Home
22:41:18:WU00:FS02:Assigned to work server 171.67.108.35
22:41:18:WU00:FS02:Requesting new work unit for slot 02: RUNNING cpu:7 from 171.67.108.35
22:41:18:WU00:FS02:Connecting to 171.67.108.35:8080
22:41:18:ERROR:WU00:FS02:Exception: Server did not assign work unit
22:42:55:WU00:FS02:Connecting to assign3.stanford.edu:8080
22:42:55:WU00:FS02:News: Welcome to Folding@Home
22:42:55:WU00:FS02:Assigned to work server 171.67.108.35
22:42:55:WU00:FS02:Requesting new work unit for slot 02: RUNNING cpu:7 from 171.67.108.35
22:42:55:WU00:FS02:Connecting to 171.67.108.35:8080
22:42:55:ERROR:WU00:FS02:Exception: Server did not assign work unit
22:45:32:WU00:FS02:Connecting to assign3.stanford.edu:8080
22:45:32:WU00:FS02:News: Welcome to Folding@Home
22:45:32:WU00:FS02:Assigned to work server 171.67.108.35
22:45:32:WU00:FS02:Requesting new work unit for slot 02: RUNNING cpu:7 from 171.67.108.35
22:45:32:WU00:FS02:Connecting to 171.67.108.35:8080
22:45:33:ERROR:WU00:FS02:Exception: Server did not assign work unit
22:46:27:WU01:FS01:0x17:Completed 550000 out of 2500000 steps (22%)
22:48:41:WU03:FS02:0xa4:Completed 1485000 out of 1500000 steps (99%)
22:49:46:WU00:FS02:Connecting to assign3.stanford.edu:8080
22:49:46:WU00:FS02:News: Welcome to Folding@Home
22:49:46:WU00:FS02:Assigned to work server 171.67.108.35
22:49:46:WU00:FS02:Requesting new work unit for slot 02: RUNNING cpu:7 from 171.67.108.35
22:49:46:WU00:FS02:Connecting to 171.67.108.35:8080
22:49:47:ERROR:WU00:FS02:Exception: Server did not assign work unit
22:53:40:WU02:FS00:0x17:Completed 325000 out of 2500000 steps (13%)
22:56:38:WU00:FS02:Connecting to assign3.stanford.edu:8080
22:56:38:WU00:FS02:News: Welcome to Folding@Home
22:56:38:WU00:FS02:Assigned to work server 171.67.108.35
22:56:38:WU00:FS02:Requesting new work unit for slot 02: RUNNING cpu:7 from 171.67.108.35
22:56:38:WU00:FS02:Connecting to 171.67.108.35:8080
22:56:38:ERROR:WU00:FS02:Exception: Server did not assign work unit
22:56:58:WU03:FS02:0xa4:Completed 1500000 out of 1500000 steps (100%)
22:56:59:WU03:FS02:0xa4
ynamicWrapper: Finished Work Unit: sleep=10000
22:57:09:WU03:FS02:0xa4:
22:57:09:WU03:FS02:0xa4:Finished Work Unit:
22:57:09:WU03:FS02:0xa4:- Reading up to 2908800 from \"03/wudata_01.trr\": Read 2908800
22:57:09:WU03:FS02:0xa4:trr file hash check passed.
22:57:09:WU03:FS02:0xa4:- Reading up to 1554520 from \"03/wudata_01.xtc\": Read 1554520
22:57:09:WU03:FS02:0xa4:xtc file hash check passed.
22:57:09:WU03:FS02:0xa4:edr file hash check passed.
22:57:09:WU03:FS02:0xa4:logfile size: 27727
22:57:09:WU03:FS02:0xa4:Leaving Run
22:57:12:WU03:FS02:0xa4:- Writing 4496059 bytes of core data to disk...
22:57:13:WU03:FS02:0xa4
one: 4495547 -> 4325742 (compressed to 96.2 percent)
22:57:13:WU03:FS02:0xa4: ... Done.
22:57:13:WU03:FS02:0xa4:- Shutting down core
22:57:13:WU03:FS02:0xa4:Folding@home Core Shutdown: FINISHED_UNIT
22:57:13:WU03:FS02:FahCore returned: FINISHED_UNIT (100 = 0x64)
22:57:13:WU03:FS02:Sending unit results: id:03 state:SEND error:NO_ERROR project:7809 run:4 clone:175 gen:39 core:0xa4 unit:0x000000440a3b1e874e310df0c0f4e59a
22:57:13:WU03:FS02:Uploading 4.13MiB to 171.64.65.99
22:57:13:WU03:FS02:Connecting to 171.64.65.99:8080
22:57:19:WU03:FS02:Upload 18.18%
22:57:25:WU03:FS02:Upload 34.84%
22:57:31:WU03:FS02:Upload 51.50%
22:57:37:WU03:FS02:Upload 68.17%
22:57:43:WU03:FS02:Upload 84.83%
22:57:49:WU03:FS02:Upload complete
22:57:49:WU03:FS02:Server responded WORK_ACK (400)
22:57:49:WU03:FS02:Final credit estimate, 8663.00 points
22:57:49:WU03:FS02:Cleaning up
23:02:45:WU01:FS01:0x17:Completed 575000 out of 2500000 steps (23%)
23:07:43:WU00:FS02:Connecting to assign3.stanford.edu:8080
23:07:43:WU00:FS02:News: Welcome to Folding@Home
23:07:43:WU00:FS02:Assigned to work server 128.143.231.202
23:07:43:WU00:FS02:Requesting new work unit for slot 02: READY cpu:7 from 128.143.231.202
23:07:43:WU00:FS02:Connecting to 128.143.231.202:8080
23:07:45:WU00:FS02
ownloading 3.64MiB
23:07:47:WU00:FS02
ownload complete
23:07:47:WU00:FS02:Received Unit: id:00 state
OWNLOAD error:NO_ERROR project:6098 run:2 clone:74 gen:214 core:0xa3 unit:0x0000012a0a3b1e594e91dd4d67b65d9b
23:07:47:WU00:FS02:Starting
23:07:47:WU00:FS02:Running FahCore: \"C:\\Program Files (x86)\\FAHClient/FAHCoreWrapper.exe\" C:/Users/Brad/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/Core_a3.fah/FahCore_a3.exe -dir 00 -suffix 01 -version 703 -lifeline 2208 -checkpoint 15 -np 7
23:07:47:WU00:FS02:Started FahCore on PID 5312
23:07:47:WU00:FS02:Core PID:3324
23:07:47:WU00:FS02:FahCore 0xa3 started
23:07:48:WU00:FS02:0xa3:
23:07:48:WU00:FS02:0xa3:*------------------------------*
23:07:48:WU00:FS02:0xa3:Folding@Home Gromacs SMP Core
23:07:48:WU00:FS02:0xa3:Version 2.27 (Dec. 15, 2010)
23:07:48:WU00:FS02:0xa3:- Looking at optimizations...
23:07:48:WU00:FS02:0xa3:- Created dyn
23:07:48:WU00:FS02:0xa3:- Files status OK
23:07:48:WU00:FS02:0xa3:- Expanded 3812599 -> 4136808 (decompressed 108.5 percent)
23:07:48:WU00:FS02:0xa3:Called DecompressByteArray: compressed_data_size=3812599 data_size=4136808, decompressed_data_size=4136808 diff=0
23:07:48:WU00:FS02:0xa3:- Digital signature verified
roject: 6098 (Run 2, Clone 74, Gen 214)
23:07:48:WU00:FS02:0xa3:Assembly optimizations on if available.
23:07:48:WU00:FS02:0xa3:Entering M.D.
23:07:54:WU00:FS02:0xa3:Mapping NT from 7 to 7
23:07:54:WU00:FS02:0xa3:Completed 0 out of 500000 steps (0%)
23:09:41:WU02:FS00:0x17:Completed 350000 out of 2500000 steps (14%)
23:16:40:WU00:FS02:0xa3:Completed 5000 out of 500000 steps (1%)
23:18:50:WU01:FS01:0x17:Completed 600000 out of 2500000 steps (24%)
23:25:26:WU00:FS02:0xa3:Completed 10000 out of 500000 steps (2%)
23:26:09:WU02:FS00:0x17:Completed 375000 out of 2500000 steps (15%)
23:34:13:WU00:FS02:0xa3:Completed 15000 out of 500000 steps (3%)
23:35:14:WU01:FS01:0x17:Completed 625000 out of 2500000 steps (25%)
23:42:15:WU02:FS00:0x17:Completed 400000 out of 2500000 steps (16%)
23:42:59:WU00:FS02:0xa3:Completed 20000 out of 500000 steps (4%)
23:51:22:WU01:FS01:0x17:Completed 650000 out of 2500000 steps (26%)
23:51:45:WU00:FS02:0xa3:Completed 25000 out of 500000 steps (5%)
23:58:43:WU02:FS00:0x17:Completed 425000 out of 2500000 steps (17%)
00:00:29:WU00:FS02:0xa3:Completed 30000 out of 500000 steps (6%)
00:07:47:WU01:FS01:0x17:Completed 675000 out of 2500000 steps (27%)
00:09:17:WU00:FS02:0xa3:Completed 35000 out of 500000 steps (7%)
00:14:49:WU02:FS00:0x17:Completed 450000 out of 2500000 steps (18%)
00:18:10:WU00:FS02:0xa3:Completed 40000 out of 500000 steps (8%)
00:23:54:WU01:FS01:0x17:Completed 700000 out of 2500000 steps (28%)
00:27:01:WU00:FS02:0xa3:Completed 45000 out of 500000 steps (9%)
00:31:16:WU02:FS00:0x17:Completed 475000 out of 2500000 steps (19%)
00:35:51:WU00:FS02:0xa3:Completed 50000 out of 500000 steps (10%)
00:40:22:WU01:FS01:0x17:Completed 725000 out of 2500000 steps (29%)
00:44:36:WU00:FS02:0xa3:Completed 55000 out of 500000 steps (11%)
00:47:24:WU02:FS00:0x17:Completed 500000 out of 2500000 steps (20%)
00:53:19:WU00:FS02:0xa3:Completed 60000 out of 500000 steps (12%)
00:56:32:WU01:FS01:0x17:Completed 750000 out of 2500000 steps (30%)
01:02:05:WU00:FS02:0xa3:Completed 65000 out of 500000 steps (13%)
01:03:51:WU02:FS00:0x17:Completed 525000 out of 2500000 steps (21%)
01:10:48:WU00:FS02:0xa3:Completed 70000 out of 500000 steps (14%)
01:12:57:WU01:FS01:0x17:Completed 775000 out of 2500000 steps (31%)
01:19:29:WU00:FS02:0xa3:Completed 75000 out of 500000 steps (15%)
01:19:59:WU02:FS00:0x17:Completed 550000 out of 2500000 steps (22%)
01:28:15:WU00:FS02:0xa3:Completed 80000 out of 500000 steps (16%)
01:29:05:WU01:FS01:0x17:Completed 800000 out of 2500000 steps (32%)
01:36:26:WU02:FS00:0x17:Completed 575000 out of 2500000 steps (23%)
01:37:03:WU00:FS02:0xa3:Completed 85000 out of 500000 steps (17%)
01:45:31:WU01:FS01:0x17:Completed 825000 out of 2500000 steps (33%)
01:45:41:WU00:FS02:0xa3:Completed 90000 out of 500000 steps (18%)
01:52:34:WU02:FS00:0x17:Completed 600000 out of 2500000 steps (24%)
01:54:31:WU00:FS02:0xa3:Completed 95000 out of 500000 steps (19%)
02:01:39:WU01:FS01:0x17:Completed 850000 out of 2500000 steps (34%)
02:03:21:WU00:FS02:0xa3:Completed 100000 out of 500000 steps (20%)
******************************* Date: 2013-06-22 *******************************
02:09:01:WU02:FS00:0x17:Completed 625000 out of 2500000 steps (25%)
02:12:09:WU00:FS02:0xa3:Completed 105000 out of 500000 steps (21%)
02:18:03:WU01:FS01:0x17:Completed 875000 out of 2500000 steps (35%)
02:21:01:WU00:FS02:0xa3:Completed 110000 out of 500000 steps (22%)
02:25:07:WU02:FS00:0x17:Completed 650000 out of 2500000 steps (26%)
02:29:47:WU00:FS02:0xa3:Completed 115000 out of 500000 steps (23%)
02:34:11:WU01:FS01:0x17:Completed 900000 out of 2500000 steps (36%)
02:38:37:WU00:FS02:0xa3:Completed 120000 out of 500000 steps (24%)
02:41:35:WU02:FS00:0x17:Completed 675000 out of 2500000 steps (27%)
02:47:28:WU00:FS02:0xa3:Completed 125000 out of 500000 steps (25%)
02:50:37:WU01:FS01:0x17:Completed 925000 out of 2500000 steps (37%)
02:56:16:WU00:FS02:0xa3:Completed 130000 out of 500000 steps (26%)
02:57:42:WU02:FS00:0x17:Completed 700000 out of 2500000 steps (28%)
03:05:00:WU00:FS02:0xa3:Completed 135000 out of 500000 steps (27%)
03:06:47:WU01:FS01:0x17:Completed 950000 out of 2500000 steps (38%)
03:13:43:WU00:FS02:0xa3:Completed 140000 out of 500000 steps (28%)
03:14:10:WU02:FS00:0x17:Completed 725000 out of 2500000 steps (29%)
03:22:30:WU00:FS02:0xa3:Completed 145000 out of 500000 steps (29%)
03:23:14:WU01:FS01:0x17:Completed 975000 out of 2500000 steps (39%)
03:30:18:WU02:FS00:0x17:Completed 750000 out of 2500000 steps (30%)
03:31:17:WU00:FS02:0xa3:Completed 150000 out of 500000 steps (30%)
03:39:23:WU01:FS01:0x17:Completed 1000000 out of 2500000 steps (40%)
03:40:05:WU00:FS02:0xa3:Completed 155000 out of 500000 steps (31%)
03:46:44:WU02:FS00:0x17:Completed 775000 out of 2500000 steps (31%)
03:48:51:WU00:FS02:0xa3:Completed 160000 out of 500000 steps (32%)
03:55:49:WU01:FS01:0x17:Completed 1025000 out of 2500000 steps (41%)
03:57:41:WU00:FS02:0xa3:Completed 165000 out of 500000 steps (33%)
04:02:52:WU02:FS00:0x17:Completed 800000 out of 2500000 steps (32%)
04:06:39:WU00:FS02:0xa3:Completed 170000 out of 500000 steps (34%)
04:11:58:WU01:FS01:0x17:Completed 1050000 out of 2500000 steps (42%)
04:15:25:WU00:FS02:0xa3:Completed 175000 out of 500000 steps (35%)
04:19:19:WU02:FS00:0x17:Completed 825000 out of 2500000 steps (33%)
04:24:12:WU00:FS02:0xa3:Completed 180000 out of 500000 steps (36%)
04:28:24:WU01:FS01:0x17:Completed 1075000 out of 2500000 steps (43%)
04:32:55:WU00:FS02:0xa3:Completed 185000 out of 500000 steps (37%)
04:35:26:WU02:FS00:0x17:Completed 850000 out of 2500000 steps (34%)
04:41:38:WU00:FS02:0xa3:Completed 190000 out of 500000 steps (38%)
04:44:33:WU01:FS01:0x17:Completed 1100000 out of 2500000 steps (44%)
04:50:26:WU00:FS02:0xa3:Completed 195000 out of 500000 steps (39%)
04:51:55:WU02:FS00:0x17:Completed 875000 out of 2500000 steps (35%)
04:59:14:WU00:FS02:0xa3:Completed 200000 out of 500000 steps (40%)
05:01:10:WU01:FS01:0x17:Completed 1125000 out of 2500000 steps (45%)
05:08:00:WU00:FS02:0xa3:Completed 205000 out of 500000 steps (41%)
05:08:02:WU02:FS00:0x17:Completed 900000 out of 2500000 steps (36%)
05:16:51:WU00:FS02:0xa3:Completed 210000 out of 500000 steps (42%)
05:18:12:WU01:FS01:0x17:Completed 1150000 out of 2500000 steps (46%)
05:24:29:WU02:FS00:0x17:Completed 925000 out of 2500000 steps (37%)
05:25:36:WU00:FS02:0xa3:Completed 215000 out of 500000 steps (43%)
05:34:25:WU00:FS02:0xa3:Completed 220000 out of 500000 steps (44%)
05:35:44:WU01:FS01:0x17:Completed 1175000 out of 2500000 steps (47%)
05:40:36:WU02:FS00:0x17:Completed 950000 out of 2500000 steps (38%)
05:43:13:WU00:FS02:0xa3:Completed 225000 out of 500000 steps (45%)
05:52:00:WU00:FS02:0xa3:Completed 230000 out of 500000 steps (46%)
05:52:58:WU01:FS01:0x17:Completed 1200000 out of 2500000 steps (48%)
05:57:01:WU02:FS00:0x17:Completed 975000 out of 2500000 steps (39%)
06:00:44:WU00:FS02:0xa3:Completed 235000 out of 500000 steps (47%)
06:09:40:WU00:FS02:0xa3:Completed 240000 out of 500000 steps (48%)
06:10:32:WU01:FS01:0x17:Completed 1225000 out of 2500000 steps (49%)
06:13:06:WU02:FS00:0x17:Completed 1000000 out of 2500000 steps (40%)
06:19:23:WU00:FS02:0xa3:Completed 245000 out of 500000 steps (49%)
06:28:13:WU01:FS01:0x17:Completed 1250000 out of 2500000 steps (50%)
06:29:11:WU00:FS02:0xa3:Completed 250000 out of 500000 steps (50%)
06:29:29:WU02:FS00:0x17:Completed 1025000 out of 2500000 steps (41%)
06:38:54:WU00:FS02:0xa3:Completed 255000 out of 500000 steps (51%)
06:45:31:WU02:FS00:0x17:Completed 1050000 out of 2500000 steps (42%)
06:46:38:WU01:FS01:0x17:Completed 1275000 out of 2500000 steps (51%)
06:48:36:WU00:FS02:0xa3:Completed 260000 out of 500000 steps (52%)
06:58:19:WU00:FS02:0xa3:Completed 265000 out of 500000 steps (53%)
07:01:55:WU02:FS00:0x17:Completed 1075000 out of 2500000 steps (43%)
07:04:49:WU01:FS01:0x17:Completed 1300000 out of 2500000 steps (52%)
07:08:12:WU00:FS02:0xa3:Completed 270000 out of 500000 steps (54%)
07:17:59:WU02:FS00:0x17:Completed 1100000 out of 2500000 steps (44%)
07:18:01:WU00:FS02:0xa3:Completed 275000 out of 500000 steps (55%)
07:23:21:WU01:FS01:0x17:Completed 1325000 out of 2500000 steps (53%)
07:27:35:WU00:FS02:0xa3:Completed 280000 out of 500000 steps (56%)
07:34:24:WU02:FS00:0x17:Completed 1125000 out of 2500000 steps (45%)
07:36:50:WU00:FS02:0xa3:Completed 285000 out of 500000 steps (57%)
07:40:46:WU01:FS01:0x17:Completed 1350000 out of 2500000 steps (54%)
07:45:54:WU00:FS02:0xa3:Completed 290000 out of 500000 steps (58%)
07:50:31:WU02:FS00:0x17:Completed 1150000 out of 2500000 steps (46%)
07:54:51:WU00:FS02:0xa3:Completed 295000 out of 500000 steps (59%)
07:58:20:WU01:FS01:0x17:Completed 1375000 out of 2500000 steps (55%)
08:03:48:WU00:FS02:0xa3:Completed 300000 out of 500000 steps (60%)
08:06:52:WU02:FS00:0x17:Completed 1175000 out of 2500000 steps (47%)
08:12:45:WU00:FS02:0xa3:Completed 305000 out of 500000 steps (61%)
08:15:34:WU01:FS01:0x17:Completed 1400000 out of 2500000 steps (56%)
08:21:49:WU00:FS02:0xa3:Completed 310000 out of 500000 steps (62%)
08:22:55:WU02:FS00:0x17:Completed 1200000 out of 2500000 steps (48%)
08:30:49:WU00:FS02:0xa3:Completed 315000 out of 500000 steps (63%)
08:33:06:WU01:FS01:0x17:Completed 1425000 out of 2500000 steps (57%)
08:39:17:WU02:FS00:0x17:Completed 1225000 out of 2500000 steps (49%)
08:39:45:WU00:FS02:0xa3:Completed 320000 out of 500000 steps (64%)
08:48:44:WU00:FS02:0xa3:Completed 325000 out of 500000 steps (65%)
08:50:19:WU01:FS01:0x17:Completed 1450000 out of 2500000 steps (58%)
08:55:19:WU02:FS00:0x17:Completed 1250000 out of 2500000 steps (50%)
08:57:44:WU00:FS02:0xa3:Completed 330000 out of 500000 steps (66%)
09:06:45:WU00:FS02:0xa3:Completed 335000 out of 500000 steps (67%)
09:07:55:WU01:FS01:0x17:Completed 1475000 out of 2500000 steps (59%)
09:11:44:WU02:FS00:0x17:Completed 1275000 out of 2500000 steps (51%)
09:15:48:WU00:FS02:0xa3:Completed 340000 out of 500000 steps (68%)
09:24:47:WU00:FS02:0xa3:Completed 345000 out of 500000 steps (69%)
09:25:09:WU01:FS01:0x17:Completed 1500000 out of 2500000 steps (60%)
09:27:51:WU02:FS00:0x17:Completed 1300000 out of 2500000 steps (52%)
09:33:42:WU00:FS02:0xa3:Completed 350000 out of 500000 steps (70%)
09:42:45:WU01:FS01:0x17:Completed 1525000 out of 2500000 steps (61%)
09:42:49:WU00:FS02:0xa3:Completed 355000 out of 500000 steps (71%)
09:44:16:WU02:FS00:0x17:Completed 1325000 out of 2500000 steps (53%)
09:51:55:WU00:FS02:0xa3:Completed 360000 out of 500000 steps (72%)
10:00:01:WU01:FS01:0x17:Completed 1550000 out of 2500000 steps (62%)
10:00:23:WU02:FS00:0x17:Completed 1350000 out of 2500000 steps (54%)
10:01:02:WU00:FS02:0xa3:Completed 365000 out of 500000 steps (73%)
10:10:07:WU00:FS02:0xa3:Completed 370000 out of 500000 steps (74%)
10:16:46:WU02:FS00:0x17:Completed 1375000 out of 2500000 steps (55%)
10:17:35:WU01:FS01:0x17:Completed 1575000 out of 2500000 steps (63%)
10:19:13:WU00:FS02:0xa3:Completed 375000 out of 500000 steps (75%)
10:28:16:WU00:FS02:0xa3:Completed 380000 out of 500000 steps (76%)
10:32:49:WU02:FS00:0x17:Completed 1400000 out of 2500000 steps (56%)
10:34:49:WU01:FS01:0x17:Completed 1600000 out of 2500000 steps (64%)
10:37:20:WU00:FS02:0xa3:Completed 385000 out of 500000 steps (77%)
10:46:21:WU00:FS02:0xa3:Completed 390000 out of 500000 steps (78%)
10:49:13:WU02:FS00:0x17:Completed 1425000 out of 2500000 steps (57%)
10:52:22:WU01:FS01:0x17:Completed 1625000 out of 2500000 steps (65%)
10:55:22:WU00:FS02:0xa3:Completed 395000 out of 500000 steps (79%)
11:04:25:WU00:FS02:0xa3:Completed 400000 out of 500000 steps (80%)
11:05:16:WU02:FS00:0x17:Completed 1450000 out of 2500000 steps (58%)
11:09:37:WU01:FS01:0x17:Completed 1650000 out of 2500000 steps (66%)
11:13:29:WU00:FS02:0xa3:Completed 405000 out of 500000 steps (81%)
11:21:55:WU02:FS00:0x17:Completed 1475000 out of 2500000 steps (59%)
11:22:42:WU00:FS02:0xa3:Completed 410000 out of 500000 steps (82%)
11:27:26:WU01:FS01:0x17:Completed 1675000 out of 2500000 steps (67%)
11:31:44:WU00:FS02:0xa3:Completed 415000 out of 500000 steps (83%)
11:37:59:WU02:FS00:0x17:Completed 1500000 out of 2500000 steps (60%)
11:40:46:WU00:FS02:0xa3:Completed 420000 out of 500000 steps (84%)
11:44:41:WU01:FS01:0x17:Completed 1700000 out of 2500000 steps (68%)
11:49:51:WU00:FS02:0xa3:Completed 425000 out of 500000 steps (85%)
11:54:24:WU02:FS00:0x17:Completed 1525000 out of 2500000 steps (61%)
11:58:51:WU00:FS02:0xa3:Completed 430000 out of 500000 steps (86%)
12:02:18:WU01:FS01:0x17:Completed 1725000 out of 2500000 steps (69%)
12:07:46:WU00:FS02:0xa3:Completed 435000 out of 500000 steps (87%)
12:10:29:WU02:FS00:0x17:Completed 1550000 out of 2500000 steps (62%)
12:16:46:WU00:FS02:0xa3:Completed 440000 out of 500000 steps (88%)
12:19:35:WU01:FS01:0x17:Completed 1750000 out of 2500000 steps (70%)
12:25:49:WU00:FS02:0xa3:Completed 445000 out of 500000 steps (89%)
12:26:52:WU02:FS00:0x17:Completed 1575000 out of 2500000 steps (63%)
12:34:45:WU00:FS02:0xa3:Completed 450000 out of 500000 steps (90%)
12:37:08:WU01:FS01:0x17:Completed 1775000 out of 2500000 steps (71%)
12:42:54:WU02:FS00:0x17:Completed 1600000 out of 2500000 steps (64%)
12:43:47:WU00:FS02:0xa3:Completed 455000 out of 500000 steps (91%)
12:52:49:WU00:FS02:0xa3:Completed 460000 out of 500000 steps (92%)
12:54:24:WU01:FS01:0x17:Completed 1800000 out of 2500000 steps (72%)
12:59:20:WU02:FS00:0x17:Completed 1625000 out of 2500000 steps (65%)
13:01:52:WU00:FS02:0xa3:Completed 465000 out of 500000 steps (93%)
13:10:57:WU00:FS02:0xa3:Completed 470000 out of 500000 steps (94%)
13:11:59:WU01:FS01:0x17:Completed 1825000 out of 2500000 steps (73%)
13:15:23:WU02:FS00:0x17:Completed 1650000 out of 2500000 steps (66%)
13:19:59:WU00:FS02:0xa3:Completed 475000 out of 500000 steps (95%)
13:29:01:WU00:FS02:0xa3:Completed 480000 out of 500000 steps (96%)
13:29:13:WU01:FS01:0x17:Completed 1850000 out of 2500000 steps (74%)
13:31:48:WU02:FS00:0x17:Completed 1675000 out of 2500000 steps (67%)
13:37:59:WU00:FS02:0xa3:Completed 485000 out of 500000 steps (97%)
13:46:48:WU01:FS01:0x17:Completed 1875000 out of 2500000 steps (75%)
13:47:01:WU00:FS02:0xa3:Completed 490000 out of 500000 steps (98%)
13:47:01:WU03:FS02:Connecting to assign3.stanford.edu:8080
13:47:01:WU03:FS02:News: Welcome to Folding@Home
13:47:01:WU03:FS02:Assigned to work server 171.67.108.35
13:47:01:WU03:FS02:Requesting new work unit for slot 02: RUNNING cpu:7 from 171.67.108.35
13:47:01:WU03:FS02:Connecting to 171.67.108.35:8080
13:47:02:WU03:FS02
ownloading 1001.33KiB
13:47:03:WU03:FS02
ownload complete
13:47:03:WU03:FS02:Received Unit: id:03 state
OWNLOAD error:NO_ERROR project:8702 run:24 clone:2 gen:3 core:0xa4 unit:0x000000036652edb35196eb4883af6b40
13:47:52:WU02:FS00:0x17:Completed 1700000 out of 2500000 steps (68%)
13:55:53:WU00:FS02:0xa3:Completed 495000 out of 500000 steps (99%)
14:04:05:WU01:FS01:0x17:Completed 1900000 out of 2500000 steps (76%)
14:04:17:WU02:FS00:0x17:Completed 1725000 out of 2500000 steps (69%)
14:05:08:WU00:FS02:0xa3:Completed 500000 out of 500000 steps (100%)
14:05:10:WU00:FS02:0xa3
14:05:20:WU00:FS02:0xa3:
14:05:20:WU00:FS02:0xa3:Finished Work Unit:
14:05:20:WU00:FS02:0xa3:- Reading up to 12102120 from \"00/wudata_01.trr\": Read 12102120
14:05:20:WU00:FS02:0xa3:trr file hash check passed.
14:05:20:WU00:FS02:0xa3:edr file hash check passed.
14:05:20:WU00:FS02:0xa3:logfile size: 56088
14:05:20:WU00:FS02:0xa3:Leaving Run
14:05:20:WU00:FS02:0xa3:- Writing 12191884 bytes of core data to disk...
14:05:22:WU00:FS02:0xa3
one: 12191372 -> 11297214 (compressed to 92.6 percent)
14:05:22:WU00:FS02:0xa3: ... Done.
14:05:22:WU00:FS02:0xa3:- Shutting down core
14:05:22:WU00:FS02:0xa3:Folding@home Core Shutdown: FINISHED_UNIT
14:05:23:WU00:FS02:FahCore returned: FINISHED_UNIT (100 = 0x64)
14:05:23:WU00:FS02:Sending unit results: id:00 state:SEND error:NO_ERROR project:6098 run:2 clone:74 gen:214 core:0xa3 unit:0x0000012a0a3b1e594e91dd4d67b65d9b
14:05:23:WU00:FS02:Uploading 10.77MiB to 128.143.231.202
14:05:23:WU00:FS02:Connecting to 128.143.231.202:8080
14:05:23:WU03:FS02:Starting
14:05:23:WU03:FS02:Running FahCore: \"C:\\Program Files (x86)\\FAHClient/FAHCoreWrapper.exe\" C:/Users/Brad/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 03 -suffix 01 -version 703 -lifeline 2208 -checkpoint 15 -np 7
14:05:23:WU03:FS02:Started FahCore on PID 6960
14:05:23:WU03:FS02:Core PID:6396
14:05:23:WU03:FS02:FahCore 0xa4 started
14:05:24:WU03:FS02:0xa4:
14:05:24:WU03:FS02:0xa4:*------------------------------*
14:05:24:WU03:FS02:0xa4:Folding@Home Gromacs GB Core
14:05:24:WU03:FS02:0xa4:Version 2.27 (Dec. 15, 2010)
14:05:24:WU03:FS02:0xa4:- Looking at optimizations...
14:05:24:WU03:FS02:0xa4:- Created dyn
14:05:24:WU03:FS02:0xa4:- Files status OK
14:05:24:WU03:FS02:0xa4:- Expanded 1024853 -> 2544640 (decompressed 248.2 percent)
14:05:24:WU03:FS02:0xa4:Called DecompressByteArray: compressed_data_size=1024853 data_size=2544640, decompressed_data_size=2544640 diff=0
14:05:24:WU03:FS02:0xa4:- Digital signature verified
roject: 8702 (Run 24, Clone 2, Gen 3)
14:05:24:WU03:FS02:0xa4:Assembly optimizations on if available.
14:05:24:WU03:FS02:0xa4:Entering M.D.
14:05:29:WU00:FS02:Upload 5.80%
14:05:29:WU03:FS02:0xa4:Mapping NT from 7 to 7
14:05:30:WU03:FS02:0xa4:Completed 0 out of 250000 steps (0%)
14:05:35:WU00:FS02:Upload 10.44%
14:05:41:WU00:FS02:Upload 15.08%
14:05:47:WU00:FS02:Upload 20.30%
14:05:53:WU00:FS02:Upload 24.36%
14:05:59:WU00:FS02:Upload 29.58%
14:06:05:WU00:FS02:Upload 34.22%
14:06:11:WU00:FS02:Upload 39.45%
14:06:17:WU00:FS02:Upload 44.09%
14:06:23:WU00:FS02:Upload 48.73%
14:06:29:WU00:FS02:Upload 53.37%
14:06:35:WU00:FS02:Upload 58.01%
14:06:41:WU00:FS02:Upload 63.23%
14:06:47:WU00:FS02:Upload 67.87%
14:06:50:WU03:FS02:0xa4:Completed 2500 out of 250000 steps (1%)
14:06:53:WU00:FS02:Upload 73.09%
14:06:59:WU00:FS02:Upload 77.73%
14:07:05:WU00:FS02:Upload 82.37%
14:07:11:WU00:FS02:Upload 87.01%
14:07:17:WU00:FS02:Upload 91.65%
14:07:23:WU00:FS02:Upload 96.87%
14:07:29:WU00:FS02:Upload complete
14:07:29:WU00:FS02:Server responded WORK_ACK (400)
14:07:29:WU00:FS02:Final credit estimate, 12488.00 points
14:07:29:WU00:FS02:Cleaning up
14:08:10:WU03:FS02:0xa4:Completed 5000 out of 250000 steps (2%)
14:09:31:WU03:FS02:0xa4:Completed 7500 out of 250000 steps (3%)
14:10:52:WU03:FS02:0xa4:Completed 10000 out of 250000 steps (4%)
14:12:14:WU03:FS02:0xa4:Completed 12500 out of 250000 steps (5%)
14:13:35:WU03:FS02:0xa4:Completed 15000 out of 250000 steps (6%)
14:14:56:WU03:FS02:0xa4:Completed 17500 out of 250000 steps (7%)
14:16:19:WU03:FS02:0xa4:Completed 20000 out of 250000 steps (8%)
14:17:39:WU03:FS02:0xa4:Completed 22500 out of 250000 steps (9%)
14:19:02:WU03:FS02:0xa4:Completed 25000 out of 250000 steps (10%)
14:20:21:WU02:FS00:0x17:Completed 1750000 out of 2500000 steps (70%)
14:20:27:WU03:FS02:0xa4:Completed 27500 out of 250000 steps (11%)
14:21:41:WU01:FS01:0x17:Completed 1925000 out of 2500000 steps (77%)
14:21:52:WU03:FS02:0xa4:Completed 30000 out of 250000 steps (12%)
14:23:13:WU03:FS02:0xa4:Completed 32500 out of 250000 steps (13%)
14:24:34:WU03:FS02:0xa4:Completed 35000 out of 250000 steps (14%)
14:25:57:WU03:FS02:0xa4:Completed 37500 out of 250000 steps (15%)
14:27:20:WU03:FS02:0xa4:Completed 40000 out of 250000 steps (16%)
14:28:43:WU03:FS02:0xa4:Completed 42500 out of 250000 steps (17%)
14:30:05:WU03:FS02:0xa4:Completed 45000 out of 250000 steps (18%)
14:31:28:WU03:FS02:0xa4:Completed 47500 out of 250000 steps (19%)
14:32:49:WU03:FS02:0xa4:Completed 50000 out of 250000 steps (20%)
14:34:10:WU03:FS02:0xa4:Completed 52500 out of 250000 steps (21%)
14:35:31:WU03:FS02:0xa4:Completed 55000 out of 250000 steps (22%)
14:36:41:WU02:FS00:0x17:Completed 1775000 out of 2500000 steps (71%)
14:36:53:WU03:FS02:0xa4:Completed 57500 out of 250000 steps (23%)
14:38:15:WU03:FS02:0xa4:Completed 60000 out of 250000 steps (24%)
14:39:01:WU01:FS01:0x17:Completed 1950000 out of 2500000 steps (78%)
14:39:38:WU03:FS02:0xa4:Completed 62500 out of 250000 steps (25%)
14:40:59:WU03:FS02:0xa4:Completed 65000 out of 250000 steps (26%)
14:42:21:WU03:FS02:0xa4:Completed 67500 out of 250000 steps (27%)
14:43:43:WU03:FS02:0xa4:Completed 70000 out of 250000 steps (28%)
14:45:02:WU03:FS02:0xa4:Completed 72500 out of 250000 steps (29%)
14:46:24:WU03:FS02:0xa4:Completed 75000 out of 250000 steps (30%)
14:47:46:WU03:FS02:0xa4:Completed 77500 out of 250000 steps (31%)
14:49:07:WU03:FS02:0xa4:Completed 80000 out of 250000 steps (32%)
14:50:29:WU03:FS02:0xa4:Completed 82500 out of 250000 steps (33%)
14:51:50:WU03:FS02:0xa4:Completed 85000 out of 250000 steps (34%)
14:52:44:WU02:FS00:0x17:Completed 1800000 out of 2500000 steps (72%)
14:53:12:WU03:FS02:0xa4:Completed 87500 out of 250000 steps (35%)
14:54:32:WU03:FS02:0xa4:Completed 90000 out of 250000 steps (36%)
14:55:53:WU03:FS02:0xa4:Completed 92500 out of 250000 steps (37%)
14:56:35:WU01:FS01:0x17:Completed 1975000 out of 2500000 steps (79%)
14:57:15:WU03:FS02:0xa4:Completed 95000 out of 250000 steps (38%)
14:58:37:WU03:FS02:0xa4:Completed 97500 out of 250000 steps (39%)
14:59:59:WU03:FS02:0xa4:Completed 100000 out of 250000 steps (40%)
15:01:21:WU03:FS02:0xa4:Completed 102500 out of 250000 steps (41%)
15:02:42:WU03:FS02:0xa4:Completed 105000 out of 250000 steps (42%)
15:04:03:WU03:FS02:0xa4:Completed 107500 out of 250000 steps (43%)
15:05:25:WU03:FS02:0xa4:Completed 110000 out of 250000 steps (44%)
15:06:47:WU03:FS02:0xa4:Completed 112500 out of 250000 steps (45%)
15:08:09:WU03:FS02:0xa4:Completed 115000 out of 250000 steps (46%)
15:09:03:WU02:FS00:0x17:Completed 1825000 out of 2500000 steps (73%)
15:09:29:WU03:FS02:0xa4:Completed 117500 out of 250000 steps (47%)
15:10:48:WU03:FS02:0xa4:Completed 120000 out of 250000 steps (48%)
15:12:08:WU03:FS02:0xa4:Completed 122500 out of 250000 steps (49%)
15:13:30:WU03:FS02:0xa4:Completed 125000 out of 250000 steps (50%)
15:13:48:WU01:FS01:0x17:Completed 2000000 out of 2500000 steps (80%)
15:14:51:WU03:FS02:0xa4:Completed 127500 out of 250000 steps (51%)
15:16:10:WU03:FS02:0xa4:Completed 130000 out of 250000 steps (52%)
15:17:31:WU03:FS02:0xa4:Completed 132500 out of 250000 steps (53%)
15:18:51:WU03:FS02:0xa4:Completed 135000 out of 250000 steps (54%)
15:20:13:WU03:FS02:0xa4:Completed 137500 out of 250000 steps (55%)
15:21:34:WU03:FS02:0xa4:Completed 140000 out of 250000 steps (56%)
15:22:55:WU03:FS02:0xa4:Completed 142500 out of 250000 steps (57%)
15:24:15:WU03:FS02:0xa4:Completed 145000 out of 250000 steps (58%)
15:25:07:WU02:FS00:0x17:Completed 1850000 out of 2500000 steps (74%)
15:25:36:WU03:FS02:0xa4:Completed 147500 out of 250000 steps (59%)
15:26:57:WU03:FS02:0xa4:Completed 150000 out of 250000 steps (60%)
15:28:19:WU03:FS02:0xa4:Completed 152500 out of 250000 steps (61%)
15:29:40:WU03:FS02:0xa4:Completed 155000 out of 250000 steps (62%)
15:31:02:WU03:FS02:0xa4:Completed 157500 out of 250000 steps (63%)
15:31:22:WU01:FS01:0x17:Completed 2025000 out of 2500000 steps (81%)
15:32:24:WU03:FS02:0xa4:Completed 160000 out of 250000 steps (64%)
15:33:45:WU03:FS02:0xa4:Completed 162500 out of 250000 steps (65%)
15:35:05:WU03:FS02:0xa4:Completed 165000 out of 250000 steps (66%)
15:36:25:WU03:FS02:0xa4:Completed 167500 out of 250000 steps (67%)
15:37:46:WU03:FS02:0xa4:Completed 170000 out of 250000 steps (68%)
15:39:07:WU03:FS02:0xa4:Completed 172500 out of 250000 steps (69%)
15:40:28:WU03:FS02:0xa4:Completed 175000 out of 250000 steps (70%)
15:41:29:WU02:FS00:0x17:Completed 1875000 out of 2500000 steps (75%)
15:41:50:WU03:FS02:0xa4:Completed 177500 out of 250000 steps (71%)
15:43:12:WU03:FS02:0xa4:Completed 180000 out of 250000 steps (72%)
15:44:34:WU03:FS02:0xa4:Completed 182500 out of 250000 steps (73%)
15:45:56:WU03:FS02:0xa4:Completed 185000 out of 250000 steps (74%)
15:47:18:WU03:FS02:0xa4:Completed 187500 out of 250000 steps (75%)
15:48:34:WU01:FS01:0x17:Completed 2050000 out of 2500000 steps (82%)
15:48:42:WU03:FS02:0xa4:Completed 190000 out of 250000 steps (76%)
15:50:04:WU03:FS02:0xa4:Completed 192500 out of 250000 steps (77%)
15:51:26:WU03:FS02:0xa4:Completed 195000 out of 250000 steps (78%)
15:52:47:WU03:FS02:0xa4:Completed 197500 out of 250000 steps (79%)
15:54:09:WU03:FS02:0xa4:Completed 200000 out of 250000 steps (80%)
15:55:31:WU03:FS02:0xa4:Completed 202500 out of 250000 steps (81%)
15:56:54:WU03:FS02:0xa4:Completed 205000 out of 250000 steps (82%)
15:57:33:WU02:FS00:0x17:Completed 1900000 out of 2500000 steps (76%)
15:58:16:WU03:FS02:0xa4:Completed 207500 out of 250000 steps (83%)
15:59:37:WU03:FS02:0xa4:Completed 210000 out of 250000 steps (84%)
16:00:59:WU03:FS02:0xa4:Completed 212500 out of 250000 steps (85%)
16:02:19:WU03:FS02:0xa4:Completed 215000 out of 250000 steps (86%)
16:03:39:WU03:FS02:0xa4:Completed 217500 out of 250000 steps (87%)
16:04:58:WU03:FS02:0xa4:Completed 220000 out of 250000 steps (88%)
16:06:09:WU01:FS01:0x17:Completed 2075000 out of 2500000 steps (83%)
16:06:18:WU03:FS02:0xa4:Completed 222500 out of 250000 steps (89%)
16:07:40:WU03:FS02:0xa4:Completed 225000 out of 250000 steps (90%)
16:09:01:WU03:FS02:0xa4:Completed 227500 out of 250000 steps (91%)
16:10:21:WU03:FS02:0xa4:Completed 230000 out of 250000 steps (92%)
16:11:40:WU03:FS02:0xa4:Completed 232500 out of 250000 steps (93%)
16:13:00:WU03:FS02:0xa4:Completed 235000 out of 250000 steps (94%)
16:13:56:WU02:FS00:0x17:Completed 1925000 out of 2500000 steps (77%)
16:14:21:WU03:FS02:0xa4:Completed 237500 out of 250000 steps (95%)
16:15:43:WU03:FS02:0xa4:Completed 240000 out of 250000 steps (96%)
16:17:06:WU03:FS02:0xa4:Completed 242500 out of 250000 steps (97%)
16:18:29:WU03:FS02:0xa4:Completed 245000 out of 250000 steps (98%)
16:18:29:WU00:FS02:Connecting to assign3.stanford.edu:8080
16:18:29:WU00:FS02:News: Welcome to Folding@Home
16:18:29:WU00:FS02:Assigned to work server 171.67.108.60
16:18:29:WU00:FS02:Requesting new work unit for slot 02: RUNNING cpu:7 from 171.67.108.60
16:18:29:WU00:FS02:Connecting to 171.67.108.60:8080
16:18:30:WU00:FS02
ownloading 1.07MiB
16:18:31:WU00:FS02
ownload complete
16:18:31:WU00:FS02:Received Unit: id:00 state
OWNLOAD error:NO_ERROR project:8703 run:4369 clone:0 gen:1 core:0xa4 unit:0x000000016652edcc51c2818407f83e8f
16:19:51:WU03:FS02:0xa4:Completed 247500 out of 250000 steps (99%)
16:21:13:WU03:FS02:0xa4:Completed 250000 out of 250000 steps (100%)
16:21:23:WU03:FS02:0xa4:
16:21:23:WU03:FS02:0xa4:Finished Work Unit:
16:21:23:WU03:FS02:0xa4:- Reading up to 1567212 from \"03/wudata_01.trr\": Read 1567212
16:21:23:WU03:FS02:0xa4:trr file hash check passed.
16:21:23:WU03:FS02:0xa4:- Reading up to 1759284 from \"03/wudata_01.xtc\": Read 1759284
16:21:23:WU03:FS02:0xa4:xtc file hash check passed.
16:21:23:WU03:FS02:0xa4:edr file hash check passed.
16:21:23:WU03:FS02:0xa4:logfile size: 27082
16:21:23:WU03:FS02:0xa4:Leaving Run
16:21:27:WU03:FS02:0xa4:- Writing 3363006 bytes of core data to disk...
one: 3362494 -> 3244678 (compressed to 96.4 percent)
16:21:27:WU03:FS02:0xa4: ... Done.
16:21:27:WU03:FS02:0xa4:- Shutting down core
16:21:27:WU03:FS02:0xa4:Folding@home Core Shutdown: FINISHED_UNIT
16:21:28:WU03:FS02:FahCore returned: FINISHED_UNIT (100 = 0x64)
16:21:28:WU03:FS02:Sending unit results: id:03 state:SEND error:NO_ERROR project:8702 run:24 clone:2 gen:3 core:0xa4 unit:0x000000036652edb35196eb4883af6b40
16:21:28:WU03:FS02:Uploading 3.09MiB to 171.67.108.35
16:21:28:WU03:FS02:Connecting to 171.67.108.35:8080
16:21:28:WU00:FS02:Starting
16:21:28:WU00:FS02:Running FahCore: \"C:\\Program Files (x86)\\FAHClient/FAHCoreWrapper.exe\" C:/Users/Brad/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 00 -suffix 01 -version 703 -lifeline 2208 -checkpoint 15 -np 7
16:21:28:WU00:FS02:Started FahCore on PID 6268
16:21:28:WU00:FS02:Core PID:6340
16:21:28:WU00:FS02:FahCore 0xa4 started
16:21:28:WU00:FS02:0xa4:
16:21:28:WU00:FS02:0xa4:*------------------------------*
16:21:28:WU00:FS02:0xa4:Folding@Home Gromacs GB Core
16:21:28:WU00:FS02:0xa4:Version 2.27 (Dec. 15, 2010)
reparing to commence simulation
16:21:28:WU00:FS02:0xa4:- Looking at optimizations...
16:21:28:WU00:FS02:0xa4:- Created dyn
16:21:28:WU00:FS02:0xa4:- Files status OK
16:21:28:WU00:FS02:0xa4:- Expanded 1118014 -> 3126200 (decompressed 279.6 percent)
16:21:28:WU00:FS02:0xa4:Called DecompressByteArray: compressed_data_size=1118014 data_size=3126200, decompressed_data_size=3126200 diff=0
16:21:28:WU00:FS02:0xa4:- Digital signature verified
roject: 8703 (Run 4369, Clone 0, Gen 1)
16:21:28:WU00:FS02:0xa4:Assembly optimizations on if available.
16:21:28:WU00:FS02:0xa4:Entering M.D.
16:21:34:WU03:FS02:Upload 20.19%
16:21:34:WU00:FS02:0xa4:Mapping NT from 7 to 7
16:21:34:WU00:FS02:0xa4:Completed 0 out of 1500000 steps (0%)
16:21:40:WU03:FS02:Upload 38.37%
16:21:46:WU03:FS02:Upload 54.53%
16:21:52:WU03:FS02:Upload 72.70%
16:21:58:WU03:FS02:Upload 88.86%
16:22:03:WU03:FS02:Upload complete
16:22:03:WU03:FS02:Server responded WORK_ACK (400)
16:22:03:WU03:FS02:Final credit estimate, 1461.00 points
16:22:03:WU03:FS02:Cleaning up
16:23:23:WU01:FS01:0x17:Completed 2100000 out of 2500000 steps (84%)
16:29:53:WU00:FS02:0xa4:Completed 15000 out of 1500000 steps (1%)
16:30:00:WU02:FS00:0x17:Completed 1950000 out of 2500000 steps (78%)
16:38:08:WU00:FS02:0xa4:Completed 30000 out of 1500000 steps (2%)
16:41:00:WU01:FS01:0x17:Completed 2125000 out of 2500000 steps (85%)
16:46:19:WU02:FS00:0x17:Completed 1975000 out of 2500000 steps (79%)
16:46:21:WU00:FS02:0xa4:Completed 45000 out of 1500000 steps (3%)
16:54:32:WU00:FS02:0xa4:Completed 60000 out of 1500000 steps (4%)
16:58:15:WU01:FS01:0x17:Completed 2150000 out of 2500000 steps (86%)
17:02:21:WU02:FS00:0x17:Completed 2000000 out of 2500000 steps (80%)
17:02:52:WU00:FS02:0xa4:Completed 75000 out of 1500000 steps (5%)
17:10:58:WU00:FS02:0xa4:Completed 90000 out of 1500000 steps (6%)
17:15:48:WU01:FS01:0x17:Completed 2175000 out of 2500000 steps (87%)
17:18:42:WU02:FS00:0x17:Completed 2025000 out of 2500000 steps (81%)
17:19:12:WU00:FS02:0xa4:Completed 105000 out of 1500000 steps (7%)
17:27:28:WU00:FS02:0xa4:Completed 120000 out of 1500000 steps (8%)
17:33:06:WU01:FS01:0x17:Completed 2200000 out of 2500000 steps (88%)
17:34:44:WU02:FS00:0x17:Completed 2050000 out of 2500000 steps (82%)
17:35:47:WU00:FS02:0xa4:Completed 135000 out of 1500000 steps (9%)
17:44:02:WU00:FS02:0xa4:Completed 150000 out of 1500000 steps (10%)
17:50:43:WU01:FS01:0x17:Completed 2225000 out of 2500000 steps (89%)
17:51:06:WU02:FS00:0x17:Completed 2075000 out of 2500000 steps (83%)
17:52:17:WU00:FS02:0xa4:Completed 165000 out of 1500000 steps (11%)
18:00:32:WU00:FS02:0xa4:Completed 180000 out of 1500000 steps (12%)
18:07:09:WU02:FS00:0x17:Completed 2100000 out of 2500000 steps (84%)
18:07:57:WU01:FS01:0x17:Completed 2250000 out of 2500000 steps (90%)
18:08:48:WU00:FS02:0xa4:Completed 195000 out of 1500000 steps (13%)
18:17:03:WU00:FS02:0xa4:Completed 210000 out of 1500000 steps (14%)
18:23:32:WU02:FS00:0x17:Completed 2125000 out of 2500000 steps (85%)
18:25:18:WU00:FS02:0xa4:Completed 225000 out of 1500000 steps (15%)
18:25:32:WU01:FS01:0x17:Completed 2275000 out of 2500000 steps (91%)
18:33:32:WU00:FS02:0xa4:Completed 240000 out of 1500000 steps (16%)
18:39:35:WU02:FS00:0x17:Completed 2150000 out of 2500000 steps (86%)
18:41:44:WU00:FS02:0xa4:Completed 255000 out of 1500000 steps (17%)
18:42:48:WU01:FS01:0x17:Completed 2300000 out of 2500000 steps (92%)
18:49:58:WU00:FS02:0xa4:Completed 270000 out of 1500000 steps (18%)
18:55:55:WU02:FS00:0x17:Completed 2175000 out of 2500000 steps (87%)
18:58:10:WU00:FS02:0xa4:Completed 285000 out of 1500000 steps (19%)
19:00:23:WU01:FS01:0x17:Completed 2325000 out of 2500000 steps (93%)
19:06:25:WU00:FS02:0xa4:Completed 300000 out of 1500000 steps (20%)
19:11:56:WU02:FS00:0x17:Completed 2200000 out of 2500000 steps (88%)
19:14:46:WU00:FS02:0xa4:Completed 315000 out of 1500000 steps (21%)
19:17:38:WU01:FS01:0x17:Completed 2350000 out of 2500000 steps (94%)
19:22:57:WU00:FS02:0xa4:Completed 330000 out of 1500000 steps (22%)
19:28:17:WU02:FS00:0x17:Completed 2225000 out of 2500000 steps (89%)
19:31:10:WU00:FS02:0xa4:Completed 345000 out of 1500000 steps (23%)
19:35:12:WU01:FS01:0x17:Completed 2375000 out of 2500000 steps (95%)
19:39:26:WU00:FS02:0xa4:Completed 360000 out of 1500000 steps (24%)
19:44:17:WU02:FS00:0x17:Completed 2250000 out of 2500000 steps (90%)
19:47:43:WU00:FS02:0xa4:Completed 375000 out of 1500000 steps (25%)
19:52:26:WU01:FS01:0x17:Completed 2400000 out of 2500000 steps (96%)
19:56:00:WU00:FS02:0xa4:Completed 390000 out of 1500000 steps (26%)
20:00:40:WU02:FS00:0x17:Completed 2275000 out of 2500000 steps (91%)
20:04:17:WU00:FS02:0xa4:Completed 405000 out of 1500000 steps (27%)
20:09:58:WU01:FS01:0x17:Completed 2425000 out of 2500000 steps (97%)
20:12:25:WU00:FS02:0xa4:Completed 420000 out of 1500000 steps (28%)
20:16:43:WU02:FS00:0x17:Completed 2300000 out of 2500000 steps (92%)
20:20:41:WU00:FS02:0xa4:Completed 435000 out of 1500000 steps (29%)
20:27:12:WU01:FS01:0x17:Completed 2450000 out of 2500000 steps (98%)
20:27:13:WU03:FS01:Connecting to assign-GPU.stanford.edu:80
20:27:13:WU03:FS01:News: Welcome to Folding@Home
20:27:13:WU03:FS01:Assigned to work server 171.64.65.69
20:27:13:WU03:FS01:Requesting new work unit for slot 01: RUNNING gpu:1:Barts XT [ATI Radeon HD 6800 Series] from 171.64.65.69
20:27:13:WU03:FS01:Connecting to 171.64.65.69:8080
20:27:13:WU03:FS01
ownloading 4.17MiB
20:27:16:WU03:FS01
ownload complete
20:27:16:WU03:FS01:Received Unit: id:03 state
OWNLOAD error:NO_ERROR project:8900 run:666 clone:0 gen:20 core:0x17 unit:0x00000017028c126651a6bac181eeb0ac
20:28:59:WU00:FS02:0xa4:Completed 450000 out of 1500000 steps (30%)
20:33:06:WU02:FS00:0x17:Completed 2325000 out of 2500000 steps (93%)
20:37:14:WU00:FS02:0xa4:Completed 465000 out of 1500000 steps (31%)
20:44:46:WU01:FS01:0x17:Completed 2475000 out of 2500000 steps (99%)
20:45:27:WU00:FS02:0xa4:Completed 480000 out of 1500000 steps (32%)
20:49:08:WU02:FS00:0x17:Completed 2350000 out of 2500000 steps (94%)
20:53:43:WU00:FS02:0xa4:Completed 495000 out of 1500000 steps (33%)
21:01:55:WU00:FS02:0xa4:Completed 510000 out of 1500000 steps (34%)
21:02:02:WU01:FS01:0x17:Completed 2500000 out of 2500000 steps (100%)
21:02:22:WU01:FS01:0x17:Saving result file logfile_01.txt
21:02:22:WU01:FS01:0x17:Saving result file checkpointState.xml
21:02:24:WU01:FS01:0x17:Saving result file checkpt.crc
21:02:24:WU01:FS01:0x17:Saving result file log.txt
21:02:24:WU01:FS01:0x17:Saving result file positions.xtc
21:02:26:WU01:FS01:0x17:Folding@home Core Shutdown: FINISHED_UNIT
21:02:27:WU01:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
21:02:27:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:8900 run:359 clone:1 gen:21 core:0x17 unit:0x00000018028c126651a6767321c7a4b2
21:02:27:WU01:FS01:Uploading 12.96MiB to 171.64.65.69
21:02:27:WU01:FS01:Connecting to 171.64.65.69:8080
21:02:27:WU03:FS01:Starting
21:02:27:WU03:FS01:Running FahCore: \"C:\\Program Files (x86)\\FAHClient/FAHCoreWrapper.exe\" C:/Users/Brad/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/beta/Core_17.fah/FahCore_17.exe -dir 03 -suffix 01 -version 703 -lifeline 2208 -checkpoint 15 -gpu 1 -gpu-vendor ati
21:02:27:WU03:FS01:Started FahCore on PID 3384
21:02:27:WU03:FS01:Core PID:6292
21:02:27:WU03:FS01:FahCore 0x17 started
21:02:27:WU03:FS01:0x17:*********************** Log Started 2013-06-22T21:02:27Z ***********************
roject: 8900 (Run 666, Clone 0, Gen 20)
21:02:27:WU03:FS01:0x17:Unit: 0x00000017028c126651a6bac181eeb0ac
21:02:27:WU03:FS01:0x17:CPU: 0x00000000000000000000000000000000
21:02:27:WU03:FS01:0x17:Machine: 1
21:02:27:WU03:FS01:0x17:Reading tar file state.xml
21:02:28:WU03:FS01:0x17:Reading tar file system.xml
21:02:28:WU03:FS01:0x17:Reading tar file integrator.xml
21:02:28:WU03:FS01:0x17:Reading tar file core.xml
igital signatures verified
21:02:33:WU01:FS01:Upload 5.31%
21:02:39:WU01:FS01:Upload 9.16%
21:02:45:WU01:FS01:Upload 13.02%
21:02:51:WU01:FS01:Upload 17.36%
21:02:57:WU01:FS01:Upload 21.22%
21:03:03:WU01:FS01:Upload 25.08%
21:03:09:WU01:FS01:Upload 29.42%
21:03:15:WU01:FS01:Upload 33.28%
21:03:21:WU01:FS01:Upload 37.62%
21:03:27:WU01:FS01:Upload 41.48%
21:03:33:WU01:FS01:Upload 45.33%
21:03:39:WU01:FS01:Upload 49.68%
21:03:45:WU01:FS01:Upload 53.53%
21:03:51:WU01:FS01:Upload 57.39%
21:03:57:WU01:FS01:Upload 61.25%
21:04:03:WU01:FS01:Upload 65.59%
21:04:09:WU01:FS01:Upload 69.45%
21:04:15:WU01:FS01:Upload 73.79%
21:04:21:WU01:FS01:Upload 77.65%
21:04:27:WU01:FS01:Upload 81.99%
21:04:33:WU01:FS01:Upload 85.85%
21:04:39:WU01:FS01:Upload 89.71%
21:04:45:WU01:FS01:Upload 93.56%
21:04:51:WU01:FS01:Upload 97.42%
21:05:02:WU01:FS01:Upload complete
21:05:03:WU01:FS01:Server responded WORK_ACK (400)
21:05:03:WU01:FS01:Final credit estimate, 14068.00 points
21:05:03:WU01:FS01:Cleaning up
21:05:13:WU03:FS01:0x17:Completed 0 out of 2500000 steps (0%)
21:05:36:WU02:FS00:0x17:Completed 2375000 out of 2500000 steps (95%)
21:10:23:WU00:FS02:0xa4:Completed 525000 out of 1500000 steps (35%)
21:18:37:WU00:FS02:0xa4:Completed 540000 out of 1500000 steps (36%)
21:21:37:WU02:FS00:0x17:Completed 2400000 out of 2500000 steps (96%)
21:22:42:WU03:FS01:0x17:Completed 25000 out of 2500000 steps (1%)
21:26:52:WU00:FS02:0xa4:Completed 555000 out of 1500000 steps (37%)
21:35:05:WU00:FS02:0xa4:Completed 570000 out of 1500000 steps (38%)
21:37:56:WU02:FS00:0x17:Completed 2425000 out of 2500000 steps (97%)
21:39:53:WU03:FS01:0x17:Completed 50000 out of 2500000 steps (2%)
21:43:22:WU00:FS02:0xa4:Completed 585000 out of 1500000 steps (39%)
21:51:35:WU00:FS02:0xa4:Completed 600000 out of 1500000 steps (40%)
21:53:58:WU02:FS00:0x17:Completed 2450000 out of 2500000 steps (98%)
21:53:59:WU01:FS00:Connecting to assign-GPU.stanford.edu:80
21:53:59:WU01:FS00:News: Welcome to Folding@Home
21:53:59:WU01:FS00:Assigned to work server 171.64.65.69
21:53:59:WU01:FS00:Requesting new work unit for slot 00: RUNNING gpu:0:Barts XT [ATI Radeon HD 6800 Series] from 171.64.65.69
21:53:59:WU01:FS00:Connecting to 171.64.65.69:8080
21:53:59:WU01:FS00
ownloading 4.17MiB
21:54:02:WU01:FS00
ownload complete
21:54:02:WU01:FS00:Received Unit: id:01 state
OWNLOAD error:NO_ERROR project:8900 run:310 clone:0 gen:19 core:0x17 unit:0x00000017028c126651a66b8c1138fbd1
21:57:25:WU03:FS01:0x17:Completed 75000 out of 2500000 steps (3%)
21:59:52:WU00:FS02:0xa4:Completed 615000 out of 1500000 steps (41%)
22:08:04:WU00:FS02:0xa4:Completed 630000 out of 1500000 steps (42%)
22:10:20:WU02:FS00:0x17:Completed 2475000 out of 2500000 steps (99%)
22:14:36:WU03:FS01:0x17:Completed 100000 out of 2500000 steps (4%)
22:16:22:WU00:FS02:0xa4:Completed 645000 out of 1500000 steps (43%)
22:24:40:WU00:FS02:0xa4:Completed 660000 out of 1500000 steps (44%)
22:26:23:WU02:FS00:0x17:Completed 2500000 out of 2500000 steps (100%)
22:26:42:WU02:FS00:0x17:Saving result file logfile_01.txt
22:26:42:WU02:FS00:0x17:Saving result file checkpointState.xml
22:26:44:WU02:FS00:0x17:Saving result file checkpt.crc
22:26:44:WU02:FS00:0x17:Saving result file log.txt
22:26:44:WU02:FS00:0x17:Saving result file positions.xtc
22:26:47:WU02:FS00:0x17:Folding@home Core Shutdown: FINISHED_UNIT
22:26:47:WU02:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
22:26:47:WU02:FS00:Sending unit results: id:02 state:SEND error:NO_ERROR project:8900 run:749 clone:1 gen:9 core:0x17 unit:0x0000000d028c126651a6cd406ad018d7
22:26:47:WU02:FS00:Uploading 12.96MiB to 171.64.65.69
22:26:47:WU02:FS00:Connecting to 171.64.65.69:8080
22:26:47:WU01:FS00:Starting
22:26:47:WU01:FS00:Running FahCore: \"C:\\Program Files (x86)\\FAHClient/FAHCoreWrapper.exe\" C:/Users/Brad/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/beta/Core_17.fah/FahCore_17.exe -dir 01 -suffix 01 -version 703 -lifeline 2208 -checkpoint 15 -gpu 0 -gpu-vendor ati
22:26:47:WU01:FS00:Started FahCore on PID 5896
22:26:47:WU01:FS00:Core PID:4228
22:26:47:WU01:FS00:FahCore 0x17 started
22:26:48:WU01:FS00:0x17:*********************** Log Started 2013-06-22T22:26:47Z ***********************
roject: 8900 (Run 310, Clone 0, Gen 19)
22:26:48:WU01:FS00:0x17:Unit: 0x00000017028c126651a66b8c1138fbd1
22:26:48:WU01:FS00:0x17:CPU: 0x00000000000000000000000000000000
22:26:48:WU01:FS00:0x17:Machine: 0
22:26:48:WU01:FS00:0x17:Reading tar file state.xml
22:26:48:WU01:FS00:0x17:Reading tar file system.xml
22:26:48:WU01:FS00:0x17:Reading tar file integrator.xml
22:26:48:WU01:FS00:0x17:Reading tar file core.xml
22:26:53:WU02:FS00:Upload 4.82%
22:26:59:WU02:FS00:Upload 8.68%
22:27:05:WU02:FS00:Upload 13.02%
22:27:11:WU02:FS00:Upload 16.88%
22:27:17:WU02:FS00:Upload 21.22%
22:27:23:WU02:FS00:Upload 25.07%
22:27:29:WU02:FS00:Upload 28.93%
22:27:35:WU02:FS00:Upload 33.27%
22:27:41:WU02:FS00:Upload 37.13%
22:27:47:WU02:FS00:Upload 40.99%
22:27:53:WU02:FS00:Upload 45.32%
22:27:59:WU02:FS00:Upload 49.18%
22:28:05:WU02:FS00:Upload 53.52%
22:28:11:WU02:FS00:Upload 57.86%
22:28:17:WU02:FS00:Upload 61.72%
22:28:23:WU02:FS00:Upload 65.58%
22:28:29:WU02:FS00:Upload 69.43%
22:28:35:WU02:FS00:Upload 73.29%
22:28:41:WU02:FS00:Upload 77.63%
22:28:47:WU02:FS00:Upload 81.49%
22:28:53:WU02:FS00:Upload 85.83%
22:28:59:WU02:FS00:Upload 89.69%
22:29:05:WU02:FS00:Upload 93.54%
22:29:11:WU02:FS00:Upload 97.88%
22:29:22:WU02:FS00:Upload complete
22:29:23:WU02:FS00:Server responded WORK_ACK (400)
22:29:23:WU02:FS00:Final credit estimate, 11383.00 points
22:29:23:WU02:FS00:Cleaning up
22:29:39:WU01:FS00:0x17:Completed 0 out of 2500000 steps (0%)
22:32:13:WU03:FS01:0x17:Completed 125000 out of 2500000 steps (5%)
22:32:59:WU00:FS02:0xa4:Completed 675000 out of 1500000 steps (45%)
22:41:07:WU00:FS02:0xa4:Completed 690000 out of 1500000 steps (46%)
22:45:55:WU01:FS00:0x17:Completed 25000 out of 2500000 steps (1%)
22:49:11:WU00:FS02:0xa4:Completed 705000 out of 1500000 steps (47%)
22:49:25:WU03:FS01:0x17:Completed 150000 out of 2500000 steps (6%)
22:57:28:WU00:FS02:0xa4:Completed 720000 out of 1500000 steps (48%)
23:01:57:WU01:FS00:0x17:Completed 50000 out of 2500000 steps (2%)
23:05:46:WU00:FS02:0xa4:Completed 735000 out of 1500000 steps (49%)
23:06:57:WU03:FS01:0x17:Completed 175000 out of 2500000 steps (7%)
23:14:02:WU00:FS02:0xa4:Completed 750000 out of 1500000 steps (50%)
23:18:16:WU01:FS00:0x17:Completed 75000 out of 2500000 steps (3%)
23:22:12:WU00:FS02:0xa4:Completed 765000 out of 1500000 steps (51%)
23:24:07:WU03:FS01:0x17:Completed 200000 out of 2500000 steps (8%)
23:30:27:WU00:FS02:0xa4:Completed 780000 out of 1500000 steps (52%)
23:34:18:WU01:FS00:0x17:Completed 100000 out of 2500000 steps (4%)
23:38:42:WU00:FS02:0xa4:Completed 795000 out of 1500000 steps (53%)
23:41:38:WU03:FS01:0x17:Completed 225000 out of 2500000 steps (9%)
23:47:00:WU00:FS02:0xa4:Completed 810000 out of 1500000 steps (54%)
23:50:39:WU01:FS00:0x17:Completed 125000 out of 2500000 steps (5%)
23:55:16:WU00:FS02:0xa4:Completed 825000 out of 1500000 steps (55%)
23:58:48:WU03:FS01:0x17:Completed 250000 out of 2500000 steps (10%)
00:03:31:WU00:FS02:0xa4:Completed 840000 out of 1500000 steps (56%)
00:06:44:WU01:FS00:0x17:Completed 150000 out of 2500000 steps (6%)
00:11:45:WU00:FS02:0xa4:Completed 855000 out of 1500000 steps (57%)
00:16:19:WU03:FS01:0x17:Completed 275000 out of 2500000 steps (11%)
00:19:50:WU00:FS02:0xa4:Completed 870000 out of 1500000 steps (58%)
00:23:03:WU01:FS00:0x17:Completed 175000 out of 2500000 steps (7%)
00:27:52:WU00:FS02:0xa4:Completed 885000 out of 1500000 steps (59%)
00:33:27:WU03:FS01:0x17:Completed 300000 out of 2500000 steps (12%)
00:36:00:WU00:FS02:0xa4:Completed 900000 out of 1500000 steps (60%)
00:39:07:WU01:FS00:0x17:Completed 200000 out of 2500000 steps (8%)
00:44:08:WU00:FS02:0xa4:Completed 915000 out of 1500000 steps (61%)
00:50:56:WU03:FS01:0x17:Completed 325000 out of 2500000 steps (13%)
00:52:11:WU00:FS02:0xa4:Completed 930000 out of 1500000 steps (62%)
00:55:27:WU01:FS00:0x17:Completed 225000 out of 2500000 steps (9%)
01:00:15:WU00:FS02:0xa4:Completed 945000 out of 1500000 steps (63%)
01:08:04:WU03:FS01:0x17:Completed 350000 out of 2500000 steps (14%)
01:08:19:WU00:FS02:0xa4:Completed 960000 out of 1500000 steps (64%)
01:11:31:WU01:FS00:0x17:Completed 250000 out of 2500000 steps (10%)
01:16:20:WU00:FS02:0xa4:Completed 975000 out of 1500000 steps (65%)
01:24:18:WU00:FS02:0xa4:Completed 990000 out of 1500000 steps (66%)
01:25:32:WU03:FS01:0x17:Completed 375000 out of 2500000 steps (15%)
01:27:54:WU01:FS00:0x17:Completed 275000 out of 2500000 steps (11%)
01:32:20:WU00:FS02:0xa4:Completed 1005000 out of 1500000 steps (67%)
01:40:26:WU00:FS02:0xa4:Completed 1020000 out of 1500000 steps (68%)
01:42:40:WU03:FS01:0x17:Completed 400000 out of 2500000 steps (16%)
01:43:58:WU01:FS00:0x17:Completed 300000 out of 2500000 steps (12%)
01:48:35:WU00:FS02:0xa4:Completed 1035000 out of 1500000 steps (69%)
01:56:38:WU00:FS02:0xa4:Completed 1050000 out of 1500000 steps (70%)
02:00:09:WU03:FS01:0x17:Completed 425000 out of 2500000 steps (17%)
02:00:20:WU01:FS00:0x17:Completed 325000 out of 2500000 steps (13%)
02:04:41:WU00:FS02:0xa4:Completed 1065000 out of 1500000 steps (71%)
02:12:47:WU00:FS02:0xa4:Completed 1080000 out of 1500000 steps (72%)
02:16:24:WU01:FS00:0x17:Completed 350000 out of 2500000 steps (14%)
******************************* Date: 2013-06-23 *******************************
02:17:18:WU03:FS01:0x17:Completed 450000 out of 2500000 steps (18%)
02:20:53:WU00:FS02:0xa4:Completed 1095000 out of 1500000 steps (73%)
02:28:56:WU00:FS02:0xa4:Completed 1110000 out of 1500000 steps (74%)
02:32:44:WU01:FS00:0x17:Completed 375000 out of 2500000 steps (15%)
02:34:46:WU03:FS01:0x17:Completed 475000 out of 2500000 steps (19%)
02:36:59:WU00:FS02:0xa4:Completed 1125000 out of 1500000 steps (75%)
02:45:01:WU00:FS02:0xa4:Completed 1140000 out of 1500000 steps (76%)
02:48:45:WU01:FS00:0x17:Completed 400000 out of 2500000 steps (16%)
02:51:55:WU03:FS01:0x17:Completed 500000 out of 2500000 steps (20%)
02:53:07:WU00:FS02:0xa4:Completed 1155000 out of 1500000 steps (77%)
03:01:05:WU00:FS02:0xa4:Completed 1170000 out of 1500000 steps (78%)
03:05:07:WU01:FS00:0x17:Completed 425000 out of 2500000 steps (17%)
03:09:09:WU00:FS02:0xa4:Completed 1185000 out of 1500000 steps (79%)
03:09:23:WU03:FS01:0x17:Completed 525000 out of 2500000 steps (21%)
03:17:11:WU00:FS02:0xa4:Completed 1200000 out of 1500000 steps (80%)
03:21:08:WU01:FS00:0x17:Completed 450000 out of 2500000 steps (18%)
03:25:18:WU00:FS02:0xa4:Completed 1215000 out of 1500000 steps (81%)
03:26:33:WU03:FS01:0x17:Completed 550000 out of 2500000 steps (22%)
03:33:21:WU00:FS02:0xa4:Completed 1230000 out of 1500000 steps (82%)
03:37:31:WU01:FS00:0x17:Completed 475000 out of 2500000 steps (19%)
03:41:25:WU00:FS02:0xa4:Completed 1245000 out of 1500000 steps (83%)
03:44:00:WU03:FS01:0x17:Completed 575000 out of 2500000 steps (23%)
03:49:28:WU00:FS02:0xa4:Completed 1260000 out of 1500000 steps (84%)
03:53:35:WU01:FS00:0x17:Completed 500000 out of 2500000 steps (20%)
03:57:27:WU00:FS02:0xa4:Completed 1275000 out of 1500000 steps (85%)
04:01:09:WU03:FS01:0x17:Completed 600000 out of 2500000 steps (24%)
04:05:30:WU00:FS02:0xa4:Completed 1290000 out of 1500000 steps (86%)
04:09:58:WU01:FS00:0x17:Completed 525000 out of 2500000 steps (21%)
04:13:39:WU00:FS02:0xa4:Completed 1305000 out of 1500000 steps (87%)
04:18:36:WU03:FS01:0x17:Completed 625000 out of 2500000 steps (25%)
04:21:43:WU00:FS02:0xa4:Completed 1320000 out of 1500000 steps (88%)
04:26:02:WU01:FS00:0x17:Completed 550000 out of 2500000 steps (22%)
04:29:44:WU00:FS02:0xa4:Completed 1335000 out of 1500000 steps (89%)
04:35:47:WU03:FS01:0x17:Completed 650000 out of 2500000 steps (26%)
04:37:53:WU00:FS02:0xa4:Completed 1350000 out of 1500000 steps (90%)
04:42:23:WU01:FS00:0x17:Completed 575000 out of 2500000 steps (23%)
04:45:54:WU00:FS02:0xa4:Completed 1365000 out of 1500000 steps (91%)
04:53:15:WU03:FS01:0x17:Completed 675000 out of 2500000 steps (27%)
04:53:55:WU00:FS02:0xa4:Completed 1380000 out of 1500000 steps (92%)
04:58:24:WU01:FS00:0x17:Completed 600000 out of 2500000 steps (24%)
05:01:59:WU00:FS02:0xa4:Completed 1395000 out of 1500000 steps (93%)
05:09:56:WU00:FS02:0xa4:Completed 1410000 out of 1500000 steps (94%)
05:10:23:WU03:FS01:0x17:Completed 700000 out of 2500000 steps (28%)
05:14:45:WU01:FS00:0x17:Completed 625000 out of 2500000 steps (25%)
05:17:54:WU00:FS02:0xa4:Completed 1425000 out of 1500000 steps (95%)
05:25:55:WU00:FS02:0xa4:Completed 1440000 out of 1500000 steps (96%)
05:27:50:WU03:FS01:0x17:Completed 725000 out of 2500000 steps (29%)
05:30:47:WU01:FS00:0x17:Completed 650000 out of 2500000 steps (26%)
05:33:56:WU00:FS02:0xa4:Completed 1455000 out of 1500000 steps (97%)
05:41:56:WU00:FS02:0xa4:Completed 1470000 out of 1500000 steps (98%)
05:41:57:WU02:FS02:Connecting to assign3.stanford.edu:8080
05:41:57:WU02:FS02:News: Welcome to Folding@Home
05:41:57:WU02:FS02:Assigned to work server 171.67.108.35
05:41:57:WU02:FS02:Requesting new work unit for slot 02: RUNNING cpu:7 from 171.67.108.35
05:41:57:WU02:FS02:Connecting to 171.67.108.35:8080
05:41:58:WU02:FS02
ownloading 1001.92KiB
05:41:59:WU02:FS02
ownload complete
05:41:59:WU02:FS02:Received Unit: id:02 state
OWNLOAD error:NO_ERROR project:8702 run:79 clone:7 gen:1 core:0xa4 unit:0x000000016652edb35196ee83c6d58b65
05:44:59:WU03:FS01:0x17:Completed 750000 out of 2500000 steps (30%)
05:47:10:WU01:FS00:0x17:Completed 675000 out of 2500000 steps (27%)
05:49:59:WU00:FS02:0xa4:Completed 1485000 out of 1500000 steps (99%)
05:58:01:WU00:FS02:0xa4:Completed 1500000 out of 1500000 steps (100%)
05:58:11:WU00:FS02:0xa4:
05:58:11:WU00:FS02:0xa4:Finished Work Unit:
05:58:11:WU00:FS02:0xa4:- Reading up to 1405644 from \"00/wudata_01.trr\": Read 1405644
05:58:11:WU00:FS02:0xa4:trr file hash check passed.
05:58:11:WU00:FS02:0xa4:- Reading up to 4413364 from \"00/wudata_01.xtc\": Read 4413364
05:58:11:WU00:FS02:0xa4:xtc file hash check passed.
05:58:11:WU00:FS02:0xa4:edr file hash check passed.
05:58:11:WU00:FS02:0xa4:logfile size: 43361
05:58:11:WU00:FS02:0xa4:Leaving Run
05:58:13:WU00:FS02:0xa4:- Writing 5884873 bytes of core data to disk...
05:58:14:WU00:FS02:0xa4
one: 5884361 -> 5786012 (compressed to 98.3 percent)
05:58:14:WU00:FS02:0xa4: ... Done.
05:58:14:WU00:FS02:0xa4:- Shutting down core
05:58:14:WU00:FS02:0xa4:Folding@home Core Shutdown: FINISHED_UNIT
05:58:15:WU00:FS02:FahCore returned: FINISHED_UNIT (100 = 0x64)
05:58:15:WU00:FS02:Sending unit results: id:00 state:SEND error:NO_ERROR project:8703 run:4369 clone:0 gen:1 core:0xa4 unit:0x000000016652edcc51c2818407f83e8f
05:58:15:WU00:FS02:Uploading 5.52MiB to 171.67.108.60
05:58:15:WU00:FS02:Connecting to 171.67.108.60:8080
05:58:15:WU02:FS02:Starting
05:58:15:WU02:FS02:Running FahCore: \"C:\\Program Files (x86)\\FAHClient/FAHCoreWrapper.exe\" C:/Users/Brad/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 02 -suffix 01 -version 703 -lifeline 2208 -checkpoint 15 -np 7
05:58:15:WU02:FS02:Started FahCore on PID 1680
05:58:15:WU02:FS02:Core PID:2592
05:58:15:WU02:FS02:FahCore 0xa4 started
05:58:15:WU02:FS02:0xa4:
05:58:15:WU02:FS02:0xa4:*------------------------------*
05:58:15:WU02:FS02:0xa4:Folding@Home Gromacs GB Core
05:58:15:WU02:FS02:0xa4:Version 2.27 (Dec. 15, 2010)
05:58:15:WU02:FS02:0xa4:- Looking at optimizations...
05:58:15:WU02:FS02:0xa4:- Created dyn
05:58:15:WU02:FS02:0xa4:- Files status OK
05:58:15:WU02:FS02:0xa4:- Expanded 1025452 -> 2544640 (decompressed 248.1 percent)
05:58:15:WU02:FS02:0xa4:Called DecompressByteArray: compressed_data_size=1025452 data_size=2544640, decompressed_data_size=2544640 diff=0
05:58:15:WU02:FS02:0xa4:- Digital signature verified
roject: 8702 (Run 79, Clone 7, Gen 1)
05:58:15:WU02:FS02:0xa4:Assembly optimizations on if available.
05:58:15:WU02:FS02:0xa4:Entering M.D.
05:58:21:WU02:FS02:0xa4:Mapping NT from 7 to 7
05:58:21:WU00:FS02:Upload 12.46%
05:58:21:WU02:FS02:0xa4:Completed 0 out of 250000 steps (0%)
05:58:27:WU00:FS02:Upload 22.65%
05:58:33:WU00:FS02:Upload 31.71%
05:58:39:WU00:FS02:Upload 43.04%
05:58:45:WU00:FS02:Upload 52.10%
05:58:51:WU00:FS02:Upload 62.29%
05:58:57:WU00:FS02:Upload 72.48%
05:59:03:WU00:FS02:Upload 82.68%
05:59:09:WU00:FS02:Upload 92.87%
05:59:14:WU00:FS02:Upload complete
05:59:14:WU00:FS02:Server responded WORK_ACK (400)
05:59:14:WU00:FS02:Final credit estimate, 12471.00 points
05:59:14:WU00:FS02:Cleaning up
05:59:41:WU02:FS02:0xa4:Completed 2500 out of 250000 steps (1%)
06:01:01:WU02:FS02:0xa4:Completed 5000 out of 250000 steps (2%)
06:02:21:WU02:FS02:0xa4:Completed 7500 out of 250000 steps (3%)
06:02:23:WU03:FS01:0x17:Completed 775000 out of 2500000 steps (31%)
06:03:12:WU01:FS00:0x17:Completed 700000 out of 2500000 steps (28%)
06:03:41:WU02:FS02:0xa4:Completed 10000 out of 250000 steps (4%)
06:04:59:WU02:FS02:0xa4:Completed 12500 out of 250000 steps (5%)
06:06:19:WU02:FS02:0xa4:Completed 15000 out of 250000 steps (6%)
06:07:37:WU02:FS02:0xa4:Completed 17500 out of 250000 steps (7%)
06:08:58:WU02:FS02:0xa4:Completed 20000 out of 250000 steps (8%)
06:10:16:WU02:FS02:0xa4:Completed 22500 out of 250000 steps (9%)
06:11:35:WU02:FS02:0xa4:Completed 25000 out of 250000 steps (10%)
06:12:54:WU02:FS02:0xa4:Completed 27500 out of 250000 steps (11%)
06:14:13:WU02:FS02:0xa4:Completed 30000 out of 250000 steps (12%)
06:15:32:WU02:FS02:0xa4:Completed 32500 out of 250000 steps (13%)
06:16:51:WU02:FS02:0xa4:Completed 35000 out of 250000 steps (14%)
06:18:09:WU02:FS02:0xa4:Completed 37500 out of 250000 steps (15%)
06:19:29:WU02:FS02:0xa4:Completed 40000 out of 250000 steps (16%)
06:19:30:WU03:FS01:0x17:Completed 800000 out of 2500000 steps (32%)
06:19:35:WU01:FS00:0x17:Completed 725000 out of 2500000 steps (29%)
06:20:48:WU02:FS02:0xa4:Completed 42500 out of 250000 steps (17%)
06:22:07:WU02:FS02:0xa4:Completed 45000 out of 250000 steps (18%)
06:23:26:WU02:FS02:0xa4:Completed 47500 out of 250000 steps (19%)
06:24:45:WU02:FS02:0xa4:Completed 50000 out of 250000 steps (20%)
06:26:04:WU02:FS02:0xa4:Completed 52500 out of 250000 steps (21%)
06:27:24:WU02:FS02:0xa4:Completed 55000 out of 250000 steps (22%)
06:28:41:WU02:FS02:0xa4:Completed 57500 out of 250000 steps (23%)
06:30:01:WU02:FS02:0xa4:Completed 60000 out of 250000 steps (24%)
06:31:20:WU02:FS02:0xa4:Completed 62500 out of 250000 steps (25%)
06:32:40:WU02:FS02:0xa4:Completed 65000 out of 250000 steps (26%)
06:33:59:WU02:FS02:0xa4:Completed 67500 out of 250000 steps (27%)
06:35:18:WU02:FS02:0xa4:Completed 70000 out of 250000 steps (28%)
06:35:40:WU01:FS00:0x17:Completed 750000 out of 2500000 steps (30%)
06:36:38:WU02:FS02:0xa4:Completed 72500 out of 250000 steps (29%)
06:36:55:WU03:FS01:0x17:Completed 825000 out of 2500000 steps (33%)
06:37:55:WU02:FS02:0xa4:Completed 75000 out of 250000 steps (30%)
06:39:12:WU02:FS02:0xa4:Completed 77500 out of 250000 steps (31%)
06:40:31:WU02:FS02:0xa4:Completed 80000 out of 250000 steps (32%)
06:41:50:WU02:FS02:0xa4:Completed 82500 out of 250000 steps (33%)
06:43:08:WU02:FS02:0xa4:Completed 85000 out of 250000 steps (34%)
06:44:25:WU02:FS02:0xa4:Completed 87500 out of 250000 steps (35%)
06:45:43:WU02:FS02:0xa4:Completed 90000 out of 250000 steps (36%)
06:47:01:WU02:FS02:0xa4:Completed 92500 out of 250000 steps (37%)
06:48:18:WU02:FS02:0xa4:Completed 95000 out of 250000 steps (38%)
06:49:34:WU02:FS02:0xa4:Completed 97500 out of 250000 steps (39%)
06:50:51:WU02:FS02:0xa4:Completed 100000 out of 250000 steps (40%)
06:52:00:WU01:FS00:0x17:Completed 775000 out of 2500000 steps (31%)
06:52:09:WU02:FS02:0xa4:Completed 102500 out of 250000 steps (41%)
06:53:28:WU02:FS02:0xa4:Completed 105000 out of 250000 steps (42%)
06:54:01:WU03:FS01:0x17:Completed 850000 out of 2500000 steps (34%)
06:54:45:WU02:FS02:0xa4:Completed 107500 out of 250000 steps (43%)
06:56:01:WU02:FS02:0xa4:Completed 110000 out of 250000 steps (44%)
06:57:18:WU02:FS02:0xa4:Completed 112500 out of 250000 steps (45%)
06:58:38:WU02:FS02:0xa4:Completed 115000 out of 250000 steps (46%)
06:59:54:WU02:FS02:0xa4:Completed 117500 out of 250000 steps (47%)
07:01:14:WU02:FS02:0xa4:Completed 120000 out of 250000 steps (48%)
07:02:33:WU02:FS02:0xa4:Completed 122500 out of 250000 steps (49%)
07:03:53:WU02:FS02:0xa4:Completed 125000 out of 250000 steps (50%)
07:05:14:WU02:FS02:0xa4:Completed 127500 out of 250000 steps (51%)
07:06:45:WU02:FS02:0xa4:Completed 130000 out of 250000 steps (52%)
07:08:03:WU01:FS00:0x17:Completed 800000 out of 2500000 steps (32%)
07:08:19:WU02:FS02:0xa4:Completed 132500 out of 250000 steps (53%)
07:09:53:WU02:FS02:0xa4:Completed 135000 out of 250000 steps (54%)
07:11:22:WU02:FS02:0xa4:Completed 137500 out of 250000 steps (55%)
07:11:35:WU03:FS01:0x17:Completed 875000 out of 2500000 steps (35%)
07:12:52:WU02:FS02:0xa4:Completed 140000 out of 250000 steps (56%)
07:14:23:WU02:FS02:0xa4:Completed 142500 out of 250000 steps (57%)
07:15:53:WU02:FS02:0xa4:Completed 145000 out of 250000 steps (58%)
07:17:22:WU02:FS02:0xa4:Completed 147500 out of 250000 steps (59%)
07:18:52:WU02:FS02:0xa4:Completed 150000 out of 250000 steps (60%)
07:20:23:WU02:FS02:0xa4:Completed 152500 out of 250000 steps (61%)
07:21:53:WU02:FS02:0xa4:Completed 155000 out of 250000 steps (62%)
07:23:16:WU02:FS02:0xa4:Completed 157500 out of 250000 steps (63%)
07:24:25:WU01:FS00:0x17:Completed 825000 out of 2500000 steps (33%)
07:24:42:WU02:FS02:0xa4:Completed 160000 out of 250000 steps (64%)
07:26:11:WU02:FS02:0xa4:Completed 162500 out of 250000 steps (65%)
07:27:40:WU02:FS02:0xa4:Completed 165000 out of 250000 steps (66%)
07:29:08:WU02:FS02:0xa4:Completed 167500 out of 250000 steps (67%)
07:29:26:WU03:FS01:0x17:Completed 900000 out of 2500000 steps (36%)
07:30:34:WU02:FS02:0xa4:Completed 170000 out of 250000 steps (68%)
07:31:58:WU02:FS02:0xa4:Completed 172500 out of 250000 steps (69%)
07:33:24:WU02:FS02:0xa4:Completed 175000 out of 250000 steps (70%)
07:34:49:WU02:FS02:0xa4:Completed 177500 out of 250000 steps (71%)
07:36:16:WU02:FS02:0xa4:Completed 180000 out of 250000 steps (72%)
07:37:41:WU02:FS02:0xa4:Completed 182500 out of 250000 steps (73%)
07:39:06:WU02:FS02:0xa4:Completed 185000 out of 250000 steps (74%)
07:40:28:WU01:FS00:0x17:Completed 850000 out of 2500000 steps (34%)
07:40:32:WU02:FS02:0xa4:Completed 187500 out of 250000 steps (75%)
07:41:57:WU02:FS02:0xa4:Completed 190000 out of 250000 steps (76%)
07:43:20:WU02:FS02:0xa4:Completed 192500 out of 250000 steps (77%)
07:44:41:WU02:FS02:0xa4:Completed 195000 out of 250000 steps (78%)
07:46:07:WU02:FS02:0xa4:Completed 197500 out of 250000 steps (79%)
07:47:15:WU03:FS01:0x17:Completed 925000 out of 2500000 steps (37%)
07:47:35:WU02:FS02:0xa4:Completed 200000 out of 250000 steps (80%)
07:49:03:WU02:FS02:0xa4:Completed 202500 out of 250000 steps (81%)
07:50:35:WU02:FS02:0xa4:Completed 205000 out of 250000 steps (82%)
07:52:04:WU02:FS02:0xa4:Completed 207500 out of 250000 steps (83%)
07:53:32:WU02:FS02:0xa4:Completed 210000 out of 250000 steps (84%)
07:55:00:WU02:FS02:0xa4:Completed 212500 out of 250000 steps (85%)
07:56:30:WU02:FS02:0xa4:Completed 215000 out of 250000 steps (86%)
07:56:52:WU01:FS00:0x17:Completed 875000 out of 2500000 steps (35%)
07:57:59:WU02:FS02:0xa4:Completed 217500 out of 250000 steps (87%)
07:59:28:WU02:FS02:0xa4:Completed 220000 out of 250000 steps (88%)
08:00:58:WU02:FS02:0xa4:Completed 222500 out of 250000 steps (89%)
08:02:27:WU02:FS02:0xa4:Completed 225000 out of 250000 steps (90%)
08:03:57:WU02:FS02:0xa4:Completed 227500 out of 250000 steps (91%)
08:05:21:WU03:FS01:0x17:Completed 950000 out of 2500000 steps (38%)
08:05:28:WU02:FS02:0xa4:Completed 230000 out of 250000 steps (92%)
08:06:58:WU02:FS02:0xa4:Completed 232500 out of 250000 steps (93%)
08:08:29:WU02:FS02:0xa4:Completed 235000 out of 250000 steps (94%)
08:09:49:WU02:FS02:0xa4:Completed 237500 out of 250000 steps (95%)
08:11:11:WU02:FS02:0xa4:Completed 240000 out of 250000 steps (96%)
08:12:32:WU02:FS02:0xa4:Completed 242500 out of 250000 steps (97%)
08:12:55:WU01:FS00:0x17:Completed 900000 out of 2500000 steps (36%)
08:13:53:WU02:FS02:0xa4:Completed 245000 out of 250000 steps (98%)
08:13:54:WU00:FS02:Connecting to assign3.stanford.edu:8080
08:13:54:WU00:FS02:News: Welcome to Folding@Home
08:13:54:WU00:FS02:Assigned to work server 128.143.231.202
08:13:54:WU00:FS02:Requesting new work unit for slot 02: RUNNING cpu:7 from 128.143.231.202
08:13:54:WU00:FS02:Connecting to 128.143.231.202:8080
08:13:56:WU00:FS02
ownloading 3.64MiB
08:13:58:WU00:FS02
ownload complete
08:13:58:WU00:FS02:Received Unit: id:00 state
OWNLOAD error:NO_ERROR project:6099 run:3 clone:15 gen:291 core:0xa3 unit:0x000001850a3b1e594e889fc0cac37232
08:15:14:WU02:FS02:0xa4:Completed 247500 out of 250000 steps (99%)
08:16:36:WU02:FS02:0xa4:Completed 250000 out of 250000 steps (100%)
ynamicWrapper: Finished Work Unit: sleep=10000
08:16:46:WU02:FS02:0xa4:
08:16:46:WU02:FS02:0xa4:Finished Work Unit:
08:16:46:WU02:FS02:0xa4:- Reading up to 1567212 from \"02/wudata_01.trr\": Read 1567212
08:16:46:WU02:FS02:0xa4:trr file hash check passed.
08:16:46:WU02:FS02:0xa4:- Reading up to 1760108 from \"02/wudata_01.xtc\": Read 1760108
08:16:46:WU02:FS02:0xa4:xtc file hash check passed.
08:16:46:WU02:FS02:0xa4:edr file hash check passed.
08:16:46:WU02:FS02:0xa4:logfile size: 27082
08:16:46:WU02:FS02:0xa4:Leaving Run
08:16:48:WU02:FS02:0xa4:- Writing 3363830 bytes of core data to disk...
08:16:49:WU02:FS02:0xa4
one: 3363318 -> 3245492 (compressed to 96.4 percent)
08:16:49:WU02:FS02:0xa4: ... Done.
08:16:49:WU02:FS02:FahCore returned: FINISHED_UNIT (100 = 0x64)
08:16:49:WU02:FS02:Sending unit results: id:02 state:SEND error:NO_ERROR project:8702 run:79 clone:7 gen:1 core:0xa4 unit:0x000000016652edb35196ee83c6d58b65
08:16:49:WU02:FS02:Uploading 3.10MiB to 171.67.108.35
08:16:49:WU02:FS02:Connecting to 171.67.108.35:8080
08:16:49:WU00:FS02:Starting
08:16:49:WU00:FS02:Running FahCore: \"C:\\Program Files (x86)\\FAHClient/FAHCoreWrapper.exe\" C:/Users/Brad/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/Core_a3.fah/FahCore_a3.exe -dir 00 -suffix 01 -version 703 -lifeline 2208 -checkpoint 15 -np 7
08:16:49:WU00:FS02:Started FahCore on PID 5712
08:16:49:WU00:FS02:Core PID:6108
08:16:49:WU00:FS02:FahCore 0xa3 started
08:16:50:WU00:FS02:0xa3:
08:16:50:WU00:FS02:0xa3:*------------------------------*
08:16:50:WU00:FS02:0xa3:Folding@Home Gromacs SMP Core
08:16:50:WU00:FS02:0xa3:Version 2.27 (Dec. 15, 2010)
08:16:50:WU00:FS02:0xa3:- Looking at optimizations...
08:16:50:WU00:FS02:0xa3:- Created dyn
08:16:50:WU00:FS02:0xa3:- Files status OK
08:16:50:WU00:FS02:0xa3:- Expanded 3813434 -> 4169428 (decompressed 109.3 percent)
08:16:50:WU00:FS02:0xa3:Called DecompressByteArray: compressed_data_size=3813434 data_size=4169428, decompressed_data_size=4169428 diff=0
08:16:50:WU00:FS02:0xa3:- Digital signature verified
roject: 6099 (Run 3, Clone 15, Gen 291)
08:16:50:WU00:FS02:0xa3:Assembly optimizations on if available.
08:16:50:WU00:FS02:0xa3:Entering M.D.
08:16:55:WU02:FS02:Upload 20.19%
08:16:56:WU00:FS02:0xa3:Mapping NT from 7 to 7
08:16:56:WU00:FS02:0xa3:Completed 0 out of 500000 steps (0%)
08:17:01:WU02:FS02:Upload 38.36%
08:17:07:WU02:FS02:Upload 56.53%
08:17:13:WU02:FS02:Upload 72.68%
08:17:19:WU02:FS02:Upload 90.85%
08:17:23:WU02:FS02:Upload complete
08:17:23:WU02:FS02:Server responded WORK_ACK (400)
08:17:23:WU02:FS02:Final credit estimate, 1459.00 points
08:17:23:WU02:FS02:Cleaning up
08:23:04:WU03:FS01:0x17:Completed 975000 out of 2500000 steps (39%)
08:25:52:WU00:FS02:0xa3:Completed 5000 out of 500000 steps (1%)
08:29:20:WU01:FS00:0x17:Completed 925000 out of 2500000 steps (37%)
08:34:51:WU00:FS02:0xa3:Completed 10000 out of 500000 steps (2%)
08:40:17:WU03:FS01:0x17:Completed 1000000 out of 2500000 steps (40%)
08:43:43:WU00:FS02:0xa3:Completed 15000 out of 500000 steps (3%)
08:45:27:WU01:FS00:0x17:Completed 950000 out of 2500000 steps (38%)
08:52:39:WU00:FS02:0xa3:Completed 20000 out of 500000 steps (4%)
08:57:54:WU03:FS01:0x17:Completed 1025000 out of 2500000 steps (41%)
09:01:37:WU00:FS02:0xa3:Completed 25000 out of 500000 steps (5%)
09:01:53:WU01:FS00:0x17:Completed 975000 out of 2500000 steps (39%)
09:10:31:WU00:FS02:0xa3:Completed 30000 out of 500000 steps (6%)
09:15:04:WU03:FS01:0x17:Completed 1050000 out of 2500000 steps (42%)
09:17:59:WU01:FS00:0x17:Completed 1000000 out of 2500000 steps (40%)
09:19:26:WU00:FS02:0xa3:Completed 35000 out of 500000 steps (7%)
09:28:16:WU00:FS02:0xa3:Completed 40000 out of 500000 steps (8%)
09:32:36:WU03:FS01:0x17:Completed 1075000 out of 2500000 steps (43%)
09:34:22:WU01:FS00:0x17:Completed 1025000 out of 2500000 steps (41%)
09:37:08:WU00:FS02:0xa3:Completed 45000 out of 500000 steps (9%)
09:45:59:WU00:FS02:0xa3:Completed 50000 out of 500000 steps (10%)
09:49:49:WU03:FS01:0x17:Completed 1100000 out of 2500000 steps (44%)
09:50:28:WU01:FS00:0x17:Completed 1050000 out of 2500000 steps (42%)
09:54:55:WU00:FS02:0xa3:Completed 55000 out of 500000 steps (11%)
10:03:50:WU00:FS02:0xa3:Completed 60000 out of 500000 steps (12%)
10:06:52:WU01:FS00:0x17:Completed 1075000 out of 2500000 steps (43%)
10:07:24:WU03:FS01:0x17:Completed 1125000 out of 2500000 steps (45%)
10:12:45:WU00:FS02:0xa3:Completed 65000 out of 500000 steps (13%)
10:21:39:WU00:FS02:0xa3:Completed 70000 out of 500000 steps (14%)
10:22:57:WU01:FS00:0x17:Completed 1100000 out of 2500000 steps (44%)
10:24:37:WU03:FS01:0x17:Completed 1150000 out of 2500000 steps (46%)
10:30:34:WU00:FS02:0xa3:Completed 75000 out of 500000 steps (15%)
10:39:24:WU01:FS00:0x17:Completed 1125000 out of 2500000 steps (45%)
10:39:27:WU00:FS02:0xa3:Completed 80000 out of 500000 steps (16%)
10:42:08:WU03:FS01:0x17:Completed 1175000 out of 2500000 steps (47%)
10:48:23:WU00:FS02:0xa3:Completed 85000 out of 500000 steps (17%)
10:55:30:WU01:FS00:0x17:Completed 1150000 out of 2500000 steps (46%)
10:57:19:WU00:FS02:0xa3:Completed 90000 out of 500000 steps (18%)
10:59:20:WU03:FS01:0x17:Completed 1200000 out of 2500000 steps (48%)
11:06:16:WU00:FS02:0xa3:Completed 95000 out of 500000 steps (19%)
11:11:54:WU01:FS00:0x17:Completed 1175000 out of 2500000 steps (47%)
11:15:17:WU00:FS02:0xa3:Completed 100000 out of 500000 steps (20%)
11:16:53:WU03:FS01:0x17:Completed 1225000 out of 2500000 steps (49%)
11:24:20:WU00:FS02:0xa3:Completed 105000 out of 500000 steps (21%)
11:28:18:WU01:FS00:0x17:Completed 1200000 out of 2500000 steps (48%)
11:33:27:WU00:FS02:0xa3:Completed 110000 out of 500000 steps (22%)
11:34:25:WU03:FS01:0x17:Completed 1250000 out of 2500000 steps (50%)
11:42:24:WU00:FS02:0xa3:Completed 115000 out of 500000 steps (23%)
11:44:42:WU01:FS00:0x17:Completed 1225000 out of 2500000 steps (49%)
11:51:22:WU00:FS02:0xa3:Completed 120000 out of 500000 steps (24%)
11:51:59:WU03:FS01:0x17:Completed 1275000 out of 2500000 steps (51%)
12:00:17:WU00:FS02:0xa3:Completed 125000 out of 500000 steps (25%)
12:00:46:WU01:FS00:0x17:Completed 1250000 out of 2500000 steps (50%)
12:09:09:WU00:FS02:0xa3:Completed 130000 out of 500000 steps (26%)
12:09:13:WU03:FS01:0x17:Completed 1300000 out of 2500000 steps (52%)
12:17:12:WU01:FS00:0x17:Completed 1275000 out of 2500000 steps (51%)
12:17:57:WU00:FS02:0xa3:Completed 135000 out of 500000 steps (27%)
12:26:44:WU00:FS02:0xa3:Completed 140000 out of 500000 steps (28%)
12:26:47:WU03:FS01:0x17:Completed 1325000 out of 2500000 steps (53%)
12:33:16:WU01:FS00:0x17:Completed 1300000 out of 2500000 steps (52%)
12:35:43:WU00:FS02:0xa3:Completed 145000 out of 500000 steps (29%)
12:44:01:WU03:FS01:0x17:Completed 1350000 out of 2500000 steps (54%)
12:44:35:WU00:FS02:0xa3:Completed 150000 out of 500000 steps (30%)
12:49:43:WU01:FS00:0x17:Completed 1325000 out of 2500000 steps (53%)
12:53:32:WU00:FS02:0xa3:Completed 155000 out of 500000 steps (31%)
13:01:31:WU03:FS01:0x17:Completed 1375000 out of 2500000 steps (55%)
13:02:30:WU00:FS02:0xa3:Completed 160000 out of 500000 steps (32%)
13:05:49:WU01:FS00:0x17:Completed 1350000 out of 2500000 steps (54%)
13:11:21:WU00:FS02:0xa3:Completed 165000 out of 500000 steps (33%)
13:18:43:WU03:FS01:0x17:Completed 1400000 out of 2500000 steps (56%)
13:20:13:WU00:FS02:0xa3:Completed 170000 out of 500000 steps (34%)
13:22:13:WU01:FS00:0x17:Completed 1375000 out of 2500000 steps (55%)
13:29:06:WU00:FS02:0xa3:Completed 175000 out of 500000 steps (35%)
13:36:14:WU03:FS01:0x17:Completed 1425000 out of 2500000 steps (57%)
13:37:59:WU00:FS02:0xa3:Completed 180000 out of 500000 steps (36%)
13:38:17:WU01:FS00:0x17:Completed 1400000 out of 2500000 steps (56%)
13:46:55:WU00:FS02:0xa3:Completed 185000 out of 500000 steps (37%)
13:53:25:WU03:FS01:0x17:Completed 1450000 out of 2500000 steps (58%)
13:54:41:WU01:FS00:0x17:Completed 1425000 out of 2500000 steps (57%)
13:55:49:WU00:FS02:0xa3:Completed 190000 out of 500000 steps (38%)
14:04:44:WU00:FS02:0xa3:Completed 195000 out of 500000 steps (39%)
14:10:45:WU01:FS00:0x17:Completed 1450000 out of 2500000 steps (58%)
14:10:59:WU03:FS01:0x17:Completed 1475000 out of 2500000 steps (59%)
14:13:37:WU00:FS02:0xa3:Completed 200000 out of 500000 steps (40%)
14:22:39:WU00:FS02:0xa3:Completed 205000 out of 500000 steps (41%)
14:27:09:WU01:FS00:0x17:Completed 1475000 out of 2500000 steps (59%)
14:28:14:WU03:FS01:0x17:Completed 1500000 out of 2500000 steps (60%)
14:31:34:WU00:FS02:0xa3:Completed 210000 out of 500000 steps (42%)
14:40:28:WU00:FS02:0xa3:Completed 215000 out of 500000 steps (43%)
14:43:16:WU01:FS00:0x17:Completed 1500000 out of 2500000 steps (60%)
14:45:47:WU03:FS01:0x17:Completed 1525000 out of 2500000 steps (61%)
14:49:26:WU00:FS02:0xa3:Completed 220000 out of 500000 steps (44%)
14:58:20:WU00:FS02:0xa3:Completed 225000 out of 500000 steps (45%)
14:59:41:WU01:FS00:0x17:Completed 1525000 out of 2500000 steps (61%)
15:03:00:WU03:FS01:0x17:Completed 1550000 out of 2500000 steps (62%)
15:07:12:WU00:FS02:0xa3:Completed 230000 out of 500000 steps (46%)
15:15:48:WU01:FS00:0x17:Completed 1550000 out of 2500000 steps (62%)
15:16:08:WU00:FS02:0xa3:Completed 235000 out of 500000 steps (47%)
15:20:31:WU03:FS01:0x17:Completed 1575000 out of 2500000 steps (63%)
15:25:04:WU00:FS02:0xa3:Completed 240000 out of 500000 steps (48%)
15:32:11:WU01:FS00:0x17:Completed 1575000 out of 2500000 steps (63%)
15:34:03:WU00:FS02:0xa3:Completed 245000 out of 500000 steps (49%)
15:37:42:WU03:FS01:0x17:Completed 1600000 out of 2500000 steps (64%)
15:42:55:WU00:FS02:0xa3:Completed 250000 out of 500000 steps (50%)
15:48:17:WU01:FS00:0x17:Completed 1600000 out of 2500000 steps (64%)
15:51:50:WU00:FS02:0xa3:Completed 255000 out of 500000 steps (51%)
15:55:12:WU03:FS01:0x17:Completed 1625000 out of 2500000 steps (65%)
16:00:41:WU00:FS02:0xa3:Completed 260000 out of 500000 steps (52%)
16:04:39:WU01:FS00:0x17:Completed 1625000 out of 2500000 steps (65%)
16:09:35:WU00:FS02:0xa3:Completed 265000 out of 500000 steps (53%)
16:12:23:WU03:FS01:0x17:Completed 1650000 out of 2500000 steps (66%)
16:18:31:WU00:FS02:0xa3:Completed 270000 out of 500000 steps (54%)
16:20:45:WU01:FS00:0x17:Completed 1650000 out of 2500000 steps (66%)
16:27:26:WU00:FS02:0xa3:Completed 275000 out of 500000 steps (55%)
16:29:55:WU03:FS01:0x17:Completed 1675000 out of 2500000 steps (67%)
16:36:15:WU00:FS02:0xa3:Completed 280000 out of 500000 steps (56%)
16:37:11:WU01:FS00:0x17:Completed 1675000 out of 2500000 steps (67%)
16:45:07:WU00:FS02:0xa3:Completed 285000 out of 500000 steps (57%)
16:47:08:WU03:FS01:0x17:Completed 1700000 out of 2500000 steps (68%)
16:53:17:WU01:FS00:0x17:Completed 1700000 out of 2500000 steps (68%)
16:54:02:WU00:FS02:0xa3:Completed 290000 out of 500000 steps (58%)
17:02:56:WU00:FS02:0xa3:Completed 295000 out of 500000 steps (59%)
17:04:42:WU03:FS01:0x17:Completed 1725000 out of 2500000 steps (69%)
17:09:42:WU01:FS00:0x17:Completed 1725000 out of 2500000 steps (69%)
17:11:48:WU00:FS02:0xa3:Completed 300000 out of 500000 steps (60%)
17:20:44:WU00:FS02:0xa3:Completed 305000 out of 500000 steps (61%)
17:21:56:WU03:FS01:0x17:Completed 1750000 out of 2500000 steps (70%)
17:25:49:WU01:FS00:0x17:Completed 1750000 out of 2500000 steps (70%)
17:29:41:WU00:FS02:0xa3:Completed 310000 out of 500000 steps (62%)
17:38:31:WU00:FS02:0xa3:Completed 315000 out of 500000 steps (63%)
17:39:27:WU03:FS01:0x17:Completed 1775000 out of 2500000 steps (71%)
17:42:12:WU01:FS00:0x17:Completed 1775000 out of 2500000 steps (71%)
17:47:26:WU00:FS02:0xa3:Completed 320000 out of 500000 steps (64%)
17:56:18:WU00:FS02:0xa3:Completed 325000 out of 500000 steps (65%)
17:56:38:WU03:FS01:0x17:Completed 1800000 out of 2500000 steps (72%)
17:58:18:WU01:FS00:0x17:Completed 1800000 out of 2500000 steps (72%)
18:05:17:WU00:FS02:0xa3:Completed 330000 out of 500000 steps (66%)
18:14:09:WU03:FS01:0x17:Completed 1825000 out of 2500000 steps (73%)
18:14:13:WU00:FS02:0xa3:Completed 335000 out of 500000 steps (67%)
18:14:41:WU01:FS00:0x17:Completed 1825000 out of 2500000 steps (73%)
18:23:06:WU00:FS02:0xa3:Completed 340000 out of 500000 steps (68%)
18:30:43:WU01:FS00:0x17:Completed 1850000 out of 2500000 steps (74%)
18:31:22:WU03:FS01:0x17:Completed 1850000 out of 2500000 steps (74%)
18:32:02:WU00:FS02:0xa3:Completed 345000 out of 500000 steps (69%)
18:40:57:WU00:FS02:0xa3:Completed 350000 out of 500000 steps (70%)
18:47:09:WU01:FS00:0x17:Completed 1875000 out of 2500000 steps (75%)
18:48:53:WU03:FS01:0x17:Completed 1875000 out of 2500000 steps (75%)
18:49:52:WU00:FS02:0xa3:Completed 355000 out of 500000 steps (71%)
18:58:42:WU00:FS02:0xa3:Completed 360000 out of 500000 steps (72%)
19:03:15:WU01:FS00:0x17:Completed 1900000 out of 2500000 steps (76%)
19:06:07:WU03:FS01:0x17:Completed 1900000 out of 2500000 steps (76%)
19:07:42:WU00:FS02:0xa3:Completed 365000 out of 500000 steps (73%)
19:16:40:WU00:FS02:0xa3:Completed 370000 out of 500000 steps (74%)
19:19:41:WU01:FS00:0x17:Completed 1925000 out of 2500000 steps (77%)
19:23:39:WU03:FS01:0x17:Completed 1925000 out of 2500000 steps (77%)
19:25:41:WU00:FS02:0xa3:Completed 375000 out of 500000 steps (75%)
19:34:39:WU00:FS02:0xa3:Completed 380000 out of 500000 steps (76%)
19:35:47:WU01:FS00:0x17:Completed 1950000 out of 2500000 steps (78%)
19:40:54:WU03:FS01:0x17:Completed 1950000 out of 2500000 steps (78%)
19:43:38:WU00:FS02:0xa3:Completed 385000 out of 500000 steps (77%)
19:52:11:WU01:FS00:0x17:Completed 1975000 out of 2500000 steps (79%)
19:52:34:WU00:FS02:0xa3:Completed 390000 out of 500000 steps (78%)
19:58:24:WU03:FS01:0x17:Completed 1975000 out of 2500000 steps (79%)
20:01:30:WU00:FS02:0xa3:Completed 395000 out of 500000 steps (79%)
20:08:14:WU01:FS00:0x17:Completed 2000000 out of 2500000 steps (80%)
20:10:27:WU00:FS02:0xa3:Completed 400000 out of 500000 steps (80%)
20:15:36:WU03:FS01:0x17:Completed 2000000 out of 2500000 steps (80%)
20:19:22:WU00:FS02:0xa3:Completed 405000 out of 500000 steps (81%)
20:24:39:WU01:FS00:0x17:Completed 2025000 out of 2500000 steps (81%)
20:28:15:WU00:FS02:0xa3:Completed 410000 out of 500000 steps (82%)
20:33:07:WU03:FS01:0x17:Completed 2025000 out of 2500000 steps (81%)
20:37:07:WU00:FS02:0xa3:Completed 415000 out of 500000 steps (83%)
20:40:43:WU01:FS00:0x17:Completed 2050000 out of 2500000 steps (82%)
20:45:59:WU00:FS02:0xa3:Completed 420000 out of 500000 steps (84%)
20:50:20:WU03:FS01:0x17:Completed 2050000 out of 2500000 steps (82%)
20:54:54:WU00:FS02:0xa3:Completed 425000 out of 500000 steps (85%)
20:57:08:WU01:FS00:0x17:Completed 2075000 out of 2500000 steps (83%)
21:03:43:WU00:FS02:0xa3:Completed 430000 out of 500000 steps (86%)
21:07:52:WU03:FS01:0x17:Completed 2075000 out of 2500000 steps (83%)
21:12:32:WU00:FS02:0xa3:Completed 435000 out of 500000 steps (87%)
21:13:12:WU01:FS00:0x17:Completed 2100000 out of 2500000 steps (84%)
21:21:29:WU00:FS02:0xa3:Completed 440000 out of 500000 steps (88%)
21:25:06:WU03:FS01:0x17:Completed 2100000 out of 2500000 steps (84%)
21:29:39:WU01:FS00:0x17:Completed 2125000 out of 2500000 steps (85%)
21:30:20:WU00:FS02:0xa3:Completed 445000 out of 500000 steps (89%)
21:39:13:WU00:FS02:0xa3:Completed 450000 out of 500000 steps (90%)
21:42:39:WU03:FS01:0x17:Completed 2125000 out of 2500000 steps (85%)
21:45:44:WU01:FS00:0x17:Completed 2150000 out of 2500000 steps (86%)
21:48:08:WU00:FS02:0xa3:Completed 455000 out of 500000 steps (91%)
21:57:04:WU00:FS02:0xa3:Completed 460000 out of 500000 steps (92%)
21:59:54:WU03:FS01:0x17:Completed 2150000 out of 2500000 steps (86%)
22:02:09:WU01:FS00:0x17:Completed 2175000 out of 2500000 steps (87%)
22:05:56:WU00:FS02:0xa3:Completed 465000 out of 500000 steps (93%)
22:14:50:WU00:FS02:0xa3:Completed 470000 out of 500000 steps (94%)
22:17:25:WU03:FS01:0x17:Completed 2175000 out of 2500000 steps (87%)
22:18:13:WU01:FS00:0x17:Completed 2200000 out of 2500000 steps (88%)
22:23:47:WU00:FS02:0xa3:Completed 475000 out of 500000 steps (95%)
22:32:38:WU00:FS02:0xa3:Completed 480000 out of 500000 steps (96%)
22:34:37:WU01:FS00:0x17:Completed 2225000 out of 2500000 steps (89%)
22:34:38:WU03:FS01:0x17:Completed 2200000 out of 2500000 steps (88%)
22:41:31:WU00:FS02:0xa3:Completed 485000 out of 500000 steps (97%)
22:50:27:WU00:FS02:0xa3:Completed 490000 out of 500000 steps (98%)
22:50:28:WU02:FS02:Connecting to assign3.stanford.edu:8080
22:50:28:WU02:FS02:News: Welcome to Folding@Home
22:50:28:WU02:FS02:Assigned to work server 128.143.231.202
22:50:28:WU02:FS02:Requesting new work unit for slot 02: RUNNING cpu:7 from 128.143.231.202
22:50:28:WU02:FS02:Connecting to 128.143.231.202:8080
22:50:30:WU02:FS02
ownloading 3.64MiB
22:50:32:WU02:FS02
ownload complete
22:50:32:WU02:FS02:Received Unit: id:02 state
OWNLOAD error:NO_ERROR project:6099 run:8 clone:88 gen:264 core:0xa3 unit:0x0000017d0a3b1e594e91e122d4db87e7
22:50:41:WU01:FS00:0x17:Completed 2250000 out of 2500000 steps (90%)
22:52:10:WU03:FS01:0x17:Completed 2225000 out of 2500000 steps (89%)
22:59:53:WU00:FS02:0xa3:Completed 495000 out of 500000 steps (99%)
23:07:04:WU01:FS00:0x17:Completed 2275000 out of 2500000 steps (91%)
23:09:21:WU00:FS02:0xa3:Completed 500000 out of 500000 steps (100%)
23:09:22:WU00:FS02:0xa3
23:09:32:WU00:FS02:0xa3:
23:09:32:WU00:FS02:0xa3:Finished Work Unit:
23:09:32:WU00:FS02:0xa3:- Reading up to 12102336 from \"00/wudata_01.trr\": Read 12102336
23:09:32:WU00:FS02:0xa3:trr file hash check passed.
23:09:32:WU00:FS02:0xa3:edr file hash check passed.
23:09:32:WU00:FS02:0xa3:logfile size: 57491
23:09:32:WU00:FS02:0xa3:Leaving Run
23:09:34:WU03:FS01:0x17:Completed 2250000 out of 2500000 steps (90%)
23:09:34:WU00:FS02:0xa3:- Writing 12193503 bytes of core data to disk...
23:09:36:WU00:FS02:0xa3
one: 12192991 -> 11294678 (compressed to 92.6 percent)
23:09:36:WU00:FS02:0xa3: ... Done.
23:09:36:WU00:FS02:0xa3:- Shutting down core
23:09:36:WU00:FS02:0xa3:Folding@home Core Shutdown: FINISHED_UNIT
23:09:36:WU00:FS02:FahCore returned: FINISHED_UNIT (100 = 0x64)
23:09:36:WU00:FS02:Sending unit results: id:00 state:SEND error:NO_ERROR project:6099 run:3 clone:15 gen:291 core:0xa3 unit:0x000001850a3b1e594e889fc0cac37232
23:09:36:WU00:FS02:Uploading 10.77MiB to 128.143.231.202
23:09:36:WU00:FS02:Connecting to 128.143.231.202:8080
23:09:36:WU02:FS02:Starting
23:09:36:WU02:FS02:Running FahCore: \"C:\\Program Files (x86)\\FAHClient/FAHCoreWrapper.exe\" C:/Users/Brad/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/Core_a3.fah/FahCore_a3.exe -dir 02 -suffix 01 -version 703 -lifeline 2208 -checkpoint 15 -np 7
23:09:36:WU02:FS02:Started FahCore on PID 7176
23:09:36:WU02:FS02:Core PID:7732
23:09:36:WU02:FS02:FahCore 0xa3 started
23:09:37:WU02:FS02:0xa3:
23:09:37:WU02:FS02:0xa3:*------------------------------*
23:09:37:WU02:FS02:0xa3:Folding@Home Gromacs SMP Core
23:09:37:WU02:FS02:0xa3:Version 2.27 (Dec. 15, 2010)
23:09:37:WU02:FS02:0xa3:- Looking at optimizations...
23:09:37:WU02:FS02:0xa3:- Created dyn
23:09:37:WU02:FS02:0xa3:- Files status OK
23:09:37:WU02:FS02:0xa3:- Expanded 3817254 -> 4169428 (decompressed 109.2 percent)
23:09:37:WU02:FS02:0xa3:Called DecompressByteArray: compressed_data_size=3817254 data_size=4169428, decompressed_data_size=4169428 diff=0
23:09:37:WU02:FS02:0xa3:- Digital signature verified
roject: 6099 (Run 8, Clone 88, Gen 264)
23:09:37:WU02:FS02:0xa3:Assembly optimizations on if available.
23:09:37:WU02:FS02:0xa3:Entering M.D.
23:09:42:WU00:FS02:Upload 5.22%
23:09:43:WU02:FS02:0xa3:Mapping NT from 7 to 7
23:09:43:WU02:FS02:0xa3:Completed 0 out of 500000 steps (0%)
23:09:48:WU00:FS02:Upload 9.86%
23:09:54:WU00:FS02:Upload 15.09%
23:10:00:WU00:FS02:Upload 20.31%
23:10:06:WU00:FS02:Upload 24.95%
23:10:12:WU00:FS02:Upload 29.59%
23:10:18:WU00:FS02:Upload 34.81%
23:10:24:WU00:FS02:Upload 39.45%
23:10:30:WU00:FS02:Upload 44.68%
23:10:36:WU00:FS02:Upload 49.32%
23:10:42:WU00:FS02:Upload 54.54%
23:10:48:WU00:FS02:Upload 59.18%
23:10:54:WU00:FS02:Upload 64.40%
23:11:00:WU00:FS02:Upload 69.05%
23:11:06:WU00:FS02:Upload 73.69%
23:11:12:WU00:FS02:Upload 78.91%
23:11:18:WU00:FS02:Upload 83.55%
23:11:24:WU00:FS02:Upload 88.19%
23:11:30:WU00:FS02:Upload 93.41%
23:11:36:WU00:FS02:Upload 98.64%
23:11:40:WU00:FS02:Upload complete
23:11:40:WU00:FS02:Server responded WORK_ACK (400)
23:11:40:WU00:FS02:Final credit estimate, 12463.00 points
23:11:40:WU00:FS02:Cleaning up
23:18:54:WU02:FS02:0xa3:Completed 5000 out of 500000 steps (1%)
23:23:08:WU01:FS00:0x17:Completed 2300000 out of 2500000 steps (92%)
23:27:27:WU03:FS01:0x17:Completed 2275000 out of 2500000 steps (91%)
23:27:49:WU02:FS02:0xa3:Completed 10000 out of 500000 steps (2%)
23:36:33:WU02:FS02:0xa3:Completed 15000 out of 500000 steps (3%)
23:39:33:WU01:FS00:0x17:Completed 2325000 out of 2500000 steps (93%)
23:44:45:WU03:FS01:0x17:Completed 2300000 out of 2500000 steps (92%)
23:45:19:WU02:FS02:0xa3:Completed 20000 out of 500000 steps (4%)
23:53:57:WU02:FS02:0xa3:Completed 25000 out of 500000 steps (5%)
23:55:39:WU01:FS00:0x17:Completed 2350000 out of 2500000 steps (94%)
00:02:30:WU03:FS01:0x17:Completed 2325000 out of 2500000 steps (93%)
00:03:02:WU02:FS02:0xa3:Completed 30000 out of 500000 steps (6%)
00:12:02:WU01:FS00:0x17:Completed 2375000 out of 2500000 steps (95%)
00:12:14:WU02:FS02:0xa3:Completed 35000 out of 500000 steps (7%)
00:20:04:WU03:FS01:0x17:Completed 2350000 out of 2500000 steps (94%)
00:20:43:WU02:FS02:0xa3:Completed 40000 out of 500000 steps (8%)
00:28:08:WU01:FS00:0x17:Completed 2400000 out of 2500000 steps (96%)
00:29:12:WU02:FS02:0xa3:Completed 45000 out of 500000 steps (9%)
00:37:37:WU03:FS01:0x17:Completed 2375000 out of 2500000 steps (95%)
00:37:41:WU02:FS02:0xa3:Completed 50000 out of 500000 steps (10%)
00:44:34:WU01:FS00:0x17:Completed 2425000 out of 2500000 steps (97%)
00:46:09:WU02:FS02:0xa3:Completed 55000 out of 500000 steps (11%)
00:54:39:WU02:FS02:0xa3:Completed 60000 out of 500000 steps (12%)
00:54:46:WU03:FS01:0x17:Completed 2400000 out of 2500000 steps (96%)
01:00:41:WU01:FS00:0x17:Completed 2450000 out of 2500000 steps (98%)
01:00:41:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
01:00:41:WU00:FS00:News: Welcome to Folding@Home
01:00:41:WU00:FS00:Assigned to work server 171.64.65.69
01:00:41:WU00:FS00:Requesting new work unit for slot 00: RUNNING gpu:0:Barts XT [ATI Radeon HD 6800 Series] from 171.64.65.69
01:00:41:WU00:FS00:Connecting to 171.64.65.69:8080
01:00:42:WU00:FS00
ownloading 4.18MiB
01:00:44:WU00:FS00
ownload complete
01:00:44:WU00:FS00:Received Unit: id:00 state
OWNLOAD error:NO_ERROR project:8900 run:571 clone:0 gen:41 core:0x17 unit:0x0000002f028c126651a6a5a83a8c954d
01:03:06:WU02:FS02:0xa3:Completed 65000 out of 500000 steps (13%)
01:11:32:WU02:FS02:0xa3:Completed 70000 out of 500000 steps (14%)
01:12:17:WU03:FS01:0x17:Completed 2425000 out of 2500000 steps (97%)
01:17:06:WU01:FS00:0x17:Completed 2475000 out of 2500000 steps (99%)
01:20:02:WU02:FS02:0xa3:Completed 75000 out of 500000 steps (15%)
01:28:29:WU02:FS02:0xa3:Completed 80000 out of 500000 steps (16%)
01:29:26:WU03:FS01:0x17:Completed 2450000 out of 2500000 steps (98%)
01:29:26:WU04:FS01:Connecting to assign-GPU.stanford.edu:80
01:29:26:WU04:FS01:News: Welcome to Folding@Home
01:29:26:WU04:FS01:Assigned to work server 171.64.65.69
01:29:26:WU04:FS01:Requesting new work unit for slot 01: RUNNING gpu:1:Barts XT [ATI Radeon HD 6800 Series] from 171.64.65.69
01:29:26:WU04:FS01:Connecting to 171.64.65.69:8080
01:29:26:WU04:FS01
ownloading 4.17MiB
01:29:29:WU04:FS01
ownload complete
01:29:29:WU04:FS01:Received Unit: id:04 state
OWNLOAD error:NO_ERROR project:8900 run:524 clone:0 gen:35 core:0x17 unit:0x00000026028c126651a69b38cb53d819
01:33:14:WU01:FS00:0x17:Completed 2500000 out of 2500000 steps (100%)
01:33:34:WU01:FS00:0x17:Saving result file logfile_01.txt
01:33:34:WU01:FS00:0x17:Saving result file checkpointState.xml
01:33:36:WU01:FS00:0x17:Saving result file checkpt.crc
01:33:36:WU01:FS00:0x17:Saving result file log.txt
01:33:36:WU01:FS00:0x17:Saving result file positions.xtc
01:33:39:WU01:FS00:0x17:Folding@home Core Shutdown: FINISHED_UNIT
01:33:39:WU01:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
01:33:39:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:8900 run:310 clone:0 gen:19 core:0x17 unit:0x00000017028c126651a66b8c1138fbd1
01:33:39:WU01:FS00:Uploading 12.96MiB to 171.64.65.69
01:33:39:WU01:FS00:Connecting to 171.64.65.69:8080
01:33:40:WU00:FS00:Starting
01:33:40:WU00:FS00:Running FahCore: \"C:\\Program Files (x86)\\FAHClient/FAHCoreWrapper.exe\" C:/Users/Brad/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/beta/Core_17.fah/FahCore_17.exe -dir 00 -suffix 01 -version 703 -lifeline 2208 -checkpoint 15 -gpu 0 -gpu-vendor ati
01:33:40:WU00:FS00:Started FahCore on PID 6024
01:33:40:WU00:FS00:Core PID:7232
01:33:40:WU00:FS00:FahCore 0x17 started
01:33:40:WU00:FS00:0x17:*********************** Log Started 2013-06-24T01:33:40Z ***********************
roject: 8900 (Run 571, Clone 0, Gen 41)
01:33:40:WU00:FS00:0x17:Unit: 0x0000002f028c126651a6a5a83a8c954d
01:33:40:WU00:FS00:0x17:CPU: 0x00000000000000000000000000000000
01:33:40:WU00:FS00:0x17:Machine: 0
01:33:40:WU00:FS00:0x17:Reading tar file state.xml
01:33:40:WU00:FS00:0x17:Reading tar file system.xml
01:33:41:WU00:FS00:0x17:Reading tar file integrator.xml
01:33:41:WU00:FS00:0x17:Reading tar file core.xml
01:33:45:WU01:FS00:Upload 4.82%
01:33:51:WU01:FS00:Upload 9.16%
01:33:57:WU01:FS00:Upload 13.02%
01:34:03:WU01:FS00:Upload 17.36%
01:34:09:WU01:FS00:Upload 20.74%
01:34:15:WU01:FS00:Upload 25.08%
01:34:21:WU01:FS00:Upload 29.42%
01:34:27:WU01:FS00:Upload 33.27%
01:34:33:WU01:FS00:Upload 37.61%
01:34:39:WU01:FS00:Upload 41.95%
01:34:45:WU01:FS00:Upload 46.29%
01:34:51:WU01:FS00:Upload 50.15%
01:34:57:WU01:FS00:Upload 54.49%
01:35:03:WU01:FS00:Upload 58.35%
01:35:09:WU01:FS00:Upload 62.69%
01:35:15:WU01:FS00:Upload 66.55%
01:35:21:WU01:FS00:Upload 70.89%
01:35:27:WU01:FS00:Upload 74.75%
01:35:33:WU01:FS00:Upload 79.09%
01:35:39:WU01:FS00:Upload 82.95%
01:35:45:WU01:FS00:Upload 87.29%
01:35:51:WU01:FS00:Upload 91.63%
01:35:57:WU01:FS00:Upload 95.48%
01:36:03:WU01:FS00:Upload 99.82%
01:36:11:WU01:FS00:Upload complete
01:36:11:WU01:FS00:Server responded WORK_ACK (400)
01:36:11:WU01:FS00:Final credit estimate, 14346.00 points
01:36:11:WU01:FS00:Cleaning up
01:36:23:WU00:FS00:0x17:Completed 0 out of 2500000 steps (0%)
01:37:09:WU02:FS02:0xa3:Completed 85000 out of 500000 steps (17%)
01:45:46:WU02:FS02:0xa3:Completed 90000 out of 500000 steps (18%)
01:47:07:WU03:FS01:0x17:Completed 2475000 out of 2500000 steps (99%)
01:52:44:WU00:FS00:0x17:Completed 25000 out of 2500000 steps (1%)
01:54:07:WU02:FS02:0xa3:Completed 95000 out of 500000 steps (19%)
02:02:32:WU02:FS02:0xa3:Completed 100000 out of 500000 steps (20%)
02:04:18:WU03:FS01:0x17:Completed 2500000 out of 2500000 steps (100%)
02:04:37:WU03:FS01:0x17:Saving result file logfile_01.txt
02:04:38:WU03:FS01:0x17:Saving result file checkpointState.xml
02:04:39:WU03:FS01:0x17:Saving result file checkpt.crc
02:04:39:WU03:FS01:0x17:Saving result file log.txt
02:04:40:WU03:FS01:0x17:Saving result file positions.xtc
02:04:42:WU03:FS01:0x17:Folding@home Core Shutdown: FINISHED_UNIT
02:04:43:WU03:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
02:04:43:WU03:FS01:Sending unit results: id:03 state:SEND error:NO_ERROR project:8900 run:666 clone:0 gen:20 core:0x17 unit:0x00000017028c126651a6bac181eeb0ac
02:04:43:WU03:FS01:Uploading 12.96MiB to 171.64.65.69
02:04:43:WU03:FS01:Connecting to 171.64.65.69:8080
02:04:43:WU04:FS01:Starting
02:04:43:WU04:FS01:Running FahCore: \"C:\\Program Files (x86)\\FAHClient/FAHCoreWrapper.exe\" C:/Users/Brad/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/beta/Core_17.fah/FahCore_17.exe -dir 04 -suffix 01 -version 703 -lifeline 2208 -checkpoint 15 -gpu 1 -gpu-vendor ati
02:04:43:WU04:FS01:Started FahCore on PID 4128
02:04:43:WU04:FS01:Core PID:5500
02:04:43:WU04:FS01:FahCore 0x17 started
02:04:43:WU04:FS01:0x17:*********************** Log Started 2013-06-24T02:04:43Z ***********************
roject: 8900 (Run 524, Clone 0, Gen 35)
02:04:43:WU04:FS01:0x17:Unit: 0x00000026028c126651a69b38cb53d819
02:04:43:WU04:FS01:0x17:CPU: 0x00000000000000000000000000000000
02:04:43:WU04:FS01:0x17:Machine: 1
02:04:43:WU04:FS01:0x17:Reading tar file state.xml
02:04:44:WU04:FS01:0x17:Reading tar file system.xml
02:04:44:WU04:FS01:0x17:Reading tar file integrator.xml
02:04:44:WU04:FS01:0x17:Reading tar file core.xml
02:04:49:WU03:FS01:Upload 5.30%
02:04:55:WU03:FS01:Upload 9.64%
02:05:01:WU03:FS01:Upload 13.50%
02:05:07:WU03:FS01:Upload 17.84%
02:05:13:WU03:FS01:Upload 21.70%
02:05:19:WU03:FS01:Upload 26.04%
02:05:25:WU03:FS01:Upload 30.38%
02:05:31:WU03:FS01:Upload 34.24%
02:05:37:WU03:FS01:Upload 38.58%
02:05:43:WU03:FS01:Upload 42.44%
02:05:49:WU03:FS01:Upload 46.30%
02:05:55:WU03:FS01:Upload 50.64%
02:06:01:WU03:FS01:Upload 54.49%
02:06:07:WU03:FS01:Upload 58.83%
02:06:13:WU03:FS01:Upload 63.17%
02:06:19:WU03:FS01:Upload 67.51%
02:06:25:WU03:FS01:Upload 71.37%
02:06:31:WU03:FS01:Upload 75.71%
02:06:37:WU03:FS01:Upload 79.57%
02:06:43:WU03:FS01:Upload 83.91%
02:06:49:WU03:FS01:Upload 88.25%
02:06:55:WU03:FS01:Upload 92.11%
02:07:01:WU03:FS01:Upload 95.97%
02:07:14:WU03:FS01:Upload complete
02:07:14:WU03:FS01:Server responded WORK_ACK (400)
02:07:14:WU03:FS01:Final credit estimate, 13863.00 points
02:07:14:WU03:FS01:Cleaning up
02:07:28:WU04:FS01:0x17:Completed 0 out of 2500000 steps (0%)
02:09:01:WU00:FS00:0x17:Completed 50000 out of 2500000 steps (2%)
02:11:12:WU02:FS02:0xa3:Completed 105000 out of 500000 steps (21%)
02:19:46:WU02:FS02:0xa3:Completed 110000 out of 500000 steps (22%)
******************************* Date: 2013-06-24 *******************************
02:24:59:WU04:FS01:0x17:Completed 25000 out of 2500000 steps (1%)
02:25:26:WU00:FS00:0x17:Completed 75000 out of 2500000 steps (3%)
02:28:21:WU02:FS02:0xa3:Completed 115000 out of 500000 steps (23%)
02:36:55:WU02:FS02:0xa3:Completed 120000 out of 500000 steps (24%)
02:41:31:WU00:FS00:0x17:Completed 100000 out of 2500000 steps (4%)
02:42:11:WU04:FS01:0x17:Completed 50000 out of 2500000 steps (2%)
02:45:29:WU02:FS02:0xa3:Completed 125000 out of 500000 steps (25%)
02:53:55:WU02:FS02:0xa3:Completed 130000 out of 500000 steps (26%)
02:57:59:WU00:FS00:0x17:Completed 125000 out of 2500000 steps (5%)
02:59:44:WU04:FS01:0x17:Completed 75000 out of 2500000 steps (3%)
03:02:25:WU02:FS02:0xa3:Completed 135000 out of 500000 steps (27%)
03:10:58:WU02:FS02:0xa3:Completed 140000 out of 500000 steps (28%)
03:14:05:WU00:FS00:0x17:Completed 150000 out of 2500000 steps (6%)
03:16:58:WU04:FS01:0x17:Completed 100000 out of 2500000 steps (4%)
03:19:28:WU02:FS02:0xa3:Completed 145000 out of 500000 steps (29%)
03:27:59:WU02:FS02:0xa3:Completed 150000 out of 500000 steps (30%)
03:30:29:WU00:FS00:0x17:Completed 175000 out of 2500000 steps (7%)
03:34:30:WU04:FS01:0x17:Completed 125000 out of 2500000 steps (5%)
03:36:27:WU02:FS02:0xa3:Completed 155000 out of 500000 steps (31%)
03:44:53:WU02:FS02:0xa3:Completed 160000 out of 500000 steps (32%)
03:46:34:WU00:FS00:0x17:Completed 200000 out of 2500000 steps (8%)
03:51:45:WU04:FS01:0x17:Completed 150000 out of 2500000 steps (6%)
03:53:22:WU02:FS02:0xa3:Completed 165000 out of 500000 steps (33%)
04:02:45:WU02:FS02:0xa3:Completed 170000 out of 500000 steps (34%)
04:02:56:WU00:FS00:0x17:Completed 225000 out of 2500000 steps (9%)
04:09:58:WU04:FS01:0x17:Completed 175000 out of 2500000 steps (7%)
04:12:28:WU02:FS02:0xa3:Completed 175000 out of 500000 steps (35%)
04:18:59:WU00:FS00:0x17:Completed 250000 out of 2500000 steps (10%)
04:22:06:WU02:FS02:0xa3:Completed 180000 out of 500000 steps (36%)
04:28:03:WU04:FS01:0x17:Completed 200000 out of 2500000 steps (8%)
04:31:32:WU02:FS02:0xa3:Completed 185000 out of 500000 steps (37%)
04:35:24:WU00:FS00:0x17:Completed 275000 out of 2500000 steps (11%)
04:40:47:WU02:FS02:0xa3:Completed 190000 out of 500000 steps (38%)
04:46:23:WU04:FS01:0x17:Completed 225000 out of 2500000 steps (9%)
04:50:19:WU02:FS02:0xa3:Completed 195000 out of 500000 steps (39%)
04:51:27:WU00:FS00:0x17:Completed 300000 out of 2500000 steps (12%)
04:59:45:WU02:FS02:0xa3:Completed 200000 out of 500000 steps (40%)
05:04:27:WU04:FS01:0x17:Completed 250000 out of 2500000 steps (10%)
05:07:53:WU00:FS00:0x17:Completed 325000 out of 2500000 steps (13%)
05:09:15:WU02:FS02:0xa3:Completed 205000 out of 500000 steps (41%)
05:12:24:FS02:Shutting core down
05:12:24:FS00:Shutting core down
05:12:24:FS01:Shutting core down
05:12:25:WU00:FS00:0x17:WARNING:Console control signal 1 on PID 7232
05:12:25:WU00:FS00:0x17:Exiting, please wait. . .
05:12:25:WU04:FS01:0x17:WARNING:Console control signal 1 on PID 5500
05:12:25:WU04:FS01:0x17:Exiting, please wait. . .
05:12:25:WU04:FS01:0x17:Lost lifeline PID 4128, exiting
05:12:25:WU04:FS01:0x17:ERROR:103: Lost client lifeline
05:12:25:WU04:FS01:0x17:Folding@home Core Shutdown: CLIENT_DIED
05:12:26:WU04:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
05:12:26:WU00:FS00:0x17:Lost lifeline PID 6024, exiting
05:12:26:WU00:FS00:0x17:ERROR:103: Lost client lifeline
05:12:26:WU00:FS00:0x17:Folding@home Core Shutdown: CLIENT_DIED
05:12:26:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
05:12:29:WU02:FS02:0xa3:Client no longer detected. Shutting down core
05:12:29:WU02:FS02:0xa3:Folding@home Core Shutdown: CLIENT_DIED
05:12:29:WU02:FS02:FahCore returned: INTERRUPTED (102 = 0x66)
05:13:26:Removing old file 'configs/config-20130618-030918.xml'
05:13:26:Saving configuration to config.xml
05:13:26:<config>
05:13:26: <!-- Folding Slot Configuration -->
05:13:26: <power v='off'/>
05:13:26:
05:13:26: <!-- Network -->
05:13:26: <proxy v=':8080'/>
05:13:26:
05:13:26: <!-- User Information -->
05:13:26: <passkey v='********************************'/>
05:13:26: <team v='32'/>
05:13:26: <user v='Rustyfender'/>
05:13:26:
05:13:26: <!-- Folding Slots -->
05:13:26: <slot id='2' type='CPU'>
05:13:26: <cpus v='7'/>
05:13:26: </slot>
05:13:26: <slot id='0' type='GPU'>
05:13:26: <client-type v='beta'/>
05:13:26: </slot>
05:13:26: <slot id='1' type='GPU'>
05:13:26: </slot>
05:13:26:</config>
05:45:02:WU02:FS02:Starting
05:45:02:WU02:FS02:Running FahCore: \"C:\\Program Files (x86)\\FAHClient/FAHCoreWrapper.exe\" C:/Users/Brad/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/Core_a3.fah/FahCore_a3.exe -dir 02 -suffix 01 -version 703 -lifeline 2208 -checkpoint 15 -np 7
05:45:02:WU02:FS02:Started FahCore on PID 4796
05:45:02:WU02:FS02:Core PID:6516
05:45:02:WU02:FS02:FahCore 0xa3 started
05:45:02:WU00:FS00:Starting
05:45:02:WU00:FS00:Running FahCore: \"C:\\Program Files (x86)\\FAHClient/FAHCoreWrapper.exe\" C:/Users/Brad/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/beta/Core_17.fah/FahCore_17.exe -dir 00 -suffix 01 -version 703 -lifeline 2208 -checkpoint 15 -gpu 0 -gpu-vendor ati
05:45:02:WU00:FS00:Started FahCore on PID 6060
05:45:02:WU00:FS00:Core PID:7936
05:45:02:WU00:FS00:FahCore 0x17 started
05:45:02:WU04:FS01:Starting
05:45:02:WU04:FS01:Running FahCore: \"C:\\Program Files (x86)\\FAHClient/FAHCoreWrapper.exe\" C:/Users/Brad/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/beta/Core_17.fah/FahCore_17.exe -dir 04 -suffix 01 -version 703 -lifeline 2208 -checkpoint 15 -gpu 1 -gpu-vendor ati
05:45:02:WU04:FS01:Started FahCore on PID 5252
05:45:02:WU04:FS01:Core PID:7488
05:45:02:WU04:FS01:FahCore 0x17 started
05:45:03:WU02:FS02:0xa3:
05:45:03:WU02:FS02:0xa3:*------------------------------*
05:45:03:WU02:FS02:0xa3:Folding@Home Gromacs SMP Core
05:45:03:WU02:FS02:0xa3:Version 2.27 (Dec. 15, 2010)
reparing to commence simulation
05:45:03:WU02:FS02:0xa3:- Looking at optimizations...
05:45:03:WU02:FS02:0xa3:- Files status OK
05:45:03:WU02:FS02:0xa3:- Expanded 3817254 -> 4169428 (decompressed 109.2 percent)
05:45:03:WU02:FS02:0xa3:Called DecompressByteArray: compressed_data_size=3817254 data_size=4169428, decompressed_data_size=4169428 diff=0
05:45:03:WU02:FS02:0xa3:- Digital signature verified
05:45:03:WU02:FS02:0xa3:Assembly optimizations on if available.
05:45:03:WU02:FS02:0xa3:Entering M.D.
05:45:03:WU00:FS00:0x17:*********************** Log Started 2013-06-24T05:45:02Z ***********************
05:45:03:WU00:FS00:0x17:Unit: 0x0000002f028c126651a6a5a83a8c954d
05:45:03:WU00:FS00:0x17:CPU: 0x00000000000000000000000000000000
05:45:03:WU00:FS00:0x17:Machine: 0
igital signatures verified
05:45:03:WU00:FS00:0x17: Found a checkpoint file
05:45:03:WU04:FS01:0x17:*********************** Log Started 2013-06-24T05:45:02Z ***********************
05:45:03:WU04:FS01:0x17:Unit: 0x00000026028c126651a69b38cb53d819
05:45:03:WU04:FS01:0x17:CPU: 0x00000000000000000000000000000000
05:45:03:WU04:FS01:0x17:Machine: 1
05:45:03:WU04:FS01:0x17: Found a checkpoint file
05:45:09:WU02:FS02:0xa3:Using Gromacs checkpoints
05:45:09:WU02:FS02:0xa3:Mapping NT from 7 to 7
05:45:10:WU02:FS02:0xa3:Resuming from checkpoint
05:45:10:WU02:FS02:0xa3:Verified 02/wudata_01.log
05:45:10:WU02:FS02:0xa3:Verified 02/wudata_01.trr
05:45:10:WU02:FS02:0xa3:Verified 02/wudata_01.edr
05:45:12:WU02:FS02:0xa3:Completed 205255 out of 500000 steps (41%)
05:46:03:Removing old file 'configs/config-20130618-030955.xml'
05:46:03:Saving configuration to config.xml
05:46:03:<config>
05:46:03: <!-- Folding Slot Configuration -->
05:46:03: <power v='full'/>
05:46:03:
05:46:03: <!-- Network -->
05:46:03: <proxy v=':8080'/>
05:46:03:
05:46:03: <!-- User Information -->
05:46:03: <passkey v='********************************'/>
05:46:03: <team v='32'/>
05:46:03: <user v='Rustyfender'/>
05:46:03:
05:46:03: <!-- Folding Slots -->
05:46:03: <slot id='2' type='CPU'>
05:46:03: <cpus v='7'/>
05:46:03: </slot>
05:46:03: <slot id='0' type='GPU'>
05:46:03: <client-type v='beta'/>
05:46:03: </slot>
05:46:03: <slot id='1' type='GPU'>
05:46:03: </slot>
05:46:03:</config>
05:47:54:WU00:FS00:0x17:Completed 300000 out of 2500000 steps (12%)
05:48:09:WU04:FS01:0x17:Completed 250000 out of 2500000 steps (10%)
05:55:50:WU02:FS02:0xa3:Completed 210000 out of 500000 steps (42%)
06:04:19:WU00:FS00:0x17:Completed 325000 out of 2500000 steps (13%)
06:05:11:WU02:FS02:0xa3:Completed 215000 out of 500000 steps (43%)
06:06:32:WU04:FS01:0x17:Completed 275000 out of 2500000 steps (11%)
06:14:40:WU02:FS02:0xa3:Completed 220000 out of 500000 steps (44%)
06:20:19:WU00:FS00:0x17:Completed 350000 out of 2500000 steps (14%)
06:24:06:WU02:FS02:0xa3:Completed 225000 out of 500000 steps (45%)
06:24:38:WU04:FS01:0x17:Completed 300000 out of 2500000 steps (12%)
06:33:39:WU02:FS02:0xa3:Completed 230000 out of 500000 steps (46%)
06:36:47:WU00:FS00:0x17:Completed 375000 out of 2500000 steps (15%)
06:43:04:WU02:FS02:0xa3:Completed 235000 out of 500000 steps (47%)
06:43:10:WU04:FS01:0x17:Completed 325000 out of 2500000 steps (13%)
06:52:28:WU02:FS02:0xa3:Completed 240000 out of 500000 steps (48%)
06:52:49:WU00:FS00:0x17:Completed 400000 out of 2500000 steps (16%)
07:01:12:WU04:FS01:0x17:Completed 350000 out of 2500000 steps (14%)
07:01:55:WU02:FS02:0xa3:Completed 245000 out of 500000 steps (49%)
07:09:16:WU00:FS00:0x17:Completed 425000 out of 2500000 steps (17%)
07:11:28:WU02:FS02:0xa3:Completed 250000 out of 500000 steps (50%)
07:19:40:WU04:FS01:0x17:Completed 375000 out of 2500000 steps (15%)
07:20:52:WU02:FS02:0xa3:Completed 255000 out of 500000 steps (51%)
07:25:18:WU00:FS00:0x17:Completed 450000 out of 2500000 steps (18%)
07:30:16:WU02:FS02:0xa3:Completed 260000 out of 500000 steps (52%)
07:37:45:WU04:FS01:0x17:Completed 400000 out of 2500000 steps (16%)
07:39:31:WU02:FS02:0xa3:Completed 265000 out of 500000 steps (53%)
07:41:41:WU00:FS00:0x17:Completed 475000 out of 2500000 steps (19%)
07:48:55:WU02:FS02:0xa3:Completed 270000 out of 500000 steps (54%)
07:56:15:WU04:FS01:0x17:Completed 425000 out of 2500000 steps (17%)
07:57:50:WU00:FS00:0x17:Completed 500000 out of 2500000 steps (20%)
07:58:12:WU02:FS02:0xa3:Completed 275000 out of 500000 steps (55%)
08:07:38:WU02:FS02:0xa3:Completed 280000 out of 500000 steps (56%)
08:14:10:WU00:FS00:0x17:Completed 525000 out of 2500000 steps (21%)
08:14:20:WU04:FS01:0x17:Completed 450000 out of 2500000 steps (18%)
08:17:05:WU02:FS02:0xa3:Completed 285000 out of 500000 steps (57%)
08:26:33:WU02:FS02:0xa3:Completed 290000 out of 500000 steps (58%)
08:30:11:WU00:FS00:0x17:Completed 550000 out of 2500000 steps (22%)
08:32:48:WU04:FS01:0x17:Completed 475000 out of 2500000 steps (19%)
08:36:04:WU02:FS02:0xa3:Completed 295000 out of 500000 steps (59%)
08:45:31:WU02:FS02:0xa3:Completed 300000 out of 500000 steps (60%)
08:46:33:WU00:FS00:0x17:Completed 575000 out of 2500000 steps (23%)
08:50:56:WU04:FS01:0x17:Completed 500000 out of 2500000 steps (20%)
08:54:58:WU02:FS02:0xa3:Completed 305000 out of 500000 steps (61%)
09:02:41:WU00:FS00:0x17:Completed 600000 out of 2500000 steps (24%)
09:04:14:WU02:FS02:0xa3:Completed 310000 out of 500000 steps (62%)
09:09:21:WU04:FS01:0x17:Completed 525000 out of 2500000 steps (21%)
09:13:40:WU02:FS02:0xa3:Completed 315000 out of 500000 steps (63%)
09:19:04:WU00:FS00:0x17:Completed 625000 out of 2500000 steps (25%)
09:23:11:WU02:FS02:0xa3:Completed 320000 out of 500000 steps (64%)
09:27:26:WU04:FS01:0x17:Completed 550000 out of 2500000 steps (22%)
09:32:38:WU02:FS02:0xa3:Completed 325000 out of 500000 steps (65%)
09:35:09:WU00:FS00:0x17:Completed 650000 out of 2500000 steps (26%)
09:42:01:WU02:FS02:0xa3:Completed 330000 out of 500000 steps (66%)
09:45:59:WU04:FS01:0x17:Completed 575000 out of 2500000 steps (23%)
09:51:29:WU02:FS02:0xa3:Completed 335000 out of 500000 steps (67%)
09:51:30:WU00:FS00:0x17:Completed 675000 out of 2500000 steps (27%)
10:00:57:WU02:FS02:0xa3:Completed 340000 out of 500000 steps (68%)
10:04:01:WU04:FS01:0x17:Completed 600000 out of 2500000 steps (24%)
10:07:31:WU00:FS00:0x17:Completed 700000 out of 2500000 steps (28%)
10:09:34:WU02:FS02:0xa3:Completed 345000 out of 500000 steps (69%)
10:18:10:WU02:FS02:0xa3:Completed 350000 out of 500000 steps (70%)
10:21:36:WU04:FS01:0x17:Completed 625000 out of 2500000 steps (25%)
10:23:49:WU00:FS00:0x17:Completed 725000 out of 2500000 steps (29%)
10:26:45:WU02:FS02:0xa3:Completed 355000 out of 500000 steps (71%)
10:35:25:WU02:FS02:0xa3:Completed 360000 out of 500000 steps (72%)
10:38:47:WU04:FS01:0x17:Completed 650000 out of 2500000 steps (26%)
10:39:52:WU00:FS00:0x17:Completed 750000 out of 2500000 steps (30%)
10:44:03:WU02:FS02:0xa3:Completed 365000 out of 500000 steps (73%)
10:52:40:WU02:FS02:0xa3:Completed 370000 out of 500000 steps (74%)
10:56:12:WU00:FS00:0x17:Completed 775000 out of 2500000 steps (31%)
10:56:20:WU04:FS01:0x17:Completed 675000 out of 2500000 steps (27%)
11:01:20:WU02:FS02:0xa3:Completed 375000 out of 500000 steps (75%)
11:09:59:WU02:FS02:0xa3:Completed 380000 out of 500000 steps (76%)
11:12:14:WU00:FS00:0x17:Completed 800000 out of 2500000 steps (32%)
11:13:37:WU04:FS01:0x17:Completed 700000 out of 2500000 steps (28%)
11:18:38:WU02:FS02:0xa3:Completed 385000 out of 500000 steps (77%)
11:27:21:WU02:FS02:0xa3:Completed 390000 out of 500000 steps (78%)
11:28:54:WU00:FS00:0x17:Completed 825000 out of 2500000 steps (33%)
11:31:08:WU04:FS01:0x17:Completed 725000 out of 2500000 steps (29%)
11:35:59:WU02:FS02:0xa3:Completed 395000 out of 500000 steps (79%)
11:44:39:WU02:FS02:0xa3:Completed 400000 out of 500000 steps (80%)
11:44:54:WU00:FS00:0x17:Completed 850000 out of 2500000 steps (34%)
11:48:21:WU04:FS01:0x17:Completed 750000 out of 2500000 steps (30%)
11:53:19:WU02:FS02:0xa3:Completed 405000 out of 500000 steps (81%)
12:01:14:WU00:FS00:0x17:Completed 875000 out of 2500000 steps (35%)
12:01:53:WU02:FS02:0xa3:Completed 410000 out of 500000 steps (82%)
12:05:55:WU04:FS01:0x17:Completed 775000 out of 2500000 steps (31%)
12:10:29:WU02:FS02:0xa3:Completed 415000 out of 500000 steps (83%)
12:17:12:WU00:FS00:0x17:Completed 900000 out of 2500000 steps (36%)
12:19:07:WU02:FS02:0xa3:Completed 420000 out of 500000 steps (84%)
12:23:09:WU04:FS01:0x17:Completed 800000 out of 2500000 steps (32%)
12:27:45:WU02:FS02:0xa3:Completed 425000 out of 500000 steps (85%)
12:33:35:WU00:FS00:0x17:Completed 925000 out of 2500000 steps (37%)
12:36:21:WU02:FS02:0xa3:Completed 430000 out of 500000 steps (86%)
12:40:40:WU04:FS01:0x17:Completed 825000 out of 2500000 steps (33%)
12:44:59:WU02:FS02:0xa3:Completed 435000 out of 500000 steps (87%)
12:49:33:WU00:FS00:0x17:Completed 950000 out of 2500000 steps (38%)
12:53:36:WU02:FS02:0xa3:Completed 440000 out of 500000 steps (88%)
12:57:51:WU04:FS01:0x17:Completed 850000 out of 2500000 steps (34%)
13:02:19:WU02:FS02:0xa3:Completed 445000 out of 500000 steps (89%)
13:05:57:WU00:FS00:0x17:Completed 975000 out of 2500000 steps (39%)
13:11:00:WU02:FS02:0xa3:Completed 450000 out of 500000 steps (90%)
13:15:25:WU04:FS01:0x17:Completed 875000 out of 2500000 steps (35%)
13:19:39:WU02:FS02:0xa3:Completed 455000 out of 500000 steps (91%)
13:21:56:WU00:FS00:0x17:Completed 1000000 out of 2500000 steps (40%)
13:28:22:WU02:FS02:0xa3:Completed 460000 out of 500000 steps (92%)
13:32:37:WU04:FS01:0x17:Completed 900000 out of 2500000 steps (36%)
13:37:01:WU02:FS02:0xa3:Completed 465000 out of 500000 steps (93%)
13:38:21:WU00:FS00:0x17:Completed 1025000 out of 2500000 steps (41%)
13:45:38:WU02:FS02:0xa3:Completed 470000 out of 500000 steps (94%)
13:50:10:WU04:FS01:0x17:Completed 925000 out of 2500000 steps (37%)
13:54:11:WU02:FS02:0xa3:Completed 475000 out of 500000 steps (95%)
13:54:23:WU00:FS00:0x17:Completed 1050000 out of 2500000 steps (42%)
14:02:48:WU02:FS02:0xa3:Completed 480000 out of 500000 steps (96%)
14:07:23:WU04:FS01:0x17:Completed 950000 out of 2500000 steps (38%)
14:10:45:WU00:FS00:0x17:Completed 1075000 out of 2500000 steps (43%)
14:11:28:WU02:FS02:0xa3:Completed 485000 out of 500000 steps (97%)
14:20:05:WU02:FS02:0xa3:Completed 490000 out of 500000 steps (98%)
14:20:05:WU01:FS02:Connecting to assign3.stanford.edu:8080
14:20:05:WU01:FS02:News: Welcome to Folding@Home
14:20:05:WU01:FS02:Assigned to work server 171.67.108.35
14:20:05:WU01:FS02:Requesting new work unit for slot 02: RUNNING cpu:7 from 171.67.108.35
14:20:05:WU01:FS02:Connecting to 171.67.108.35:8080
14:20:06:WU01:FS02
ownloading 1001.61KiB
14:20:07:WU01:FS02
ownload complete
14:20:07:WU01:FS02:Received Unit: id:01 state
OWNLOAD error:NO_ERROR project:8702 run:63 clone:42 gen:4 core:0xa4 unit:0x000000046652edb351c6a602ba47393c
14:24:54:WU04:FS01:0x17:Completed 975000 out of 2500000 steps (39%)
14:26:44:WU00:FS00:0x17:Completed 1100000 out of 2500000 steps (44%)
14:28:43:WU02:FS02:0xa3:Completed 495000 out of 500000 steps (99%)
14:37:24:WU02:FS02:0xa3:Completed 500000 out of 500000 steps (100%)
14:37:26:WU02:FS02:0xa3
14:37:36:WU02:FS02:0xa3:
14:37:36:WU02:FS02:0xa3:Finished Work Unit:
14:37:36:WU02:FS02:0xa3:- Reading up to 12102336 from \"02/wudata_01.trr\": Read 12102336
14:37:36:WU02:FS02:0xa3:trr file hash check passed.
14:37:36:WU02:FS02:0xa3:edr file hash check passed.
14:37:36:WU02:FS02:0xa3:logfile size: 56809
14:37:36:WU02:FS02:0xa3:Leaving Run
14:37:36:WU02:FS02:0xa3:- Writing 12192821 bytes of core data to disk...
14:37:37:WU02:FS02:0xa3
one: 12192309 -> 11304454 (compressed to 92.7 percent)
14:37:37:WU02:FS02:0xa3: ... Done.
14:37:38:WU02:FS02:0xa3:- Shutting down core
14:37:38:WU02:FS02:0xa3:Folding@home Core Shutdown: FINISHED_UNIT
14:37:38:WU02:FS02:FahCore returned: FINISHED_UNIT (100 = 0x64)
14:37:38:WU02:FS02:Sending unit results: id:02 state:SEND error:NO_ERROR project:6099 run:8 clone:88 gen:264 core:0xa3 unit:0x0000017d0a3b1e594e91e122d4db87e7
14:37:38:WU02:FS02:Uploading 10.78MiB to 128.143.231.202
14:37:38:WU02:FS02:Connecting to 128.143.231.202:8080
14:37:38:WU01:FS02:Starting
14:37:38:WU01:FS02:Running FahCore: \"C:\\Program Files (x86)\\FAHClient/FAHCoreWrapper.exe\" C:/Users/Brad/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 01 -suffix 01 -version 703 -lifeline 2208 -checkpoint 15 -np 7
14:37:38:WU01:FS02:Started FahCore on PID 7516
14:37:38:WU01:FS02:Core PID:8840
14:37:38:WU01:FS02:FahCore 0xa4 started
14:37:38:WU01:FS02:0xa4:
14:37:38:WU01:FS02:0xa4:*------------------------------*
14:37:38:WU01:FS02:0xa4:Folding@Home Gromacs GB Core
14:37:38:WU01:FS02:0xa4:Version 2.27 (Dec. 15, 2010)
14:37:38:WU01:FS02:0xa4:- Looking at optimizations...
14:37:38:WU01:FS02:0xa4:- Created dyn
14:37:38:WU01:FS02:0xa4:- Files status OK
14:37:38:WU01:FS02:0xa4:- Expanded 1025132 -> 2544640 (decompressed 248.2 percent)
14:37:38:WU01:FS02:0xa4:Called DecompressByteArray: compressed_data_size=1025132 data_size=2544640, decompressed_data_size=2544640 diff=0
14:37:38:WU01:FS02:0xa4:- Digital signature verified
roject: 8702 (Run 63, Clone 42, Gen 4)
14:37:38:WU01:FS02:0xa4:Assembly optimizations on if available.
14:37:38:WU01:FS02:0xa4:Entering M.D.
14:37:44:WU02:FS02:Upload 5.80%
14:37:44:WU01:FS02:0xa4:Mapping NT from 7 to 7
14:37:44:WU01:FS02:0xa4:Completed 0 out of 250000 steps (0%)
14:37:50:WU02:FS02:Upload 10.43%
14:37:56:WU02:FS02:Upload 14.49%
14:38:02:WU02:FS02:Upload 19.71%
14:38:08:WU02:FS02:Upload 24.35%
14:38:14:WU02:FS02:Upload 29.57%
14:38:20:WU02:FS02:Upload 34.20%
14:38:26:WU02:FS02:Upload 38.84%
14:38:32:WU02:FS02:Upload 42.90%
14:38:38:WU02:FS02:Upload 48.12%
14:38:44:WU02:FS02:Upload 52.75%
14:38:50:WU02:FS02:Upload 57.39%
14:38:56:WU02:FS02:Upload 62.61%
14:39:02:WU02:FS02:Upload 67.25%
14:39:05:WU01:FS02:0xa4:Completed 2500 out of 250000 steps (1%)
14:39:08:WU02:FS02:Upload 71.88%
14:39:14:WU02:FS02:Upload 76.52%
14:39:20:WU02:FS02:Upload 81.74%
14:39:26:WU02:FS02:Upload 86.96%
14:39:32:WU02:FS02:Upload 91.59%
14:39:39:WU02:FS02:Upload 96.81%
14:39:44:WU02:FS02:Upload complete
14:39:44:WU02:FS02:Server responded WORK_ACK (400)
14:39:44:WU02:FS02:Final credit estimate, 12120.00 points
14:39:44:WU02:FS02:Cleaning up
14:40:25:WU01:FS02:0xa4:Completed 5000 out of 250000 steps (2%)
14:41:47:WU01:FS02:0xa4:Completed 7500 out of 250000 steps (3%)
14:42:08:WU04:FS01:0x17:Completed 1000000 out of 2500000 steps (40%)
14:43:06:WU00:FS00:0x17:Completed 1125000 out of 2500000 steps (45%)
14:43:09:WU01:FS02:0xa4:Completed 10000 out of 250000 steps (4%)
14:44:30:WU01:FS02:0xa4:Completed 12500 out of 250000 steps (5%)
14:45:51:WU01:FS02:0xa4:Completed 15000 out of 250000 steps (6%)
14:47:12:WU01:FS02:0xa4:Completed 17500 out of 250000 steps (7%)
14:48:32:WU01:FS02:0xa4:Completed 20000 out of 250000 steps (8%)
14:49:53:WU01:FS02:0xa4:Completed 22500 out of 250000 steps (9%)
14:51:14:WU01:FS02:0xa4:Completed 25000 out of 250000 steps (10%)
14:52:35:WU01:FS02:0xa4:Completed 27500 out of 250000 steps (11%)
14:53:56:WU01:FS02:0xa4:Completed 30000 out of 250000 steps (12%)
14:55:17:WU01:FS02:0xa4:Completed 32500 out of 250000 steps (13%)
14:56:38:WU01:FS02:0xa4:Completed 35000 out of 250000 steps (14%)
14:58:00:WU01:FS02:0xa4:Completed 37500 out of 250000 steps (15%)
14:59:05:WU00:FS00:0x17:Completed 1150000 out of 2500000 steps (46%)
14:59:21:WU01:FS02:0xa4:Completed 40000 out of 250000 steps (16%)
14:59:38:WU04:FS01:0x17:Completed 1025000 out of 2500000 steps (41%)
15:00:41:WU01:FS02:0xa4:Completed 42500 out of 250000 steps (17%)
15:02:03:WU01:FS02:0xa4:Completed 45000 out of 250000 steps (18%)
15:03:23:WU01:FS02:0xa4:Completed 47500 out of 250000 steps (19%)
15:04:44:WU01:FS02:0xa4:Completed 50000 out of 250000 steps (20%)
15:06:05:WU01:FS02:0xa4:Completed 52500 out of 250000 steps (21%)
15:07:26:WU01:FS02:0xa4:Completed 55000 out of 250000 steps (22%)
15:08:48:WU01:FS02:0xa4:Completed 57500 out of 250000 steps (23%)
15:10:09:WU01:FS02:0xa4:Completed 60000 out of 250000 steps (24%)
15:11:30:WU01:FS02:0xa4:Completed 62500 out of 250000 steps (25%)
15:12:51:WU01:FS02:0xa4:Completed 65000 out of 250000 steps (26%)
15:14:13:WU01:FS02:0xa4:Completed 67500 out of 250000 steps (27%)
15:15:27:WU00:FS00:0x17:Completed 1175000 out of 2500000 steps (47%)
15:15:35:WU01:FS02:0xa4:Completed 70000 out of 250000 steps (28%)
15:16:48:WU04:FS01:0x17:Completed 1050000 out of 2500000 steps (42%)
15:16:55:WU01:FS02:0xa4:Completed 72500 out of 250000 steps (29%)
15:18:17:WU01:FS02:0xa4:Completed 75000 out of 250000 steps (30%)
15:19:37:WU01:FS02:0xa4:Completed 77500 out of 250000 steps (31%)
15:20:57:WU01:FS02:0xa4:Completed 80000 out of 250000 steps (32%)
15:22:17:WU01:FS02:0xa4:Completed 82500 out of 250000 steps (33%)
15:23:36:WU01:FS02:0xa4:Completed 85000 out of 250000 steps (34%)
15:24:55:WU01:FS02:0xa4:Completed 87500 out of 250000 steps (35%)
15:26:16:WU01:FS02:0xa4:Completed 90000 out of 250000 steps (36%)
15:27:36:WU01:FS02:0xa4:Completed 92500 out of 250000 steps (37%)
15:28:56:WU01:FS02:0xa4:Completed 95000 out of 250000 steps (38%)
15:30:15:WU01:FS02:0xa4:Completed 97500 out of 250000 steps (39%)
15:31:31:WU00:FS00:0x17:Completed 1200000 out of 2500000 steps (48%)
15:31:37:WU01:FS02:0xa4:Completed 100000 out of 250000 steps (40%)
15:32:59:WU01:FS02:0xa4:Completed 102500 out of 250000 steps (41%)
15:34:19:WU01:FS02:0xa4:Completed 105000 out of 250000 steps (42%)
15:34:20:WU04:FS01:0x17:Completed 1075000 out of 2500000 steps (43%)
15:35:40:WU01:FS02:0xa4:Completed 107500 out of 250000 steps (43%)
15:37:00:WU01:FS02:0xa4:Completed 110000 out of 250000 steps (44%)
15:38:20:WU01:FS02:0xa4:Completed 112500 out of 250000 steps (45%)
15:39:39:WU01:FS02:0xa4:Completed 115000 out of 250000 steps (46%)
15:41:00:WU01:FS02:0xa4:Completed 117500 out of 250000 steps (47%)
15:42:20:WU01:FS02:0xa4:Completed 120000 out of 250000 steps (48%)
15:43:41:WU01:FS02:0xa4:Completed 122500 out of 250000 steps (49%)
15:45:01:WU01:FS02:0xa4:Completed 125000 out of 250000 steps (50%)
15:46:22:WU01:FS02:0xa4:Completed 127500 out of 250000 steps (51%)
15:47:43:WU01:FS02:0xa4:Completed 130000 out of 250000 steps (52%)
15:47:51:WU00:FS00:0x17:Completed 1225000 out of 2500000 steps (49%)
15:49:03:WU01:FS02:0xa4:Completed 132500 out of 250000 steps (53%)
15:50:24:WU01:FS02:0xa4:Completed 135000 out of 250000 steps (54%)
15:51:29:WU04:FS01:0x17:Completed 1100000 out of 2500000 steps (44%)
15:51:45:WU01:FS02:0xa4:Completed 137500 out of 250000 steps (55%)
15:53:05:WU01:FS02:0xa4:Completed 140000 out of 250000 steps (56%)
15:54:25:WU01:FS02:0xa4:Completed 142500 out of 250000 steps (57%)
15:55:45:WU01:FS02:0xa4:Completed 145000 out of 250000 steps (58%)
15:57:05:WU01:FS02:0xa4:Completed 147500 out of 250000 steps (59%)
15:58:26:WU01:FS02:0xa4:Completed 150000 out of 250000 steps (60%)
15:59:46:WU01:FS02:0xa4:Completed 152500 out of 250000 steps (61%)
16:01:07:WU01:FS02:0xa4:Completed 155000 out of 250000 steps (62%)
16:02:28:WU01:FS02:0xa4:Completed 157500 out of 250000 steps (63%)
16:03:47:WU01:FS02:0xa4:Completed 160000 out of 250000 steps (64%)
16:03:56:WU00:FS00:0x17:Completed 1250000 out of 2500000 steps (50%)
16:05:09:WU01:FS02:0xa4:Completed 162500 out of 250000 steps (65%)
16:06:29:WU01:FS02:0xa4:Completed 165000 out of 250000 steps (66%)
16:07:49:WU01:FS02:0xa4:Completed 167500 out of 250000 steps (67%)
16:09:02:WU04:FS01:0x17:Completed 1125000 out of 2500000 steps (45%)
16:09:10:WU01:FS02:0xa4:Completed 170000 out of 250000 steps (68%)
16:10:30:WU01:FS02:0xa4:Completed 172500 out of 250000 steps (69%)
16:11:51:WU01:FS02:0xa4:Completed 175000 out of 250000 steps (70%)
16:13:12:WU01:FS02:0xa4:Completed 177500 out of 250000 steps (71%)
16:14:33:WU01:FS02:0xa4:Completed 180000 out of 250000 steps (72%)
16:15:54:WU01:FS02:0xa4:Completed 182500 out of 250000 steps (73%)
16:17:13:WU01:FS02:0xa4:Completed 185000 out of 250000 steps (74%)
16:18:35:WU01:FS02:0xa4:Completed 187500 out of 250000 steps (75%)
16:19:56:WU01:FS02:0xa4:Completed 190000 out of 250000 steps (76%)
16:20:15:WU00:FS00:0x17:Completed 1275000 out of 2500000 steps (51%)
16:21:18:WU01:FS02:0xa4:Completed 192500 out of 250000 steps (77%)
16:22:39:WU01:FS02:0xa4:Completed 195000 out of 250000 steps (78%)
16:24:00:WU01:FS02:0xa4:Completed 197500 out of 250000 steps (79%)
16:25:20:WU01:FS02:0xa4:Completed 200000 out of 250000 steps (80%)
16:26:12:WU04:FS01:0x17:Completed 1150000 out of 2500000 steps (46%)
16:26:41:WU01:FS02:0xa4:Completed 202500 out of 250000 steps (81%)
16:28:03:WU01:FS02:0xa4:Completed 205000 out of 250000 steps (82%)
16:29:23:WU01:FS02:0xa4:Completed 207500 out of 250000 steps (83%)
16:30:45:WU01:FS02:0xa4:Completed 210000 out of 250000 steps (84%)
16:32:06:WU01:FS02:0xa4:Completed 212500 out of 250000 steps (85%)
16:33:27:WU01:FS02:0xa4:Completed 215000 out of 250000 steps (86%)
16:34:50:WU01:FS02:0xa4:Completed 217500 out of 250000 steps (87%)
16:36:10:WU01:FS02:0xa4:Completed 220000 out of 250000 steps (88%)
16:36:18:WU00:FS00:0x17:Completed 1300000 out of 2500000 steps (52%)
16:37:32:WU01:FS02:0xa4:Completed 222500 out of 250000 steps (89%)
16:38:54:WU01:FS02:0xa4:Completed 225000 out of 250000 steps (90%)
16:40:15:WU01:FS02:0xa4:Completed 227500 out of 250000 steps (91%)
16:41:36:WU01:FS02:0xa4:Completed 230000 out of 250000 steps (92%)
16:42:57:WU01:FS02:0xa4:Completed 232500 out of 250000 steps (93%)
16:43:44:WU04:FS01:0x17:Completed 1175000 out of 2500000 steps (47%)
16:44:19:WU01:FS02:0xa4:Completed 235000 out of 250000 steps (94%)
16:45:40:WU01:FS02:0xa4:Completed 237500 out of 250000 steps (95%)
16:47:01:WU01:FS02:0xa4:Completed 240000 out of 250000 steps (96%)
16:48:21:WU01:FS02:0xa4:Completed 242500 out of 250000 steps (97%)
16:49:42:WU01:FS02:0xa4:Completed 245000 out of 250000 steps (98%)
16:49:43:WU02:FS02:Connecting to assign3.stanford.edu:8080
16:49:43:WU02:FS02:News: Welcome to Folding@Home
16:49:43:WU02:FS02:Assigned to work server 171.67.108.35
16:49:43:WU02:FS02:Requesting new work unit for slot 02: RUNNING cpu:7 from 171.67.108.35
16:49:43:WU02:FS02:Connecting to 171.67.108.35:8080
16:49:44:WU02:FS02
ownloading 1001.46KiB
16:49:45:WU02:FS02
ownload complete
16:49:45:WU02:FS02:Received Unit: id:02 state
OWNLOAD error:NO_ERROR project:8702 run:42 clone:55 gen:3 core:0xa4 unit:0x000000036652edb351c6a5149b882353
16:51:03:WU01:FS02:0xa4:Completed 247500 out of 250000 steps (99%)
16:52:24:WU01:FS02:0xa4:Completed 250000 out of 250000 steps (100%)
16:52:34:WU01:FS02:0xa4:
16:52:34:WU01:FS02:0xa4:Finished Work Unit:
16:52:34:WU01:FS02:0xa4:- Reading up to 1567212 from \"01/wudata_01.trr\": Read 1567212
16:52:34:WU01:FS02:0xa4:trr file hash check passed.
16:52:34:WU01:FS02:0xa4:- Reading up to 1758356 from \"01/wudata_01.xtc\": Read 1758356
16:52:34:WU01:FS02:0xa4:xtc file hash check passed.
16:52:34:WU01:FS02:0xa4:edr file hash check passed.
16:52:34:WU01:FS02:0xa4:logfile size: 27038
16:52:34:WU01:FS02:0xa4:Leaving Run
16:52:36:WU00:FS00:0x17:Completed 1325000 out of 2500000 steps (53%)
16:52:37:WU01:FS02:0xa4:- Writing 3362034 bytes of core data to disk...
one: 3361522 -> 3244133 (compressed to 96.5 percent)
16:52:37:WU01:FS02:0xa4: ... Done.
16:52:37:WU01:FS02:0xa4:- Shutting down core
16:52:37:WU01:FS02:0xa4:Folding@home Core Shutdown: FINISHED_UNIT
16:52:38:WU01:FS02:FahCore returned: FINISHED_UNIT (100 = 0x64)
16:52:38:WU01:FS02:Sending unit results: id:01 state:SEND error:NO_ERROR project:8702 run:63 clone:42 gen:4 core:0xa4 unit:0x000000046652edb351c6a602ba47393c
16:52:38:WU01:FS02:Uploading 3.09MiB to 171.67.108.35
16:52:38:WU01:FS02:Connecting to 171.67.108.35:8080
16:52:38:WU02:FS02:Starting
16:52:38:WU02:FS02:Running FahCore: \"C:\\Program Files (x86)\\FAHClient/FAHCoreWrapper.exe\" C:/Users/Brad/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 02 -suffix 01 -version 703 -lifeline 2208 -checkpoint 15 -np 7
16:52:38:WU02:FS02:Started FahCore on PID 9024
16:52:38:WU02:FS02:Core PID:8740
16:52:38:WU02:FS02:FahCore 0xa4 started
16:52:38:WU02:FS02:0xa4:
16:52:38:WU02:FS02:0xa4:*------------------------------*
16:52:38:WU02:FS02:0xa4:Folding@Home Gromacs GB Core
16:52:38:WU02:FS02:0xa4:Version 2.27 (Dec. 15, 2010)
16:52:38:WU02:FS02:0xa4:- Looking at optimizations...
16:52:38:WU02:FS02:0xa4:- Created dyn
16:52:38:WU02:FS02:0xa4:- Files status OK
16:52:38:WU02:FS02:0xa4:- Expanded 1024979 -> 2544640 (decompressed 248.2 percent)
16:52:38:WU02:FS02:0xa4:Called DecompressByteArray: compressed_data_size=1024979 data_size=2544640, decompressed_data_size=2544640 diff=0
16:52:38:WU02:FS02:0xa4:- Digital signature verified
roject: 8702 (Run 42, Clone 55, Gen 3)
16:52:38:WU02:FS02:0xa4:Assembly optimizations on if available.
16:52:38:WU02:FS02:0xa4:Entering M.D.
16:52:44:WU02:FS02:0xa4:Mapping NT from 7 to 7
16:52:44:WU01:FS02:Upload 22.22%
16:52:44:WU02:FS02:0xa4:Completed 0 out of 250000 steps (0%)
16:52:50:WU01:FS02:Upload 38.38%
16:52:57:WU01:FS02:Upload 56.55%
16:53:03:WU01:FS02:Upload 74.73%
16:53:09:WU01:FS02:Upload 90.89%
16:53:13:WU01:FS02:Upload complete
16:53:13:WU01:FS02:Server responded WORK_ACK (400)
16:53:13:WU01:FS02:Final credit estimate, 1470.00 points
16:53:13:WU01:FS02:Cleaning up
16:54:05:WU02:FS02:0xa4:Completed 2500 out of 250000 steps (1%)
16:55:25:WU02:FS02:0xa4:Completed 5000 out of 250000 steps (2%)
16:56:47:WU02:FS02:0xa4:Completed 7500 out of 250000 steps (3%)
16:58:08:WU02:FS02:0xa4:Completed 10000 out of 250000 steps (4%)
16:59:30:WU02:FS02:0xa4:Completed 12500 out of 250000 steps (5%)
17:00:50:WU02:FS02:0xa4:Completed 15000 out of 250000 steps (6%)
17:00:55:WU04:FS01:0x17:Completed 1200000 out of 2500000 steps (48%)
17:02:12:WU02:FS02:0xa4:Completed 17500 out of 250000 steps (7%)
17:03:33:WU02:FS02:0xa4:Completed 20000 out of 250000 steps (8%)
17:04:53:WU02:FS02:0xa4:Completed 22500 out of 250000 steps (9%)
17:06:13:WU02:FS02:0xa4:Completed 25000 out of 250000 steps (10%)
17:07:33:WU02:FS02:0xa4:Completed 27500 out of 250000 steps (11%)
17:08:39:WU00:FS00:0x17:Completed 1350000 out of 2500000 steps (54%)
17:08:54:WU02:FS02:0xa4:Completed 30000 out of 250000 steps (12%)
17:10:15:WU02:FS02:0xa4:Completed 32500 out of 250000 steps (13%)
17:11:36:WU02:FS02:0xa4:Completed 35000 out of 250000 steps (14%)
17:12:56:WU02:FS02:0xa4:Completed 37500 out of 250000 steps (15%)
17:14:17:WU02:FS02:0xa4:Completed 40000 out of 250000 steps (16%)
17:15:38:WU02:FS02:0xa4:Completed 42500 out of 250000 steps (17%)
17:16:58:WU02:FS02:0xa4:Completed 45000 out of 250000 steps (18%)
17:18:19:WU02:FS02:0xa4:Completed 47500 out of 250000 steps (19%)
17:18:25:WU04:FS01:0x17:Completed 1225000 out of 2500000 steps (49%)
17:19:40:WU02:FS02:0xa4:Completed 50000 out of 250000 steps (20%)
17:21:01:WU02:FS02:0xa4:Completed 52500 out of 250000 steps (21%)
17:22:22:WU02:FS02:0xa4:Completed 55000 out of 250000 steps (22%)
17:23:42:WU02:FS02:0xa4:Completed 57500 out of 250000 steps (23%)
17:24:59:WU00:FS00:0x17:Completed 1375000 out of 2500000 steps (55%)
17:25:04:WU02:FS02:0xa4:Completed 60000 out of 250000 steps (24%)
17:26:25:WU02:FS02:0xa4:Completed 62500 out of 250000 steps (25%)
17:27:46:WU02:FS02:0xa4:Completed 65000 out of 250000 steps (26%)
17:29:08:WU02:FS02:0xa4:Completed 67500 out of 250000 steps (27%)
17:30:29:WU02:FS02:0xa4:Completed 70000 out of 250000 steps (28%)
17:31:50:WU02:FS02:0xa4:Completed 72500 out of 250000 steps (29%)
17:33:11:WU02:FS02:0xa4:Completed 75000 out of 250000 steps (30%)
17:34:33:WU02:FS02:0xa4:Completed 77500 out of 250000 steps (31%)
17:35:34:WU04:FS01:0x17:Completed 1250000 out of 2500000 steps (50%)
17:35:53:WU02:FS02:0xa4:Completed 80000 out of 250000 steps (32%)
17:37:14:WU02:FS02:0xa4:Completed 82500 out of 250000 steps (33%)
17:38:34:WU02:FS02:0xa4:Completed 85000 out of 250000 steps (34%)
17:39:55:WU02:FS02:0xa4:Completed 87500 out of 250000 steps (35%)
17:41:02:WU00:FS00:0x17:Completed 1400000 out of 2500000 steps (56%)
17:41:14:WU02:FS02:0xa4:Completed 90000 out of 250000 steps (36%)
17:42:35:WU02:FS02:0xa4:Completed 92500 out of 250000 steps (37%)
17:43:56:WU02:FS02:0xa4:Completed 95000 out of 250000 steps (38%)
17:45:17:WU02:FS02:0xa4:Completed 97500 out of 250000 steps (39%)
17:46:37:WU02:FS02:0xa4:Completed 100000 out of 250000 steps (40%)
17:47:56:WU02:FS02:0xa4:Completed 102500 out of 250000 steps (41%)
17:49:16:WU02:FS02:0xa4:Completed 105000 out of 250000 steps (42%)
17:50:35:WU02:FS02:0xa4:Completed 107500 out of 250000 steps (43%)
17:51:55:WU02:FS02:0xa4:Completed 110000 out of 250000 steps (44%)
17:53:06:WU04:FS01:0x17:Completed 1275000 out of 2500000 steps (51%)
17:53:15:WU02:FS02:0xa4:Completed 112500 out of 250000 steps (45%)
17:54:35:WU02:FS02:0xa4:Completed 115000 out of 250000 steps (46%)
17:55:54:WU02:FS02:0xa4:Completed 117500 out of 250000 steps (47%)
17:57:13:WU02:FS02:0xa4:Completed 120000 out of 250000 steps (48%)
17:57:24:WU00:FS00:0x17:Completed 1425000 out of 2500000 steps (57%)
17:58:33:WU02:FS02:0xa4:Completed 122500 out of 250000 steps (49%)
17:59:53:WU02:FS02:0xa4:Completed 125000 out of 250000 steps (50%)
18:01:14:WU02:FS02:0xa4:Completed 127500 out of 250000 steps (51%)
18:02:34:WU02:FS02:0xa4:Completed 130000 out of 250000 steps (52%)
18:03:54:WU02:FS02:0xa4:Completed 132500 out of 250000 steps (53%)
18:05:15:WU02:FS02:0xa4:Completed 135000 out of 250000 steps (54%)
18:06:34:WU02:FS02:0xa4:Completed 137500 out of 250000 steps (55%)
18:07:55:WU02:FS02:0xa4:Completed 140000 out of 250000 steps (56%)
18:09:15:WU02:FS02:0xa4:Completed 142500 out of 250000 steps (57%)
18:10:18:WU04:FS01:0x17:Completed 1300000 out of 2500000 steps (52%)
18:10:36:WU02:FS02:0xa4:Completed 145000 out of 250000 steps (58%)
18:11:56:WU02:FS02:0xa4:Completed 147500 out of 250000 steps (59%)
18:13:18:WU02:FS02:0xa4:Completed 150000 out of 250000 steps (60%)
18:13:29:WU00:FS00:0x17:Completed 1450000 out of 2500000 steps (58%)
18:14:41:WU02:FS02:0xa4:Completed 152500 out of 250000 steps (61%)
18:16:02:WU02:FS02:0xa4:Completed 155000 out of 250000 steps (62%)
18:17:23:WU02:FS02:0xa4:Completed 157500 out of 250000 steps (63%)
18:18:42:WU02:FS02:0xa4:Completed 160000 out of 250000 steps (64%)
18:20:02:WU02:FS02:0xa4:Completed 162500 out of 250000 steps (65%)
18:21:24:WU02:FS02:0xa4:Completed 165000 out of 250000 steps (66%)
18:22:43:WU02:FS02:0xa4:Completed 167500 out of 250000 steps (67%)
18:24:03:WU02:FS02:0xa4:Completed 170000 out of 250000 steps (68%)
18:25:22:WU02:FS02:0xa4:Completed 172500 out of 250000 steps (69%)
18:26:42:WU02:FS02:0xa4:Completed 175000 out of 250000 steps (70%)
18:27:51:WU04:FS01:0x17:Completed 1325000 out of 2500000 steps (53%)
18:28:03:WU02:FS02:0xa4:Completed 177500 out of 250000 steps (71%)
18:29:24:WU02:FS02:0xa4:Completed 180000 out of 250000 steps (72%)
18:29:48:WU00:FS00:0x17:Completed 1475000 out of 2500000 steps (59%)
18:30:43:WU02:FS02:0xa4:Completed 182500 out of 250000 steps (73%)
18:32:03:WU02:FS02:0xa4:Completed 185000 out of 250000 steps (74%)
18:33:24:WU02:FS02:0xa4:Completed 187500 out of 250000 steps (75%)
18:34:46:WU02:FS02:0xa4:Completed 190000 out of 250000 steps (76%)
18:36:07:WU02:FS02:0xa4:Completed 192500 out of 250000 steps (77%)
18:37:28:WU02:FS02:0xa4:Completed 195000 out of 250000 steps (78%)
18:38:49:WU02:FS02:0xa4:Completed 197500 out of 250000 steps (79%)
18:40:09:WU02:FS02:0xa4:Completed 200000 out of 250000 steps (80%)
18:41:30:WU02:FS02:0xa4:Completed 202500 out of 250000 steps (81%)
18:42:51:WU02:FS02:0xa4:Completed 205000 out of 250000 steps (82%)
18:44:12:WU02:FS02:0xa4:Completed 207500 out of 250000 steps (83%)
18:45:02:WU04:FS01:0x17:Completed 1350000 out of 2500000 steps (54%)
18:45:32:WU02:FS02:0xa4:Completed 210000 out of 250000 steps (84%)
18:45:53:WU00:FS00:0x17:Completed 1500000 out of 2500000 steps (60%)
18:46:54:WU02:FS02:0xa4:Completed 212500 out of 250000 steps (85%)
18:48:16:WU02:FS02:0xa4:Completed 215000 out of 250000 steps (86%)
18:49:37:WU02:FS02:0xa4:Completed 217500 out of 250000 steps (87%)
18:50:58:WU02:FS02:0xa4:Completed 220000 out of 250000 steps (88%)
18:52:19:WU02:FS02:0xa4:Completed 222500 out of 250000 steps (89%)
18:53:40:WU02:FS02:0xa4:Completed 225000 out of 250000 steps (90%)
18:55:01:WU02:FS02:0xa4:Completed 227500 out of 250000 steps (91%)
18:56:23:WU02:FS02:0xa4:Completed 230000 out of 250000 steps (92%)
18:57:44:WU02:FS02:0xa4:Completed 232500 out of 250000 steps (93%)
18:59:06:WU02:FS02:0xa4:Completed 235000 out of 250000 steps (94%)
19:00:26:WU02:FS02:0xa4:Completed 237500 out of 250000 steps (95%)
19:01:47:WU02:FS02:0xa4:Completed 240000 out of 250000 steps (96%)
19:02:12:WU00:FS00:0x17:Completed 1525000 out of 2500000 steps (61%)
19:02:36:WU04:FS01:0x17:Completed 1375000 out of 2500000 steps (55%)
19:03:09:WU02:FS02:0xa4:Completed 242500 out of 250000 steps (97%)
19:04:30:WU02:FS02:0xa4:Completed 245000 out of 250000 steps (98%)
19:04:31:WU01:FS02:Connecting to assign3.stanford.edu:8080
19:04:31:WU01:FS02:News: Welcome to Folding@Home
19:04:31:WU01:FS02:Assigned to work server 128.143.231.202
19:04:31:WU01:FS02:Requesting new work unit for slot 02: RUNNING cpu:7 from 128.143.231.202
19:04:31:WU01:FS02:Connecting to 128.143.231.202:8080
19:04:33:WU01:FS02
ownloading 3.67MiB
19:04:35:WU01:FS02
ownload complete
19:04:35:WU01:FS02:Received Unit: id:01 state
OWNLOAD error:NO_ERROR project:8574 run:0 clone:7 gen:79 core:0xa3 unit:0x000004560a3b1e5951226017d4f6ff88
19:05:52:WU02:FS02:0xa4:Completed 247500 out of 250000 steps (99%)
19:07:14:WU02:FS02:0xa4:Completed 250000 out of 250000 steps (100%)
ynamicWrapper: Finished Work Unit: sleep=10000
19:07:24:WU02:FS02:0xa4:
19:07:24:WU02:FS02:0xa4:Finished Work Unit:
19:07:24:WU02:FS02:0xa4:- Reading up to 1567212 from \"02/wudata_01.trr\": Read 1567212
19:07:24:WU02:FS02:0xa4:trr file hash check passed.
19:07:24:WU02:FS02:0xa4:- Reading up to 1758580 from \"02/wudata_01.xtc\": Read 1758580
19:07:24:WU02:FS02:0xa4:xtc file hash check passed.
19:07:24:WU02:FS02:0xa4:edr file hash check passed.
19:07:24:WU02:FS02:0xa4:logfile size: 27019
19:07:24:WU02:FS02:0xa4:Leaving Run
19:07:26:WU02:FS02:0xa4:- Writing 3362239 bytes of core data to disk...
19:07:27:WU02:FS02:0xa4
one: 3361727 -> 3243848 (compressed to 96.4 percent)
19:07:27:WU02:FS02:0xa4: ... Done.
19:07:27:WU02:FS02:FahCore returned: FINISHED_UNIT (100 = 0x64)
19:07:27:WU02:FS02:Sending unit results: id:02 state:SEND error:NO_ERROR project:8702 run:42 clone:55 gen:3 core:0xa4 unit:0x000000036652edb351c6a5149b882353
19:07:27:WU02:FS02:Uploading 3.09MiB to 171.67.108.35
19:07:27:WU02:FS02:Connecting to 171.67.108.35:8080
19:07:27:WU01:FS02:Starting
19:07:27:WU01:FS02:Running FahCore: \"C:\\Program Files (x86)\\FAHClient/FAHCoreWrapper.exe\" C:/Users/Brad/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/Core_a3.fah/FahCore_a3.exe -dir 01 -suffix 01 -version 703 -lifeline 2208 -checkpoint 15 -np 7
19:07:27:WU01:FS02:Started FahCore on PID 8968
19:07:27:WU01:FS02:Core PID:6984
19:07:27:WU01:FS02:FahCore 0xa3 started
19:07:27:WU01:FS02:0xa3:
19:07:27:WU01:FS02:0xa3:*------------------------------*
19:07:27:WU01:FS02:0xa3:Folding@Home Gromacs SMP Core
19:07:27:WU01:FS02:0xa3:Version 2.27 (Dec. 15, 2010)
19:07:27:WU01:FS02:0xa3:- Looking at optimizations...
19:07:27:WU01:FS02:0xa3:- Created dyn
19:07:27:WU01:FS02:0xa3:- Files status OK
19:07:27:WU01:FS02:0xa3:- Expanded 3847686 -> 4382420 (decompressed 113.8 percent)
19:07:27:WU01:FS02:0xa3:Called DecompressByteArray: compressed_data_size=3847686 data_size=4382420, decompressed_data_size=4382420 diff=0
19:07:27:WU01:FS02:0xa3:- Digital signature verified
roject: 8574 (Run 0, Clone 7, Gen 79)
19:07:27:WU01:FS02:0xa3:Assembly optimizations on if available.
19:07:27:WU01:FS02:0xa3:Entering M.D.
19:07:33:WU02:FS02:Upload 20.20%
19:07:33:WU01:FS02:0xa3:Mapping NT from 7 to 7
19:07:34:WU01:FS02:0xa3:Completed 0 out of 500000 steps (0%)
19:07:39:WU02:FS02:Upload 38.38%
19:07:45:WU02:FS02:Upload 54.54%
19:07:51:WU02:FS02:Upload 70.70%
19:07:57:WU02:FS02:Upload 88.88%
19:08:02:WU02:FS02:Upload complete
19:08:02:WU02:FS02:Server responded WORK_ACK (400)
19:08:02:WU02:FS02:Final credit estimate, 1547.00 points
19:08:02:WU02:FS02:Cleaning up
19:17:12:WU01:FS02:0xa3:Completed 5000 out of 500000 steps (1%)
19:18:11:WU00:FS00:0x17:Completed 1550000 out of 2500000 steps (62%)
19:19:50:WU04:FS01:0x17:Completed 1400000 out of 2500000 steps (56%)
19:26:52:WU01:FS02:0xa3:Completed 10000 out of 500000 steps (2%)
19:34:34:WU00:FS00:0x17:Completed 1575000 out of 2500000 steps (63%)
19:36:27:WU01:FS02:0xa3:Completed 15000 out of 500000 steps (3%)
19:37:20:WU04:FS01:0x17:Completed 1425000 out of 2500000 steps (57%)
19:46:03:WU01:FS02:0xa3:Completed 20000 out of 500000 steps (4%)
19:50:34:WU00:FS00:0x17:Completed 1600000 out of 2500000 steps (64%)
19:54:32:WU04:FS01:0x17:Completed 1450000 out of 2500000 steps (58%)
19:55:41:WU01:FS02:0xa3:Completed 25000 out of 500000 steps (5%)
20:05:16:WU01:FS02:0xa3:Completed 30000 out of 500000 steps (6%)
20:06:58:WU00:FS00:0x17:Completed 1625000 out of 2500000 steps (65%)
20:12:03:WU04:FS01:0x17:Completed 1475000 out of 2500000 steps (59%)
20:14:52:WU01:FS02:0xa3:Completed 35000 out of 500000 steps (7%)
20:22:59:WU00:FS00:0x17:Completed 1650000 out of 2500000 steps (66%)
20:24:27:WU01:FS02:0xa3:Completed 40000 out of 500000 steps (8%)
20:29:16:WU04:FS01:0x17:Completed 1500000 out of 2500000 steps (60%)
20:34:01:WU01:FS02:0xa3:Completed 45000 out of 500000 steps (9%)
20:39:21:WU00:FS00:0x17:Completed 1675000 out of 2500000 steps (67%)
20:43:38:WU01:FS02:0xa3:Completed 50000 out of 500000 steps (10%)
20:46:49:WU04:FS01:0x17:Completed 1525000 out of 2500000 steps (61%)
20:53:06:WU01:FS02:0xa3:Completed 55000 out of 500000 steps (11%)
20:55:19:WU00:FS00:0x17:Completed 1700000 out of 2500000 steps (68%)
21:02:41:WU01:FS02:0xa3:Completed 60000 out of 500000 steps (12%)
21:04:05:WU04:FS01:0x17:Completed 1550000 out of 2500000 steps (62%)
21:11:44:WU00:FS00:0x17:Completed 1725000 out of 2500000 steps (69%)
21:12:15:WU01:FS02:0xa3:Completed 65000 out of 500000 steps (13%)
21:21:41:WU04:FS01:0x17:Completed 1575000 out of 2500000 steps (63%)
21:21:48:WU01:FS02:0xa3:Completed 70000 out of 500000 steps (14%)
21:27:43:WU00:FS00:0x17:Completed 1750000 out of 2500000 steps (70%)
21:31:25:WU01:FS02:0xa3:Completed 75000 out of 500000 steps (15%)
21:38:57:WU04:FS01:0x17:Completed 1600000 out of 2500000 steps (64%)
21:41:00:WU01:FS02:0xa3:Completed 80000 out of 500000 steps (16%)
21:44:06:WU00:FS00:0x17:Completed 1775000 out of 2500000 steps (71%)
21:50:38:WU01:FS02:0xa3:Completed 85000 out of 500000 steps (17%)
21:56:28:WU04:FS01:0x17:Completed 1625000 out of 2500000 steps (65%)
22:00:07:WU00:FS00:0x17:Completed 1800000 out of 2500000 steps (72%)
22:00:12:WU01:FS02:0xa3:Completed 90000 out of 500000 steps (18%)
22:09:47:WU01:FS02:0xa3:Completed 95000 out of 500000 steps (19%)
22:13:43:WU04:FS01:0x17:Completed 1650000 out of 2500000 steps (66%)
22:16:31:WU00:FS00:0x17:Completed 1825000 out of 2500000 steps (73%)
22:19:24:WU01:FS02:0xa3:Completed 100000 out of 500000 steps (20%)
22:28:55:WU01:FS02:0xa3:Completed 105000 out of 500000 steps (21%)
22:31:15:WU04:FS01:0x17:Completed 1675000 out of 2500000 steps (67%)
22:32:32:WU00:FS00:0x17:Completed 1850000 out of 2500000 steps (74%)
22:38:35:WU01:FS02:0xa3:Completed 110000 out of 500000 steps (22%)
22:48:12:WU01:FS02:0xa3:Completed 115000 out of 500000 steps (23%)
22:48:28:WU04:FS01:0x17:Completed 1700000 out of 2500000 steps (68%)
22:48:54:WU00:FS00:0x17:Completed 1875000 out of 2500000 steps (75%)
22:57:45:WU01:FS02:0xa3:Completed 120000 out of 500000 steps (24%)
23:04:53:WU00:FS00:0x17:Completed 1900000 out of 2500000 steps (76%)
23:06:02:WU04:FS01:0x17:Completed 1725000 out of 2500000 steps (69%)
23:07:22:WU01:FS02:0xa3:Completed 125000 out of 500000 steps (25%)
23:17:00:WU01:FS02:0xa3:Completed 130000 out of 500000 steps (26%)
23:21:12:WU00:FS00:0x17:Completed 1925000 out of 2500000 steps (77%)
23:23:15:WU04:FS01:0x17:Completed 1750000 out of 2500000 steps (70%)
23:26:33:WU01:FS02:0xa3:Completed 135000 out of 500000 steps (27%)
23:36:09:WU01:FS02:0xa3:Completed 140000 out of 500000 steps (28%)
23:37:17:WU00:FS00:0x17:Completed 1950000 out of 2500000 steps (78%)
23:40:52:WU04:FS01:0x17:Completed 1775000 out of 2500000 steps (71%)
23:45:41:WU01:FS02:0xa3:Completed 145000 out of 500000 steps (29%)
23:53:39:WU00:FS00:0x17:Completed 1975000 out of 2500000 steps (79%)
23:55:12:WU01:FS02:0xa3:Completed 150000 out of 500000 steps (30%)
23:58:08:WU04:FS01:0x17:Completed 1800000 out of 2500000 steps (72%)
00:04:48:WU01:FS02:0xa3:Completed 155000 out of 500000 steps (31%)
00:09:44:WU00:FS00:0x17:Completed 2000000 out of 2500000 steps (80%)
00:14:27:WU01:FS02:0xa3:Completed 160000 out of 500000 steps (32%)
00:15:48:WU04:FS01:0x17:Completed 1825000 out of 2500000 steps (73%)
00:24:08:WU01:FS02:0xa3:Completed 165000 out of 500000 steps (33%)
00:26:05:WU00:FS00:0x17:Completed 2025000 out of 2500000 steps (81%)
00:33:04:WU04:FS01:0x17:Completed 1850000 out of 2500000 steps (74%)
00:33:45:WU01:FS02:0xa3:Completed 170000 out of 500000 steps (34%)
00:42:11:WU00:FS00:0x17:Completed 2050000 out of 2500000 steps (82%)
00:43:03:WU01:FS02:0xa3:Completed 175000 out of 500000 steps (35%)
00:50:49:WU04:FS01:0x17:Completed 1875000 out of 2500000 steps (75%)
00:52:17:WU01:FS02:0xa3:Completed 180000 out of 500000 steps (36%)
00:58:29:WU00:FS00:0x17:Completed 2075000 out of 2500000 steps (83%)
01:01:33:WU01:FS02:0xa3:Completed 185000 out of 500000 steps (37%)
01:08:09:WU04:FS01:0x17:Completed 1900000 out of 2500000 steps (76%)
01:10:49:WU01:FS02:0xa3:Completed 190000 out of 500000 steps (38%)
01:14:34:WU00:FS00:0x17:Completed 2100000 out of 2500000 steps (84%)
01:20:05:WU01:FS02:0xa3:Completed 195000 out of 500000 steps (39%)
01:25:51:WU04:FS01:0x17:Completed 1925000 out of 2500000 steps (77%)
01:29:26:WU01:FS02:0xa3:Completed 200000 out of 500000 steps (40%)
01:30:52:WU00:FS00:0x17:Completed 2125000 out of 2500000 steps (85%)
01:39:12:WU01:FS02:0xa3:Completed 205000 out of 500000 steps (41%)
01:43:10:WU04:FS01:0x17:Completed 1950000 out of 2500000 steps (78%)
01:46:55:WU00:FS00:0x17:Completed 2150000 out of 2500000 steps (86%)
01:49:06:WU01:FS02:0xa3:Completed 210000 out of 500000 steps (42%)
01:58:57:WU01:FS02:0xa3:Completed 215000 out of 500000 steps (43%)
02:00:58:WU04:FS01:0x17:Completed 1975000 out of 2500000 steps (79%)
02:03:18:WU00:FS00:0x17:Completed 2175000 out of 2500000 steps (87%)
02:09:00:WU01:FS02:0xa3:Completed 220000 out of 500000 steps (44%)
02:18:21:WU04:FS01:0x17:Completed 2000000 out of 2500000 steps (80%)
02:19:08:WU01:FS02:0xa3:Completed 225000 out of 500000 steps (45%)
02:19:26:WU00:FS00:0x17:Completed 2200000 out of 2500000 steps (88%)
******************************* Date: 2013-06-25 *******************************
02:29:17:WU01:FS02:0xa3:Completed 230000 out of 500000 steps (46%)
02:35:46:WU00:FS00:0x17:Completed 2225000 out of 2500000 steps (89%)
02:36:12:WU04:FS01:0x17:Completed 2025000 out of 2500000 steps (81%)
02:39:33:WU01:FS02:0xa3:Completed 235000 out of 500000 steps (47%)
02:49:07:WU01:FS02:0xa3:Completed 240000 out of 500000 steps (48%)
02:51:47:WU00:FS00:0x17:Completed 2250000 out of 2500000 steps (90%)
02:53:31:WU04:FS01:0x17:Completed 2050000 out of 2500000 steps (82%)
02:58:32:WU01:FS02:0xa3:Completed 245000 out of 500000 steps (49%)
03:07:54:WU01:FS02:0xa3:Completed 250000 out of 500000 steps (50%)
03:08:09:WU00:FS00:0x17:Completed 2275000 out of 2500000 steps (91%)
03:11:00:WU04:FS01:0x17:Completed 2075000 out of 2500000 steps (83%)
03:17:15:WU01:FS02:0xa3:Completed 255000 out of 500000 steps (51%)
03:24:08:WU00:FS00:0x17:Completed 2300000 out of 2500000 steps (92%)
03:26:41:WU01:FS02:0xa3:Completed 260000 out of 500000 steps (52%)
03:28:11:WU04:FS01:0x17:Completed 2100000 out of 2500000 steps (84%)
03:36:09:WU01:FS02:0xa3:Completed 265000 out of 500000 steps (53%)
03:40:31:WU00:FS00:0x17:Completed 2325000 out of 2500000 steps (93%)
03:45:36:WU01:FS02:0xa3:Completed 270000 out of 500000 steps (54%)
03:45:44:WU04:FS01:0x17:Completed 2125000 out of 2500000 steps (85%)
03:54:59:WU01:FS02:0xa3:Completed 275000 out of 500000 steps (55%)
03:56:30:WU00:FS00:0x17:Completed 2350000 out of 2500000 steps (94%)
04:02:57:WU04:FS01:0x17:Completed 2150000 out of 2500000 steps (86%)
04:04:26:WU01:FS02:0xa3:Completed 280000 out of 500000 steps (56%)
04:12:53:WU00:FS00:0x17:Completed 2375000 out of 2500000 steps (95%)
04:14:00:WU01:FS02:0xa3:Completed 285000 out of 500000 steps (57%)
04:20:29:WU04:FS01:0x17:Completed 2175000 out of 2500000 steps (87%)
04:23:22:WU01:FS02:0xa3:Completed 290000 out of 500000 steps (58%)
04:28:53:WU00:FS00:0x17:Completed 2400000 out of 2500000 steps (96%)
04:32:49:WU01:FS02:0xa3:Completed 295000 out of 500000 steps (59%)
04:37:43:WU04:FS01:0x17:Completed 2200000 out of 2500000 steps (88%)
04:42:15:WU01:FS02:0xa3:Completed 300000 out of 500000 steps (60%)
04:45:17:WU00:FS00:0x17:Completed 2425000 out of 2500000 steps (97%)
04:52:00:WU01:FS02:0xa3:Completed 305000 out of 500000 steps (61%)
04:55:17:WU04:FS01:0x17:Completed 2225000 out of 2500000 steps (89%)
17:45:43:************************* Folding@home Client *************************
17:45:43: Website: http://folding.stanford.edu/
17:45:43: Copyright: (c) 2009-2013 Stanford University
17:45:43: Author: Joseph Coffland <[email protected]>
17:45:43: Args:
17:45:43: Config: C:/Users/Brad/AppData/Roaming/FAHClient/config.xml
17:45:43:******************************** Build ********************************
17:45:43: Version: 7.3.6
17:45:43: Date: Feb 18 2013
17:45:43: Time: 15:25:17
17:45:43: SVN Rev: 3923
17:45:43: Branch: fah/trunk/client
17:45:43: Compiler: Intel(R) C++ MSVC 1500 mode 1200
17:45:43: Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
17:45:43: /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
17:45:43: Platform: win32 XP
17:45:43: Bits: 32
17:45:43: Mode: Release
17:45:43:******************************* System ********************************
17:45:43: CPU: Intel(R) Core(TM) i7-2700K CPU @ 3.50GHz
17:45:43: CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
17:45:43: CPUs: 8
17:45:43: Memory: 15.95GiB
17:45:43: Free Memory: 14.63GiB
17:45:43: Threads: WINDOWS_THREADS
17:45:43: Has Battery: false
17:45:43: On Battery: false
17:45:43: UTC offset: -7
17:45:43: PID: 2208
17:45:43: CWD: C:/Users/Brad/AppData/Roaming/FAHClient
17:45:43: OS: Windows 7 Ultimate
17:45:43: OS Arch: AMD64
17:45:43: GPUs: 2
17:45:43: GPU 0: ATI:4 Barts XT [ATI Radeon HD 6800 Series]
17:45:43: GPU 1: ATI:4 Barts XT [ATI Radeon HD 6800 Series]
17:45:43: CUDA: Not detected
17:45:43:Win32 Service: false
17:45:43:***********************************************************************
17:45:43:<config>
17:45:43: <!-- Folding Slot Configuration -->
17:45:43: <power v='full'/>
17:45:43:
17:45:43: <!-- Network -->
17:45:43: <proxy v=':8080'/>
17:45:43:
17:45:43: <!-- User Information -->
17:45:43: <passkey v='********************************'/>
17:45:43: <team v='32'/>
17:45:43: <user v='Rustyfender'/>
17:45:43:
17:45:43: <!-- Folding Slots -->
17:45:43: <slot id='2' type='CPU'>
17:45:43: <cpus v='7'/>
17:45:43: </slot>
17:45:43: <slot id='0' type='GPU'>
17:45:43: <client-type v='beta'/>
17:45:43: </slot>
17:45:43: <slot id='1' type='GPU'>
17:45:43: </slot>
17:45:43:</config>
17:45:43:Trying to access database...
17:45:43:Successfully acquired database lock
17:45:43:Enabled folding slot 02: READY cpu:7
17:45:43:Enabled folding slot 00: READY gpu:0:Barts XT [ATI Radeon HD 6800 Series]
17:45:43:Enabled folding slot 01: READY gpu:1:Barts XT [ATI Radeon HD 6800 Series]
17:45:43:WU00:FS01:Starting
17:45:43:WU00:FS01:Running FahCore: \"C:\\Program Files (x86)\\FAHClient/FAHCoreWrapper.exe\" C:/Users/Brad/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/beta/Core_17.fah/FahCore_17.exe -dir 00 -suffix 01 -version 703 -lifeline 2208 -checkpoint 15 -gpu 1 -gpu-vendor ati
17:45:43:WU00:FS01:Started FahCore on PID 3596
17:45:43:WU00:FS01:Core PID:3636
17:45:43:WU00:FS01:FahCore 0x17 started
17:45:43:WU03:FS02:Starting
17:45:43:WU03:FS02:Running FahCore: \"C:\\Program Files (x86)\\FAHClient/FAHCoreWrapper.exe\" C:/Users/Brad/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 03 -suffix 01 -version 703 -lifeline 2208 -checkpoint 15 -np 7
17:45:43:WU03:FS02:Started FahCore on PID 3644
17:45:43:WU03:FS02:Core PID:3656
17:45:43:WU03:FS02:FahCore 0xa4 started
17:45:43:WU01:FS00:Starting
17:45:43:WU01:FS00:Running FahCore: \"C:\\Program Files (x86)\\FAHClient/FAHCoreWrapper.exe\" C:/Users/Brad/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/beta/Core_17.fah/FahCore_17.exe -dir 01 -suffix 01 -version 703 -lifeline 2208 -checkpoint 15 -gpu 0 -gpu-vendor ati
17:45:43:WU01:FS00:Started FahCore on PID 3668
17:45:43:WU01:FS00:Core PID:3680
17:45:43:WU01:FS00:FahCore 0x17 started
17:45:44:WU03:FS02:0xa4:
17:45:44:WU03:FS02:0xa4:*------------------------------*
17:45:44:WU03:FS02:0xa4:Folding@Home Gromacs GB Core
17:45:44:WU03:FS02:0xa4:Version 2.27 (Dec. 15, 2010)
17:45:44:WU03:FS02:0xa4:- Ensuring status. Please wait.
17:45:44:WU01:FS00:0x17:*********************** Log Started 2013-06-20T17:45:44Z ***********************
17:45:44:WU01:FS00:0x17:Unit: 0x0000002a028c126651a658cbd81d452c
17:45:44:WU01:FS00:0x17:CPU: 0x00000000000000000000000000000000
17:45:44:WU01:FS00:0x17:Machine: 0
17:45:44:WU00:FS01:0x17:*********************** Log Started 2013-06-20T17:45:44Z ***********************
17:45:44:WU00:FS01:0x17:Unit: 0x0000001b028c126651a68124a879bd5a
17:45:44:WU00:FS01:0x17:CPU: 0x00000000000000000000000000000000
17:45:44:WU00:FS01:0x17:Machine: 1
17:45:45:WU00:FS01:0x17: Found a checkpoint file
17:45:45:WU01:FS00:0x17: Found a checkpoint file
17:45:53:WU03:FS02:0xa4:- Looking at optimizations...
17:45:53:WU03:FS02:0xa4:- Working with standard loops on this execution.
17:45:53:WU03:FS02:0xa4:- Previous termination of core was improper.
17:45:53:WU03:FS02:0xa4:- Files status OK
17:45:53:WU03:FS02:0xa4:- Expanded 2079299 -> 5386224 (decompressed 259.0 percent)
17:45:53:WU03:FS02:0xa4:Called DecompressByteArray: compressed_data_size=2079299 data_size=5386224, decompressed_data_size=5386224 diff=0
17:45:53:WU03:FS02:0xa4:- Digital signature verified
17:45:53:WU03:FS02:0xa4:Entering M.D.
17:45:59:WU03:FS02:0xa4:Using Gromacs checkpoints
17:46:00:WU03:FS02:0xa4:Mapping NT from 7 to 7
17:48:07:WU03:FS02:0xa4:Resuming from checkpoint
17:48:07:WU03:FS02:0xa4:Verified 03/wudata_01.log
17:48:07:WU03:FS02:0xa4:Verified 03/wudata_01.trr
17:48:07:WU03:FS02:0xa4:Verified 03/wudata_01.xtc
17:48:07:WU03:FS02:0xa4:Verified 03/wudata_01.edr
17:48:07:WU03:FS02:0xa4:Completed 76390 out of 1500000 steps (5%)
17:48:08:WARNING:WU03:FS02
17:48:33:WU01:FS00:0x17:Completed 1650000 out of 2500000 steps (66%)
17:48:43:WU00:FS01:0x17:Completed 1400000 out of 2500000 steps (56%)
17:56:06:WU03:FS02:0xa4:Completed 90000 out of 1500000 steps (6%)
18:04:17:WU03:FS02:0xa4:Completed 105000 out of 1500000 steps (7%)
18:05:15:WU00:FS01:0x17:Completed 1425000 out of 2500000 steps (57%)
18:05:22:WU01:FS00:0x17:Completed 1675000 out of 2500000 steps (67%)
18:12:30:WU03:FS02:0xa4:Completed 120000 out of 1500000 steps (8%)
18:20:41:WU03:FS02:0xa4:Completed 135000 out of 1500000 steps (9%)
18:21:18:WU00:FS01:0x17:Completed 1450000 out of 2500000 steps (58%)
18:21:28:WU01:FS00:0x17:Completed 1700000 out of 2500000 steps (68%)
18:28:58:WU03:FS02:0xa4:Completed 150000 out of 1500000 steps (10%)
18:37:14:WU03:FS02:0xa4:Completed 165000 out of 1500000 steps (11%)
18:37:49:WU00:FS01:0x17:Completed 1475000 out of 2500000 steps (59%)
18:37:58:WU01:FS00:0x17:Completed 1725000 out of 2500000 steps (69%)
18:45:27:WU03:FS02:0xa4:Completed 180000 out of 1500000 steps (12%)
18:53:39:WU03:FS02:0xa4:Completed 195000 out of 1500000 steps (13%)
18:53:52:WU00:FS01:0x17:Completed 1500000 out of 2500000 steps (60%)
18:54:04:WU01:FS00:0x17:Completed 1750000 out of 2500000 steps (70%)
19:01:54:WU03:FS02:0xa4:Completed 210000 out of 1500000 steps (14%)
19:10:08:WU03:FS02:0xa4:Completed 225000 out of 1500000 steps (15%)
19:10:22:WU00:FS01:0x17:Completed 1525000 out of 2500000 steps (61%)
19:10:33:WU01:FS00:0x17:Completed 1775000 out of 2500000 steps (71%)
19:18:21:WU03:FS02:0xa4:Completed 240000 out of 1500000 steps (16%)
19:26:25:WU00:FS01:0x17:Completed 1550000 out of 2500000 steps (62%)
19:26:36:WU03:FS02:0xa4:Completed 255000 out of 1500000 steps (17%)
19:26:40:WU01:FS00:0x17:Completed 1800000 out of 2500000 steps (72%)
19:34:46:WU03:FS02:0xa4:Completed 270000 out of 1500000 steps (18%)
19:42:54:WU00:FS01:0x17:Completed 1575000 out of 2500000 steps (63%)
19:42:56:WU03:FS02:0xa4:Completed 285000 out of 1500000 steps (19%)
19:43:09:WU01:FS00:0x17:Completed 1825000 out of 2500000 steps (73%)
19:51:09:WU03:FS02:0xa4:Completed 300000 out of 1500000 steps (20%)
19:58:54:WU00:FS01:0x17:Completed 1600000 out of 2500000 steps (64%)
19:59:12:WU01:FS00:0x17:Completed 1850000 out of 2500000 steps (74%)
19:59:20:WU03:FS02:0xa4:Completed 315000 out of 1500000 steps (21%)
20:07:34:WU03:FS02:0xa4:Completed 330000 out of 1500000 steps (22%)
20:15:17:WU00:FS01:0x17:Completed 1625000 out of 2500000 steps (65%)
20:15:34:WU01:FS00:0x17:Completed 1875000 out of 2500000 steps (75%)
20:15:48:WU03:FS02:0xa4:Completed 345000 out of 1500000 steps (23%)
20:24:04:WU03:FS02:0xa4:Completed 360000 out of 1500000 steps (24%)
20:31:18:WU00:FS01:0x17:Completed 1650000 out of 2500000 steps (66%)
20:31:39:WU01:FS00:0x17:Completed 1900000 out of 2500000 steps (76%)
20:32:22:WU03:FS02:0xa4:Completed 375000 out of 1500000 steps (25%)
20:40:32:WU03:FS02:0xa4:Completed 390000 out of 1500000 steps (26%)
20:47:43:WU00:FS01:0x17:Completed 1675000 out of 2500000 steps (67%)
20:48:03:WU01:FS00:0x17:Completed 1925000 out of 2500000 steps (77%)
20:48:47:WU03:FS02:0xa4:Completed 405000 out of 1500000 steps (27%)
20:56:56:WU03:FS02:0xa4:Completed 420000 out of 1500000 steps (28%)
21:03:48:WU00:FS01:0x17:Completed 1700000 out of 2500000 steps (68%)
21:04:11:WU01:FS00:0x17:Completed 1950000 out of 2500000 steps (78%)
21:05:11:WU03:FS02:0xa4:Completed 435000 out of 1500000 steps (29%)
21:13:24:WU03:FS02:0xa4:Completed 450000 out of 1500000 steps (30%)
21:20:14:WU00:FS01:0x17:Completed 1725000 out of 2500000 steps (69%)
21:20:36:WU01:FS00:0x17:Completed 1975000 out of 2500000 steps (79%)
21:21:48:WU03:FS02:0xa4:Completed 465000 out of 1500000 steps (31%)
21:30:01:WU03:FS02:0xa4:Completed 480000 out of 1500000 steps (32%)
21:36:18:WU00:FS01:0x17:Completed 1750000 out of 2500000 steps (70%)
21:36:43:WU01:FS00:0x17:Completed 2000000 out of 2500000 steps (80%)
21:38:18:WU03:FS02:0xa4:Completed 495000 out of 1500000 steps (33%)
21:46:33:WU03:FS02:0xa4:Completed 510000 out of 1500000 steps (34%)
21:52:41:WU00:FS01:0x17:Completed 1775000 out of 2500000 steps (71%)
21:53:03:WU01:FS00:0x17:Completed 2025000 out of 2500000 steps (81%)
21:54:48:WU03:FS02:0xa4:Completed 525000 out of 1500000 steps (35%)
22:03:03:WU03:FS02:0xa4:Completed 540000 out of 1500000 steps (36%)
22:08:43:WU00:FS01:0x17:Completed 1800000 out of 2500000 steps (72%)
22:09:08:WU01:FS00:0x17:Completed 2050000 out of 2500000 steps (82%)
22:11:21:WU03:FS02:0xa4:Completed 555000 out of 1500000 steps (37%)
22:19:32:WU03:FS02:0xa4:Completed 570000 out of 1500000 steps (38%)
22:25:06:WU00:FS01:0x17:Completed 1825000 out of 2500000 steps (73%)
22:25:29:WU01:FS00:0x17:Completed 2075000 out of 2500000 steps (83%)
22:27:46:WU03:FS02:0xa4:Completed 585000 out of 1500000 steps (39%)
22:35:59:WU03:FS02:0xa4:Completed 600000 out of 1500000 steps (40%)
22:41:10:WU00:FS01:0x17:Completed 1850000 out of 2500000 steps (74%)
22:41:34:WU01:FS00:0x17:Completed 2100000 out of 2500000 steps (84%)
22:44:13:WU03:FS02:0xa4:Completed 615000 out of 1500000 steps (41%)
22:52:26:WU03:FS02:0xa4:Completed 630000 out of 1500000 steps (42%)
22:57:35:WU00:FS01:0x17:Completed 1875000 out of 2500000 steps (75%)
22:57:57:WU01:FS00:0x17:Completed 2125000 out of 2500000 steps (85%)
23:00:38:WU03:FS02:0xa4:Completed 645000 out of 1500000 steps (43%)
23:08:53:WU03:FS02:0xa4:Completed 660000 out of 1500000 steps (44%)
23:13:39:WU00:FS01:0x17:Completed 1900000 out of 2500000 steps (76%)
23:14:04:WU01:FS00:0x17:Completed 2150000 out of 2500000 steps (86%)
23:17:05:WU03:FS02:0xa4:Completed 675000 out of 1500000 steps (45%)
23:25:18:WU03:FS02:0xa4:Completed 690000 out of 1500000 steps (46%)
23:30:04:WU00:FS01:0x17:Completed 1925000 out of 2500000 steps (77%)
23:30:29:WU01:FS00:0x17:Completed 2175000 out of 2500000 steps (87%)
23:33:32:WU03:FS02:0xa4:Completed 705000 out of 1500000 steps (47%)
23:41:40:WU03:FS02:0xa4:Completed 720000 out of 1500000 steps (48%)
******************************* Date: 2013-06-20 *******************************
23:46:08:WU00:FS01:0x17:Completed 1950000 out of 2500000 steps (78%)
23:46:36:WU01:FS00:0x17:Completed 2200000 out of 2500000 steps (88%)
23:49:52:WU03:FS02:0xa4:Completed 735000 out of 1500000 steps (49%)
23:58:03:WU03:FS02:0xa4:Completed 750000 out of 1500000 steps (50%)
00:02:31:WU00:FS01:0x17:Completed 1975000 out of 2500000 steps (79%)
00:02:58:WU01:FS00:0x17:Completed 2225000 out of 2500000 steps (89%)
00:06:17:WU03:FS02:0xa4:Completed 765000 out of 1500000 steps (51%)
00:14:32:WU03:FS02:0xa4:Completed 780000 out of 1500000 steps (52%)
00:18:34:WU00:FS01:0x17:Completed 2000000 out of 2500000 steps (80%)
00:19:02:WU01:FS00:0x17:Completed 2250000 out of 2500000 steps (90%)
00:22:50:WU03:FS02:0xa4:Completed 795000 out of 1500000 steps (53%)
00:31:03:WU03:FS02:0xa4:Completed 810000 out of 1500000 steps (54%)
00:34:59:WU00:FS01:0x17:Completed 2025000 out of 2500000 steps (81%)
00:35:26:WU01:FS00:0x17:Completed 2275000 out of 2500000 steps (91%)
00:39:17:WU03:FS02:0xa4:Completed 825000 out of 1500000 steps (55%)
00:47:31:WU03:FS02:0xa4:Completed 840000 out of 1500000 steps (56%)
00:51:02:WU00:FS01:0x17:Completed 2050000 out of 2500000 steps (82%)
00:51:30:WU01:FS00:0x17:Completed 2300000 out of 2500000 steps (92%)
00:55:44:WU03:FS02:0xa4:Completed 855000 out of 1500000 steps (57%)
01:03:58:WU03:FS02:0xa4:Completed 870000 out of 1500000 steps (58%)
01:07:27:WU00:FS01:0x17:Completed 2075000 out of 2500000 steps (83%)
01:07:53:WU01:FS00:0x17:Completed 2325000 out of 2500000 steps (93%)
01:12:12:WU03:FS02:0xa4:Completed 885000 out of 1500000 steps (59%)
01:20:27:WU03:FS02:0xa4:Completed 900000 out of 1500000 steps (60%)
01:23:30:WU00:FS01:0x17:Completed 2100000 out of 2500000 steps (84%)
01:23:59:WU01:FS00:0x17:Completed 2350000 out of 2500000 steps (94%)
01:28:40:WU03:FS02:0xa4:Completed 915000 out of 1500000 steps (61%)
01:36:57:WU03:FS02:0xa4:Completed 930000 out of 1500000 steps (62%)
01:39:56:WU00:FS01:0x17:Completed 2125000 out of 2500000 steps (85%)
01:40:22:WU01:FS00:0x17:Completed 2375000 out of 2500000 steps (95%)
01:45:08:WU03:FS02:0xa4:Completed 945000 out of 1500000 steps (63%)
01:53:21:WU03:FS02:0xa4:Completed 960000 out of 1500000 steps (64%)
01:56:00:WU00:FS01:0x17:Completed 2150000 out of 2500000 steps (86%)
01:56:29:WU01:FS00:0x17:Completed 2400000 out of 2500000 steps (96%)
02:01:36:WU03:FS02:0xa4:Completed 975000 out of 1500000 steps (65%)
02:09:47:WU03:FS02:0xa4:Completed 990000 out of 1500000 steps (66%)
02:12:23:WU00:FS01:0x17:Completed 2175000 out of 2500000 steps (87%)
02:12:51:WU01:FS00:0x17:Completed 2425000 out of 2500000 steps (97%)
02:18:00:WU03:FS02:0xa4:Completed 1005000 out of 1500000 steps (67%)
02:26:13:WU03:FS02:0xa4:Completed 1020000 out of 1500000 steps (68%)
02:28:26:WU00:FS01:0x17:Completed 2200000 out of 2500000 steps (88%)
02:28:56:WU01:FS00:0x17:Completed 2450000 out of 2500000 steps (98%)
02:28:57:WU02:FS00:Connecting to assign-GPU.stanford.edu:80
02:28:57:WU02:FS00:News: Welcome to Folding@Home
02:28:57:WU02:FS00:Assigned to work server 171.64.65.69
02:28:57:WU02:FS00:Requesting new work unit for slot 00: RUNNING gpu:0:Barts XT [ATI Radeon HD 6800 Series] from 171.64.65.69
02:28:57:WU02:FS00:Connecting to 171.64.65.69:8080
02:28:57:WU02:FS00
02:29:00:WU02:FS00
02:29:00:WU02:FS00:Received Unit: id:02 state
02:34:32:WU03:FS02:0xa4:Completed 1035000 out of 1500000 steps (69%)
02:42:45:WU03:FS02:0xa4:Completed 1050000 out of 1500000 steps (70%)
02:44:49:WU00:FS01:0x17:Completed 2225000 out of 2500000 steps (89%)
02:45:17:WU01:FS00:0x17:Completed 2475000 out of 2500000 steps (99%)
02:50:58:WU03:FS02:0xa4:Completed 1065000 out of 1500000 steps (71%)
02:59:11:WU03:FS02:0xa4:Completed 1080000 out of 1500000 steps (72%)
03:00:52:WU00:FS01:0x17:Completed 2250000 out of 2500000 steps (90%)
03:01:22:WU01:FS00:0x17:Completed 2500000 out of 2500000 steps (100%)
03:01:40:WU01:FS00:0x17:Saving result file logfile_01.txt
03:01:40:WU01:FS00:0x17:Saving result file checkpointState.xml
03:01:42:WU01:FS00:0x17:Saving result file checkpt.crc
03:01:42:WU01:FS00:0x17:Saving result file log.txt
03:01:42:WU01:FS00:0x17:Saving result file positions.xtc
03:01:45:WU01:FS00:0x17:Folding@home Core Shutdown: FINISHED_UNIT
03:01:46:WU01:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
03:01:46:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:8900 run:226 clone:0 gen:33 core:0x17 unit:0x0000002a028c126651a658cbd81d452c
03:01:46:WU01:FS00:Uploading 12.96MiB to 171.64.65.69
03:01:46:WU01:FS00:Connecting to 171.64.65.69:8080
03:01:46:WU02:FS00:Starting
03:01:46:WU02:FS00:Running FahCore: \"C:\\Program Files (x86)\\FAHClient/FAHCoreWrapper.exe\" C:/Users/Brad/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/beta/Core_17.fah/FahCore_17.exe -dir 02 -suffix 01 -version 703 -lifeline 2208 -checkpoint 15 -gpu 0 -gpu-vendor ati
03:01:46:WU02:FS00:Started FahCore on PID 5664
03:01:46:WU02:FS00:Core PID:4660
03:01:46:WU02:FS00:FahCore 0x17 started
03:01:46:WU02:FS00:0x17:*********************** Log Started 2013-06-21T03:01:46Z ***********************
03:01:46:WU02:FS00:0x17:Unit: 0x0000000d028c126651a6cd406ad018d7
03:01:46:WU02:FS00:0x17:CPU: 0x00000000000000000000000000000000
03:01:46:WU02:FS00:0x17:Machine: 0
03:01:46:WU02:FS00:0x17:Reading tar file state.xml
03:01:46:WU02:FS00:0x17:Reading tar file system.xml
03:01:47:WU02:FS00:0x17:Reading tar file integrator.xml
03:01:47:WU02:FS00:0x17:Reading tar file core.xml
03:01:52:WU01:FS00:Upload 6.27%
03:01:58:WU01:FS00:Upload 12.06%
03:02:04:WU01:FS00:Upload 17.36%
03:02:10:WU01:FS00:Upload 22.67%
03:02:16:WU01:FS00:Upload 27.97%
03:02:22:WU01:FS00:Upload 33.27%
03:02:28:WU01:FS00:Upload 38.58%
03:02:34:WU01:FS00:Upload 43.88%
03:02:40:WU01:FS00:Upload 49.67%
03:02:46:WU01:FS00:Upload 54.97%
03:02:52:WU01:FS00:Upload 60.28%
03:02:58:WU01:FS00:Upload 65.58%
03:03:04:WU01:FS00:Upload 70.89%
03:03:10:WU01:FS00:Upload 76.19%
03:03:16:WU01:FS00:Upload 81.50%
03:03:22:WU01:FS00:Upload 87.28%
03:03:28:WU01:FS00:Upload 92.59%
03:03:34:WU01:FS00:Upload 97.89%
03:03:44:WU01:FS00:Upload complete
03:03:44:WU01:FS00:Server responded WORK_ACK (400)
03:03:44:WU01:FS00:Final credit estimate, 11961.00 points
03:03:44:WU01:FS00:Cleaning up
03:04:30:WU02:FS00:0x17:Completed 0 out of 2500000 steps (0%)
03:07:35:WU03:FS02:0xa4:Completed 1095000 out of 1500000 steps (73%)
03:15:57:WU03:FS02:0xa4:Completed 1110000 out of 1500000 steps (74%)
03:17:36:WU00:FS01:0x17:Completed 2275000 out of 2500000 steps (91%)
03:17:40:FS00
03:17:40:FS00:Shutting core down
03:17:41:WU02:FS00:0x17:WARNING:Console control signal 1 on PID 4660
03:17:41:WU02:FS00:0x17:Exiting, please wait. . .
03:17:41:WU02:FS00:0x17:Lost lifeline PID 5664, exiting
03:17:41:WU02:FS00:0x17:ERROR:103: Lost client lifeline
03:17:41:WU02:FS00:0x17:Folding@home Core Shutdown: CLIENT_DIED
03:17:42:WU02:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
03:24:28:WU03:FS02:0xa4:Completed 1125000 out of 1500000 steps (75%)
03:26:05:FS02
03:26:05:FS02:Shutting core down
03:26:09:WU03:FS02:0xa4:Client no longer detected. Shutting down core
03:26:09:WU03:FS02:0xa4:Folding@home Core Shutdown: CLIENT_DIED
03:26:09:WU03:FS02:FahCore returned: INTERRUPTED (102 = 0x66)
03:26:17:FS02:Unpaused
03:26:17:WU03:FS02:Starting
03:26:17:WU03:FS02:Running FahCore: \"C:\\Program Files (x86)\\FAHClient/FAHCoreWrapper.exe\" C:/Users/Brad/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 03 -suffix 01 -version 703 -lifeline 2208 -checkpoint 15 -np 7
03:26:17:WU03:FS02:Started FahCore on PID 4432
03:26:17:WU03:FS02:Core PID:2560
03:26:17:WU03:FS02:FahCore 0xa4 started
03:26:18:WU03:FS02:0xa4:
03:26:18:WU03:FS02:0xa4:*------------------------------*
03:26:18:WU03:FS02:0xa4:Folding@Home Gromacs GB Core
03:26:18:WU03:FS02:0xa4:Version 2.27 (Dec. 15, 2010)
03:26:18:WU03:FS02:0xa4:- Looking at optimizations...
03:26:18:WU03:FS02:0xa4:- Files status OK
03:26:18:WU03:FS02:0xa4:- Expanded 2079299 -> 5386224 (decompressed 259.0 percent)
03:26:18:WU03:FS02:0xa4:Called DecompressByteArray: compressed_data_size=2079299 data_size=5386224, decompressed_data_size=5386224 diff=0
03:26:18:WU03:FS02:0xa4:- Digital signature verified
03:26:18:WU03:FS02:0xa4:Assembly optimizations on if available.
03:26:18:WU03:FS02:0xa4:Entering M.D.
03:26:24:WU03:FS02:0xa4:Using Gromacs checkpoints
03:26:24:WU03:FS02:0xa4:Mapping NT from 7 to 7
03:26:24:WU03:FS02:0xa4:Resuming from checkpoint
03:26:24:WU03:FS02:0xa4:Verified 03/wudata_01.log
03:26:24:WU03:FS02:0xa4:Verified 03/wudata_01.trr
03:26:24:WU03:FS02:0xa4:Verified 03/wudata_01.xtc
03:26:24:WU03:FS02:0xa4:Verified 03/wudata_01.edr
03:26:24:WU03:FS02:0xa4:Completed 1113590 out of 1500000 steps (74%)
03:28:48:FS02
03:28:48:FS02:Shutting core down
03:28:48:WU03:FS02:FahCore returned: INTERRUPTED (102 = 0x66)
03:29:16:FS01:Shutting core down
03:29:16:WU00:FS01:0x17:WARNING:Console control signal 1 on PID 3636
03:29:16:WU00:FS01:0x17:Exiting, please wait. . .
03:29:16:WU00:FS01:0x17:Lost lifeline PID 3596, exiting
03:29:16:WU00:FS01:0x17:ERROR:103: Lost client lifeline
03:29:16:WU00:FS01:0x17:Folding@home Core Shutdown: CLIENT_DIED
03:29:16:WU00:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
03:30:19:Removing old file 'configs/config-20130618-030054.xml'
03:30:19:Saving configuration to config.xml
03:30:19:<config>
03:30:19: <!-- Folding Slot Configuration -->
03:30:19: <power v='off'/>
03:30:19:
03:30:19: <!-- Network -->
03:30:19: <proxy v=':8080'/>
03:30:19:
03:30:19: <!-- User Information -->
03:30:19: <passkey v='********************************'/>
03:30:19: <team v='32'/>
03:30:19: <user v='Rustyfender'/>
03:30:19:
03:30:19: <!-- Folding Slots -->
03:30:19: <slot id='2' type='CPU'>
03:30:19: <cpus v='7'/>
03:30:19: </slot>
03:30:19: <slot id='0' type='GPU'>
03:30:19: <client-type v='beta'/>
03:30:19: </slot>
03:30:19: <slot id='1' type='GPU'>
03:30:19: </slot>
03:30:19:</config>
******************************* Date: 2013-06-21 *******************************
14:05:51:WU00:FS01:Starting
14:05:51:WU00:FS01:Running FahCore: \"C:\\Program Files (x86)\\FAHClient/FAHCoreWrapper.exe\" C:/Users/Brad/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/beta/Core_17.fah/FahCore_17.exe -dir 00 -suffix 01 -version 703 -lifeline 2208 -checkpoint 15 -gpu 1 -gpu-vendor ati
14:05:51:WU00:FS01:Started FahCore on PID 3840
14:05:51:WU00:FS01:Core PID:4792
14:05:51:WU00:FS01:FahCore 0x17 started
14:05:52:WU00:FS01:0x17:*********************** Log Started 2013-06-21T14:05:51Z ***********************
14:05:52:WU00:FS01:0x17:Unit: 0x0000001b028c126651a68124a879bd5a
14:05:52:WU00:FS01:0x17:CPU: 0x00000000000000000000000000000000
14:05:52:WU00:FS01:0x17:Machine: 1
14:05:52:WU00:FS01:0x17: Found a checkpoint file
14:06:52:Removing old file 'configs/config-20130618-030202.xml'
14:06:52:Saving configuration to config.xml
14:06:52:<config>
14:06:52: <!-- Folding Slot Configuration -->
14:06:52: <power v='full'/>
14:06:52:
14:06:52: <!-- Network -->
14:06:52: <proxy v=':8080'/>
14:06:52:
14:06:52: <!-- User Information -->
14:06:52: <passkey v='********************************'/>
14:06:52: <team v='32'/>
14:06:52: <user v='Rustyfender'/>
14:06:52:
14:06:52: <!-- Folding Slots -->
14:06:52: <slot id='2' type='CPU'>
14:06:52: <cpus v='7'/>
14:06:52: </slot>
14:06:52: <slot id='0' type='GPU'>
14:06:52: <client-type v='beta'/>
14:06:52: </slot>
14:06:52: <slot id='1' type='GPU'>
14:06:52: </slot>
14:06:52:</config>
14:07:39:WU00:FS01:0x17:Completed 2250000 out of 2500000 steps (90%)
14:23:49:WU00:FS01:0x17:Completed 2275000 out of 2500000 steps (91%)
14:39:47:WU00:FS01:0x17:Completed 2300000 out of 2500000 steps (92%)
14:55:59:WU00:FS01:0x17:Completed 2325000 out of 2500000 steps (93%)
15:11:58:WU00:FS01:0x17:Completed 2350000 out of 2500000 steps (94%)
15:28:12:WU00:FS01:0x17:Completed 2375000 out of 2500000 steps (95%)
15:44:13:WU00:FS01:0x17:Completed 2400000 out of 2500000 steps (96%)
16:00:24:WU00:FS01:0x17:Completed 2425000 out of 2500000 steps (97%)
16:16:24:WU00:FS01:0x17:Completed 2450000 out of 2500000 steps (98%)
16:16:25:WU01:FS01:Connecting to assign-GPU.stanford.edu:80
16:16:25:WU01:FS01:News: Welcome to Folding@Home
16:16:25:WU01:FS01:Assigned to work server 171.64.65.69
16:16:25:WU01:FS01:Requesting new work unit for slot 01: RUNNING gpu:1:Barts XT [ATI Radeon HD 6800 Series] from 171.64.65.69
16:16:25:WU01:FS01:Connecting to 171.64.65.69:8080
16:16:25:WU01:FS01
16:16:28:WU01:FS01
16:16:28:WU01:FS01:Received Unit: id:01 state
16:32:34:WU00:FS01:0x17:Completed 2475000 out of 2500000 steps (99%)
16:48:33:WU00:FS01:0x17:Completed 2500000 out of 2500000 steps (100%)
16:48:46:WU00:FS01:0x17:Saving result file logfile_01.txt
16:48:46:WU00:FS01:0x17:Saving result file checkpointState.xml
16:48:47:WU00:FS01:0x17:Saving result file checkpt.crc
16:48:47:WU00:FS01:0x17:Saving result file log.txt
16:48:47:WU00:FS01:0x17:Saving result file positions.xtc
16:48:48:WU00:FS01:0x17:Folding@home Core Shutdown: FINISHED_UNIT
16:48:49:WU00:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
16:48:49:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:8900 run:407 clone:1 gen:26 core:0x17 unit:0x0000001b028c126651a68124a879bd5a
16:48:49:WU00:FS01:Uploading 12.96MiB to 171.64.65.69
16:48:49:WU00:FS01:Connecting to 171.64.65.69:8080
16:48:49:WU01:FS01:Starting
16:48:49:WU01:FS01:Running FahCore: \"C:\\Program Files (x86)\\FAHClient/FAHCoreWrapper.exe\" C:/Users/Brad/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/beta/Core_17.fah/FahCore_17.exe -dir 01 -suffix 01 -version 703 -lifeline 2208 -checkpoint 15 -gpu 1 -gpu-vendor ati
16:48:49:WU01:FS01:Started FahCore on PID 3676
16:48:49:WU01:FS01:Core PID:5884
16:48:49:WU01:FS01:FahCore 0x17 started
16:48:49:WU01:FS01:0x17:*********************** Log Started 2013-06-21T16:48:49Z ***********************
16:48:49:WU01:FS01:0x17:Unit: 0x00000018028c126651a6767321c7a4b2
16:48:49:WU01:FS01:0x17:CPU: 0x00000000000000000000000000000000
16:48:49:WU01:FS01:0x17:Machine: 1
16:48:49:WU01:FS01:0x17:Reading tar file state.xml
16:48:50:WU01:FS01:0x17:Reading tar file system.xml
16:48:50:WU01:FS01:0x17:Reading tar file integrator.xml
16:48:50:WU01:FS01:0x17:Reading tar file core.xml
16:48:55:WU00:FS01:Upload 6.27%
16:49:01:WU00:FS01:Upload 11.09%
16:49:08:WU00:FS01:Upload 15.43%
16:49:14:WU00:FS01:Upload 19.77%
16:49:20:WU00:FS01:Upload 25.08%
16:49:26:WU00:FS01:Upload 30.38%
16:49:32:WU00:FS01:Upload 35.69%
16:49:38:WU00:FS01:Upload 40.99%
16:49:44:WU00:FS01:Upload 46.30%
16:49:50:WU00:FS01:Upload 51.60%
16:49:56:WU00:FS01:Upload 56.91%
16:50:02:WU00:FS01:Upload 62.70%
16:50:08:WU00:FS01:Upload 67.52%
16:50:14:WU00:FS01:Upload 72.82%
16:50:20:WU00:FS01:Upload 78.61%
16:50:26:WU00:FS01:Upload 83.92%
16:50:32:WU00:FS01:Upload 89.22%
16:50:37:WU01:FS01:0x17:Completed 0 out of 2500000 steps (0%)
16:50:38:WU00:FS01:Upload 94.53%
16:50:44:WU00:FS01:Upload 99.83%
16:50:52:WU00:FS01:Upload complete
16:50:53:WU00:FS01:Server responded WORK_ACK (400)
16:50:53:WU00:FS01:Final credit estimate, 10422.00 points
16:50:53:WU00:FS01:Cleaning up
17:06:47:WU01:FS01:0x17:Completed 25000 out of 2500000 steps (1%)
17:22:46:WU01:FS01:0x17:Completed 50000 out of 2500000 steps (2%)
17:38:59:WU01:FS01:0x17:Completed 75000 out of 2500000 steps (3%)
17:54:59:WU01:FS01:0x17:Completed 100000 out of 2500000 steps (4%)
18:11:11:WU01:FS01:0x17:Completed 125000 out of 2500000 steps (5%)
18:27:12:WU01:FS01:0x17:Completed 150000 out of 2500000 steps (6%)
18:43:24:WU01:FS01:0x17:Completed 175000 out of 2500000 steps (7%)
18:59:23:WU01:FS01:0x17:Completed 200000 out of 2500000 steps (8%)
19:15:35:WU01:FS01:0x17:Completed 225000 out of 2500000 steps (9%)
19:20:00:FS00:Unpaused
19:20:00:WU02:FS00:Starting
19:20:00:WU02:FS00:Running FahCore: \"C:\\Program Files (x86)\\FAHClient/FAHCoreWrapper.exe\" C:/Users/Brad/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/beta/Core_17.fah/FahCore_17.exe -dir 02 -suffix 01 -version 703 -lifeline 2208 -checkpoint 15 -gpu 0 -gpu-vendor ati
19:20:00:WU02:FS00:Started FahCore on PID 2632
19:20:00:WU02:FS00:Core PID:2368
19:20:00:WU02:FS00:FahCore 0x17 started
19:20:01:WU02:FS00:0x17:*********************** Log Started 2013-06-21T19:20:00Z ***********************
19:20:01:WU02:FS00:0x17:Unit: 0x0000000d028c126651a6cd406ad018d7
19:20:01:WU02:FS00:0x17:CPU: 0x00000000000000000000000000000000
19:20:01:WU02:FS00:0x17:Machine: 0
19:20:02:FS02:Unpaused
19:20:02:WU03:FS02:Starting
19:20:02:WU03:FS02:Running FahCore: \"C:\\Program Files (x86)\\FAHClient/FAHCoreWrapper.exe\" C:/Users/Brad/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 03 -suffix 01 -version 703 -lifeline 2208 -checkpoint 15 -np 7
19:20:02:WU03:FS02:Started FahCore on PID 4128
19:20:02:WU03:FS02:Core PID:2108
19:20:02:WU03:FS02:FahCore 0xa4 started
19:20:03:WU03:FS02:0xa4:
19:20:03:WU03:FS02:0xa4:*------------------------------*
19:20:03:WU03:FS02:0xa4:Folding@Home Gromacs GB Core
19:20:03:WU03:FS02:0xa4:Version 2.27 (Dec. 15, 2010)
19:20:03:WU03:FS02:0xa4:- Looking at optimizations...
19:20:03:WU03:FS02:0xa4:- Files status OK
19:20:03:WU03:FS02:0xa4:- Expanded 2079299 -> 5386224 (decompressed 259.0 percent)
19:20:03:WU03:FS02:0xa4:Called DecompressByteArray: compressed_data_size=2079299 data_size=5386224, decompressed_data_size=5386224 diff=0
19:20:03:WU03:FS02:0xa4:- Digital signature verified
19:20:03:WU03:FS02:0xa4:Assembly optimizations on if available.
19:20:03:WU03:FS02:0xa4:Entering M.D.
19:20:09:WU03:FS02:0xa4:Using Gromacs checkpoints
19:20:09:WU03:FS02:0xa4:Mapping NT from 7 to 7
19:20:09:WU03:FS02:0xa4:Resuming from checkpoint
19:20:09:WU03:FS02:0xa4:Verified 03/wudata_01.log
19:20:09:WU03:FS02:0xa4:Verified 03/wudata_01.trr
19:20:09:WU03:FS02:0xa4:Verified 03/wudata_01.xtc
19:20:09:WU03:FS02:0xa4:Verified 03/wudata_01.edr
19:20:09:WU03:FS02:0xa4:Completed 1113590 out of 1500000 steps (74%)
19:22:39:WU02:FS00:0x17:Completed 0 out of 2500000 steps (0%)
19:26:40:WU03:FS02:0xa4:Completed 1125000 out of 1500000 steps (75%)
19:31:49:WU01:FS01:0x17:Completed 250000 out of 2500000 steps (10%)
19:35:07:WU03:FS02:0xa4:Completed 1140000 out of 1500000 steps (76%)
19:39:00:WU02:FS00:0x17:Completed 25000 out of 2500000 steps (1%)
19:43:32:WU03:FS02:0xa4:Completed 1155000 out of 1500000 steps (77%)
19:48:11:WU01:FS01:0x17:Completed 275000 out of 2500000 steps (11%)
19:51:58:WU03:FS02:0xa4:Completed 1170000 out of 1500000 steps (78%)
19:55:02:WU02:FS00:0x17:Completed 50000 out of 2500000 steps (2%)
20:00:26:WU03:FS02:0xa4:Completed 1185000 out of 1500000 steps (79%)
20:04:17:WU01:FS01:0x17:Completed 300000 out of 2500000 steps (12%)
20:08:53:WU03:FS02:0xa4:Completed 1200000 out of 1500000 steps (80%)
20:11:26:WU02:FS00:0x17:Completed 75000 out of 2500000 steps (3%)
20:17:14:WU03:FS02:0xa4:Completed 1215000 out of 1500000 steps (81%)
20:20:41:WU01:FS01:0x17:Completed 325000 out of 2500000 steps (13%)
20:25:37:WU03:FS02:0xa4:Completed 1230000 out of 1500000 steps (82%)
20:27:30:WU02:FS00:0x17:Completed 100000 out of 2500000 steps (4%)
20:34:06:WU03:FS02:0xa4:Completed 1245000 out of 1500000 steps (83%)
20:36:46:WU01:FS01:0x17:Completed 350000 out of 2500000 steps (14%)
20:42:25:WU03:FS02:0xa4:Completed 1260000 out of 1500000 steps (84%)
20:43:54:WU02:FS00:0x17:Completed 125000 out of 2500000 steps (5%)
20:50:42:WU03:FS02:0xa4:Completed 1275000 out of 1500000 steps (85%)
20:53:06:WU01:FS01:0x17:Completed 375000 out of 2500000 steps (15%)
20:59:10:WU03:FS02:0xa4:Completed 1290000 out of 1500000 steps (86%)
20:59:58:WU02:FS00:0x17:Completed 150000 out of 2500000 steps (6%)
21:07:39:WU03:FS02:0xa4:Completed 1305000 out of 1500000 steps (87%)
21:09:09:WU01:FS01:0x17:Completed 400000 out of 2500000 steps (16%)
21:16:02:WU03:FS02:0xa4:Completed 1320000 out of 1500000 steps (88%)
21:16:20:WU02:FS00:0x17:Completed 175000 out of 2500000 steps (7%)
21:24:24:WU03:FS02:0xa4:Completed 1335000 out of 1500000 steps (89%)
21:25:30:WU01:FS01:0x17:Completed 425000 out of 2500000 steps (17%)
21:32:22:WU02:FS00:0x17:Completed 200000 out of 2500000 steps (8%)
21:32:48:WU03:FS02:0xa4:Completed 1350000 out of 1500000 steps (90%)
21:41:16:WU03:FS02:0xa4:Completed 1365000 out of 1500000 steps (91%)
21:41:33:WU01:FS01:0x17:Completed 450000 out of 2500000 steps (18%)
21:48:44:WU02:FS00:0x17:Completed 225000 out of 2500000 steps (9%)
21:49:44:WU03:FS02:0xa4:Completed 1380000 out of 1500000 steps (92%)
21:57:54:WU01:FS01:0x17:Completed 475000 out of 2500000 steps (19%)
21:58:09:WU03:FS02:0xa4:Completed 1395000 out of 1500000 steps (93%)
22:04:47:WU02:FS00:0x17:Completed 250000 out of 2500000 steps (10%)
22:06:37:WU03:FS02:0xa4:Completed 1410000 out of 1500000 steps (94%)
22:13:59:WU01:FS01:0x17:Completed 500000 out of 2500000 steps (20%)
22:15:03:WU03:FS02:0xa4:Completed 1425000 out of 1500000 steps (95%)
22:21:10:WU02:FS00:0x17:Completed 275000 out of 2500000 steps (11%)
22:23:30:WU03:FS02:0xa4:Completed 1440000 out of 1500000 steps (96%)
22:30:21:WU01:FS01:0x17:Completed 525000 out of 2500000 steps (21%)
22:31:55:WU03:FS02:0xa4:Completed 1455000 out of 1500000 steps (97%)
22:37:15:WU02:FS00:0x17:Completed 300000 out of 2500000 steps (12%)
22:40:17:WU03:FS02:0xa4:Completed 1470000 out of 1500000 steps (98%)
22:40:17:WU00:FS02:Connecting to assign3.stanford.edu:8080
22:40:17:WU00:FS02:News: Welcome to Folding@Home
22:40:17:WU00:FS02:Assigned to work server 171.67.108.35
22:40:17:WU00:FS02:Requesting new work unit for slot 02: RUNNING cpu:7 from 171.67.108.35
22:40:17:WU00:FS02:Connecting to 171.67.108.35:8080
22:40:17:ERROR:WU00:FS02:Exception: Server did not assign work unit
22:40:18:WU00:FS02:Connecting to assign3.stanford.edu:8080
22:40:18:WU00:FS02:News: Welcome to Folding@Home
22:40:18:WU00:FS02:Assigned to work server 171.67.108.35
22:40:18:WU00:FS02:Requesting new work unit for slot 02: RUNNING cpu:7 from 171.67.108.35
22:40:18:WU00:FS02:Connecting to 171.67.108.35:8080
22:40:18:ERROR:WU00:FS02:Exception: Server did not assign work unit
22:41:18:WU00:FS02:Connecting to assign3.stanford.edu:8080
22:41:18:WU00:FS02:News: Welcome to Folding@Home
22:41:18:WU00:FS02:Assigned to work server 171.67.108.35
22:41:18:WU00:FS02:Requesting new work unit for slot 02: RUNNING cpu:7 from 171.67.108.35
22:41:18:WU00:FS02:Connecting to 171.67.108.35:8080
22:41:18:ERROR:WU00:FS02:Exception: Server did not assign work unit
22:42:55:WU00:FS02:Connecting to assign3.stanford.edu:8080
22:42:55:WU00:FS02:News: Welcome to Folding@Home
22:42:55:WU00:FS02:Assigned to work server 171.67.108.35
22:42:55:WU00:FS02:Requesting new work unit for slot 02: RUNNING cpu:7 from 171.67.108.35
22:42:55:WU00:FS02:Connecting to 171.67.108.35:8080
22:42:55:ERROR:WU00:FS02:Exception: Server did not assign work unit
22:45:32:WU00:FS02:Connecting to assign3.stanford.edu:8080
22:45:32:WU00:FS02:News: Welcome to Folding@Home
22:45:32:WU00:FS02:Assigned to work server 171.67.108.35
22:45:32:WU00:FS02:Requesting new work unit for slot 02: RUNNING cpu:7 from 171.67.108.35
22:45:32:WU00:FS02:Connecting to 171.67.108.35:8080
22:45:33:ERROR:WU00:FS02:Exception: Server did not assign work unit
22:46:27:WU01:FS01:0x17:Completed 550000 out of 2500000 steps (22%)
22:48:41:WU03:FS02:0xa4:Completed 1485000 out of 1500000 steps (99%)
22:49:46:WU00:FS02:Connecting to assign3.stanford.edu:8080
22:49:46:WU00:FS02:News: Welcome to Folding@Home
22:49:46:WU00:FS02:Assigned to work server 171.67.108.35
22:49:46:WU00:FS02:Requesting new work unit for slot 02: RUNNING cpu:7 from 171.67.108.35
22:49:46:WU00:FS02:Connecting to 171.67.108.35:8080
22:49:47:ERROR:WU00:FS02:Exception: Server did not assign work unit
22:53:40:WU02:FS00:0x17:Completed 325000 out of 2500000 steps (13%)
22:56:38:WU00:FS02:Connecting to assign3.stanford.edu:8080
22:56:38:WU00:FS02:News: Welcome to Folding@Home
22:56:38:WU00:FS02:Assigned to work server 171.67.108.35
22:56:38:WU00:FS02:Requesting new work unit for slot 02: RUNNING cpu:7 from 171.67.108.35
22:56:38:WU00:FS02:Connecting to 171.67.108.35:8080
22:56:38:ERROR:WU00:FS02:Exception: Server did not assign work unit
22:56:58:WU03:FS02:0xa4:Completed 1500000 out of 1500000 steps (100%)
22:56:59:WU03:FS02:0xa4
22:57:09:WU03:FS02:0xa4:
22:57:09:WU03:FS02:0xa4:Finished Work Unit:
22:57:09:WU03:FS02:0xa4:- Reading up to 2908800 from \"03/wudata_01.trr\": Read 2908800
22:57:09:WU03:FS02:0xa4:trr file hash check passed.
22:57:09:WU03:FS02:0xa4:- Reading up to 1554520 from \"03/wudata_01.xtc\": Read 1554520
22:57:09:WU03:FS02:0xa4:xtc file hash check passed.
22:57:09:WU03:FS02:0xa4:edr file hash check passed.
22:57:09:WU03:FS02:0xa4:logfile size: 27727
22:57:09:WU03:FS02:0xa4:Leaving Run
22:57:12:WU03:FS02:0xa4:- Writing 4496059 bytes of core data to disk...
22:57:13:WU03:FS02:0xa4
22:57:13:WU03:FS02:0xa4: ... Done.
22:57:13:WU03:FS02:0xa4:- Shutting down core
22:57:13:WU03:FS02:0xa4:Folding@home Core Shutdown: FINISHED_UNIT
22:57:13:WU03:FS02:FahCore returned: FINISHED_UNIT (100 = 0x64)
22:57:13:WU03:FS02:Sending unit results: id:03 state:SEND error:NO_ERROR project:7809 run:4 clone:175 gen:39 core:0xa4 unit:0x000000440a3b1e874e310df0c0f4e59a
22:57:13:WU03:FS02:Uploading 4.13MiB to 171.64.65.99
22:57:13:WU03:FS02:Connecting to 171.64.65.99:8080
22:57:19:WU03:FS02:Upload 18.18%
22:57:25:WU03:FS02:Upload 34.84%
22:57:31:WU03:FS02:Upload 51.50%
22:57:37:WU03:FS02:Upload 68.17%
22:57:43:WU03:FS02:Upload 84.83%
22:57:49:WU03:FS02:Upload complete
22:57:49:WU03:FS02:Server responded WORK_ACK (400)
22:57:49:WU03:FS02:Final credit estimate, 8663.00 points
22:57:49:WU03:FS02:Cleaning up
23:02:45:WU01:FS01:0x17:Completed 575000 out of 2500000 steps (23%)
23:07:43:WU00:FS02:Connecting to assign3.stanford.edu:8080
23:07:43:WU00:FS02:News: Welcome to Folding@Home
23:07:43:WU00:FS02:Assigned to work server 128.143.231.202
23:07:43:WU00:FS02:Requesting new work unit for slot 02: READY cpu:7 from 128.143.231.202
23:07:43:WU00:FS02:Connecting to 128.143.231.202:8080
23:07:45:WU00:FS02
23:07:47:WU00:FS02
23:07:47:WU00:FS02:Received Unit: id:00 state
23:07:47:WU00:FS02:Starting
23:07:47:WU00:FS02:Running FahCore: \"C:\\Program Files (x86)\\FAHClient/FAHCoreWrapper.exe\" C:/Users/Brad/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/Core_a3.fah/FahCore_a3.exe -dir 00 -suffix 01 -version 703 -lifeline 2208 -checkpoint 15 -np 7
23:07:47:WU00:FS02:Started FahCore on PID 5312
23:07:47:WU00:FS02:Core PID:3324
23:07:47:WU00:FS02:FahCore 0xa3 started
23:07:48:WU00:FS02:0xa3:
23:07:48:WU00:FS02:0xa3:*------------------------------*
23:07:48:WU00:FS02:0xa3:Folding@Home Gromacs SMP Core
23:07:48:WU00:FS02:0xa3:Version 2.27 (Dec. 15, 2010)
23:07:48:WU00:FS02:0xa3:- Looking at optimizations...
23:07:48:WU00:FS02:0xa3:- Created dyn
23:07:48:WU00:FS02:0xa3:- Files status OK
23:07:48:WU00:FS02:0xa3:- Expanded 3812599 -> 4136808 (decompressed 108.5 percent)
23:07:48:WU00:FS02:0xa3:Called DecompressByteArray: compressed_data_size=3812599 data_size=4136808, decompressed_data_size=4136808 diff=0
23:07:48:WU00:FS02:0xa3:- Digital signature verified
23:07:48:WU00:FS02:0xa3:Assembly optimizations on if available.
23:07:48:WU00:FS02:0xa3:Entering M.D.
23:07:54:WU00:FS02:0xa3:Mapping NT from 7 to 7
23:07:54:WU00:FS02:0xa3:Completed 0 out of 500000 steps (0%)
23:09:41:WU02:FS00:0x17:Completed 350000 out of 2500000 steps (14%)
23:16:40:WU00:FS02:0xa3:Completed 5000 out of 500000 steps (1%)
23:18:50:WU01:FS01:0x17:Completed 600000 out of 2500000 steps (24%)
23:25:26:WU00:FS02:0xa3:Completed 10000 out of 500000 steps (2%)
23:26:09:WU02:FS00:0x17:Completed 375000 out of 2500000 steps (15%)
23:34:13:WU00:FS02:0xa3:Completed 15000 out of 500000 steps (3%)
23:35:14:WU01:FS01:0x17:Completed 625000 out of 2500000 steps (25%)
23:42:15:WU02:FS00:0x17:Completed 400000 out of 2500000 steps (16%)
23:42:59:WU00:FS02:0xa3:Completed 20000 out of 500000 steps (4%)
23:51:22:WU01:FS01:0x17:Completed 650000 out of 2500000 steps (26%)
23:51:45:WU00:FS02:0xa3:Completed 25000 out of 500000 steps (5%)
23:58:43:WU02:FS00:0x17:Completed 425000 out of 2500000 steps (17%)
00:00:29:WU00:FS02:0xa3:Completed 30000 out of 500000 steps (6%)
00:07:47:WU01:FS01:0x17:Completed 675000 out of 2500000 steps (27%)
00:09:17:WU00:FS02:0xa3:Completed 35000 out of 500000 steps (7%)
00:14:49:WU02:FS00:0x17:Completed 450000 out of 2500000 steps (18%)
00:18:10:WU00:FS02:0xa3:Completed 40000 out of 500000 steps (8%)
00:23:54:WU01:FS01:0x17:Completed 700000 out of 2500000 steps (28%)
00:27:01:WU00:FS02:0xa3:Completed 45000 out of 500000 steps (9%)
00:31:16:WU02:FS00:0x17:Completed 475000 out of 2500000 steps (19%)
00:35:51:WU00:FS02:0xa3:Completed 50000 out of 500000 steps (10%)
00:40:22:WU01:FS01:0x17:Completed 725000 out of 2500000 steps (29%)
00:44:36:WU00:FS02:0xa3:Completed 55000 out of 500000 steps (11%)
00:47:24:WU02:FS00:0x17:Completed 500000 out of 2500000 steps (20%)
00:53:19:WU00:FS02:0xa3:Completed 60000 out of 500000 steps (12%)
00:56:32:WU01:FS01:0x17:Completed 750000 out of 2500000 steps (30%)
01:02:05:WU00:FS02:0xa3:Completed 65000 out of 500000 steps (13%)
01:03:51:WU02:FS00:0x17:Completed 525000 out of 2500000 steps (21%)
01:10:48:WU00:FS02:0xa3:Completed 70000 out of 500000 steps (14%)
01:12:57:WU01:FS01:0x17:Completed 775000 out of 2500000 steps (31%)
01:19:29:WU00:FS02:0xa3:Completed 75000 out of 500000 steps (15%)
01:19:59:WU02:FS00:0x17:Completed 550000 out of 2500000 steps (22%)
01:28:15:WU00:FS02:0xa3:Completed 80000 out of 500000 steps (16%)
01:29:05:WU01:FS01:0x17:Completed 800000 out of 2500000 steps (32%)
01:36:26:WU02:FS00:0x17:Completed 575000 out of 2500000 steps (23%)
01:37:03:WU00:FS02:0xa3:Completed 85000 out of 500000 steps (17%)
01:45:31:WU01:FS01:0x17:Completed 825000 out of 2500000 steps (33%)
01:45:41:WU00:FS02:0xa3:Completed 90000 out of 500000 steps (18%)
01:52:34:WU02:FS00:0x17:Completed 600000 out of 2500000 steps (24%)
01:54:31:WU00:FS02:0xa3:Completed 95000 out of 500000 steps (19%)
02:01:39:WU01:FS01:0x17:Completed 850000 out of 2500000 steps (34%)
02:03:21:WU00:FS02:0xa3:Completed 100000 out of 500000 steps (20%)
******************************* Date: 2013-06-22 *******************************
02:09:01:WU02:FS00:0x17:Completed 625000 out of 2500000 steps (25%)
02:12:09:WU00:FS02:0xa3:Completed 105000 out of 500000 steps (21%)
02:18:03:WU01:FS01:0x17:Completed 875000 out of 2500000 steps (35%)
02:21:01:WU00:FS02:0xa3:Completed 110000 out of 500000 steps (22%)
02:25:07:WU02:FS00:0x17:Completed 650000 out of 2500000 steps (26%)
02:29:47:WU00:FS02:0xa3:Completed 115000 out of 500000 steps (23%)
02:34:11:WU01:FS01:0x17:Completed 900000 out of 2500000 steps (36%)
02:38:37:WU00:FS02:0xa3:Completed 120000 out of 500000 steps (24%)
02:41:35:WU02:FS00:0x17:Completed 675000 out of 2500000 steps (27%)
02:47:28:WU00:FS02:0xa3:Completed 125000 out of 500000 steps (25%)
02:50:37:WU01:FS01:0x17:Completed 925000 out of 2500000 steps (37%)
02:56:16:WU00:FS02:0xa3:Completed 130000 out of 500000 steps (26%)
02:57:42:WU02:FS00:0x17:Completed 700000 out of 2500000 steps (28%)
03:05:00:WU00:FS02:0xa3:Completed 135000 out of 500000 steps (27%)
03:06:47:WU01:FS01:0x17:Completed 950000 out of 2500000 steps (38%)
03:13:43:WU00:FS02:0xa3:Completed 140000 out of 500000 steps (28%)
03:14:10:WU02:FS00:0x17:Completed 725000 out of 2500000 steps (29%)
03:22:30:WU00:FS02:0xa3:Completed 145000 out of 500000 steps (29%)
03:23:14:WU01:FS01:0x17:Completed 975000 out of 2500000 steps (39%)
03:30:18:WU02:FS00:0x17:Completed 750000 out of 2500000 steps (30%)
03:31:17:WU00:FS02:0xa3:Completed 150000 out of 500000 steps (30%)
03:39:23:WU01:FS01:0x17:Completed 1000000 out of 2500000 steps (40%)
03:40:05:WU00:FS02:0xa3:Completed 155000 out of 500000 steps (31%)
03:46:44:WU02:FS00:0x17:Completed 775000 out of 2500000 steps (31%)
03:48:51:WU00:FS02:0xa3:Completed 160000 out of 500000 steps (32%)
03:55:49:WU01:FS01:0x17:Completed 1025000 out of 2500000 steps (41%)
03:57:41:WU00:FS02:0xa3:Completed 165000 out of 500000 steps (33%)
04:02:52:WU02:FS00:0x17:Completed 800000 out of 2500000 steps (32%)
04:06:39:WU00:FS02:0xa3:Completed 170000 out of 500000 steps (34%)
04:11:58:WU01:FS01:0x17:Completed 1050000 out of 2500000 steps (42%)
04:15:25:WU00:FS02:0xa3:Completed 175000 out of 500000 steps (35%)
04:19:19:WU02:FS00:0x17:Completed 825000 out of 2500000 steps (33%)
04:24:12:WU00:FS02:0xa3:Completed 180000 out of 500000 steps (36%)
04:28:24:WU01:FS01:0x17:Completed 1075000 out of 2500000 steps (43%)
04:32:55:WU00:FS02:0xa3:Completed 185000 out of 500000 steps (37%)
04:35:26:WU02:FS00:0x17:Completed 850000 out of 2500000 steps (34%)
04:41:38:WU00:FS02:0xa3:Completed 190000 out of 500000 steps (38%)
04:44:33:WU01:FS01:0x17:Completed 1100000 out of 2500000 steps (44%)
04:50:26:WU00:FS02:0xa3:Completed 195000 out of 500000 steps (39%)
04:51:55:WU02:FS00:0x17:Completed 875000 out of 2500000 steps (35%)
04:59:14:WU00:FS02:0xa3:Completed 200000 out of 500000 steps (40%)
05:01:10:WU01:FS01:0x17:Completed 1125000 out of 2500000 steps (45%)
05:08:00:WU00:FS02:0xa3:Completed 205000 out of 500000 steps (41%)
05:08:02:WU02:FS00:0x17:Completed 900000 out of 2500000 steps (36%)
05:16:51:WU00:FS02:0xa3:Completed 210000 out of 500000 steps (42%)
05:18:12:WU01:FS01:0x17:Completed 1150000 out of 2500000 steps (46%)
05:24:29:WU02:FS00:0x17:Completed 925000 out of 2500000 steps (37%)
05:25:36:WU00:FS02:0xa3:Completed 215000 out of 500000 steps (43%)
05:34:25:WU00:FS02:0xa3:Completed 220000 out of 500000 steps (44%)
05:35:44:WU01:FS01:0x17:Completed 1175000 out of 2500000 steps (47%)
05:40:36:WU02:FS00:0x17:Completed 950000 out of 2500000 steps (38%)
05:43:13:WU00:FS02:0xa3:Completed 225000 out of 500000 steps (45%)
05:52:00:WU00:FS02:0xa3:Completed 230000 out of 500000 steps (46%)
05:52:58:WU01:FS01:0x17:Completed 1200000 out of 2500000 steps (48%)
05:57:01:WU02:FS00:0x17:Completed 975000 out of 2500000 steps (39%)
06:00:44:WU00:FS02:0xa3:Completed 235000 out of 500000 steps (47%)
06:09:40:WU00:FS02:0xa3:Completed 240000 out of 500000 steps (48%)
06:10:32:WU01:FS01:0x17:Completed 1225000 out of 2500000 steps (49%)
06:13:06:WU02:FS00:0x17:Completed 1000000 out of 2500000 steps (40%)
06:19:23:WU00:FS02:0xa3:Completed 245000 out of 500000 steps (49%)
06:28:13:WU01:FS01:0x17:Completed 1250000 out of 2500000 steps (50%)
06:29:11:WU00:FS02:0xa3:Completed 250000 out of 500000 steps (50%)
06:29:29:WU02:FS00:0x17:Completed 1025000 out of 2500000 steps (41%)
06:38:54:WU00:FS02:0xa3:Completed 255000 out of 500000 steps (51%)
06:45:31:WU02:FS00:0x17:Completed 1050000 out of 2500000 steps (42%)
06:46:38:WU01:FS01:0x17:Completed 1275000 out of 2500000 steps (51%)
06:48:36:WU00:FS02:0xa3:Completed 260000 out of 500000 steps (52%)
06:58:19:WU00:FS02:0xa3:Completed 265000 out of 500000 steps (53%)
07:01:55:WU02:FS00:0x17:Completed 1075000 out of 2500000 steps (43%)
07:04:49:WU01:FS01:0x17:Completed 1300000 out of 2500000 steps (52%)
07:08:12:WU00:FS02:0xa3:Completed 270000 out of 500000 steps (54%)
07:17:59:WU02:FS00:0x17:Completed 1100000 out of 2500000 steps (44%)
07:18:01:WU00:FS02:0xa3:Completed 275000 out of 500000 steps (55%)
07:23:21:WU01:FS01:0x17:Completed 1325000 out of 2500000 steps (53%)
07:27:35:WU00:FS02:0xa3:Completed 280000 out of 500000 steps (56%)
07:34:24:WU02:FS00:0x17:Completed 1125000 out of 2500000 steps (45%)
07:36:50:WU00:FS02:0xa3:Completed 285000 out of 500000 steps (57%)
07:40:46:WU01:FS01:0x17:Completed 1350000 out of 2500000 steps (54%)
07:45:54:WU00:FS02:0xa3:Completed 290000 out of 500000 steps (58%)
07:50:31:WU02:FS00:0x17:Completed 1150000 out of 2500000 steps (46%)
07:54:51:WU00:FS02:0xa3:Completed 295000 out of 500000 steps (59%)
07:58:20:WU01:FS01:0x17:Completed 1375000 out of 2500000 steps (55%)
08:03:48:WU00:FS02:0xa3:Completed 300000 out of 500000 steps (60%)
08:06:52:WU02:FS00:0x17:Completed 1175000 out of 2500000 steps (47%)
08:12:45:WU00:FS02:0xa3:Completed 305000 out of 500000 steps (61%)
08:15:34:WU01:FS01:0x17:Completed 1400000 out of 2500000 steps (56%)
08:21:49:WU00:FS02:0xa3:Completed 310000 out of 500000 steps (62%)
08:22:55:WU02:FS00:0x17:Completed 1200000 out of 2500000 steps (48%)
08:30:49:WU00:FS02:0xa3:Completed 315000 out of 500000 steps (63%)
08:33:06:WU01:FS01:0x17:Completed 1425000 out of 2500000 steps (57%)
08:39:17:WU02:FS00:0x17:Completed 1225000 out of 2500000 steps (49%)
08:39:45:WU00:FS02:0xa3:Completed 320000 out of 500000 steps (64%)
08:48:44:WU00:FS02:0xa3:Completed 325000 out of 500000 steps (65%)
08:50:19:WU01:FS01:0x17:Completed 1450000 out of 2500000 steps (58%)
08:55:19:WU02:FS00:0x17:Completed 1250000 out of 2500000 steps (50%)
08:57:44:WU00:FS02:0xa3:Completed 330000 out of 500000 steps (66%)
09:06:45:WU00:FS02:0xa3:Completed 335000 out of 500000 steps (67%)
09:07:55:WU01:FS01:0x17:Completed 1475000 out of 2500000 steps (59%)
09:11:44:WU02:FS00:0x17:Completed 1275000 out of 2500000 steps (51%)
09:15:48:WU00:FS02:0xa3:Completed 340000 out of 500000 steps (68%)
09:24:47:WU00:FS02:0xa3:Completed 345000 out of 500000 steps (69%)
09:25:09:WU01:FS01:0x17:Completed 1500000 out of 2500000 steps (60%)
09:27:51:WU02:FS00:0x17:Completed 1300000 out of 2500000 steps (52%)
09:33:42:WU00:FS02:0xa3:Completed 350000 out of 500000 steps (70%)
09:42:45:WU01:FS01:0x17:Completed 1525000 out of 2500000 steps (61%)
09:42:49:WU00:FS02:0xa3:Completed 355000 out of 500000 steps (71%)
09:44:16:WU02:FS00:0x17:Completed 1325000 out of 2500000 steps (53%)
09:51:55:WU00:FS02:0xa3:Completed 360000 out of 500000 steps (72%)
10:00:01:WU01:FS01:0x17:Completed 1550000 out of 2500000 steps (62%)
10:00:23:WU02:FS00:0x17:Completed 1350000 out of 2500000 steps (54%)
10:01:02:WU00:FS02:0xa3:Completed 365000 out of 500000 steps (73%)
10:10:07:WU00:FS02:0xa3:Completed 370000 out of 500000 steps (74%)
10:16:46:WU02:FS00:0x17:Completed 1375000 out of 2500000 steps (55%)
10:17:35:WU01:FS01:0x17:Completed 1575000 out of 2500000 steps (63%)
10:19:13:WU00:FS02:0xa3:Completed 375000 out of 500000 steps (75%)
10:28:16:WU00:FS02:0xa3:Completed 380000 out of 500000 steps (76%)
10:32:49:WU02:FS00:0x17:Completed 1400000 out of 2500000 steps (56%)
10:34:49:WU01:FS01:0x17:Completed 1600000 out of 2500000 steps (64%)
10:37:20:WU00:FS02:0xa3:Completed 385000 out of 500000 steps (77%)
10:46:21:WU00:FS02:0xa3:Completed 390000 out of 500000 steps (78%)
10:49:13:WU02:FS00:0x17:Completed 1425000 out of 2500000 steps (57%)
10:52:22:WU01:FS01:0x17:Completed 1625000 out of 2500000 steps (65%)
10:55:22:WU00:FS02:0xa3:Completed 395000 out of 500000 steps (79%)
11:04:25:WU00:FS02:0xa3:Completed 400000 out of 500000 steps (80%)
11:05:16:WU02:FS00:0x17:Completed 1450000 out of 2500000 steps (58%)
11:09:37:WU01:FS01:0x17:Completed 1650000 out of 2500000 steps (66%)
11:13:29:WU00:FS02:0xa3:Completed 405000 out of 500000 steps (81%)
11:21:55:WU02:FS00:0x17:Completed 1475000 out of 2500000 steps (59%)
11:22:42:WU00:FS02:0xa3:Completed 410000 out of 500000 steps (82%)
11:27:26:WU01:FS01:0x17:Completed 1675000 out of 2500000 steps (67%)
11:31:44:WU00:FS02:0xa3:Completed 415000 out of 500000 steps (83%)
11:37:59:WU02:FS00:0x17:Completed 1500000 out of 2500000 steps (60%)
11:40:46:WU00:FS02:0xa3:Completed 420000 out of 500000 steps (84%)
11:44:41:WU01:FS01:0x17:Completed 1700000 out of 2500000 steps (68%)
11:49:51:WU00:FS02:0xa3:Completed 425000 out of 500000 steps (85%)
11:54:24:WU02:FS00:0x17:Completed 1525000 out of 2500000 steps (61%)
11:58:51:WU00:FS02:0xa3:Completed 430000 out of 500000 steps (86%)
12:02:18:WU01:FS01:0x17:Completed 1725000 out of 2500000 steps (69%)
12:07:46:WU00:FS02:0xa3:Completed 435000 out of 500000 steps (87%)
12:10:29:WU02:FS00:0x17:Completed 1550000 out of 2500000 steps (62%)
12:16:46:WU00:FS02:0xa3:Completed 440000 out of 500000 steps (88%)
12:19:35:WU01:FS01:0x17:Completed 1750000 out of 2500000 steps (70%)
12:25:49:WU00:FS02:0xa3:Completed 445000 out of 500000 steps (89%)
12:26:52:WU02:FS00:0x17:Completed 1575000 out of 2500000 steps (63%)
12:34:45:WU00:FS02:0xa3:Completed 450000 out of 500000 steps (90%)
12:37:08:WU01:FS01:0x17:Completed 1775000 out of 2500000 steps (71%)
12:42:54:WU02:FS00:0x17:Completed 1600000 out of 2500000 steps (64%)
12:43:47:WU00:FS02:0xa3:Completed 455000 out of 500000 steps (91%)
12:52:49:WU00:FS02:0xa3:Completed 460000 out of 500000 steps (92%)
12:54:24:WU01:FS01:0x17:Completed 1800000 out of 2500000 steps (72%)
12:59:20:WU02:FS00:0x17:Completed 1625000 out of 2500000 steps (65%)
13:01:52:WU00:FS02:0xa3:Completed 465000 out of 500000 steps (93%)
13:10:57:WU00:FS02:0xa3:Completed 470000 out of 500000 steps (94%)
13:11:59:WU01:FS01:0x17:Completed 1825000 out of 2500000 steps (73%)
13:15:23:WU02:FS00:0x17:Completed 1650000 out of 2500000 steps (66%)
13:19:59:WU00:FS02:0xa3:Completed 475000 out of 500000 steps (95%)
13:29:01:WU00:FS02:0xa3:Completed 480000 out of 500000 steps (96%)
13:29:13:WU01:FS01:0x17:Completed 1850000 out of 2500000 steps (74%)
13:31:48:WU02:FS00:0x17:Completed 1675000 out of 2500000 steps (67%)
13:37:59:WU00:FS02:0xa3:Completed 485000 out of 500000 steps (97%)
13:46:48:WU01:FS01:0x17:Completed 1875000 out of 2500000 steps (75%)
13:47:01:WU00:FS02:0xa3:Completed 490000 out of 500000 steps (98%)
13:47:01:WU03:FS02:Connecting to assign3.stanford.edu:8080
13:47:01:WU03:FS02:News: Welcome to Folding@Home
13:47:01:WU03:FS02:Assigned to work server 171.67.108.35
13:47:01:WU03:FS02:Requesting new work unit for slot 02: RUNNING cpu:7 from 171.67.108.35
13:47:01:WU03:FS02:Connecting to 171.67.108.35:8080
13:47:02:WU03:FS02
13:47:03:WU03:FS02
13:47:03:WU03:FS02:Received Unit: id:03 state
13:47:52:WU02:FS00:0x17:Completed 1700000 out of 2500000 steps (68%)
13:55:53:WU00:FS02:0xa3:Completed 495000 out of 500000 steps (99%)
14:04:05:WU01:FS01:0x17:Completed 1900000 out of 2500000 steps (76%)
14:04:17:WU02:FS00:0x17:Completed 1725000 out of 2500000 steps (69%)
14:05:08:WU00:FS02:0xa3:Completed 500000 out of 500000 steps (100%)
14:05:10:WU00:FS02:0xa3
14:05:20:WU00:FS02:0xa3:
14:05:20:WU00:FS02:0xa3:Finished Work Unit:
14:05:20:WU00:FS02:0xa3:- Reading up to 12102120 from \"00/wudata_01.trr\": Read 12102120
14:05:20:WU00:FS02:0xa3:trr file hash check passed.
14:05:20:WU00:FS02:0xa3:edr file hash check passed.
14:05:20:WU00:FS02:0xa3:logfile size: 56088
14:05:20:WU00:FS02:0xa3:Leaving Run
14:05:20:WU00:FS02:0xa3:- Writing 12191884 bytes of core data to disk...
14:05:22:WU00:FS02:0xa3
14:05:22:WU00:FS02:0xa3: ... Done.
14:05:22:WU00:FS02:0xa3:- Shutting down core
14:05:22:WU00:FS02:0xa3:Folding@home Core Shutdown: FINISHED_UNIT
14:05:23:WU00:FS02:FahCore returned: FINISHED_UNIT (100 = 0x64)
14:05:23:WU00:FS02:Sending unit results: id:00 state:SEND error:NO_ERROR project:6098 run:2 clone:74 gen:214 core:0xa3 unit:0x0000012a0a3b1e594e91dd4d67b65d9b
14:05:23:WU00:FS02:Uploading 10.77MiB to 128.143.231.202
14:05:23:WU00:FS02:Connecting to 128.143.231.202:8080
14:05:23:WU03:FS02:Starting
14:05:23:WU03:FS02:Running FahCore: \"C:\\Program Files (x86)\\FAHClient/FAHCoreWrapper.exe\" C:/Users/Brad/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 03 -suffix 01 -version 703 -lifeline 2208 -checkpoint 15 -np 7
14:05:23:WU03:FS02:Started FahCore on PID 6960
14:05:23:WU03:FS02:Core PID:6396
14:05:23:WU03:FS02:FahCore 0xa4 started
14:05:24:WU03:FS02:0xa4:
14:05:24:WU03:FS02:0xa4:*------------------------------*
14:05:24:WU03:FS02:0xa4:Folding@Home Gromacs GB Core
14:05:24:WU03:FS02:0xa4:Version 2.27 (Dec. 15, 2010)
14:05:24:WU03:FS02:0xa4:- Looking at optimizations...
14:05:24:WU03:FS02:0xa4:- Created dyn
14:05:24:WU03:FS02:0xa4:- Files status OK
14:05:24:WU03:FS02:0xa4:- Expanded 1024853 -> 2544640 (decompressed 248.2 percent)
14:05:24:WU03:FS02:0xa4:Called DecompressByteArray: compressed_data_size=1024853 data_size=2544640, decompressed_data_size=2544640 diff=0
14:05:24:WU03:FS02:0xa4:- Digital signature verified
14:05:24:WU03:FS02:0xa4:Assembly optimizations on if available.
14:05:24:WU03:FS02:0xa4:Entering M.D.
14:05:29:WU00:FS02:Upload 5.80%
14:05:29:WU03:FS02:0xa4:Mapping NT from 7 to 7
14:05:30:WU03:FS02:0xa4:Completed 0 out of 250000 steps (0%)
14:05:35:WU00:FS02:Upload 10.44%
14:05:41:WU00:FS02:Upload 15.08%
14:05:47:WU00:FS02:Upload 20.30%
14:05:53:WU00:FS02:Upload 24.36%
14:05:59:WU00:FS02:Upload 29.58%
14:06:05:WU00:FS02:Upload 34.22%
14:06:11:WU00:FS02:Upload 39.45%
14:06:17:WU00:FS02:Upload 44.09%
14:06:23:WU00:FS02:Upload 48.73%
14:06:29:WU00:FS02:Upload 53.37%
14:06:35:WU00:FS02:Upload 58.01%
14:06:41:WU00:FS02:Upload 63.23%
14:06:47:WU00:FS02:Upload 67.87%
14:06:50:WU03:FS02:0xa4:Completed 2500 out of 250000 steps (1%)
14:06:53:WU00:FS02:Upload 73.09%
14:06:59:WU00:FS02:Upload 77.73%
14:07:05:WU00:FS02:Upload 82.37%
14:07:11:WU00:FS02:Upload 87.01%
14:07:17:WU00:FS02:Upload 91.65%
14:07:23:WU00:FS02:Upload 96.87%
14:07:29:WU00:FS02:Upload complete
14:07:29:WU00:FS02:Server responded WORK_ACK (400)
14:07:29:WU00:FS02:Final credit estimate, 12488.00 points
14:07:29:WU00:FS02:Cleaning up
14:08:10:WU03:FS02:0xa4:Completed 5000 out of 250000 steps (2%)
14:09:31:WU03:FS02:0xa4:Completed 7500 out of 250000 steps (3%)
14:10:52:WU03:FS02:0xa4:Completed 10000 out of 250000 steps (4%)
14:12:14:WU03:FS02:0xa4:Completed 12500 out of 250000 steps (5%)
14:13:35:WU03:FS02:0xa4:Completed 15000 out of 250000 steps (6%)
14:14:56:WU03:FS02:0xa4:Completed 17500 out of 250000 steps (7%)
14:16:19:WU03:FS02:0xa4:Completed 20000 out of 250000 steps (8%)
14:17:39:WU03:FS02:0xa4:Completed 22500 out of 250000 steps (9%)
14:19:02:WU03:FS02:0xa4:Completed 25000 out of 250000 steps (10%)
14:20:21:WU02:FS00:0x17:Completed 1750000 out of 2500000 steps (70%)
14:20:27:WU03:FS02:0xa4:Completed 27500 out of 250000 steps (11%)
14:21:41:WU01:FS01:0x17:Completed 1925000 out of 2500000 steps (77%)
14:21:52:WU03:FS02:0xa4:Completed 30000 out of 250000 steps (12%)
14:23:13:WU03:FS02:0xa4:Completed 32500 out of 250000 steps (13%)
14:24:34:WU03:FS02:0xa4:Completed 35000 out of 250000 steps (14%)
14:25:57:WU03:FS02:0xa4:Completed 37500 out of 250000 steps (15%)
14:27:20:WU03:FS02:0xa4:Completed 40000 out of 250000 steps (16%)
14:28:43:WU03:FS02:0xa4:Completed 42500 out of 250000 steps (17%)
14:30:05:WU03:FS02:0xa4:Completed 45000 out of 250000 steps (18%)
14:31:28:WU03:FS02:0xa4:Completed 47500 out of 250000 steps (19%)
14:32:49:WU03:FS02:0xa4:Completed 50000 out of 250000 steps (20%)
14:34:10:WU03:FS02:0xa4:Completed 52500 out of 250000 steps (21%)
14:35:31:WU03:FS02:0xa4:Completed 55000 out of 250000 steps (22%)
14:36:41:WU02:FS00:0x17:Completed 1775000 out of 2500000 steps (71%)
14:36:53:WU03:FS02:0xa4:Completed 57500 out of 250000 steps (23%)
14:38:15:WU03:FS02:0xa4:Completed 60000 out of 250000 steps (24%)
14:39:01:WU01:FS01:0x17:Completed 1950000 out of 2500000 steps (78%)
14:39:38:WU03:FS02:0xa4:Completed 62500 out of 250000 steps (25%)
14:40:59:WU03:FS02:0xa4:Completed 65000 out of 250000 steps (26%)
14:42:21:WU03:FS02:0xa4:Completed 67500 out of 250000 steps (27%)
14:43:43:WU03:FS02:0xa4:Completed 70000 out of 250000 steps (28%)
14:45:02:WU03:FS02:0xa4:Completed 72500 out of 250000 steps (29%)
14:46:24:WU03:FS02:0xa4:Completed 75000 out of 250000 steps (30%)
14:47:46:WU03:FS02:0xa4:Completed 77500 out of 250000 steps (31%)
14:49:07:WU03:FS02:0xa4:Completed 80000 out of 250000 steps (32%)
14:50:29:WU03:FS02:0xa4:Completed 82500 out of 250000 steps (33%)
14:51:50:WU03:FS02:0xa4:Completed 85000 out of 250000 steps (34%)
14:52:44:WU02:FS00:0x17:Completed 1800000 out of 2500000 steps (72%)
14:53:12:WU03:FS02:0xa4:Completed 87500 out of 250000 steps (35%)
14:54:32:WU03:FS02:0xa4:Completed 90000 out of 250000 steps (36%)
14:55:53:WU03:FS02:0xa4:Completed 92500 out of 250000 steps (37%)
14:56:35:WU01:FS01:0x17:Completed 1975000 out of 2500000 steps (79%)
14:57:15:WU03:FS02:0xa4:Completed 95000 out of 250000 steps (38%)
14:58:37:WU03:FS02:0xa4:Completed 97500 out of 250000 steps (39%)
14:59:59:WU03:FS02:0xa4:Completed 100000 out of 250000 steps (40%)
15:01:21:WU03:FS02:0xa4:Completed 102500 out of 250000 steps (41%)
15:02:42:WU03:FS02:0xa4:Completed 105000 out of 250000 steps (42%)
15:04:03:WU03:FS02:0xa4:Completed 107500 out of 250000 steps (43%)
15:05:25:WU03:FS02:0xa4:Completed 110000 out of 250000 steps (44%)
15:06:47:WU03:FS02:0xa4:Completed 112500 out of 250000 steps (45%)
15:08:09:WU03:FS02:0xa4:Completed 115000 out of 250000 steps (46%)
15:09:03:WU02:FS00:0x17:Completed 1825000 out of 2500000 steps (73%)
15:09:29:WU03:FS02:0xa4:Completed 117500 out of 250000 steps (47%)
15:10:48:WU03:FS02:0xa4:Completed 120000 out of 250000 steps (48%)
15:12:08:WU03:FS02:0xa4:Completed 122500 out of 250000 steps (49%)
15:13:30:WU03:FS02:0xa4:Completed 125000 out of 250000 steps (50%)
15:13:48:WU01:FS01:0x17:Completed 2000000 out of 2500000 steps (80%)
15:14:51:WU03:FS02:0xa4:Completed 127500 out of 250000 steps (51%)
15:16:10:WU03:FS02:0xa4:Completed 130000 out of 250000 steps (52%)
15:17:31:WU03:FS02:0xa4:Completed 132500 out of 250000 steps (53%)
15:18:51:WU03:FS02:0xa4:Completed 135000 out of 250000 steps (54%)
15:20:13:WU03:FS02:0xa4:Completed 137500 out of 250000 steps (55%)
15:21:34:WU03:FS02:0xa4:Completed 140000 out of 250000 steps (56%)
15:22:55:WU03:FS02:0xa4:Completed 142500 out of 250000 steps (57%)
15:24:15:WU03:FS02:0xa4:Completed 145000 out of 250000 steps (58%)
15:25:07:WU02:FS00:0x17:Completed 1850000 out of 2500000 steps (74%)
15:25:36:WU03:FS02:0xa4:Completed 147500 out of 250000 steps (59%)
15:26:57:WU03:FS02:0xa4:Completed 150000 out of 250000 steps (60%)
15:28:19:WU03:FS02:0xa4:Completed 152500 out of 250000 steps (61%)
15:29:40:WU03:FS02:0xa4:Completed 155000 out of 250000 steps (62%)
15:31:02:WU03:FS02:0xa4:Completed 157500 out of 250000 steps (63%)
15:31:22:WU01:FS01:0x17:Completed 2025000 out of 2500000 steps (81%)
15:32:24:WU03:FS02:0xa4:Completed 160000 out of 250000 steps (64%)
15:33:45:WU03:FS02:0xa4:Completed 162500 out of 250000 steps (65%)
15:35:05:WU03:FS02:0xa4:Completed 165000 out of 250000 steps (66%)
15:36:25:WU03:FS02:0xa4:Completed 167500 out of 250000 steps (67%)
15:37:46:WU03:FS02:0xa4:Completed 170000 out of 250000 steps (68%)
15:39:07:WU03:FS02:0xa4:Completed 172500 out of 250000 steps (69%)
15:40:28:WU03:FS02:0xa4:Completed 175000 out of 250000 steps (70%)
15:41:29:WU02:FS00:0x17:Completed 1875000 out of 2500000 steps (75%)
15:41:50:WU03:FS02:0xa4:Completed 177500 out of 250000 steps (71%)
15:43:12:WU03:FS02:0xa4:Completed 180000 out of 250000 steps (72%)
15:44:34:WU03:FS02:0xa4:Completed 182500 out of 250000 steps (73%)
15:45:56:WU03:FS02:0xa4:Completed 185000 out of 250000 steps (74%)
15:47:18:WU03:FS02:0xa4:Completed 187500 out of 250000 steps (75%)
15:48:34:WU01:FS01:0x17:Completed 2050000 out of 2500000 steps (82%)
15:48:42:WU03:FS02:0xa4:Completed 190000 out of 250000 steps (76%)
15:50:04:WU03:FS02:0xa4:Completed 192500 out of 250000 steps (77%)
15:51:26:WU03:FS02:0xa4:Completed 195000 out of 250000 steps (78%)
15:52:47:WU03:FS02:0xa4:Completed 197500 out of 250000 steps (79%)
15:54:09:WU03:FS02:0xa4:Completed 200000 out of 250000 steps (80%)
15:55:31:WU03:FS02:0xa4:Completed 202500 out of 250000 steps (81%)
15:56:54:WU03:FS02:0xa4:Completed 205000 out of 250000 steps (82%)
15:57:33:WU02:FS00:0x17:Completed 1900000 out of 2500000 steps (76%)
15:58:16:WU03:FS02:0xa4:Completed 207500 out of 250000 steps (83%)
15:59:37:WU03:FS02:0xa4:Completed 210000 out of 250000 steps (84%)
16:00:59:WU03:FS02:0xa4:Completed 212500 out of 250000 steps (85%)
16:02:19:WU03:FS02:0xa4:Completed 215000 out of 250000 steps (86%)
16:03:39:WU03:FS02:0xa4:Completed 217500 out of 250000 steps (87%)
16:04:58:WU03:FS02:0xa4:Completed 220000 out of 250000 steps (88%)
16:06:09:WU01:FS01:0x17:Completed 2075000 out of 2500000 steps (83%)
16:06:18:WU03:FS02:0xa4:Completed 222500 out of 250000 steps (89%)
16:07:40:WU03:FS02:0xa4:Completed 225000 out of 250000 steps (90%)
16:09:01:WU03:FS02:0xa4:Completed 227500 out of 250000 steps (91%)
16:10:21:WU03:FS02:0xa4:Completed 230000 out of 250000 steps (92%)
16:11:40:WU03:FS02:0xa4:Completed 232500 out of 250000 steps (93%)
16:13:00:WU03:FS02:0xa4:Completed 235000 out of 250000 steps (94%)
16:13:56:WU02:FS00:0x17:Completed 1925000 out of 2500000 steps (77%)
16:14:21:WU03:FS02:0xa4:Completed 237500 out of 250000 steps (95%)
16:15:43:WU03:FS02:0xa4:Completed 240000 out of 250000 steps (96%)
16:17:06:WU03:FS02:0xa4:Completed 242500 out of 250000 steps (97%)
16:18:29:WU03:FS02:0xa4:Completed 245000 out of 250000 steps (98%)
16:18:29:WU00:FS02:Connecting to assign3.stanford.edu:8080
16:18:29:WU00:FS02:News: Welcome to Folding@Home
16:18:29:WU00:FS02:Assigned to work server 171.67.108.60
16:18:29:WU00:FS02:Requesting new work unit for slot 02: RUNNING cpu:7 from 171.67.108.60
16:18:29:WU00:FS02:Connecting to 171.67.108.60:8080
16:18:30:WU00:FS02
16:18:31:WU00:FS02
16:18:31:WU00:FS02:Received Unit: id:00 state
16:19:51:WU03:FS02:0xa4:Completed 247500 out of 250000 steps (99%)
16:21:13:WU03:FS02:0xa4:Completed 250000 out of 250000 steps (100%)
16:21:23:WU03:FS02:0xa4:
16:21:23:WU03:FS02:0xa4:Finished Work Unit:
16:21:23:WU03:FS02:0xa4:- Reading up to 1567212 from \"03/wudata_01.trr\": Read 1567212
16:21:23:WU03:FS02:0xa4:trr file hash check passed.
16:21:23:WU03:FS02:0xa4:- Reading up to 1759284 from \"03/wudata_01.xtc\": Read 1759284
16:21:23:WU03:FS02:0xa4:xtc file hash check passed.
16:21:23:WU03:FS02:0xa4:edr file hash check passed.
16:21:23:WU03:FS02:0xa4:logfile size: 27082
16:21:23:WU03:FS02:0xa4:Leaving Run
16:21:27:WU03:FS02:0xa4:- Writing 3363006 bytes of core data to disk...
16:21:27:WU03:FS02:0xa4: ... Done.
16:21:27:WU03:FS02:0xa4:- Shutting down core
16:21:27:WU03:FS02:0xa4:Folding@home Core Shutdown: FINISHED_UNIT
16:21:28:WU03:FS02:FahCore returned: FINISHED_UNIT (100 = 0x64)
16:21:28:WU03:FS02:Sending unit results: id:03 state:SEND error:NO_ERROR project:8702 run:24 clone:2 gen:3 core:0xa4 unit:0x000000036652edb35196eb4883af6b40
16:21:28:WU03:FS02:Uploading 3.09MiB to 171.67.108.35
16:21:28:WU03:FS02:Connecting to 171.67.108.35:8080
16:21:28:WU00:FS02:Starting
16:21:28:WU00:FS02:Running FahCore: \"C:\\Program Files (x86)\\FAHClient/FAHCoreWrapper.exe\" C:/Users/Brad/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 00 -suffix 01 -version 703 -lifeline 2208 -checkpoint 15 -np 7
16:21:28:WU00:FS02:Started FahCore on PID 6268
16:21:28:WU00:FS02:Core PID:6340
16:21:28:WU00:FS02:FahCore 0xa4 started
16:21:28:WU00:FS02:0xa4:
16:21:28:WU00:FS02:0xa4:*------------------------------*
16:21:28:WU00:FS02:0xa4:Folding@Home Gromacs GB Core
16:21:28:WU00:FS02:0xa4:Version 2.27 (Dec. 15, 2010)
16:21:28:WU00:FS02:0xa4:- Looking at optimizations...
16:21:28:WU00:FS02:0xa4:- Created dyn
16:21:28:WU00:FS02:0xa4:- Files status OK
16:21:28:WU00:FS02:0xa4:- Expanded 1118014 -> 3126200 (decompressed 279.6 percent)
16:21:28:WU00:FS02:0xa4:Called DecompressByteArray: compressed_data_size=1118014 data_size=3126200, decompressed_data_size=3126200 diff=0
16:21:28:WU00:FS02:0xa4:- Digital signature verified
16:21:28:WU00:FS02:0xa4:Assembly optimizations on if available.
16:21:28:WU00:FS02:0xa4:Entering M.D.
16:21:34:WU03:FS02:Upload 20.19%
16:21:34:WU00:FS02:0xa4:Mapping NT from 7 to 7
16:21:34:WU00:FS02:0xa4:Completed 0 out of 1500000 steps (0%)
16:21:40:WU03:FS02:Upload 38.37%
16:21:46:WU03:FS02:Upload 54.53%
16:21:52:WU03:FS02:Upload 72.70%
16:21:58:WU03:FS02:Upload 88.86%
16:22:03:WU03:FS02:Upload complete
16:22:03:WU03:FS02:Server responded WORK_ACK (400)
16:22:03:WU03:FS02:Final credit estimate, 1461.00 points
16:22:03:WU03:FS02:Cleaning up
16:23:23:WU01:FS01:0x17:Completed 2100000 out of 2500000 steps (84%)
16:29:53:WU00:FS02:0xa4:Completed 15000 out of 1500000 steps (1%)
16:30:00:WU02:FS00:0x17:Completed 1950000 out of 2500000 steps (78%)
16:38:08:WU00:FS02:0xa4:Completed 30000 out of 1500000 steps (2%)
16:41:00:WU01:FS01:0x17:Completed 2125000 out of 2500000 steps (85%)
16:46:19:WU02:FS00:0x17:Completed 1975000 out of 2500000 steps (79%)
16:46:21:WU00:FS02:0xa4:Completed 45000 out of 1500000 steps (3%)
16:54:32:WU00:FS02:0xa4:Completed 60000 out of 1500000 steps (4%)
16:58:15:WU01:FS01:0x17:Completed 2150000 out of 2500000 steps (86%)
17:02:21:WU02:FS00:0x17:Completed 2000000 out of 2500000 steps (80%)
17:02:52:WU00:FS02:0xa4:Completed 75000 out of 1500000 steps (5%)
17:10:58:WU00:FS02:0xa4:Completed 90000 out of 1500000 steps (6%)
17:15:48:WU01:FS01:0x17:Completed 2175000 out of 2500000 steps (87%)
17:18:42:WU02:FS00:0x17:Completed 2025000 out of 2500000 steps (81%)
17:19:12:WU00:FS02:0xa4:Completed 105000 out of 1500000 steps (7%)
17:27:28:WU00:FS02:0xa4:Completed 120000 out of 1500000 steps (8%)
17:33:06:WU01:FS01:0x17:Completed 2200000 out of 2500000 steps (88%)
17:34:44:WU02:FS00:0x17:Completed 2050000 out of 2500000 steps (82%)
17:35:47:WU00:FS02:0xa4:Completed 135000 out of 1500000 steps (9%)
17:44:02:WU00:FS02:0xa4:Completed 150000 out of 1500000 steps (10%)
17:50:43:WU01:FS01:0x17:Completed 2225000 out of 2500000 steps (89%)
17:51:06:WU02:FS00:0x17:Completed 2075000 out of 2500000 steps (83%)
17:52:17:WU00:FS02:0xa4:Completed 165000 out of 1500000 steps (11%)
18:00:32:WU00:FS02:0xa4:Completed 180000 out of 1500000 steps (12%)
18:07:09:WU02:FS00:0x17:Completed 2100000 out of 2500000 steps (84%)
18:07:57:WU01:FS01:0x17:Completed 2250000 out of 2500000 steps (90%)
18:08:48:WU00:FS02:0xa4:Completed 195000 out of 1500000 steps (13%)
18:17:03:WU00:FS02:0xa4:Completed 210000 out of 1500000 steps (14%)
18:23:32:WU02:FS00:0x17:Completed 2125000 out of 2500000 steps (85%)
18:25:18:WU00:FS02:0xa4:Completed 225000 out of 1500000 steps (15%)
18:25:32:WU01:FS01:0x17:Completed 2275000 out of 2500000 steps (91%)
18:33:32:WU00:FS02:0xa4:Completed 240000 out of 1500000 steps (16%)
18:39:35:WU02:FS00:0x17:Completed 2150000 out of 2500000 steps (86%)
18:41:44:WU00:FS02:0xa4:Completed 255000 out of 1500000 steps (17%)
18:42:48:WU01:FS01:0x17:Completed 2300000 out of 2500000 steps (92%)
18:49:58:WU00:FS02:0xa4:Completed 270000 out of 1500000 steps (18%)
18:55:55:WU02:FS00:0x17:Completed 2175000 out of 2500000 steps (87%)
18:58:10:WU00:FS02:0xa4:Completed 285000 out of 1500000 steps (19%)
19:00:23:WU01:FS01:0x17:Completed 2325000 out of 2500000 steps (93%)
19:06:25:WU00:FS02:0xa4:Completed 300000 out of 1500000 steps (20%)
19:11:56:WU02:FS00:0x17:Completed 2200000 out of 2500000 steps (88%)
19:14:46:WU00:FS02:0xa4:Completed 315000 out of 1500000 steps (21%)
19:17:38:WU01:FS01:0x17:Completed 2350000 out of 2500000 steps (94%)
19:22:57:WU00:FS02:0xa4:Completed 330000 out of 1500000 steps (22%)
19:28:17:WU02:FS00:0x17:Completed 2225000 out of 2500000 steps (89%)
19:31:10:WU00:FS02:0xa4:Completed 345000 out of 1500000 steps (23%)
19:35:12:WU01:FS01:0x17:Completed 2375000 out of 2500000 steps (95%)
19:39:26:WU00:FS02:0xa4:Completed 360000 out of 1500000 steps (24%)
19:44:17:WU02:FS00:0x17:Completed 2250000 out of 2500000 steps (90%)
19:47:43:WU00:FS02:0xa4:Completed 375000 out of 1500000 steps (25%)
19:52:26:WU01:FS01:0x17:Completed 2400000 out of 2500000 steps (96%)
19:56:00:WU00:FS02:0xa4:Completed 390000 out of 1500000 steps (26%)
20:00:40:WU02:FS00:0x17:Completed 2275000 out of 2500000 steps (91%)
20:04:17:WU00:FS02:0xa4:Completed 405000 out of 1500000 steps (27%)
20:09:58:WU01:FS01:0x17:Completed 2425000 out of 2500000 steps (97%)
20:12:25:WU00:FS02:0xa4:Completed 420000 out of 1500000 steps (28%)
20:16:43:WU02:FS00:0x17:Completed 2300000 out of 2500000 steps (92%)
20:20:41:WU00:FS02:0xa4:Completed 435000 out of 1500000 steps (29%)
20:27:12:WU01:FS01:0x17:Completed 2450000 out of 2500000 steps (98%)
20:27:13:WU03:FS01:Connecting to assign-GPU.stanford.edu:80
20:27:13:WU03:FS01:News: Welcome to Folding@Home
20:27:13:WU03:FS01:Assigned to work server 171.64.65.69
20:27:13:WU03:FS01:Requesting new work unit for slot 01: RUNNING gpu:1:Barts XT [ATI Radeon HD 6800 Series] from 171.64.65.69
20:27:13:WU03:FS01:Connecting to 171.64.65.69:8080
20:27:13:WU03:FS01
20:27:16:WU03:FS01
20:27:16:WU03:FS01:Received Unit: id:03 state
20:28:59:WU00:FS02:0xa4:Completed 450000 out of 1500000 steps (30%)
20:33:06:WU02:FS00:0x17:Completed 2325000 out of 2500000 steps (93%)
20:37:14:WU00:FS02:0xa4:Completed 465000 out of 1500000 steps (31%)
20:44:46:WU01:FS01:0x17:Completed 2475000 out of 2500000 steps (99%)
20:45:27:WU00:FS02:0xa4:Completed 480000 out of 1500000 steps (32%)
20:49:08:WU02:FS00:0x17:Completed 2350000 out of 2500000 steps (94%)
20:53:43:WU00:FS02:0xa4:Completed 495000 out of 1500000 steps (33%)
21:01:55:WU00:FS02:0xa4:Completed 510000 out of 1500000 steps (34%)
21:02:02:WU01:FS01:0x17:Completed 2500000 out of 2500000 steps (100%)
21:02:22:WU01:FS01:0x17:Saving result file logfile_01.txt
21:02:22:WU01:FS01:0x17:Saving result file checkpointState.xml
21:02:24:WU01:FS01:0x17:Saving result file checkpt.crc
21:02:24:WU01:FS01:0x17:Saving result file log.txt
21:02:24:WU01:FS01:0x17:Saving result file positions.xtc
21:02:26:WU01:FS01:0x17:Folding@home Core Shutdown: FINISHED_UNIT
21:02:27:WU01:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
21:02:27:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:8900 run:359 clone:1 gen:21 core:0x17 unit:0x00000018028c126651a6767321c7a4b2
21:02:27:WU01:FS01:Uploading 12.96MiB to 171.64.65.69
21:02:27:WU01:FS01:Connecting to 171.64.65.69:8080
21:02:27:WU03:FS01:Starting
21:02:27:WU03:FS01:Running FahCore: \"C:\\Program Files (x86)\\FAHClient/FAHCoreWrapper.exe\" C:/Users/Brad/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/beta/Core_17.fah/FahCore_17.exe -dir 03 -suffix 01 -version 703 -lifeline 2208 -checkpoint 15 -gpu 1 -gpu-vendor ati
21:02:27:WU03:FS01:Started FahCore on PID 3384
21:02:27:WU03:FS01:Core PID:6292
21:02:27:WU03:FS01:FahCore 0x17 started
21:02:27:WU03:FS01:0x17:*********************** Log Started 2013-06-22T21:02:27Z ***********************
21:02:27:WU03:FS01:0x17:Unit: 0x00000017028c126651a6bac181eeb0ac
21:02:27:WU03:FS01:0x17:CPU: 0x00000000000000000000000000000000
21:02:27:WU03:FS01:0x17:Machine: 1
21:02:27:WU03:FS01:0x17:Reading tar file state.xml
21:02:28:WU03:FS01:0x17:Reading tar file system.xml
21:02:28:WU03:FS01:0x17:Reading tar file integrator.xml
21:02:28:WU03:FS01:0x17:Reading tar file core.xml
21:02:33:WU01:FS01:Upload 5.31%
21:02:39:WU01:FS01:Upload 9.16%
21:02:45:WU01:FS01:Upload 13.02%
21:02:51:WU01:FS01:Upload 17.36%
21:02:57:WU01:FS01:Upload 21.22%
21:03:03:WU01:FS01:Upload 25.08%
21:03:09:WU01:FS01:Upload 29.42%
21:03:15:WU01:FS01:Upload 33.28%
21:03:21:WU01:FS01:Upload 37.62%
21:03:27:WU01:FS01:Upload 41.48%
21:03:33:WU01:FS01:Upload 45.33%
21:03:39:WU01:FS01:Upload 49.68%
21:03:45:WU01:FS01:Upload 53.53%
21:03:51:WU01:FS01:Upload 57.39%
21:03:57:WU01:FS01:Upload 61.25%
21:04:03:WU01:FS01:Upload 65.59%
21:04:09:WU01:FS01:Upload 69.45%
21:04:15:WU01:FS01:Upload 73.79%
21:04:21:WU01:FS01:Upload 77.65%
21:04:27:WU01:FS01:Upload 81.99%
21:04:33:WU01:FS01:Upload 85.85%
21:04:39:WU01:FS01:Upload 89.71%
21:04:45:WU01:FS01:Upload 93.56%
21:04:51:WU01:FS01:Upload 97.42%
21:05:02:WU01:FS01:Upload complete
21:05:03:WU01:FS01:Server responded WORK_ACK (400)
21:05:03:WU01:FS01:Final credit estimate, 14068.00 points
21:05:03:WU01:FS01:Cleaning up
21:05:13:WU03:FS01:0x17:Completed 0 out of 2500000 steps (0%)
21:05:36:WU02:FS00:0x17:Completed 2375000 out of 2500000 steps (95%)
21:10:23:WU00:FS02:0xa4:Completed 525000 out of 1500000 steps (35%)
21:18:37:WU00:FS02:0xa4:Completed 540000 out of 1500000 steps (36%)
21:21:37:WU02:FS00:0x17:Completed 2400000 out of 2500000 steps (96%)
21:22:42:WU03:FS01:0x17:Completed 25000 out of 2500000 steps (1%)
21:26:52:WU00:FS02:0xa4:Completed 555000 out of 1500000 steps (37%)
21:35:05:WU00:FS02:0xa4:Completed 570000 out of 1500000 steps (38%)
21:37:56:WU02:FS00:0x17:Completed 2425000 out of 2500000 steps (97%)
21:39:53:WU03:FS01:0x17:Completed 50000 out of 2500000 steps (2%)
21:43:22:WU00:FS02:0xa4:Completed 585000 out of 1500000 steps (39%)
21:51:35:WU00:FS02:0xa4:Completed 600000 out of 1500000 steps (40%)
21:53:58:WU02:FS00:0x17:Completed 2450000 out of 2500000 steps (98%)
21:53:59:WU01:FS00:Connecting to assign-GPU.stanford.edu:80
21:53:59:WU01:FS00:News: Welcome to Folding@Home
21:53:59:WU01:FS00:Assigned to work server 171.64.65.69
21:53:59:WU01:FS00:Requesting new work unit for slot 00: RUNNING gpu:0:Barts XT [ATI Radeon HD 6800 Series] from 171.64.65.69
21:53:59:WU01:FS00:Connecting to 171.64.65.69:8080
21:53:59:WU01:FS00
21:54:02:WU01:FS00
21:54:02:WU01:FS00:Received Unit: id:01 state
21:57:25:WU03:FS01:0x17:Completed 75000 out of 2500000 steps (3%)
21:59:52:WU00:FS02:0xa4:Completed 615000 out of 1500000 steps (41%)
22:08:04:WU00:FS02:0xa4:Completed 630000 out of 1500000 steps (42%)
22:10:20:WU02:FS00:0x17:Completed 2475000 out of 2500000 steps (99%)
22:14:36:WU03:FS01:0x17:Completed 100000 out of 2500000 steps (4%)
22:16:22:WU00:FS02:0xa4:Completed 645000 out of 1500000 steps (43%)
22:24:40:WU00:FS02:0xa4:Completed 660000 out of 1500000 steps (44%)
22:26:23:WU02:FS00:0x17:Completed 2500000 out of 2500000 steps (100%)
22:26:42:WU02:FS00:0x17:Saving result file logfile_01.txt
22:26:42:WU02:FS00:0x17:Saving result file checkpointState.xml
22:26:44:WU02:FS00:0x17:Saving result file checkpt.crc
22:26:44:WU02:FS00:0x17:Saving result file log.txt
22:26:44:WU02:FS00:0x17:Saving result file positions.xtc
22:26:47:WU02:FS00:0x17:Folding@home Core Shutdown: FINISHED_UNIT
22:26:47:WU02:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
22:26:47:WU02:FS00:Sending unit results: id:02 state:SEND error:NO_ERROR project:8900 run:749 clone:1 gen:9 core:0x17 unit:0x0000000d028c126651a6cd406ad018d7
22:26:47:WU02:FS00:Uploading 12.96MiB to 171.64.65.69
22:26:47:WU02:FS00:Connecting to 171.64.65.69:8080
22:26:47:WU01:FS00:Starting
22:26:47:WU01:FS00:Running FahCore: \"C:\\Program Files (x86)\\FAHClient/FAHCoreWrapper.exe\" C:/Users/Brad/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/beta/Core_17.fah/FahCore_17.exe -dir 01 -suffix 01 -version 703 -lifeline 2208 -checkpoint 15 -gpu 0 -gpu-vendor ati
22:26:47:WU01:FS00:Started FahCore on PID 5896
22:26:47:WU01:FS00:Core PID:4228
22:26:47:WU01:FS00:FahCore 0x17 started
22:26:48:WU01:FS00:0x17:*********************** Log Started 2013-06-22T22:26:47Z ***********************
22:26:48:WU01:FS00:0x17:Unit: 0x00000017028c126651a66b8c1138fbd1
22:26:48:WU01:FS00:0x17:CPU: 0x00000000000000000000000000000000
22:26:48:WU01:FS00:0x17:Machine: 0
22:26:48:WU01:FS00:0x17:Reading tar file state.xml
22:26:48:WU01:FS00:0x17:Reading tar file system.xml
22:26:48:WU01:FS00:0x17:Reading tar file integrator.xml
22:26:48:WU01:FS00:0x17:Reading tar file core.xml
22:26:53:WU02:FS00:Upload 4.82%
22:26:59:WU02:FS00:Upload 8.68%
22:27:05:WU02:FS00:Upload 13.02%
22:27:11:WU02:FS00:Upload 16.88%
22:27:17:WU02:FS00:Upload 21.22%
22:27:23:WU02:FS00:Upload 25.07%
22:27:29:WU02:FS00:Upload 28.93%
22:27:35:WU02:FS00:Upload 33.27%
22:27:41:WU02:FS00:Upload 37.13%
22:27:47:WU02:FS00:Upload 40.99%
22:27:53:WU02:FS00:Upload 45.32%
22:27:59:WU02:FS00:Upload 49.18%
22:28:05:WU02:FS00:Upload 53.52%
22:28:11:WU02:FS00:Upload 57.86%
22:28:17:WU02:FS00:Upload 61.72%
22:28:23:WU02:FS00:Upload 65.58%
22:28:29:WU02:FS00:Upload 69.43%
22:28:35:WU02:FS00:Upload 73.29%
22:28:41:WU02:FS00:Upload 77.63%
22:28:47:WU02:FS00:Upload 81.49%
22:28:53:WU02:FS00:Upload 85.83%
22:28:59:WU02:FS00:Upload 89.69%
22:29:05:WU02:FS00:Upload 93.54%
22:29:11:WU02:FS00:Upload 97.88%
22:29:22:WU02:FS00:Upload complete
22:29:23:WU02:FS00:Server responded WORK_ACK (400)
22:29:23:WU02:FS00:Final credit estimate, 11383.00 points
22:29:23:WU02:FS00:Cleaning up
22:29:39:WU01:FS00:0x17:Completed 0 out of 2500000 steps (0%)
22:32:13:WU03:FS01:0x17:Completed 125000 out of 2500000 steps (5%)
22:32:59:WU00:FS02:0xa4:Completed 675000 out of 1500000 steps (45%)
22:41:07:WU00:FS02:0xa4:Completed 690000 out of 1500000 steps (46%)
22:45:55:WU01:FS00:0x17:Completed 25000 out of 2500000 steps (1%)
22:49:11:WU00:FS02:0xa4:Completed 705000 out of 1500000 steps (47%)
22:49:25:WU03:FS01:0x17:Completed 150000 out of 2500000 steps (6%)
22:57:28:WU00:FS02:0xa4:Completed 720000 out of 1500000 steps (48%)
23:01:57:WU01:FS00:0x17:Completed 50000 out of 2500000 steps (2%)
23:05:46:WU00:FS02:0xa4:Completed 735000 out of 1500000 steps (49%)
23:06:57:WU03:FS01:0x17:Completed 175000 out of 2500000 steps (7%)
23:14:02:WU00:FS02:0xa4:Completed 750000 out of 1500000 steps (50%)
23:18:16:WU01:FS00:0x17:Completed 75000 out of 2500000 steps (3%)
23:22:12:WU00:FS02:0xa4:Completed 765000 out of 1500000 steps (51%)
23:24:07:WU03:FS01:0x17:Completed 200000 out of 2500000 steps (8%)
23:30:27:WU00:FS02:0xa4:Completed 780000 out of 1500000 steps (52%)
23:34:18:WU01:FS00:0x17:Completed 100000 out of 2500000 steps (4%)
23:38:42:WU00:FS02:0xa4:Completed 795000 out of 1500000 steps (53%)
23:41:38:WU03:FS01:0x17:Completed 225000 out of 2500000 steps (9%)
23:47:00:WU00:FS02:0xa4:Completed 810000 out of 1500000 steps (54%)
23:50:39:WU01:FS00:0x17:Completed 125000 out of 2500000 steps (5%)
23:55:16:WU00:FS02:0xa4:Completed 825000 out of 1500000 steps (55%)
23:58:48:WU03:FS01:0x17:Completed 250000 out of 2500000 steps (10%)
00:03:31:WU00:FS02:0xa4:Completed 840000 out of 1500000 steps (56%)
00:06:44:WU01:FS00:0x17:Completed 150000 out of 2500000 steps (6%)
00:11:45:WU00:FS02:0xa4:Completed 855000 out of 1500000 steps (57%)
00:16:19:WU03:FS01:0x17:Completed 275000 out of 2500000 steps (11%)
00:19:50:WU00:FS02:0xa4:Completed 870000 out of 1500000 steps (58%)
00:23:03:WU01:FS00:0x17:Completed 175000 out of 2500000 steps (7%)
00:27:52:WU00:FS02:0xa4:Completed 885000 out of 1500000 steps (59%)
00:33:27:WU03:FS01:0x17:Completed 300000 out of 2500000 steps (12%)
00:36:00:WU00:FS02:0xa4:Completed 900000 out of 1500000 steps (60%)
00:39:07:WU01:FS00:0x17:Completed 200000 out of 2500000 steps (8%)
00:44:08:WU00:FS02:0xa4:Completed 915000 out of 1500000 steps (61%)
00:50:56:WU03:FS01:0x17:Completed 325000 out of 2500000 steps (13%)
00:52:11:WU00:FS02:0xa4:Completed 930000 out of 1500000 steps (62%)
00:55:27:WU01:FS00:0x17:Completed 225000 out of 2500000 steps (9%)
01:00:15:WU00:FS02:0xa4:Completed 945000 out of 1500000 steps (63%)
01:08:04:WU03:FS01:0x17:Completed 350000 out of 2500000 steps (14%)
01:08:19:WU00:FS02:0xa4:Completed 960000 out of 1500000 steps (64%)
01:11:31:WU01:FS00:0x17:Completed 250000 out of 2500000 steps (10%)
01:16:20:WU00:FS02:0xa4:Completed 975000 out of 1500000 steps (65%)
01:24:18:WU00:FS02:0xa4:Completed 990000 out of 1500000 steps (66%)
01:25:32:WU03:FS01:0x17:Completed 375000 out of 2500000 steps (15%)
01:27:54:WU01:FS00:0x17:Completed 275000 out of 2500000 steps (11%)
01:32:20:WU00:FS02:0xa4:Completed 1005000 out of 1500000 steps (67%)
01:40:26:WU00:FS02:0xa4:Completed 1020000 out of 1500000 steps (68%)
01:42:40:WU03:FS01:0x17:Completed 400000 out of 2500000 steps (16%)
01:43:58:WU01:FS00:0x17:Completed 300000 out of 2500000 steps (12%)
01:48:35:WU00:FS02:0xa4:Completed 1035000 out of 1500000 steps (69%)
01:56:38:WU00:FS02:0xa4:Completed 1050000 out of 1500000 steps (70%)
02:00:09:WU03:FS01:0x17:Completed 425000 out of 2500000 steps (17%)
02:00:20:WU01:FS00:0x17:Completed 325000 out of 2500000 steps (13%)
02:04:41:WU00:FS02:0xa4:Completed 1065000 out of 1500000 steps (71%)
02:12:47:WU00:FS02:0xa4:Completed 1080000 out of 1500000 steps (72%)
02:16:24:WU01:FS00:0x17:Completed 350000 out of 2500000 steps (14%)
******************************* Date: 2013-06-23 *******************************
02:17:18:WU03:FS01:0x17:Completed 450000 out of 2500000 steps (18%)
02:20:53:WU00:FS02:0xa4:Completed 1095000 out of 1500000 steps (73%)
02:28:56:WU00:FS02:0xa4:Completed 1110000 out of 1500000 steps (74%)
02:32:44:WU01:FS00:0x17:Completed 375000 out of 2500000 steps (15%)
02:34:46:WU03:FS01:0x17:Completed 475000 out of 2500000 steps (19%)
02:36:59:WU00:FS02:0xa4:Completed 1125000 out of 1500000 steps (75%)
02:45:01:WU00:FS02:0xa4:Completed 1140000 out of 1500000 steps (76%)
02:48:45:WU01:FS00:0x17:Completed 400000 out of 2500000 steps (16%)
02:51:55:WU03:FS01:0x17:Completed 500000 out of 2500000 steps (20%)
02:53:07:WU00:FS02:0xa4:Completed 1155000 out of 1500000 steps (77%)
03:01:05:WU00:FS02:0xa4:Completed 1170000 out of 1500000 steps (78%)
03:05:07:WU01:FS00:0x17:Completed 425000 out of 2500000 steps (17%)
03:09:09:WU00:FS02:0xa4:Completed 1185000 out of 1500000 steps (79%)
03:09:23:WU03:FS01:0x17:Completed 525000 out of 2500000 steps (21%)
03:17:11:WU00:FS02:0xa4:Completed 1200000 out of 1500000 steps (80%)
03:21:08:WU01:FS00:0x17:Completed 450000 out of 2500000 steps (18%)
03:25:18:WU00:FS02:0xa4:Completed 1215000 out of 1500000 steps (81%)
03:26:33:WU03:FS01:0x17:Completed 550000 out of 2500000 steps (22%)
03:33:21:WU00:FS02:0xa4:Completed 1230000 out of 1500000 steps (82%)
03:37:31:WU01:FS00:0x17:Completed 475000 out of 2500000 steps (19%)
03:41:25:WU00:FS02:0xa4:Completed 1245000 out of 1500000 steps (83%)
03:44:00:WU03:FS01:0x17:Completed 575000 out of 2500000 steps (23%)
03:49:28:WU00:FS02:0xa4:Completed 1260000 out of 1500000 steps (84%)
03:53:35:WU01:FS00:0x17:Completed 500000 out of 2500000 steps (20%)
03:57:27:WU00:FS02:0xa4:Completed 1275000 out of 1500000 steps (85%)
04:01:09:WU03:FS01:0x17:Completed 600000 out of 2500000 steps (24%)
04:05:30:WU00:FS02:0xa4:Completed 1290000 out of 1500000 steps (86%)
04:09:58:WU01:FS00:0x17:Completed 525000 out of 2500000 steps (21%)
04:13:39:WU00:FS02:0xa4:Completed 1305000 out of 1500000 steps (87%)
04:18:36:WU03:FS01:0x17:Completed 625000 out of 2500000 steps (25%)
04:21:43:WU00:FS02:0xa4:Completed 1320000 out of 1500000 steps (88%)
04:26:02:WU01:FS00:0x17:Completed 550000 out of 2500000 steps (22%)
04:29:44:WU00:FS02:0xa4:Completed 1335000 out of 1500000 steps (89%)
04:35:47:WU03:FS01:0x17:Completed 650000 out of 2500000 steps (26%)
04:37:53:WU00:FS02:0xa4:Completed 1350000 out of 1500000 steps (90%)
04:42:23:WU01:FS00:0x17:Completed 575000 out of 2500000 steps (23%)
04:45:54:WU00:FS02:0xa4:Completed 1365000 out of 1500000 steps (91%)
04:53:15:WU03:FS01:0x17:Completed 675000 out of 2500000 steps (27%)
04:53:55:WU00:FS02:0xa4:Completed 1380000 out of 1500000 steps (92%)
04:58:24:WU01:FS00:0x17:Completed 600000 out of 2500000 steps (24%)
05:01:59:WU00:FS02:0xa4:Completed 1395000 out of 1500000 steps (93%)
05:09:56:WU00:FS02:0xa4:Completed 1410000 out of 1500000 steps (94%)
05:10:23:WU03:FS01:0x17:Completed 700000 out of 2500000 steps (28%)
05:14:45:WU01:FS00:0x17:Completed 625000 out of 2500000 steps (25%)
05:17:54:WU00:FS02:0xa4:Completed 1425000 out of 1500000 steps (95%)
05:25:55:WU00:FS02:0xa4:Completed 1440000 out of 1500000 steps (96%)
05:27:50:WU03:FS01:0x17:Completed 725000 out of 2500000 steps (29%)
05:30:47:WU01:FS00:0x17:Completed 650000 out of 2500000 steps (26%)
05:33:56:WU00:FS02:0xa4:Completed 1455000 out of 1500000 steps (97%)
05:41:56:WU00:FS02:0xa4:Completed 1470000 out of 1500000 steps (98%)
05:41:57:WU02:FS02:Connecting to assign3.stanford.edu:8080
05:41:57:WU02:FS02:News: Welcome to Folding@Home
05:41:57:WU02:FS02:Assigned to work server 171.67.108.35
05:41:57:WU02:FS02:Requesting new work unit for slot 02: RUNNING cpu:7 from 171.67.108.35
05:41:57:WU02:FS02:Connecting to 171.67.108.35:8080
05:41:58:WU02:FS02
05:41:59:WU02:FS02
05:41:59:WU02:FS02:Received Unit: id:02 state
05:44:59:WU03:FS01:0x17:Completed 750000 out of 2500000 steps (30%)
05:47:10:WU01:FS00:0x17:Completed 675000 out of 2500000 steps (27%)
05:49:59:WU00:FS02:0xa4:Completed 1485000 out of 1500000 steps (99%)
05:58:01:WU00:FS02:0xa4:Completed 1500000 out of 1500000 steps (100%)
05:58:11:WU00:FS02:0xa4:
05:58:11:WU00:FS02:0xa4:Finished Work Unit:
05:58:11:WU00:FS02:0xa4:- Reading up to 1405644 from \"00/wudata_01.trr\": Read 1405644
05:58:11:WU00:FS02:0xa4:trr file hash check passed.
05:58:11:WU00:FS02:0xa4:- Reading up to 4413364 from \"00/wudata_01.xtc\": Read 4413364
05:58:11:WU00:FS02:0xa4:xtc file hash check passed.
05:58:11:WU00:FS02:0xa4:edr file hash check passed.
05:58:11:WU00:FS02:0xa4:logfile size: 43361
05:58:11:WU00:FS02:0xa4:Leaving Run
05:58:13:WU00:FS02:0xa4:- Writing 5884873 bytes of core data to disk...
05:58:14:WU00:FS02:0xa4
05:58:14:WU00:FS02:0xa4: ... Done.
05:58:14:WU00:FS02:0xa4:- Shutting down core
05:58:14:WU00:FS02:0xa4:Folding@home Core Shutdown: FINISHED_UNIT
05:58:15:WU00:FS02:FahCore returned: FINISHED_UNIT (100 = 0x64)
05:58:15:WU00:FS02:Sending unit results: id:00 state:SEND error:NO_ERROR project:8703 run:4369 clone:0 gen:1 core:0xa4 unit:0x000000016652edcc51c2818407f83e8f
05:58:15:WU00:FS02:Uploading 5.52MiB to 171.67.108.60
05:58:15:WU00:FS02:Connecting to 171.67.108.60:8080
05:58:15:WU02:FS02:Starting
05:58:15:WU02:FS02:Running FahCore: \"C:\\Program Files (x86)\\FAHClient/FAHCoreWrapper.exe\" C:/Users/Brad/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 02 -suffix 01 -version 703 -lifeline 2208 -checkpoint 15 -np 7
05:58:15:WU02:FS02:Started FahCore on PID 1680
05:58:15:WU02:FS02:Core PID:2592
05:58:15:WU02:FS02:FahCore 0xa4 started
05:58:15:WU02:FS02:0xa4:
05:58:15:WU02:FS02:0xa4:*------------------------------*
05:58:15:WU02:FS02:0xa4:Folding@Home Gromacs GB Core
05:58:15:WU02:FS02:0xa4:Version 2.27 (Dec. 15, 2010)
05:58:15:WU02:FS02:0xa4:- Looking at optimizations...
05:58:15:WU02:FS02:0xa4:- Created dyn
05:58:15:WU02:FS02:0xa4:- Files status OK
05:58:15:WU02:FS02:0xa4:- Expanded 1025452 -> 2544640 (decompressed 248.1 percent)
05:58:15:WU02:FS02:0xa4:Called DecompressByteArray: compressed_data_size=1025452 data_size=2544640, decompressed_data_size=2544640 diff=0
05:58:15:WU02:FS02:0xa4:- Digital signature verified
05:58:15:WU02:FS02:0xa4:Assembly optimizations on if available.
05:58:15:WU02:FS02:0xa4:Entering M.D.
05:58:21:WU02:FS02:0xa4:Mapping NT from 7 to 7
05:58:21:WU00:FS02:Upload 12.46%
05:58:21:WU02:FS02:0xa4:Completed 0 out of 250000 steps (0%)
05:58:27:WU00:FS02:Upload 22.65%
05:58:33:WU00:FS02:Upload 31.71%
05:58:39:WU00:FS02:Upload 43.04%
05:58:45:WU00:FS02:Upload 52.10%
05:58:51:WU00:FS02:Upload 62.29%
05:58:57:WU00:FS02:Upload 72.48%
05:59:03:WU00:FS02:Upload 82.68%
05:59:09:WU00:FS02:Upload 92.87%
05:59:14:WU00:FS02:Upload complete
05:59:14:WU00:FS02:Server responded WORK_ACK (400)
05:59:14:WU00:FS02:Final credit estimate, 12471.00 points
05:59:14:WU00:FS02:Cleaning up
05:59:41:WU02:FS02:0xa4:Completed 2500 out of 250000 steps (1%)
06:01:01:WU02:FS02:0xa4:Completed 5000 out of 250000 steps (2%)
06:02:21:WU02:FS02:0xa4:Completed 7500 out of 250000 steps (3%)
06:02:23:WU03:FS01:0x17:Completed 775000 out of 2500000 steps (31%)
06:03:12:WU01:FS00:0x17:Completed 700000 out of 2500000 steps (28%)
06:03:41:WU02:FS02:0xa4:Completed 10000 out of 250000 steps (4%)
06:04:59:WU02:FS02:0xa4:Completed 12500 out of 250000 steps (5%)
06:06:19:WU02:FS02:0xa4:Completed 15000 out of 250000 steps (6%)
06:07:37:WU02:FS02:0xa4:Completed 17500 out of 250000 steps (7%)
06:08:58:WU02:FS02:0xa4:Completed 20000 out of 250000 steps (8%)
06:10:16:WU02:FS02:0xa4:Completed 22500 out of 250000 steps (9%)
06:11:35:WU02:FS02:0xa4:Completed 25000 out of 250000 steps (10%)
06:12:54:WU02:FS02:0xa4:Completed 27500 out of 250000 steps (11%)
06:14:13:WU02:FS02:0xa4:Completed 30000 out of 250000 steps (12%)
06:15:32:WU02:FS02:0xa4:Completed 32500 out of 250000 steps (13%)
06:16:51:WU02:FS02:0xa4:Completed 35000 out of 250000 steps (14%)
06:18:09:WU02:FS02:0xa4:Completed 37500 out of 250000 steps (15%)
06:19:29:WU02:FS02:0xa4:Completed 40000 out of 250000 steps (16%)
06:19:30:WU03:FS01:0x17:Completed 800000 out of 2500000 steps (32%)
06:19:35:WU01:FS00:0x17:Completed 725000 out of 2500000 steps (29%)
06:20:48:WU02:FS02:0xa4:Completed 42500 out of 250000 steps (17%)
06:22:07:WU02:FS02:0xa4:Completed 45000 out of 250000 steps (18%)
06:23:26:WU02:FS02:0xa4:Completed 47500 out of 250000 steps (19%)
06:24:45:WU02:FS02:0xa4:Completed 50000 out of 250000 steps (20%)
06:26:04:WU02:FS02:0xa4:Completed 52500 out of 250000 steps (21%)
06:27:24:WU02:FS02:0xa4:Completed 55000 out of 250000 steps (22%)
06:28:41:WU02:FS02:0xa4:Completed 57500 out of 250000 steps (23%)
06:30:01:WU02:FS02:0xa4:Completed 60000 out of 250000 steps (24%)
06:31:20:WU02:FS02:0xa4:Completed 62500 out of 250000 steps (25%)
06:32:40:WU02:FS02:0xa4:Completed 65000 out of 250000 steps (26%)
06:33:59:WU02:FS02:0xa4:Completed 67500 out of 250000 steps (27%)
06:35:18:WU02:FS02:0xa4:Completed 70000 out of 250000 steps (28%)
06:35:40:WU01:FS00:0x17:Completed 750000 out of 2500000 steps (30%)
06:36:38:WU02:FS02:0xa4:Completed 72500 out of 250000 steps (29%)
06:36:55:WU03:FS01:0x17:Completed 825000 out of 2500000 steps (33%)
06:37:55:WU02:FS02:0xa4:Completed 75000 out of 250000 steps (30%)
06:39:12:WU02:FS02:0xa4:Completed 77500 out of 250000 steps (31%)
06:40:31:WU02:FS02:0xa4:Completed 80000 out of 250000 steps (32%)
06:41:50:WU02:FS02:0xa4:Completed 82500 out of 250000 steps (33%)
06:43:08:WU02:FS02:0xa4:Completed 85000 out of 250000 steps (34%)
06:44:25:WU02:FS02:0xa4:Completed 87500 out of 250000 steps (35%)
06:45:43:WU02:FS02:0xa4:Completed 90000 out of 250000 steps (36%)
06:47:01:WU02:FS02:0xa4:Completed 92500 out of 250000 steps (37%)
06:48:18:WU02:FS02:0xa4:Completed 95000 out of 250000 steps (38%)
06:49:34:WU02:FS02:0xa4:Completed 97500 out of 250000 steps (39%)
06:50:51:WU02:FS02:0xa4:Completed 100000 out of 250000 steps (40%)
06:52:00:WU01:FS00:0x17:Completed 775000 out of 2500000 steps (31%)
06:52:09:WU02:FS02:0xa4:Completed 102500 out of 250000 steps (41%)
06:53:28:WU02:FS02:0xa4:Completed 105000 out of 250000 steps (42%)
06:54:01:WU03:FS01:0x17:Completed 850000 out of 2500000 steps (34%)
06:54:45:WU02:FS02:0xa4:Completed 107500 out of 250000 steps (43%)
06:56:01:WU02:FS02:0xa4:Completed 110000 out of 250000 steps (44%)
06:57:18:WU02:FS02:0xa4:Completed 112500 out of 250000 steps (45%)
06:58:38:WU02:FS02:0xa4:Completed 115000 out of 250000 steps (46%)
06:59:54:WU02:FS02:0xa4:Completed 117500 out of 250000 steps (47%)
07:01:14:WU02:FS02:0xa4:Completed 120000 out of 250000 steps (48%)
07:02:33:WU02:FS02:0xa4:Completed 122500 out of 250000 steps (49%)
07:03:53:WU02:FS02:0xa4:Completed 125000 out of 250000 steps (50%)
07:05:14:WU02:FS02:0xa4:Completed 127500 out of 250000 steps (51%)
07:06:45:WU02:FS02:0xa4:Completed 130000 out of 250000 steps (52%)
07:08:03:WU01:FS00:0x17:Completed 800000 out of 2500000 steps (32%)
07:08:19:WU02:FS02:0xa4:Completed 132500 out of 250000 steps (53%)
07:09:53:WU02:FS02:0xa4:Completed 135000 out of 250000 steps (54%)
07:11:22:WU02:FS02:0xa4:Completed 137500 out of 250000 steps (55%)
07:11:35:WU03:FS01:0x17:Completed 875000 out of 2500000 steps (35%)
07:12:52:WU02:FS02:0xa4:Completed 140000 out of 250000 steps (56%)
07:14:23:WU02:FS02:0xa4:Completed 142500 out of 250000 steps (57%)
07:15:53:WU02:FS02:0xa4:Completed 145000 out of 250000 steps (58%)
07:17:22:WU02:FS02:0xa4:Completed 147500 out of 250000 steps (59%)
07:18:52:WU02:FS02:0xa4:Completed 150000 out of 250000 steps (60%)
07:20:23:WU02:FS02:0xa4:Completed 152500 out of 250000 steps (61%)
07:21:53:WU02:FS02:0xa4:Completed 155000 out of 250000 steps (62%)
07:23:16:WU02:FS02:0xa4:Completed 157500 out of 250000 steps (63%)
07:24:25:WU01:FS00:0x17:Completed 825000 out of 2500000 steps (33%)
07:24:42:WU02:FS02:0xa4:Completed 160000 out of 250000 steps (64%)
07:26:11:WU02:FS02:0xa4:Completed 162500 out of 250000 steps (65%)
07:27:40:WU02:FS02:0xa4:Completed 165000 out of 250000 steps (66%)
07:29:08:WU02:FS02:0xa4:Completed 167500 out of 250000 steps (67%)
07:29:26:WU03:FS01:0x17:Completed 900000 out of 2500000 steps (36%)
07:30:34:WU02:FS02:0xa4:Completed 170000 out of 250000 steps (68%)
07:31:58:WU02:FS02:0xa4:Completed 172500 out of 250000 steps (69%)
07:33:24:WU02:FS02:0xa4:Completed 175000 out of 250000 steps (70%)
07:34:49:WU02:FS02:0xa4:Completed 177500 out of 250000 steps (71%)
07:36:16:WU02:FS02:0xa4:Completed 180000 out of 250000 steps (72%)
07:37:41:WU02:FS02:0xa4:Completed 182500 out of 250000 steps (73%)
07:39:06:WU02:FS02:0xa4:Completed 185000 out of 250000 steps (74%)
07:40:28:WU01:FS00:0x17:Completed 850000 out of 2500000 steps (34%)
07:40:32:WU02:FS02:0xa4:Completed 187500 out of 250000 steps (75%)
07:41:57:WU02:FS02:0xa4:Completed 190000 out of 250000 steps (76%)
07:43:20:WU02:FS02:0xa4:Completed 192500 out of 250000 steps (77%)
07:44:41:WU02:FS02:0xa4:Completed 195000 out of 250000 steps (78%)
07:46:07:WU02:FS02:0xa4:Completed 197500 out of 250000 steps (79%)
07:47:15:WU03:FS01:0x17:Completed 925000 out of 2500000 steps (37%)
07:47:35:WU02:FS02:0xa4:Completed 200000 out of 250000 steps (80%)
07:49:03:WU02:FS02:0xa4:Completed 202500 out of 250000 steps (81%)
07:50:35:WU02:FS02:0xa4:Completed 205000 out of 250000 steps (82%)
07:52:04:WU02:FS02:0xa4:Completed 207500 out of 250000 steps (83%)
07:53:32:WU02:FS02:0xa4:Completed 210000 out of 250000 steps (84%)
07:55:00:WU02:FS02:0xa4:Completed 212500 out of 250000 steps (85%)
07:56:30:WU02:FS02:0xa4:Completed 215000 out of 250000 steps (86%)
07:56:52:WU01:FS00:0x17:Completed 875000 out of 2500000 steps (35%)
07:57:59:WU02:FS02:0xa4:Completed 217500 out of 250000 steps (87%)
07:59:28:WU02:FS02:0xa4:Completed 220000 out of 250000 steps (88%)
08:00:58:WU02:FS02:0xa4:Completed 222500 out of 250000 steps (89%)
08:02:27:WU02:FS02:0xa4:Completed 225000 out of 250000 steps (90%)
08:03:57:WU02:FS02:0xa4:Completed 227500 out of 250000 steps (91%)
08:05:21:WU03:FS01:0x17:Completed 950000 out of 2500000 steps (38%)
08:05:28:WU02:FS02:0xa4:Completed 230000 out of 250000 steps (92%)
08:06:58:WU02:FS02:0xa4:Completed 232500 out of 250000 steps (93%)
08:08:29:WU02:FS02:0xa4:Completed 235000 out of 250000 steps (94%)
08:09:49:WU02:FS02:0xa4:Completed 237500 out of 250000 steps (95%)
08:11:11:WU02:FS02:0xa4:Completed 240000 out of 250000 steps (96%)
08:12:32:WU02:FS02:0xa4:Completed 242500 out of 250000 steps (97%)
08:12:55:WU01:FS00:0x17:Completed 900000 out of 2500000 steps (36%)
08:13:53:WU02:FS02:0xa4:Completed 245000 out of 250000 steps (98%)
08:13:54:WU00:FS02:Connecting to assign3.stanford.edu:8080
08:13:54:WU00:FS02:News: Welcome to Folding@Home
08:13:54:WU00:FS02:Assigned to work server 128.143.231.202
08:13:54:WU00:FS02:Requesting new work unit for slot 02: RUNNING cpu:7 from 128.143.231.202
08:13:54:WU00:FS02:Connecting to 128.143.231.202:8080
08:13:56:WU00:FS02
08:13:58:WU00:FS02
08:13:58:WU00:FS02:Received Unit: id:00 state
08:15:14:WU02:FS02:0xa4:Completed 247500 out of 250000 steps (99%)
08:16:36:WU02:FS02:0xa4:Completed 250000 out of 250000 steps (100%)
08:16:46:WU02:FS02:0xa4:
08:16:46:WU02:FS02:0xa4:Finished Work Unit:
08:16:46:WU02:FS02:0xa4:- Reading up to 1567212 from \"02/wudata_01.trr\": Read 1567212
08:16:46:WU02:FS02:0xa4:trr file hash check passed.
08:16:46:WU02:FS02:0xa4:- Reading up to 1760108 from \"02/wudata_01.xtc\": Read 1760108
08:16:46:WU02:FS02:0xa4:xtc file hash check passed.
08:16:46:WU02:FS02:0xa4:edr file hash check passed.
08:16:46:WU02:FS02:0xa4:logfile size: 27082
08:16:46:WU02:FS02:0xa4:Leaving Run
08:16:48:WU02:FS02:0xa4:- Writing 3363830 bytes of core data to disk...
08:16:49:WU02:FS02:0xa4
08:16:49:WU02:FS02:0xa4: ... Done.
08:16:49:WU02:FS02:FahCore returned: FINISHED_UNIT (100 = 0x64)
08:16:49:WU02:FS02:Sending unit results: id:02 state:SEND error:NO_ERROR project:8702 run:79 clone:7 gen:1 core:0xa4 unit:0x000000016652edb35196ee83c6d58b65
08:16:49:WU02:FS02:Uploading 3.10MiB to 171.67.108.35
08:16:49:WU02:FS02:Connecting to 171.67.108.35:8080
08:16:49:WU00:FS02:Starting
08:16:49:WU00:FS02:Running FahCore: \"C:\\Program Files (x86)\\FAHClient/FAHCoreWrapper.exe\" C:/Users/Brad/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/Core_a3.fah/FahCore_a3.exe -dir 00 -suffix 01 -version 703 -lifeline 2208 -checkpoint 15 -np 7
08:16:49:WU00:FS02:Started FahCore on PID 5712
08:16:49:WU00:FS02:Core PID:6108
08:16:49:WU00:FS02:FahCore 0xa3 started
08:16:50:WU00:FS02:0xa3:
08:16:50:WU00:FS02:0xa3:*------------------------------*
08:16:50:WU00:FS02:0xa3:Folding@Home Gromacs SMP Core
08:16:50:WU00:FS02:0xa3:Version 2.27 (Dec. 15, 2010)
08:16:50:WU00:FS02:0xa3:- Looking at optimizations...
08:16:50:WU00:FS02:0xa3:- Created dyn
08:16:50:WU00:FS02:0xa3:- Files status OK
08:16:50:WU00:FS02:0xa3:- Expanded 3813434 -> 4169428 (decompressed 109.3 percent)
08:16:50:WU00:FS02:0xa3:Called DecompressByteArray: compressed_data_size=3813434 data_size=4169428, decompressed_data_size=4169428 diff=0
08:16:50:WU00:FS02:0xa3:- Digital signature verified
08:16:50:WU00:FS02:0xa3:Assembly optimizations on if available.
08:16:50:WU00:FS02:0xa3:Entering M.D.
08:16:55:WU02:FS02:Upload 20.19%
08:16:56:WU00:FS02:0xa3:Mapping NT from 7 to 7
08:16:56:WU00:FS02:0xa3:Completed 0 out of 500000 steps (0%)
08:17:01:WU02:FS02:Upload 38.36%
08:17:07:WU02:FS02:Upload 56.53%
08:17:13:WU02:FS02:Upload 72.68%
08:17:19:WU02:FS02:Upload 90.85%
08:17:23:WU02:FS02:Upload complete
08:17:23:WU02:FS02:Server responded WORK_ACK (400)
08:17:23:WU02:FS02:Final credit estimate, 1459.00 points
08:17:23:WU02:FS02:Cleaning up
08:23:04:WU03:FS01:0x17:Completed 975000 out of 2500000 steps (39%)
08:25:52:WU00:FS02:0xa3:Completed 5000 out of 500000 steps (1%)
08:29:20:WU01:FS00:0x17:Completed 925000 out of 2500000 steps (37%)
08:34:51:WU00:FS02:0xa3:Completed 10000 out of 500000 steps (2%)
08:40:17:WU03:FS01:0x17:Completed 1000000 out of 2500000 steps (40%)
08:43:43:WU00:FS02:0xa3:Completed 15000 out of 500000 steps (3%)
08:45:27:WU01:FS00:0x17:Completed 950000 out of 2500000 steps (38%)
08:52:39:WU00:FS02:0xa3:Completed 20000 out of 500000 steps (4%)
08:57:54:WU03:FS01:0x17:Completed 1025000 out of 2500000 steps (41%)
09:01:37:WU00:FS02:0xa3:Completed 25000 out of 500000 steps (5%)
09:01:53:WU01:FS00:0x17:Completed 975000 out of 2500000 steps (39%)
09:10:31:WU00:FS02:0xa3:Completed 30000 out of 500000 steps (6%)
09:15:04:WU03:FS01:0x17:Completed 1050000 out of 2500000 steps (42%)
09:17:59:WU01:FS00:0x17:Completed 1000000 out of 2500000 steps (40%)
09:19:26:WU00:FS02:0xa3:Completed 35000 out of 500000 steps (7%)
09:28:16:WU00:FS02:0xa3:Completed 40000 out of 500000 steps (8%)
09:32:36:WU03:FS01:0x17:Completed 1075000 out of 2500000 steps (43%)
09:34:22:WU01:FS00:0x17:Completed 1025000 out of 2500000 steps (41%)
09:37:08:WU00:FS02:0xa3:Completed 45000 out of 500000 steps (9%)
09:45:59:WU00:FS02:0xa3:Completed 50000 out of 500000 steps (10%)
09:49:49:WU03:FS01:0x17:Completed 1100000 out of 2500000 steps (44%)
09:50:28:WU01:FS00:0x17:Completed 1050000 out of 2500000 steps (42%)
09:54:55:WU00:FS02:0xa3:Completed 55000 out of 500000 steps (11%)
10:03:50:WU00:FS02:0xa3:Completed 60000 out of 500000 steps (12%)
10:06:52:WU01:FS00:0x17:Completed 1075000 out of 2500000 steps (43%)
10:07:24:WU03:FS01:0x17:Completed 1125000 out of 2500000 steps (45%)
10:12:45:WU00:FS02:0xa3:Completed 65000 out of 500000 steps (13%)
10:21:39:WU00:FS02:0xa3:Completed 70000 out of 500000 steps (14%)
10:22:57:WU01:FS00:0x17:Completed 1100000 out of 2500000 steps (44%)
10:24:37:WU03:FS01:0x17:Completed 1150000 out of 2500000 steps (46%)
10:30:34:WU00:FS02:0xa3:Completed 75000 out of 500000 steps (15%)
10:39:24:WU01:FS00:0x17:Completed 1125000 out of 2500000 steps (45%)
10:39:27:WU00:FS02:0xa3:Completed 80000 out of 500000 steps (16%)
10:42:08:WU03:FS01:0x17:Completed 1175000 out of 2500000 steps (47%)
10:48:23:WU00:FS02:0xa3:Completed 85000 out of 500000 steps (17%)
10:55:30:WU01:FS00:0x17:Completed 1150000 out of 2500000 steps (46%)
10:57:19:WU00:FS02:0xa3:Completed 90000 out of 500000 steps (18%)
10:59:20:WU03:FS01:0x17:Completed 1200000 out of 2500000 steps (48%)
11:06:16:WU00:FS02:0xa3:Completed 95000 out of 500000 steps (19%)
11:11:54:WU01:FS00:0x17:Completed 1175000 out of 2500000 steps (47%)
11:15:17:WU00:FS02:0xa3:Completed 100000 out of 500000 steps (20%)
11:16:53:WU03:FS01:0x17:Completed 1225000 out of 2500000 steps (49%)
11:24:20:WU00:FS02:0xa3:Completed 105000 out of 500000 steps (21%)
11:28:18:WU01:FS00:0x17:Completed 1200000 out of 2500000 steps (48%)
11:33:27:WU00:FS02:0xa3:Completed 110000 out of 500000 steps (22%)
11:34:25:WU03:FS01:0x17:Completed 1250000 out of 2500000 steps (50%)
11:42:24:WU00:FS02:0xa3:Completed 115000 out of 500000 steps (23%)
11:44:42:WU01:FS00:0x17:Completed 1225000 out of 2500000 steps (49%)
11:51:22:WU00:FS02:0xa3:Completed 120000 out of 500000 steps (24%)
11:51:59:WU03:FS01:0x17:Completed 1275000 out of 2500000 steps (51%)
12:00:17:WU00:FS02:0xa3:Completed 125000 out of 500000 steps (25%)
12:00:46:WU01:FS00:0x17:Completed 1250000 out of 2500000 steps (50%)
12:09:09:WU00:FS02:0xa3:Completed 130000 out of 500000 steps (26%)
12:09:13:WU03:FS01:0x17:Completed 1300000 out of 2500000 steps (52%)
12:17:12:WU01:FS00:0x17:Completed 1275000 out of 2500000 steps (51%)
12:17:57:WU00:FS02:0xa3:Completed 135000 out of 500000 steps (27%)
12:26:44:WU00:FS02:0xa3:Completed 140000 out of 500000 steps (28%)
12:26:47:WU03:FS01:0x17:Completed 1325000 out of 2500000 steps (53%)
12:33:16:WU01:FS00:0x17:Completed 1300000 out of 2500000 steps (52%)
12:35:43:WU00:FS02:0xa3:Completed 145000 out of 500000 steps (29%)
12:44:01:WU03:FS01:0x17:Completed 1350000 out of 2500000 steps (54%)
12:44:35:WU00:FS02:0xa3:Completed 150000 out of 500000 steps (30%)
12:49:43:WU01:FS00:0x17:Completed 1325000 out of 2500000 steps (53%)
12:53:32:WU00:FS02:0xa3:Completed 155000 out of 500000 steps (31%)
13:01:31:WU03:FS01:0x17:Completed 1375000 out of 2500000 steps (55%)
13:02:30:WU00:FS02:0xa3:Completed 160000 out of 500000 steps (32%)
13:05:49:WU01:FS00:0x17:Completed 1350000 out of 2500000 steps (54%)
13:11:21:WU00:FS02:0xa3:Completed 165000 out of 500000 steps (33%)
13:18:43:WU03:FS01:0x17:Completed 1400000 out of 2500000 steps (56%)
13:20:13:WU00:FS02:0xa3:Completed 170000 out of 500000 steps (34%)
13:22:13:WU01:FS00:0x17:Completed 1375000 out of 2500000 steps (55%)
13:29:06:WU00:FS02:0xa3:Completed 175000 out of 500000 steps (35%)
13:36:14:WU03:FS01:0x17:Completed 1425000 out of 2500000 steps (57%)
13:37:59:WU00:FS02:0xa3:Completed 180000 out of 500000 steps (36%)
13:38:17:WU01:FS00:0x17:Completed 1400000 out of 2500000 steps (56%)
13:46:55:WU00:FS02:0xa3:Completed 185000 out of 500000 steps (37%)
13:53:25:WU03:FS01:0x17:Completed 1450000 out of 2500000 steps (58%)
13:54:41:WU01:FS00:0x17:Completed 1425000 out of 2500000 steps (57%)
13:55:49:WU00:FS02:0xa3:Completed 190000 out of 500000 steps (38%)
14:04:44:WU00:FS02:0xa3:Completed 195000 out of 500000 steps (39%)
14:10:45:WU01:FS00:0x17:Completed 1450000 out of 2500000 steps (58%)
14:10:59:WU03:FS01:0x17:Completed 1475000 out of 2500000 steps (59%)
14:13:37:WU00:FS02:0xa3:Completed 200000 out of 500000 steps (40%)
14:22:39:WU00:FS02:0xa3:Completed 205000 out of 500000 steps (41%)
14:27:09:WU01:FS00:0x17:Completed 1475000 out of 2500000 steps (59%)
14:28:14:WU03:FS01:0x17:Completed 1500000 out of 2500000 steps (60%)
14:31:34:WU00:FS02:0xa3:Completed 210000 out of 500000 steps (42%)
14:40:28:WU00:FS02:0xa3:Completed 215000 out of 500000 steps (43%)
14:43:16:WU01:FS00:0x17:Completed 1500000 out of 2500000 steps (60%)
14:45:47:WU03:FS01:0x17:Completed 1525000 out of 2500000 steps (61%)
14:49:26:WU00:FS02:0xa3:Completed 220000 out of 500000 steps (44%)
14:58:20:WU00:FS02:0xa3:Completed 225000 out of 500000 steps (45%)
14:59:41:WU01:FS00:0x17:Completed 1525000 out of 2500000 steps (61%)
15:03:00:WU03:FS01:0x17:Completed 1550000 out of 2500000 steps (62%)
15:07:12:WU00:FS02:0xa3:Completed 230000 out of 500000 steps (46%)
15:15:48:WU01:FS00:0x17:Completed 1550000 out of 2500000 steps (62%)
15:16:08:WU00:FS02:0xa3:Completed 235000 out of 500000 steps (47%)
15:20:31:WU03:FS01:0x17:Completed 1575000 out of 2500000 steps (63%)
15:25:04:WU00:FS02:0xa3:Completed 240000 out of 500000 steps (48%)
15:32:11:WU01:FS00:0x17:Completed 1575000 out of 2500000 steps (63%)
15:34:03:WU00:FS02:0xa3:Completed 245000 out of 500000 steps (49%)
15:37:42:WU03:FS01:0x17:Completed 1600000 out of 2500000 steps (64%)
15:42:55:WU00:FS02:0xa3:Completed 250000 out of 500000 steps (50%)
15:48:17:WU01:FS00:0x17:Completed 1600000 out of 2500000 steps (64%)
15:51:50:WU00:FS02:0xa3:Completed 255000 out of 500000 steps (51%)
15:55:12:WU03:FS01:0x17:Completed 1625000 out of 2500000 steps (65%)
16:00:41:WU00:FS02:0xa3:Completed 260000 out of 500000 steps (52%)
16:04:39:WU01:FS00:0x17:Completed 1625000 out of 2500000 steps (65%)
16:09:35:WU00:FS02:0xa3:Completed 265000 out of 500000 steps (53%)
16:12:23:WU03:FS01:0x17:Completed 1650000 out of 2500000 steps (66%)
16:18:31:WU00:FS02:0xa3:Completed 270000 out of 500000 steps (54%)
16:20:45:WU01:FS00:0x17:Completed 1650000 out of 2500000 steps (66%)
16:27:26:WU00:FS02:0xa3:Completed 275000 out of 500000 steps (55%)
16:29:55:WU03:FS01:0x17:Completed 1675000 out of 2500000 steps (67%)
16:36:15:WU00:FS02:0xa3:Completed 280000 out of 500000 steps (56%)
16:37:11:WU01:FS00:0x17:Completed 1675000 out of 2500000 steps (67%)
16:45:07:WU00:FS02:0xa3:Completed 285000 out of 500000 steps (57%)
16:47:08:WU03:FS01:0x17:Completed 1700000 out of 2500000 steps (68%)
16:53:17:WU01:FS00:0x17:Completed 1700000 out of 2500000 steps (68%)
16:54:02:WU00:FS02:0xa3:Completed 290000 out of 500000 steps (58%)
17:02:56:WU00:FS02:0xa3:Completed 295000 out of 500000 steps (59%)
17:04:42:WU03:FS01:0x17:Completed 1725000 out of 2500000 steps (69%)
17:09:42:WU01:FS00:0x17:Completed 1725000 out of 2500000 steps (69%)
17:11:48:WU00:FS02:0xa3:Completed 300000 out of 500000 steps (60%)
17:20:44:WU00:FS02:0xa3:Completed 305000 out of 500000 steps (61%)
17:21:56:WU03:FS01:0x17:Completed 1750000 out of 2500000 steps (70%)
17:25:49:WU01:FS00:0x17:Completed 1750000 out of 2500000 steps (70%)
17:29:41:WU00:FS02:0xa3:Completed 310000 out of 500000 steps (62%)
17:38:31:WU00:FS02:0xa3:Completed 315000 out of 500000 steps (63%)
17:39:27:WU03:FS01:0x17:Completed 1775000 out of 2500000 steps (71%)
17:42:12:WU01:FS00:0x17:Completed 1775000 out of 2500000 steps (71%)
17:47:26:WU00:FS02:0xa3:Completed 320000 out of 500000 steps (64%)
17:56:18:WU00:FS02:0xa3:Completed 325000 out of 500000 steps (65%)
17:56:38:WU03:FS01:0x17:Completed 1800000 out of 2500000 steps (72%)
17:58:18:WU01:FS00:0x17:Completed 1800000 out of 2500000 steps (72%)
18:05:17:WU00:FS02:0xa3:Completed 330000 out of 500000 steps (66%)
18:14:09:WU03:FS01:0x17:Completed 1825000 out of 2500000 steps (73%)
18:14:13:WU00:FS02:0xa3:Completed 335000 out of 500000 steps (67%)
18:14:41:WU01:FS00:0x17:Completed 1825000 out of 2500000 steps (73%)
18:23:06:WU00:FS02:0xa3:Completed 340000 out of 500000 steps (68%)
18:30:43:WU01:FS00:0x17:Completed 1850000 out of 2500000 steps (74%)
18:31:22:WU03:FS01:0x17:Completed 1850000 out of 2500000 steps (74%)
18:32:02:WU00:FS02:0xa3:Completed 345000 out of 500000 steps (69%)
18:40:57:WU00:FS02:0xa3:Completed 350000 out of 500000 steps (70%)
18:47:09:WU01:FS00:0x17:Completed 1875000 out of 2500000 steps (75%)
18:48:53:WU03:FS01:0x17:Completed 1875000 out of 2500000 steps (75%)
18:49:52:WU00:FS02:0xa3:Completed 355000 out of 500000 steps (71%)
18:58:42:WU00:FS02:0xa3:Completed 360000 out of 500000 steps (72%)
19:03:15:WU01:FS00:0x17:Completed 1900000 out of 2500000 steps (76%)
19:06:07:WU03:FS01:0x17:Completed 1900000 out of 2500000 steps (76%)
19:07:42:WU00:FS02:0xa3:Completed 365000 out of 500000 steps (73%)
19:16:40:WU00:FS02:0xa3:Completed 370000 out of 500000 steps (74%)
19:19:41:WU01:FS00:0x17:Completed 1925000 out of 2500000 steps (77%)
19:23:39:WU03:FS01:0x17:Completed 1925000 out of 2500000 steps (77%)
19:25:41:WU00:FS02:0xa3:Completed 375000 out of 500000 steps (75%)
19:34:39:WU00:FS02:0xa3:Completed 380000 out of 500000 steps (76%)
19:35:47:WU01:FS00:0x17:Completed 1950000 out of 2500000 steps (78%)
19:40:54:WU03:FS01:0x17:Completed 1950000 out of 2500000 steps (78%)
19:43:38:WU00:FS02:0xa3:Completed 385000 out of 500000 steps (77%)
19:52:11:WU01:FS00:0x17:Completed 1975000 out of 2500000 steps (79%)
19:52:34:WU00:FS02:0xa3:Completed 390000 out of 500000 steps (78%)
19:58:24:WU03:FS01:0x17:Completed 1975000 out of 2500000 steps (79%)
20:01:30:WU00:FS02:0xa3:Completed 395000 out of 500000 steps (79%)
20:08:14:WU01:FS00:0x17:Completed 2000000 out of 2500000 steps (80%)
20:10:27:WU00:FS02:0xa3:Completed 400000 out of 500000 steps (80%)
20:15:36:WU03:FS01:0x17:Completed 2000000 out of 2500000 steps (80%)
20:19:22:WU00:FS02:0xa3:Completed 405000 out of 500000 steps (81%)
20:24:39:WU01:FS00:0x17:Completed 2025000 out of 2500000 steps (81%)
20:28:15:WU00:FS02:0xa3:Completed 410000 out of 500000 steps (82%)
20:33:07:WU03:FS01:0x17:Completed 2025000 out of 2500000 steps (81%)
20:37:07:WU00:FS02:0xa3:Completed 415000 out of 500000 steps (83%)
20:40:43:WU01:FS00:0x17:Completed 2050000 out of 2500000 steps (82%)
20:45:59:WU00:FS02:0xa3:Completed 420000 out of 500000 steps (84%)
20:50:20:WU03:FS01:0x17:Completed 2050000 out of 2500000 steps (82%)
20:54:54:WU00:FS02:0xa3:Completed 425000 out of 500000 steps (85%)
20:57:08:WU01:FS00:0x17:Completed 2075000 out of 2500000 steps (83%)
21:03:43:WU00:FS02:0xa3:Completed 430000 out of 500000 steps (86%)
21:07:52:WU03:FS01:0x17:Completed 2075000 out of 2500000 steps (83%)
21:12:32:WU00:FS02:0xa3:Completed 435000 out of 500000 steps (87%)
21:13:12:WU01:FS00:0x17:Completed 2100000 out of 2500000 steps (84%)
21:21:29:WU00:FS02:0xa3:Completed 440000 out of 500000 steps (88%)
21:25:06:WU03:FS01:0x17:Completed 2100000 out of 2500000 steps (84%)
21:29:39:WU01:FS00:0x17:Completed 2125000 out of 2500000 steps (85%)
21:30:20:WU00:FS02:0xa3:Completed 445000 out of 500000 steps (89%)
21:39:13:WU00:FS02:0xa3:Completed 450000 out of 500000 steps (90%)
21:42:39:WU03:FS01:0x17:Completed 2125000 out of 2500000 steps (85%)
21:45:44:WU01:FS00:0x17:Completed 2150000 out of 2500000 steps (86%)
21:48:08:WU00:FS02:0xa3:Completed 455000 out of 500000 steps (91%)
21:57:04:WU00:FS02:0xa3:Completed 460000 out of 500000 steps (92%)
21:59:54:WU03:FS01:0x17:Completed 2150000 out of 2500000 steps (86%)
22:02:09:WU01:FS00:0x17:Completed 2175000 out of 2500000 steps (87%)
22:05:56:WU00:FS02:0xa3:Completed 465000 out of 500000 steps (93%)
22:14:50:WU00:FS02:0xa3:Completed 470000 out of 500000 steps (94%)
22:17:25:WU03:FS01:0x17:Completed 2175000 out of 2500000 steps (87%)
22:18:13:WU01:FS00:0x17:Completed 2200000 out of 2500000 steps (88%)
22:23:47:WU00:FS02:0xa3:Completed 475000 out of 500000 steps (95%)
22:32:38:WU00:FS02:0xa3:Completed 480000 out of 500000 steps (96%)
22:34:37:WU01:FS00:0x17:Completed 2225000 out of 2500000 steps (89%)
22:34:38:WU03:FS01:0x17:Completed 2200000 out of 2500000 steps (88%)
22:41:31:WU00:FS02:0xa3:Completed 485000 out of 500000 steps (97%)
22:50:27:WU00:FS02:0xa3:Completed 490000 out of 500000 steps (98%)
22:50:28:WU02:FS02:Connecting to assign3.stanford.edu:8080
22:50:28:WU02:FS02:News: Welcome to Folding@Home
22:50:28:WU02:FS02:Assigned to work server 128.143.231.202
22:50:28:WU02:FS02:Requesting new work unit for slot 02: RUNNING cpu:7 from 128.143.231.202
22:50:28:WU02:FS02:Connecting to 128.143.231.202:8080
22:50:30:WU02:FS02
22:50:32:WU02:FS02
22:50:32:WU02:FS02:Received Unit: id:02 state
22:50:41:WU01:FS00:0x17:Completed 2250000 out of 2500000 steps (90%)
22:52:10:WU03:FS01:0x17:Completed 2225000 out of 2500000 steps (89%)
22:59:53:WU00:FS02:0xa3:Completed 495000 out of 500000 steps (99%)
23:07:04:WU01:FS00:0x17:Completed 2275000 out of 2500000 steps (91%)
23:09:21:WU00:FS02:0xa3:Completed 500000 out of 500000 steps (100%)
23:09:22:WU00:FS02:0xa3
23:09:32:WU00:FS02:0xa3:
23:09:32:WU00:FS02:0xa3:Finished Work Unit:
23:09:32:WU00:FS02:0xa3:- Reading up to 12102336 from \"00/wudata_01.trr\": Read 12102336
23:09:32:WU00:FS02:0xa3:trr file hash check passed.
23:09:32:WU00:FS02:0xa3:edr file hash check passed.
23:09:32:WU00:FS02:0xa3:logfile size: 57491
23:09:32:WU00:FS02:0xa3:Leaving Run
23:09:34:WU03:FS01:0x17:Completed 2250000 out of 2500000 steps (90%)
23:09:34:WU00:FS02:0xa3:- Writing 12193503 bytes of core data to disk...
23:09:36:WU00:FS02:0xa3
23:09:36:WU00:FS02:0xa3: ... Done.
23:09:36:WU00:FS02:0xa3:- Shutting down core
23:09:36:WU00:FS02:0xa3:Folding@home Core Shutdown: FINISHED_UNIT
23:09:36:WU00:FS02:FahCore returned: FINISHED_UNIT (100 = 0x64)
23:09:36:WU00:FS02:Sending unit results: id:00 state:SEND error:NO_ERROR project:6099 run:3 clone:15 gen:291 core:0xa3 unit:0x000001850a3b1e594e889fc0cac37232
23:09:36:WU00:FS02:Uploading 10.77MiB to 128.143.231.202
23:09:36:WU00:FS02:Connecting to 128.143.231.202:8080
23:09:36:WU02:FS02:Starting
23:09:36:WU02:FS02:Running FahCore: \"C:\\Program Files (x86)\\FAHClient/FAHCoreWrapper.exe\" C:/Users/Brad/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/Core_a3.fah/FahCore_a3.exe -dir 02 -suffix 01 -version 703 -lifeline 2208 -checkpoint 15 -np 7
23:09:36:WU02:FS02:Started FahCore on PID 7176
23:09:36:WU02:FS02:Core PID:7732
23:09:36:WU02:FS02:FahCore 0xa3 started
23:09:37:WU02:FS02:0xa3:
23:09:37:WU02:FS02:0xa3:*------------------------------*
23:09:37:WU02:FS02:0xa3:Folding@Home Gromacs SMP Core
23:09:37:WU02:FS02:0xa3:Version 2.27 (Dec. 15, 2010)
23:09:37:WU02:FS02:0xa3:- Looking at optimizations...
23:09:37:WU02:FS02:0xa3:- Created dyn
23:09:37:WU02:FS02:0xa3:- Files status OK
23:09:37:WU02:FS02:0xa3:- Expanded 3817254 -> 4169428 (decompressed 109.2 percent)
23:09:37:WU02:FS02:0xa3:Called DecompressByteArray: compressed_data_size=3817254 data_size=4169428, decompressed_data_size=4169428 diff=0
23:09:37:WU02:FS02:0xa3:- Digital signature verified
23:09:37:WU02:FS02:0xa3:Assembly optimizations on if available.
23:09:37:WU02:FS02:0xa3:Entering M.D.
23:09:42:WU00:FS02:Upload 5.22%
23:09:43:WU02:FS02:0xa3:Mapping NT from 7 to 7
23:09:43:WU02:FS02:0xa3:Completed 0 out of 500000 steps (0%)
23:09:48:WU00:FS02:Upload 9.86%
23:09:54:WU00:FS02:Upload 15.09%
23:10:00:WU00:FS02:Upload 20.31%
23:10:06:WU00:FS02:Upload 24.95%
23:10:12:WU00:FS02:Upload 29.59%
23:10:18:WU00:FS02:Upload 34.81%
23:10:24:WU00:FS02:Upload 39.45%
23:10:30:WU00:FS02:Upload 44.68%
23:10:36:WU00:FS02:Upload 49.32%
23:10:42:WU00:FS02:Upload 54.54%
23:10:48:WU00:FS02:Upload 59.18%
23:10:54:WU00:FS02:Upload 64.40%
23:11:00:WU00:FS02:Upload 69.05%
23:11:06:WU00:FS02:Upload 73.69%
23:11:12:WU00:FS02:Upload 78.91%
23:11:18:WU00:FS02:Upload 83.55%
23:11:24:WU00:FS02:Upload 88.19%
23:11:30:WU00:FS02:Upload 93.41%
23:11:36:WU00:FS02:Upload 98.64%
23:11:40:WU00:FS02:Upload complete
23:11:40:WU00:FS02:Server responded WORK_ACK (400)
23:11:40:WU00:FS02:Final credit estimate, 12463.00 points
23:11:40:WU00:FS02:Cleaning up
23:18:54:WU02:FS02:0xa3:Completed 5000 out of 500000 steps (1%)
23:23:08:WU01:FS00:0x17:Completed 2300000 out of 2500000 steps (92%)
23:27:27:WU03:FS01:0x17:Completed 2275000 out of 2500000 steps (91%)
23:27:49:WU02:FS02:0xa3:Completed 10000 out of 500000 steps (2%)
23:36:33:WU02:FS02:0xa3:Completed 15000 out of 500000 steps (3%)
23:39:33:WU01:FS00:0x17:Completed 2325000 out of 2500000 steps (93%)
23:44:45:WU03:FS01:0x17:Completed 2300000 out of 2500000 steps (92%)
23:45:19:WU02:FS02:0xa3:Completed 20000 out of 500000 steps (4%)
23:53:57:WU02:FS02:0xa3:Completed 25000 out of 500000 steps (5%)
23:55:39:WU01:FS00:0x17:Completed 2350000 out of 2500000 steps (94%)
00:02:30:WU03:FS01:0x17:Completed 2325000 out of 2500000 steps (93%)
00:03:02:WU02:FS02:0xa3:Completed 30000 out of 500000 steps (6%)
00:12:02:WU01:FS00:0x17:Completed 2375000 out of 2500000 steps (95%)
00:12:14:WU02:FS02:0xa3:Completed 35000 out of 500000 steps (7%)
00:20:04:WU03:FS01:0x17:Completed 2350000 out of 2500000 steps (94%)
00:20:43:WU02:FS02:0xa3:Completed 40000 out of 500000 steps (8%)
00:28:08:WU01:FS00:0x17:Completed 2400000 out of 2500000 steps (96%)
00:29:12:WU02:FS02:0xa3:Completed 45000 out of 500000 steps (9%)
00:37:37:WU03:FS01:0x17:Completed 2375000 out of 2500000 steps (95%)
00:37:41:WU02:FS02:0xa3:Completed 50000 out of 500000 steps (10%)
00:44:34:WU01:FS00:0x17:Completed 2425000 out of 2500000 steps (97%)
00:46:09:WU02:FS02:0xa3:Completed 55000 out of 500000 steps (11%)
00:54:39:WU02:FS02:0xa3:Completed 60000 out of 500000 steps (12%)
00:54:46:WU03:FS01:0x17:Completed 2400000 out of 2500000 steps (96%)
01:00:41:WU01:FS00:0x17:Completed 2450000 out of 2500000 steps (98%)
01:00:41:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
01:00:41:WU00:FS00:News: Welcome to Folding@Home
01:00:41:WU00:FS00:Assigned to work server 171.64.65.69
01:00:41:WU00:FS00:Requesting new work unit for slot 00: RUNNING gpu:0:Barts XT [ATI Radeon HD 6800 Series] from 171.64.65.69
01:00:41:WU00:FS00:Connecting to 171.64.65.69:8080
01:00:42:WU00:FS00
01:00:44:WU00:FS00
01:00:44:WU00:FS00:Received Unit: id:00 state
01:03:06:WU02:FS02:0xa3:Completed 65000 out of 500000 steps (13%)
01:11:32:WU02:FS02:0xa3:Completed 70000 out of 500000 steps (14%)
01:12:17:WU03:FS01:0x17:Completed 2425000 out of 2500000 steps (97%)
01:17:06:WU01:FS00:0x17:Completed 2475000 out of 2500000 steps (99%)
01:20:02:WU02:FS02:0xa3:Completed 75000 out of 500000 steps (15%)
01:28:29:WU02:FS02:0xa3:Completed 80000 out of 500000 steps (16%)
01:29:26:WU03:FS01:0x17:Completed 2450000 out of 2500000 steps (98%)
01:29:26:WU04:FS01:Connecting to assign-GPU.stanford.edu:80
01:29:26:WU04:FS01:News: Welcome to Folding@Home
01:29:26:WU04:FS01:Assigned to work server 171.64.65.69
01:29:26:WU04:FS01:Requesting new work unit for slot 01: RUNNING gpu:1:Barts XT [ATI Radeon HD 6800 Series] from 171.64.65.69
01:29:26:WU04:FS01:Connecting to 171.64.65.69:8080
01:29:26:WU04:FS01
01:29:29:WU04:FS01
01:29:29:WU04:FS01:Received Unit: id:04 state
01:33:14:WU01:FS00:0x17:Completed 2500000 out of 2500000 steps (100%)
01:33:34:WU01:FS00:0x17:Saving result file logfile_01.txt
01:33:34:WU01:FS00:0x17:Saving result file checkpointState.xml
01:33:36:WU01:FS00:0x17:Saving result file checkpt.crc
01:33:36:WU01:FS00:0x17:Saving result file log.txt
01:33:36:WU01:FS00:0x17:Saving result file positions.xtc
01:33:39:WU01:FS00:0x17:Folding@home Core Shutdown: FINISHED_UNIT
01:33:39:WU01:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
01:33:39:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:8900 run:310 clone:0 gen:19 core:0x17 unit:0x00000017028c126651a66b8c1138fbd1
01:33:39:WU01:FS00:Uploading 12.96MiB to 171.64.65.69
01:33:39:WU01:FS00:Connecting to 171.64.65.69:8080
01:33:40:WU00:FS00:Starting
01:33:40:WU00:FS00:Running FahCore: \"C:\\Program Files (x86)\\FAHClient/FAHCoreWrapper.exe\" C:/Users/Brad/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/beta/Core_17.fah/FahCore_17.exe -dir 00 -suffix 01 -version 703 -lifeline 2208 -checkpoint 15 -gpu 0 -gpu-vendor ati
01:33:40:WU00:FS00:Started FahCore on PID 6024
01:33:40:WU00:FS00:Core PID:7232
01:33:40:WU00:FS00:FahCore 0x17 started
01:33:40:WU00:FS00:0x17:*********************** Log Started 2013-06-24T01:33:40Z ***********************
01:33:40:WU00:FS00:0x17:Unit: 0x0000002f028c126651a6a5a83a8c954d
01:33:40:WU00:FS00:0x17:CPU: 0x00000000000000000000000000000000
01:33:40:WU00:FS00:0x17:Machine: 0
01:33:40:WU00:FS00:0x17:Reading tar file state.xml
01:33:40:WU00:FS00:0x17:Reading tar file system.xml
01:33:41:WU00:FS00:0x17:Reading tar file integrator.xml
01:33:41:WU00:FS00:0x17:Reading tar file core.xml
01:33:45:WU01:FS00:Upload 4.82%
01:33:51:WU01:FS00:Upload 9.16%
01:33:57:WU01:FS00:Upload 13.02%
01:34:03:WU01:FS00:Upload 17.36%
01:34:09:WU01:FS00:Upload 20.74%
01:34:15:WU01:FS00:Upload 25.08%
01:34:21:WU01:FS00:Upload 29.42%
01:34:27:WU01:FS00:Upload 33.27%
01:34:33:WU01:FS00:Upload 37.61%
01:34:39:WU01:FS00:Upload 41.95%
01:34:45:WU01:FS00:Upload 46.29%
01:34:51:WU01:FS00:Upload 50.15%
01:34:57:WU01:FS00:Upload 54.49%
01:35:03:WU01:FS00:Upload 58.35%
01:35:09:WU01:FS00:Upload 62.69%
01:35:15:WU01:FS00:Upload 66.55%
01:35:21:WU01:FS00:Upload 70.89%
01:35:27:WU01:FS00:Upload 74.75%
01:35:33:WU01:FS00:Upload 79.09%
01:35:39:WU01:FS00:Upload 82.95%
01:35:45:WU01:FS00:Upload 87.29%
01:35:51:WU01:FS00:Upload 91.63%
01:35:57:WU01:FS00:Upload 95.48%
01:36:03:WU01:FS00:Upload 99.82%
01:36:11:WU01:FS00:Upload complete
01:36:11:WU01:FS00:Server responded WORK_ACK (400)
01:36:11:WU01:FS00:Final credit estimate, 14346.00 points
01:36:11:WU01:FS00:Cleaning up
01:36:23:WU00:FS00:0x17:Completed 0 out of 2500000 steps (0%)
01:37:09:WU02:FS02:0xa3:Completed 85000 out of 500000 steps (17%)
01:45:46:WU02:FS02:0xa3:Completed 90000 out of 500000 steps (18%)
01:47:07:WU03:FS01:0x17:Completed 2475000 out of 2500000 steps (99%)
01:52:44:WU00:FS00:0x17:Completed 25000 out of 2500000 steps (1%)
01:54:07:WU02:FS02:0xa3:Completed 95000 out of 500000 steps (19%)
02:02:32:WU02:FS02:0xa3:Completed 100000 out of 500000 steps (20%)
02:04:18:WU03:FS01:0x17:Completed 2500000 out of 2500000 steps (100%)
02:04:37:WU03:FS01:0x17:Saving result file logfile_01.txt
02:04:38:WU03:FS01:0x17:Saving result file checkpointState.xml
02:04:39:WU03:FS01:0x17:Saving result file checkpt.crc
02:04:39:WU03:FS01:0x17:Saving result file log.txt
02:04:40:WU03:FS01:0x17:Saving result file positions.xtc
02:04:42:WU03:FS01:0x17:Folding@home Core Shutdown: FINISHED_UNIT
02:04:43:WU03:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
02:04:43:WU03:FS01:Sending unit results: id:03 state:SEND error:NO_ERROR project:8900 run:666 clone:0 gen:20 core:0x17 unit:0x00000017028c126651a6bac181eeb0ac
02:04:43:WU03:FS01:Uploading 12.96MiB to 171.64.65.69
02:04:43:WU03:FS01:Connecting to 171.64.65.69:8080
02:04:43:WU04:FS01:Starting
02:04:43:WU04:FS01:Running FahCore: \"C:\\Program Files (x86)\\FAHClient/FAHCoreWrapper.exe\" C:/Users/Brad/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/beta/Core_17.fah/FahCore_17.exe -dir 04 -suffix 01 -version 703 -lifeline 2208 -checkpoint 15 -gpu 1 -gpu-vendor ati
02:04:43:WU04:FS01:Started FahCore on PID 4128
02:04:43:WU04:FS01:Core PID:5500
02:04:43:WU04:FS01:FahCore 0x17 started
02:04:43:WU04:FS01:0x17:*********************** Log Started 2013-06-24T02:04:43Z ***********************
02:04:43:WU04:FS01:0x17:Unit: 0x00000026028c126651a69b38cb53d819
02:04:43:WU04:FS01:0x17:CPU: 0x00000000000000000000000000000000
02:04:43:WU04:FS01:0x17:Machine: 1
02:04:43:WU04:FS01:0x17:Reading tar file state.xml
02:04:44:WU04:FS01:0x17:Reading tar file system.xml
02:04:44:WU04:FS01:0x17:Reading tar file integrator.xml
02:04:44:WU04:FS01:0x17:Reading tar file core.xml
02:04:49:WU03:FS01:Upload 5.30%
02:04:55:WU03:FS01:Upload 9.64%
02:05:01:WU03:FS01:Upload 13.50%
02:05:07:WU03:FS01:Upload 17.84%
02:05:13:WU03:FS01:Upload 21.70%
02:05:19:WU03:FS01:Upload 26.04%
02:05:25:WU03:FS01:Upload 30.38%
02:05:31:WU03:FS01:Upload 34.24%
02:05:37:WU03:FS01:Upload 38.58%
02:05:43:WU03:FS01:Upload 42.44%
02:05:49:WU03:FS01:Upload 46.30%
02:05:55:WU03:FS01:Upload 50.64%
02:06:01:WU03:FS01:Upload 54.49%
02:06:07:WU03:FS01:Upload 58.83%
02:06:13:WU03:FS01:Upload 63.17%
02:06:19:WU03:FS01:Upload 67.51%
02:06:25:WU03:FS01:Upload 71.37%
02:06:31:WU03:FS01:Upload 75.71%
02:06:37:WU03:FS01:Upload 79.57%
02:06:43:WU03:FS01:Upload 83.91%
02:06:49:WU03:FS01:Upload 88.25%
02:06:55:WU03:FS01:Upload 92.11%
02:07:01:WU03:FS01:Upload 95.97%
02:07:14:WU03:FS01:Upload complete
02:07:14:WU03:FS01:Server responded WORK_ACK (400)
02:07:14:WU03:FS01:Final credit estimate, 13863.00 points
02:07:14:WU03:FS01:Cleaning up
02:07:28:WU04:FS01:0x17:Completed 0 out of 2500000 steps (0%)
02:09:01:WU00:FS00:0x17:Completed 50000 out of 2500000 steps (2%)
02:11:12:WU02:FS02:0xa3:Completed 105000 out of 500000 steps (21%)
02:19:46:WU02:FS02:0xa3:Completed 110000 out of 500000 steps (22%)
******************************* Date: 2013-06-24 *******************************
02:24:59:WU04:FS01:0x17:Completed 25000 out of 2500000 steps (1%)
02:25:26:WU00:FS00:0x17:Completed 75000 out of 2500000 steps (3%)
02:28:21:WU02:FS02:0xa3:Completed 115000 out of 500000 steps (23%)
02:36:55:WU02:FS02:0xa3:Completed 120000 out of 500000 steps (24%)
02:41:31:WU00:FS00:0x17:Completed 100000 out of 2500000 steps (4%)
02:42:11:WU04:FS01:0x17:Completed 50000 out of 2500000 steps (2%)
02:45:29:WU02:FS02:0xa3:Completed 125000 out of 500000 steps (25%)
02:53:55:WU02:FS02:0xa3:Completed 130000 out of 500000 steps (26%)
02:57:59:WU00:FS00:0x17:Completed 125000 out of 2500000 steps (5%)
02:59:44:WU04:FS01:0x17:Completed 75000 out of 2500000 steps (3%)
03:02:25:WU02:FS02:0xa3:Completed 135000 out of 500000 steps (27%)
03:10:58:WU02:FS02:0xa3:Completed 140000 out of 500000 steps (28%)
03:14:05:WU00:FS00:0x17:Completed 150000 out of 2500000 steps (6%)
03:16:58:WU04:FS01:0x17:Completed 100000 out of 2500000 steps (4%)
03:19:28:WU02:FS02:0xa3:Completed 145000 out of 500000 steps (29%)
03:27:59:WU02:FS02:0xa3:Completed 150000 out of 500000 steps (30%)
03:30:29:WU00:FS00:0x17:Completed 175000 out of 2500000 steps (7%)
03:34:30:WU04:FS01:0x17:Completed 125000 out of 2500000 steps (5%)
03:36:27:WU02:FS02:0xa3:Completed 155000 out of 500000 steps (31%)
03:44:53:WU02:FS02:0xa3:Completed 160000 out of 500000 steps (32%)
03:46:34:WU00:FS00:0x17:Completed 200000 out of 2500000 steps (8%)
03:51:45:WU04:FS01:0x17:Completed 150000 out of 2500000 steps (6%)
03:53:22:WU02:FS02:0xa3:Completed 165000 out of 500000 steps (33%)
04:02:45:WU02:FS02:0xa3:Completed 170000 out of 500000 steps (34%)
04:02:56:WU00:FS00:0x17:Completed 225000 out of 2500000 steps (9%)
04:09:58:WU04:FS01:0x17:Completed 175000 out of 2500000 steps (7%)
04:12:28:WU02:FS02:0xa3:Completed 175000 out of 500000 steps (35%)
04:18:59:WU00:FS00:0x17:Completed 250000 out of 2500000 steps (10%)
04:22:06:WU02:FS02:0xa3:Completed 180000 out of 500000 steps (36%)
04:28:03:WU04:FS01:0x17:Completed 200000 out of 2500000 steps (8%)
04:31:32:WU02:FS02:0xa3:Completed 185000 out of 500000 steps (37%)
04:35:24:WU00:FS00:0x17:Completed 275000 out of 2500000 steps (11%)
04:40:47:WU02:FS02:0xa3:Completed 190000 out of 500000 steps (38%)
04:46:23:WU04:FS01:0x17:Completed 225000 out of 2500000 steps (9%)
04:50:19:WU02:FS02:0xa3:Completed 195000 out of 500000 steps (39%)
04:51:27:WU00:FS00:0x17:Completed 300000 out of 2500000 steps (12%)
04:59:45:WU02:FS02:0xa3:Completed 200000 out of 500000 steps (40%)
05:04:27:WU04:FS01:0x17:Completed 250000 out of 2500000 steps (10%)
05:07:53:WU00:FS00:0x17:Completed 325000 out of 2500000 steps (13%)
05:09:15:WU02:FS02:0xa3:Completed 205000 out of 500000 steps (41%)
05:12:24:FS02:Shutting core down
05:12:24:FS00:Shutting core down
05:12:24:FS01:Shutting core down
05:12:25:WU00:FS00:0x17:WARNING:Console control signal 1 on PID 7232
05:12:25:WU00:FS00:0x17:Exiting, please wait. . .
05:12:25:WU04:FS01:0x17:WARNING:Console control signal 1 on PID 5500
05:12:25:WU04:FS01:0x17:Exiting, please wait. . .
05:12:25:WU04:FS01:0x17:Lost lifeline PID 4128, exiting
05:12:25:WU04:FS01:0x17:ERROR:103: Lost client lifeline
05:12:25:WU04:FS01:0x17:Folding@home Core Shutdown: CLIENT_DIED
05:12:26:WU04:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
05:12:26:WU00:FS00:0x17:Lost lifeline PID 6024, exiting
05:12:26:WU00:FS00:0x17:ERROR:103: Lost client lifeline
05:12:26:WU00:FS00:0x17:Folding@home Core Shutdown: CLIENT_DIED
05:12:26:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
05:12:29:WU02:FS02:0xa3:Client no longer detected. Shutting down core
05:12:29:WU02:FS02:0xa3:Folding@home Core Shutdown: CLIENT_DIED
05:12:29:WU02:FS02:FahCore returned: INTERRUPTED (102 = 0x66)
05:13:26:Removing old file 'configs/config-20130618-030918.xml'
05:13:26:Saving configuration to config.xml
05:13:26:<config>
05:13:26: <!-- Folding Slot Configuration -->
05:13:26: <power v='off'/>
05:13:26:
05:13:26: <!-- Network -->
05:13:26: <proxy v=':8080'/>
05:13:26:
05:13:26: <!-- User Information -->
05:13:26: <passkey v='********************************'/>
05:13:26: <team v='32'/>
05:13:26: <user v='Rustyfender'/>
05:13:26:
05:13:26: <!-- Folding Slots -->
05:13:26: <slot id='2' type='CPU'>
05:13:26: <cpus v='7'/>
05:13:26: </slot>
05:13:26: <slot id='0' type='GPU'>
05:13:26: <client-type v='beta'/>
05:13:26: </slot>
05:13:26: <slot id='1' type='GPU'>
05:13:26: </slot>
05:13:26:</config>
05:45:02:WU02:FS02:Starting
05:45:02:WU02:FS02:Running FahCore: \"C:\\Program Files (x86)\\FAHClient/FAHCoreWrapper.exe\" C:/Users/Brad/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/Core_a3.fah/FahCore_a3.exe -dir 02 -suffix 01 -version 703 -lifeline 2208 -checkpoint 15 -np 7
05:45:02:WU02:FS02:Started FahCore on PID 4796
05:45:02:WU02:FS02:Core PID:6516
05:45:02:WU02:FS02:FahCore 0xa3 started
05:45:02:WU00:FS00:Starting
05:45:02:WU00:FS00:Running FahCore: \"C:\\Program Files (x86)\\FAHClient/FAHCoreWrapper.exe\" C:/Users/Brad/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/beta/Core_17.fah/FahCore_17.exe -dir 00 -suffix 01 -version 703 -lifeline 2208 -checkpoint 15 -gpu 0 -gpu-vendor ati
05:45:02:WU00:FS00:Started FahCore on PID 6060
05:45:02:WU00:FS00:Core PID:7936
05:45:02:WU00:FS00:FahCore 0x17 started
05:45:02:WU04:FS01:Starting
05:45:02:WU04:FS01:Running FahCore: \"C:\\Program Files (x86)\\FAHClient/FAHCoreWrapper.exe\" C:/Users/Brad/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/beta/Core_17.fah/FahCore_17.exe -dir 04 -suffix 01 -version 703 -lifeline 2208 -checkpoint 15 -gpu 1 -gpu-vendor ati
05:45:02:WU04:FS01:Started FahCore on PID 5252
05:45:02:WU04:FS01:Core PID:7488
05:45:02:WU04:FS01:FahCore 0x17 started
05:45:03:WU02:FS02:0xa3:
05:45:03:WU02:FS02:0xa3:*------------------------------*
05:45:03:WU02:FS02:0xa3:Folding@Home Gromacs SMP Core
05:45:03:WU02:FS02:0xa3:Version 2.27 (Dec. 15, 2010)
05:45:03:WU02:FS02:0xa3:- Looking at optimizations...
05:45:03:WU02:FS02:0xa3:- Files status OK
05:45:03:WU02:FS02:0xa3:- Expanded 3817254 -> 4169428 (decompressed 109.2 percent)
05:45:03:WU02:FS02:0xa3:Called DecompressByteArray: compressed_data_size=3817254 data_size=4169428, decompressed_data_size=4169428 diff=0
05:45:03:WU02:FS02:0xa3:- Digital signature verified
05:45:03:WU02:FS02:0xa3:Assembly optimizations on if available.
05:45:03:WU02:FS02:0xa3:Entering M.D.
05:45:03:WU00:FS00:0x17:*********************** Log Started 2013-06-24T05:45:02Z ***********************
05:45:03:WU00:FS00:0x17:Unit: 0x0000002f028c126651a6a5a83a8c954d
05:45:03:WU00:FS00:0x17:CPU: 0x00000000000000000000000000000000
05:45:03:WU00:FS00:0x17:Machine: 0
05:45:03:WU00:FS00:0x17: Found a checkpoint file
05:45:03:WU04:FS01:0x17:*********************** Log Started 2013-06-24T05:45:02Z ***********************
05:45:03:WU04:FS01:0x17:Unit: 0x00000026028c126651a69b38cb53d819
05:45:03:WU04:FS01:0x17:CPU: 0x00000000000000000000000000000000
05:45:03:WU04:FS01:0x17:Machine: 1
05:45:03:WU04:FS01:0x17: Found a checkpoint file
05:45:09:WU02:FS02:0xa3:Using Gromacs checkpoints
05:45:09:WU02:FS02:0xa3:Mapping NT from 7 to 7
05:45:10:WU02:FS02:0xa3:Resuming from checkpoint
05:45:10:WU02:FS02:0xa3:Verified 02/wudata_01.log
05:45:10:WU02:FS02:0xa3:Verified 02/wudata_01.trr
05:45:10:WU02:FS02:0xa3:Verified 02/wudata_01.edr
05:45:12:WU02:FS02:0xa3:Completed 205255 out of 500000 steps (41%)
05:46:03:Removing old file 'configs/config-20130618-030955.xml'
05:46:03:Saving configuration to config.xml
05:46:03:<config>
05:46:03: <!-- Folding Slot Configuration -->
05:46:03: <power v='full'/>
05:46:03:
05:46:03: <!-- Network -->
05:46:03: <proxy v=':8080'/>
05:46:03:
05:46:03: <!-- User Information -->
05:46:03: <passkey v='********************************'/>
05:46:03: <team v='32'/>
05:46:03: <user v='Rustyfender'/>
05:46:03:
05:46:03: <!-- Folding Slots -->
05:46:03: <slot id='2' type='CPU'>
05:46:03: <cpus v='7'/>
05:46:03: </slot>
05:46:03: <slot id='0' type='GPU'>
05:46:03: <client-type v='beta'/>
05:46:03: </slot>
05:46:03: <slot id='1' type='GPU'>
05:46:03: </slot>
05:46:03:</config>
05:47:54:WU00:FS00:0x17:Completed 300000 out of 2500000 steps (12%)
05:48:09:WU04:FS01:0x17:Completed 250000 out of 2500000 steps (10%)
05:55:50:WU02:FS02:0xa3:Completed 210000 out of 500000 steps (42%)
06:04:19:WU00:FS00:0x17:Completed 325000 out of 2500000 steps (13%)
06:05:11:WU02:FS02:0xa3:Completed 215000 out of 500000 steps (43%)
06:06:32:WU04:FS01:0x17:Completed 275000 out of 2500000 steps (11%)
06:14:40:WU02:FS02:0xa3:Completed 220000 out of 500000 steps (44%)
06:20:19:WU00:FS00:0x17:Completed 350000 out of 2500000 steps (14%)
06:24:06:WU02:FS02:0xa3:Completed 225000 out of 500000 steps (45%)
06:24:38:WU04:FS01:0x17:Completed 300000 out of 2500000 steps (12%)
06:33:39:WU02:FS02:0xa3:Completed 230000 out of 500000 steps (46%)
06:36:47:WU00:FS00:0x17:Completed 375000 out of 2500000 steps (15%)
06:43:04:WU02:FS02:0xa3:Completed 235000 out of 500000 steps (47%)
06:43:10:WU04:FS01:0x17:Completed 325000 out of 2500000 steps (13%)
06:52:28:WU02:FS02:0xa3:Completed 240000 out of 500000 steps (48%)
06:52:49:WU00:FS00:0x17:Completed 400000 out of 2500000 steps (16%)
07:01:12:WU04:FS01:0x17:Completed 350000 out of 2500000 steps (14%)
07:01:55:WU02:FS02:0xa3:Completed 245000 out of 500000 steps (49%)
07:09:16:WU00:FS00:0x17:Completed 425000 out of 2500000 steps (17%)
07:11:28:WU02:FS02:0xa3:Completed 250000 out of 500000 steps (50%)
07:19:40:WU04:FS01:0x17:Completed 375000 out of 2500000 steps (15%)
07:20:52:WU02:FS02:0xa3:Completed 255000 out of 500000 steps (51%)
07:25:18:WU00:FS00:0x17:Completed 450000 out of 2500000 steps (18%)
07:30:16:WU02:FS02:0xa3:Completed 260000 out of 500000 steps (52%)
07:37:45:WU04:FS01:0x17:Completed 400000 out of 2500000 steps (16%)
07:39:31:WU02:FS02:0xa3:Completed 265000 out of 500000 steps (53%)
07:41:41:WU00:FS00:0x17:Completed 475000 out of 2500000 steps (19%)
07:48:55:WU02:FS02:0xa3:Completed 270000 out of 500000 steps (54%)
07:56:15:WU04:FS01:0x17:Completed 425000 out of 2500000 steps (17%)
07:57:50:WU00:FS00:0x17:Completed 500000 out of 2500000 steps (20%)
07:58:12:WU02:FS02:0xa3:Completed 275000 out of 500000 steps (55%)
08:07:38:WU02:FS02:0xa3:Completed 280000 out of 500000 steps (56%)
08:14:10:WU00:FS00:0x17:Completed 525000 out of 2500000 steps (21%)
08:14:20:WU04:FS01:0x17:Completed 450000 out of 2500000 steps (18%)
08:17:05:WU02:FS02:0xa3:Completed 285000 out of 500000 steps (57%)
08:26:33:WU02:FS02:0xa3:Completed 290000 out of 500000 steps (58%)
08:30:11:WU00:FS00:0x17:Completed 550000 out of 2500000 steps (22%)
08:32:48:WU04:FS01:0x17:Completed 475000 out of 2500000 steps (19%)
08:36:04:WU02:FS02:0xa3:Completed 295000 out of 500000 steps (59%)
08:45:31:WU02:FS02:0xa3:Completed 300000 out of 500000 steps (60%)
08:46:33:WU00:FS00:0x17:Completed 575000 out of 2500000 steps (23%)
08:50:56:WU04:FS01:0x17:Completed 500000 out of 2500000 steps (20%)
08:54:58:WU02:FS02:0xa3:Completed 305000 out of 500000 steps (61%)
09:02:41:WU00:FS00:0x17:Completed 600000 out of 2500000 steps (24%)
09:04:14:WU02:FS02:0xa3:Completed 310000 out of 500000 steps (62%)
09:09:21:WU04:FS01:0x17:Completed 525000 out of 2500000 steps (21%)
09:13:40:WU02:FS02:0xa3:Completed 315000 out of 500000 steps (63%)
09:19:04:WU00:FS00:0x17:Completed 625000 out of 2500000 steps (25%)
09:23:11:WU02:FS02:0xa3:Completed 320000 out of 500000 steps (64%)
09:27:26:WU04:FS01:0x17:Completed 550000 out of 2500000 steps (22%)
09:32:38:WU02:FS02:0xa3:Completed 325000 out of 500000 steps (65%)
09:35:09:WU00:FS00:0x17:Completed 650000 out of 2500000 steps (26%)
09:42:01:WU02:FS02:0xa3:Completed 330000 out of 500000 steps (66%)
09:45:59:WU04:FS01:0x17:Completed 575000 out of 2500000 steps (23%)
09:51:29:WU02:FS02:0xa3:Completed 335000 out of 500000 steps (67%)
09:51:30:WU00:FS00:0x17:Completed 675000 out of 2500000 steps (27%)
10:00:57:WU02:FS02:0xa3:Completed 340000 out of 500000 steps (68%)
10:04:01:WU04:FS01:0x17:Completed 600000 out of 2500000 steps (24%)
10:07:31:WU00:FS00:0x17:Completed 700000 out of 2500000 steps (28%)
10:09:34:WU02:FS02:0xa3:Completed 345000 out of 500000 steps (69%)
10:18:10:WU02:FS02:0xa3:Completed 350000 out of 500000 steps (70%)
10:21:36:WU04:FS01:0x17:Completed 625000 out of 2500000 steps (25%)
10:23:49:WU00:FS00:0x17:Completed 725000 out of 2500000 steps (29%)
10:26:45:WU02:FS02:0xa3:Completed 355000 out of 500000 steps (71%)
10:35:25:WU02:FS02:0xa3:Completed 360000 out of 500000 steps (72%)
10:38:47:WU04:FS01:0x17:Completed 650000 out of 2500000 steps (26%)
10:39:52:WU00:FS00:0x17:Completed 750000 out of 2500000 steps (30%)
10:44:03:WU02:FS02:0xa3:Completed 365000 out of 500000 steps (73%)
10:52:40:WU02:FS02:0xa3:Completed 370000 out of 500000 steps (74%)
10:56:12:WU00:FS00:0x17:Completed 775000 out of 2500000 steps (31%)
10:56:20:WU04:FS01:0x17:Completed 675000 out of 2500000 steps (27%)
11:01:20:WU02:FS02:0xa3:Completed 375000 out of 500000 steps (75%)
11:09:59:WU02:FS02:0xa3:Completed 380000 out of 500000 steps (76%)
11:12:14:WU00:FS00:0x17:Completed 800000 out of 2500000 steps (32%)
11:13:37:WU04:FS01:0x17:Completed 700000 out of 2500000 steps (28%)
11:18:38:WU02:FS02:0xa3:Completed 385000 out of 500000 steps (77%)
11:27:21:WU02:FS02:0xa3:Completed 390000 out of 500000 steps (78%)
11:28:54:WU00:FS00:0x17:Completed 825000 out of 2500000 steps (33%)
11:31:08:WU04:FS01:0x17:Completed 725000 out of 2500000 steps (29%)
11:35:59:WU02:FS02:0xa3:Completed 395000 out of 500000 steps (79%)
11:44:39:WU02:FS02:0xa3:Completed 400000 out of 500000 steps (80%)
11:44:54:WU00:FS00:0x17:Completed 850000 out of 2500000 steps (34%)
11:48:21:WU04:FS01:0x17:Completed 750000 out of 2500000 steps (30%)
11:53:19:WU02:FS02:0xa3:Completed 405000 out of 500000 steps (81%)
12:01:14:WU00:FS00:0x17:Completed 875000 out of 2500000 steps (35%)
12:01:53:WU02:FS02:0xa3:Completed 410000 out of 500000 steps (82%)
12:05:55:WU04:FS01:0x17:Completed 775000 out of 2500000 steps (31%)
12:10:29:WU02:FS02:0xa3:Completed 415000 out of 500000 steps (83%)
12:17:12:WU00:FS00:0x17:Completed 900000 out of 2500000 steps (36%)
12:19:07:WU02:FS02:0xa3:Completed 420000 out of 500000 steps (84%)
12:23:09:WU04:FS01:0x17:Completed 800000 out of 2500000 steps (32%)
12:27:45:WU02:FS02:0xa3:Completed 425000 out of 500000 steps (85%)
12:33:35:WU00:FS00:0x17:Completed 925000 out of 2500000 steps (37%)
12:36:21:WU02:FS02:0xa3:Completed 430000 out of 500000 steps (86%)
12:40:40:WU04:FS01:0x17:Completed 825000 out of 2500000 steps (33%)
12:44:59:WU02:FS02:0xa3:Completed 435000 out of 500000 steps (87%)
12:49:33:WU00:FS00:0x17:Completed 950000 out of 2500000 steps (38%)
12:53:36:WU02:FS02:0xa3:Completed 440000 out of 500000 steps (88%)
12:57:51:WU04:FS01:0x17:Completed 850000 out of 2500000 steps (34%)
13:02:19:WU02:FS02:0xa3:Completed 445000 out of 500000 steps (89%)
13:05:57:WU00:FS00:0x17:Completed 975000 out of 2500000 steps (39%)
13:11:00:WU02:FS02:0xa3:Completed 450000 out of 500000 steps (90%)
13:15:25:WU04:FS01:0x17:Completed 875000 out of 2500000 steps (35%)
13:19:39:WU02:FS02:0xa3:Completed 455000 out of 500000 steps (91%)
13:21:56:WU00:FS00:0x17:Completed 1000000 out of 2500000 steps (40%)
13:28:22:WU02:FS02:0xa3:Completed 460000 out of 500000 steps (92%)
13:32:37:WU04:FS01:0x17:Completed 900000 out of 2500000 steps (36%)
13:37:01:WU02:FS02:0xa3:Completed 465000 out of 500000 steps (93%)
13:38:21:WU00:FS00:0x17:Completed 1025000 out of 2500000 steps (41%)
13:45:38:WU02:FS02:0xa3:Completed 470000 out of 500000 steps (94%)
13:50:10:WU04:FS01:0x17:Completed 925000 out of 2500000 steps (37%)
13:54:11:WU02:FS02:0xa3:Completed 475000 out of 500000 steps (95%)
13:54:23:WU00:FS00:0x17:Completed 1050000 out of 2500000 steps (42%)
14:02:48:WU02:FS02:0xa3:Completed 480000 out of 500000 steps (96%)
14:07:23:WU04:FS01:0x17:Completed 950000 out of 2500000 steps (38%)
14:10:45:WU00:FS00:0x17:Completed 1075000 out of 2500000 steps (43%)
14:11:28:WU02:FS02:0xa3:Completed 485000 out of 500000 steps (97%)
14:20:05:WU02:FS02:0xa3:Completed 490000 out of 500000 steps (98%)
14:20:05:WU01:FS02:Connecting to assign3.stanford.edu:8080
14:20:05:WU01:FS02:News: Welcome to Folding@Home
14:20:05:WU01:FS02:Assigned to work server 171.67.108.35
14:20:05:WU01:FS02:Requesting new work unit for slot 02: RUNNING cpu:7 from 171.67.108.35
14:20:05:WU01:FS02:Connecting to 171.67.108.35:8080
14:20:06:WU01:FS02
14:20:07:WU01:FS02
14:20:07:WU01:FS02:Received Unit: id:01 state
14:24:54:WU04:FS01:0x17:Completed 975000 out of 2500000 steps (39%)
14:26:44:WU00:FS00:0x17:Completed 1100000 out of 2500000 steps (44%)
14:28:43:WU02:FS02:0xa3:Completed 495000 out of 500000 steps (99%)
14:37:24:WU02:FS02:0xa3:Completed 500000 out of 500000 steps (100%)
14:37:26:WU02:FS02:0xa3
14:37:36:WU02:FS02:0xa3:
14:37:36:WU02:FS02:0xa3:Finished Work Unit:
14:37:36:WU02:FS02:0xa3:- Reading up to 12102336 from \"02/wudata_01.trr\": Read 12102336
14:37:36:WU02:FS02:0xa3:trr file hash check passed.
14:37:36:WU02:FS02:0xa3:edr file hash check passed.
14:37:36:WU02:FS02:0xa3:logfile size: 56809
14:37:36:WU02:FS02:0xa3:Leaving Run
14:37:36:WU02:FS02:0xa3:- Writing 12192821 bytes of core data to disk...
14:37:37:WU02:FS02:0xa3
14:37:37:WU02:FS02:0xa3: ... Done.
14:37:38:WU02:FS02:0xa3:- Shutting down core
14:37:38:WU02:FS02:0xa3:Folding@home Core Shutdown: FINISHED_UNIT
14:37:38:WU02:FS02:FahCore returned: FINISHED_UNIT (100 = 0x64)
14:37:38:WU02:FS02:Sending unit results: id:02 state:SEND error:NO_ERROR project:6099 run:8 clone:88 gen:264 core:0xa3 unit:0x0000017d0a3b1e594e91e122d4db87e7
14:37:38:WU02:FS02:Uploading 10.78MiB to 128.143.231.202
14:37:38:WU02:FS02:Connecting to 128.143.231.202:8080
14:37:38:WU01:FS02:Starting
14:37:38:WU01:FS02:Running FahCore: \"C:\\Program Files (x86)\\FAHClient/FAHCoreWrapper.exe\" C:/Users/Brad/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 01 -suffix 01 -version 703 -lifeline 2208 -checkpoint 15 -np 7
14:37:38:WU01:FS02:Started FahCore on PID 7516
14:37:38:WU01:FS02:Core PID:8840
14:37:38:WU01:FS02:FahCore 0xa4 started
14:37:38:WU01:FS02:0xa4:
14:37:38:WU01:FS02:0xa4:*------------------------------*
14:37:38:WU01:FS02:0xa4:Folding@Home Gromacs GB Core
14:37:38:WU01:FS02:0xa4:Version 2.27 (Dec. 15, 2010)
14:37:38:WU01:FS02:0xa4:- Looking at optimizations...
14:37:38:WU01:FS02:0xa4:- Created dyn
14:37:38:WU01:FS02:0xa4:- Files status OK
14:37:38:WU01:FS02:0xa4:- Expanded 1025132 -> 2544640 (decompressed 248.2 percent)
14:37:38:WU01:FS02:0xa4:Called DecompressByteArray: compressed_data_size=1025132 data_size=2544640, decompressed_data_size=2544640 diff=0
14:37:38:WU01:FS02:0xa4:- Digital signature verified
14:37:38:WU01:FS02:0xa4:Assembly optimizations on if available.
14:37:38:WU01:FS02:0xa4:Entering M.D.
14:37:44:WU02:FS02:Upload 5.80%
14:37:44:WU01:FS02:0xa4:Mapping NT from 7 to 7
14:37:44:WU01:FS02:0xa4:Completed 0 out of 250000 steps (0%)
14:37:50:WU02:FS02:Upload 10.43%
14:37:56:WU02:FS02:Upload 14.49%
14:38:02:WU02:FS02:Upload 19.71%
14:38:08:WU02:FS02:Upload 24.35%
14:38:14:WU02:FS02:Upload 29.57%
14:38:20:WU02:FS02:Upload 34.20%
14:38:26:WU02:FS02:Upload 38.84%
14:38:32:WU02:FS02:Upload 42.90%
14:38:38:WU02:FS02:Upload 48.12%
14:38:44:WU02:FS02:Upload 52.75%
14:38:50:WU02:FS02:Upload 57.39%
14:38:56:WU02:FS02:Upload 62.61%
14:39:02:WU02:FS02:Upload 67.25%
14:39:05:WU01:FS02:0xa4:Completed 2500 out of 250000 steps (1%)
14:39:08:WU02:FS02:Upload 71.88%
14:39:14:WU02:FS02:Upload 76.52%
14:39:20:WU02:FS02:Upload 81.74%
14:39:26:WU02:FS02:Upload 86.96%
14:39:32:WU02:FS02:Upload 91.59%
14:39:39:WU02:FS02:Upload 96.81%
14:39:44:WU02:FS02:Upload complete
14:39:44:WU02:FS02:Server responded WORK_ACK (400)
14:39:44:WU02:FS02:Final credit estimate, 12120.00 points
14:39:44:WU02:FS02:Cleaning up
14:40:25:WU01:FS02:0xa4:Completed 5000 out of 250000 steps (2%)
14:41:47:WU01:FS02:0xa4:Completed 7500 out of 250000 steps (3%)
14:42:08:WU04:FS01:0x17:Completed 1000000 out of 2500000 steps (40%)
14:43:06:WU00:FS00:0x17:Completed 1125000 out of 2500000 steps (45%)
14:43:09:WU01:FS02:0xa4:Completed 10000 out of 250000 steps (4%)
14:44:30:WU01:FS02:0xa4:Completed 12500 out of 250000 steps (5%)
14:45:51:WU01:FS02:0xa4:Completed 15000 out of 250000 steps (6%)
14:47:12:WU01:FS02:0xa4:Completed 17500 out of 250000 steps (7%)
14:48:32:WU01:FS02:0xa4:Completed 20000 out of 250000 steps (8%)
14:49:53:WU01:FS02:0xa4:Completed 22500 out of 250000 steps (9%)
14:51:14:WU01:FS02:0xa4:Completed 25000 out of 250000 steps (10%)
14:52:35:WU01:FS02:0xa4:Completed 27500 out of 250000 steps (11%)
14:53:56:WU01:FS02:0xa4:Completed 30000 out of 250000 steps (12%)
14:55:17:WU01:FS02:0xa4:Completed 32500 out of 250000 steps (13%)
14:56:38:WU01:FS02:0xa4:Completed 35000 out of 250000 steps (14%)
14:58:00:WU01:FS02:0xa4:Completed 37500 out of 250000 steps (15%)
14:59:05:WU00:FS00:0x17:Completed 1150000 out of 2500000 steps (46%)
14:59:21:WU01:FS02:0xa4:Completed 40000 out of 250000 steps (16%)
14:59:38:WU04:FS01:0x17:Completed 1025000 out of 2500000 steps (41%)
15:00:41:WU01:FS02:0xa4:Completed 42500 out of 250000 steps (17%)
15:02:03:WU01:FS02:0xa4:Completed 45000 out of 250000 steps (18%)
15:03:23:WU01:FS02:0xa4:Completed 47500 out of 250000 steps (19%)
15:04:44:WU01:FS02:0xa4:Completed 50000 out of 250000 steps (20%)
15:06:05:WU01:FS02:0xa4:Completed 52500 out of 250000 steps (21%)
15:07:26:WU01:FS02:0xa4:Completed 55000 out of 250000 steps (22%)
15:08:48:WU01:FS02:0xa4:Completed 57500 out of 250000 steps (23%)
15:10:09:WU01:FS02:0xa4:Completed 60000 out of 250000 steps (24%)
15:11:30:WU01:FS02:0xa4:Completed 62500 out of 250000 steps (25%)
15:12:51:WU01:FS02:0xa4:Completed 65000 out of 250000 steps (26%)
15:14:13:WU01:FS02:0xa4:Completed 67500 out of 250000 steps (27%)
15:15:27:WU00:FS00:0x17:Completed 1175000 out of 2500000 steps (47%)
15:15:35:WU01:FS02:0xa4:Completed 70000 out of 250000 steps (28%)
15:16:48:WU04:FS01:0x17:Completed 1050000 out of 2500000 steps (42%)
15:16:55:WU01:FS02:0xa4:Completed 72500 out of 250000 steps (29%)
15:18:17:WU01:FS02:0xa4:Completed 75000 out of 250000 steps (30%)
15:19:37:WU01:FS02:0xa4:Completed 77500 out of 250000 steps (31%)
15:20:57:WU01:FS02:0xa4:Completed 80000 out of 250000 steps (32%)
15:22:17:WU01:FS02:0xa4:Completed 82500 out of 250000 steps (33%)
15:23:36:WU01:FS02:0xa4:Completed 85000 out of 250000 steps (34%)
15:24:55:WU01:FS02:0xa4:Completed 87500 out of 250000 steps (35%)
15:26:16:WU01:FS02:0xa4:Completed 90000 out of 250000 steps (36%)
15:27:36:WU01:FS02:0xa4:Completed 92500 out of 250000 steps (37%)
15:28:56:WU01:FS02:0xa4:Completed 95000 out of 250000 steps (38%)
15:30:15:WU01:FS02:0xa4:Completed 97500 out of 250000 steps (39%)
15:31:31:WU00:FS00:0x17:Completed 1200000 out of 2500000 steps (48%)
15:31:37:WU01:FS02:0xa4:Completed 100000 out of 250000 steps (40%)
15:32:59:WU01:FS02:0xa4:Completed 102500 out of 250000 steps (41%)
15:34:19:WU01:FS02:0xa4:Completed 105000 out of 250000 steps (42%)
15:34:20:WU04:FS01:0x17:Completed 1075000 out of 2500000 steps (43%)
15:35:40:WU01:FS02:0xa4:Completed 107500 out of 250000 steps (43%)
15:37:00:WU01:FS02:0xa4:Completed 110000 out of 250000 steps (44%)
15:38:20:WU01:FS02:0xa4:Completed 112500 out of 250000 steps (45%)
15:39:39:WU01:FS02:0xa4:Completed 115000 out of 250000 steps (46%)
15:41:00:WU01:FS02:0xa4:Completed 117500 out of 250000 steps (47%)
15:42:20:WU01:FS02:0xa4:Completed 120000 out of 250000 steps (48%)
15:43:41:WU01:FS02:0xa4:Completed 122500 out of 250000 steps (49%)
15:45:01:WU01:FS02:0xa4:Completed 125000 out of 250000 steps (50%)
15:46:22:WU01:FS02:0xa4:Completed 127500 out of 250000 steps (51%)
15:47:43:WU01:FS02:0xa4:Completed 130000 out of 250000 steps (52%)
15:47:51:WU00:FS00:0x17:Completed 1225000 out of 2500000 steps (49%)
15:49:03:WU01:FS02:0xa4:Completed 132500 out of 250000 steps (53%)
15:50:24:WU01:FS02:0xa4:Completed 135000 out of 250000 steps (54%)
15:51:29:WU04:FS01:0x17:Completed 1100000 out of 2500000 steps (44%)
15:51:45:WU01:FS02:0xa4:Completed 137500 out of 250000 steps (55%)
15:53:05:WU01:FS02:0xa4:Completed 140000 out of 250000 steps (56%)
15:54:25:WU01:FS02:0xa4:Completed 142500 out of 250000 steps (57%)
15:55:45:WU01:FS02:0xa4:Completed 145000 out of 250000 steps (58%)
15:57:05:WU01:FS02:0xa4:Completed 147500 out of 250000 steps (59%)
15:58:26:WU01:FS02:0xa4:Completed 150000 out of 250000 steps (60%)
15:59:46:WU01:FS02:0xa4:Completed 152500 out of 250000 steps (61%)
16:01:07:WU01:FS02:0xa4:Completed 155000 out of 250000 steps (62%)
16:02:28:WU01:FS02:0xa4:Completed 157500 out of 250000 steps (63%)
16:03:47:WU01:FS02:0xa4:Completed 160000 out of 250000 steps (64%)
16:03:56:WU00:FS00:0x17:Completed 1250000 out of 2500000 steps (50%)
16:05:09:WU01:FS02:0xa4:Completed 162500 out of 250000 steps (65%)
16:06:29:WU01:FS02:0xa4:Completed 165000 out of 250000 steps (66%)
16:07:49:WU01:FS02:0xa4:Completed 167500 out of 250000 steps (67%)
16:09:02:WU04:FS01:0x17:Completed 1125000 out of 2500000 steps (45%)
16:09:10:WU01:FS02:0xa4:Completed 170000 out of 250000 steps (68%)
16:10:30:WU01:FS02:0xa4:Completed 172500 out of 250000 steps (69%)
16:11:51:WU01:FS02:0xa4:Completed 175000 out of 250000 steps (70%)
16:13:12:WU01:FS02:0xa4:Completed 177500 out of 250000 steps (71%)
16:14:33:WU01:FS02:0xa4:Completed 180000 out of 250000 steps (72%)
16:15:54:WU01:FS02:0xa4:Completed 182500 out of 250000 steps (73%)
16:17:13:WU01:FS02:0xa4:Completed 185000 out of 250000 steps (74%)
16:18:35:WU01:FS02:0xa4:Completed 187500 out of 250000 steps (75%)
16:19:56:WU01:FS02:0xa4:Completed 190000 out of 250000 steps (76%)
16:20:15:WU00:FS00:0x17:Completed 1275000 out of 2500000 steps (51%)
16:21:18:WU01:FS02:0xa4:Completed 192500 out of 250000 steps (77%)
16:22:39:WU01:FS02:0xa4:Completed 195000 out of 250000 steps (78%)
16:24:00:WU01:FS02:0xa4:Completed 197500 out of 250000 steps (79%)
16:25:20:WU01:FS02:0xa4:Completed 200000 out of 250000 steps (80%)
16:26:12:WU04:FS01:0x17:Completed 1150000 out of 2500000 steps (46%)
16:26:41:WU01:FS02:0xa4:Completed 202500 out of 250000 steps (81%)
16:28:03:WU01:FS02:0xa4:Completed 205000 out of 250000 steps (82%)
16:29:23:WU01:FS02:0xa4:Completed 207500 out of 250000 steps (83%)
16:30:45:WU01:FS02:0xa4:Completed 210000 out of 250000 steps (84%)
16:32:06:WU01:FS02:0xa4:Completed 212500 out of 250000 steps (85%)
16:33:27:WU01:FS02:0xa4:Completed 215000 out of 250000 steps (86%)
16:34:50:WU01:FS02:0xa4:Completed 217500 out of 250000 steps (87%)
16:36:10:WU01:FS02:0xa4:Completed 220000 out of 250000 steps (88%)
16:36:18:WU00:FS00:0x17:Completed 1300000 out of 2500000 steps (52%)
16:37:32:WU01:FS02:0xa4:Completed 222500 out of 250000 steps (89%)
16:38:54:WU01:FS02:0xa4:Completed 225000 out of 250000 steps (90%)
16:40:15:WU01:FS02:0xa4:Completed 227500 out of 250000 steps (91%)
16:41:36:WU01:FS02:0xa4:Completed 230000 out of 250000 steps (92%)
16:42:57:WU01:FS02:0xa4:Completed 232500 out of 250000 steps (93%)
16:43:44:WU04:FS01:0x17:Completed 1175000 out of 2500000 steps (47%)
16:44:19:WU01:FS02:0xa4:Completed 235000 out of 250000 steps (94%)
16:45:40:WU01:FS02:0xa4:Completed 237500 out of 250000 steps (95%)
16:47:01:WU01:FS02:0xa4:Completed 240000 out of 250000 steps (96%)
16:48:21:WU01:FS02:0xa4:Completed 242500 out of 250000 steps (97%)
16:49:42:WU01:FS02:0xa4:Completed 245000 out of 250000 steps (98%)
16:49:43:WU02:FS02:Connecting to assign3.stanford.edu:8080
16:49:43:WU02:FS02:News: Welcome to Folding@Home
16:49:43:WU02:FS02:Assigned to work server 171.67.108.35
16:49:43:WU02:FS02:Requesting new work unit for slot 02: RUNNING cpu:7 from 171.67.108.35
16:49:43:WU02:FS02:Connecting to 171.67.108.35:8080
16:49:44:WU02:FS02
16:49:45:WU02:FS02
16:49:45:WU02:FS02:Received Unit: id:02 state
16:51:03:WU01:FS02:0xa4:Completed 247500 out of 250000 steps (99%)
16:52:24:WU01:FS02:0xa4:Completed 250000 out of 250000 steps (100%)
16:52:34:WU01:FS02:0xa4:
16:52:34:WU01:FS02:0xa4:Finished Work Unit:
16:52:34:WU01:FS02:0xa4:- Reading up to 1567212 from \"01/wudata_01.trr\": Read 1567212
16:52:34:WU01:FS02:0xa4:trr file hash check passed.
16:52:34:WU01:FS02:0xa4:- Reading up to 1758356 from \"01/wudata_01.xtc\": Read 1758356
16:52:34:WU01:FS02:0xa4:xtc file hash check passed.
16:52:34:WU01:FS02:0xa4:edr file hash check passed.
16:52:34:WU01:FS02:0xa4:logfile size: 27038
16:52:34:WU01:FS02:0xa4:Leaving Run
16:52:36:WU00:FS00:0x17:Completed 1325000 out of 2500000 steps (53%)
16:52:37:WU01:FS02:0xa4:- Writing 3362034 bytes of core data to disk...
16:52:37:WU01:FS02:0xa4: ... Done.
16:52:37:WU01:FS02:0xa4:- Shutting down core
16:52:37:WU01:FS02:0xa4:Folding@home Core Shutdown: FINISHED_UNIT
16:52:38:WU01:FS02:FahCore returned: FINISHED_UNIT (100 = 0x64)
16:52:38:WU01:FS02:Sending unit results: id:01 state:SEND error:NO_ERROR project:8702 run:63 clone:42 gen:4 core:0xa4 unit:0x000000046652edb351c6a602ba47393c
16:52:38:WU01:FS02:Uploading 3.09MiB to 171.67.108.35
16:52:38:WU01:FS02:Connecting to 171.67.108.35:8080
16:52:38:WU02:FS02:Starting
16:52:38:WU02:FS02:Running FahCore: \"C:\\Program Files (x86)\\FAHClient/FAHCoreWrapper.exe\" C:/Users/Brad/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 02 -suffix 01 -version 703 -lifeline 2208 -checkpoint 15 -np 7
16:52:38:WU02:FS02:Started FahCore on PID 9024
16:52:38:WU02:FS02:Core PID:8740
16:52:38:WU02:FS02:FahCore 0xa4 started
16:52:38:WU02:FS02:0xa4:
16:52:38:WU02:FS02:0xa4:*------------------------------*
16:52:38:WU02:FS02:0xa4:Folding@Home Gromacs GB Core
16:52:38:WU02:FS02:0xa4:Version 2.27 (Dec. 15, 2010)
16:52:38:WU02:FS02:0xa4:- Looking at optimizations...
16:52:38:WU02:FS02:0xa4:- Created dyn
16:52:38:WU02:FS02:0xa4:- Files status OK
16:52:38:WU02:FS02:0xa4:- Expanded 1024979 -> 2544640 (decompressed 248.2 percent)
16:52:38:WU02:FS02:0xa4:Called DecompressByteArray: compressed_data_size=1024979 data_size=2544640, decompressed_data_size=2544640 diff=0
16:52:38:WU02:FS02:0xa4:- Digital signature verified
16:52:38:WU02:FS02:0xa4:Assembly optimizations on if available.
16:52:38:WU02:FS02:0xa4:Entering M.D.
16:52:44:WU02:FS02:0xa4:Mapping NT from 7 to 7
16:52:44:WU01:FS02:Upload 22.22%
16:52:44:WU02:FS02:0xa4:Completed 0 out of 250000 steps (0%)
16:52:50:WU01:FS02:Upload 38.38%
16:52:57:WU01:FS02:Upload 56.55%
16:53:03:WU01:FS02:Upload 74.73%
16:53:09:WU01:FS02:Upload 90.89%
16:53:13:WU01:FS02:Upload complete
16:53:13:WU01:FS02:Server responded WORK_ACK (400)
16:53:13:WU01:FS02:Final credit estimate, 1470.00 points
16:53:13:WU01:FS02:Cleaning up
16:54:05:WU02:FS02:0xa4:Completed 2500 out of 250000 steps (1%)
16:55:25:WU02:FS02:0xa4:Completed 5000 out of 250000 steps (2%)
16:56:47:WU02:FS02:0xa4:Completed 7500 out of 250000 steps (3%)
16:58:08:WU02:FS02:0xa4:Completed 10000 out of 250000 steps (4%)
16:59:30:WU02:FS02:0xa4:Completed 12500 out of 250000 steps (5%)
17:00:50:WU02:FS02:0xa4:Completed 15000 out of 250000 steps (6%)
17:00:55:WU04:FS01:0x17:Completed 1200000 out of 2500000 steps (48%)
17:02:12:WU02:FS02:0xa4:Completed 17500 out of 250000 steps (7%)
17:03:33:WU02:FS02:0xa4:Completed 20000 out of 250000 steps (8%)
17:04:53:WU02:FS02:0xa4:Completed 22500 out of 250000 steps (9%)
17:06:13:WU02:FS02:0xa4:Completed 25000 out of 250000 steps (10%)
17:07:33:WU02:FS02:0xa4:Completed 27500 out of 250000 steps (11%)
17:08:39:WU00:FS00:0x17:Completed 1350000 out of 2500000 steps (54%)
17:08:54:WU02:FS02:0xa4:Completed 30000 out of 250000 steps (12%)
17:10:15:WU02:FS02:0xa4:Completed 32500 out of 250000 steps (13%)
17:11:36:WU02:FS02:0xa4:Completed 35000 out of 250000 steps (14%)
17:12:56:WU02:FS02:0xa4:Completed 37500 out of 250000 steps (15%)
17:14:17:WU02:FS02:0xa4:Completed 40000 out of 250000 steps (16%)
17:15:38:WU02:FS02:0xa4:Completed 42500 out of 250000 steps (17%)
17:16:58:WU02:FS02:0xa4:Completed 45000 out of 250000 steps (18%)
17:18:19:WU02:FS02:0xa4:Completed 47500 out of 250000 steps (19%)
17:18:25:WU04:FS01:0x17:Completed 1225000 out of 2500000 steps (49%)
17:19:40:WU02:FS02:0xa4:Completed 50000 out of 250000 steps (20%)
17:21:01:WU02:FS02:0xa4:Completed 52500 out of 250000 steps (21%)
17:22:22:WU02:FS02:0xa4:Completed 55000 out of 250000 steps (22%)
17:23:42:WU02:FS02:0xa4:Completed 57500 out of 250000 steps (23%)
17:24:59:WU00:FS00:0x17:Completed 1375000 out of 2500000 steps (55%)
17:25:04:WU02:FS02:0xa4:Completed 60000 out of 250000 steps (24%)
17:26:25:WU02:FS02:0xa4:Completed 62500 out of 250000 steps (25%)
17:27:46:WU02:FS02:0xa4:Completed 65000 out of 250000 steps (26%)
17:29:08:WU02:FS02:0xa4:Completed 67500 out of 250000 steps (27%)
17:30:29:WU02:FS02:0xa4:Completed 70000 out of 250000 steps (28%)
17:31:50:WU02:FS02:0xa4:Completed 72500 out of 250000 steps (29%)
17:33:11:WU02:FS02:0xa4:Completed 75000 out of 250000 steps (30%)
17:34:33:WU02:FS02:0xa4:Completed 77500 out of 250000 steps (31%)
17:35:34:WU04:FS01:0x17:Completed 1250000 out of 2500000 steps (50%)
17:35:53:WU02:FS02:0xa4:Completed 80000 out of 250000 steps (32%)
17:37:14:WU02:FS02:0xa4:Completed 82500 out of 250000 steps (33%)
17:38:34:WU02:FS02:0xa4:Completed 85000 out of 250000 steps (34%)
17:39:55:WU02:FS02:0xa4:Completed 87500 out of 250000 steps (35%)
17:41:02:WU00:FS00:0x17:Completed 1400000 out of 2500000 steps (56%)
17:41:14:WU02:FS02:0xa4:Completed 90000 out of 250000 steps (36%)
17:42:35:WU02:FS02:0xa4:Completed 92500 out of 250000 steps (37%)
17:43:56:WU02:FS02:0xa4:Completed 95000 out of 250000 steps (38%)
17:45:17:WU02:FS02:0xa4:Completed 97500 out of 250000 steps (39%)
17:46:37:WU02:FS02:0xa4:Completed 100000 out of 250000 steps (40%)
17:47:56:WU02:FS02:0xa4:Completed 102500 out of 250000 steps (41%)
17:49:16:WU02:FS02:0xa4:Completed 105000 out of 250000 steps (42%)
17:50:35:WU02:FS02:0xa4:Completed 107500 out of 250000 steps (43%)
17:51:55:WU02:FS02:0xa4:Completed 110000 out of 250000 steps (44%)
17:53:06:WU04:FS01:0x17:Completed 1275000 out of 2500000 steps (51%)
17:53:15:WU02:FS02:0xa4:Completed 112500 out of 250000 steps (45%)
17:54:35:WU02:FS02:0xa4:Completed 115000 out of 250000 steps (46%)
17:55:54:WU02:FS02:0xa4:Completed 117500 out of 250000 steps (47%)
17:57:13:WU02:FS02:0xa4:Completed 120000 out of 250000 steps (48%)
17:57:24:WU00:FS00:0x17:Completed 1425000 out of 2500000 steps (57%)
17:58:33:WU02:FS02:0xa4:Completed 122500 out of 250000 steps (49%)
17:59:53:WU02:FS02:0xa4:Completed 125000 out of 250000 steps (50%)
18:01:14:WU02:FS02:0xa4:Completed 127500 out of 250000 steps (51%)
18:02:34:WU02:FS02:0xa4:Completed 130000 out of 250000 steps (52%)
18:03:54:WU02:FS02:0xa4:Completed 132500 out of 250000 steps (53%)
18:05:15:WU02:FS02:0xa4:Completed 135000 out of 250000 steps (54%)
18:06:34:WU02:FS02:0xa4:Completed 137500 out of 250000 steps (55%)
18:07:55:WU02:FS02:0xa4:Completed 140000 out of 250000 steps (56%)
18:09:15:WU02:FS02:0xa4:Completed 142500 out of 250000 steps (57%)
18:10:18:WU04:FS01:0x17:Completed 1300000 out of 2500000 steps (52%)
18:10:36:WU02:FS02:0xa4:Completed 145000 out of 250000 steps (58%)
18:11:56:WU02:FS02:0xa4:Completed 147500 out of 250000 steps (59%)
18:13:18:WU02:FS02:0xa4:Completed 150000 out of 250000 steps (60%)
18:13:29:WU00:FS00:0x17:Completed 1450000 out of 2500000 steps (58%)
18:14:41:WU02:FS02:0xa4:Completed 152500 out of 250000 steps (61%)
18:16:02:WU02:FS02:0xa4:Completed 155000 out of 250000 steps (62%)
18:17:23:WU02:FS02:0xa4:Completed 157500 out of 250000 steps (63%)
18:18:42:WU02:FS02:0xa4:Completed 160000 out of 250000 steps (64%)
18:20:02:WU02:FS02:0xa4:Completed 162500 out of 250000 steps (65%)
18:21:24:WU02:FS02:0xa4:Completed 165000 out of 250000 steps (66%)
18:22:43:WU02:FS02:0xa4:Completed 167500 out of 250000 steps (67%)
18:24:03:WU02:FS02:0xa4:Completed 170000 out of 250000 steps (68%)
18:25:22:WU02:FS02:0xa4:Completed 172500 out of 250000 steps (69%)
18:26:42:WU02:FS02:0xa4:Completed 175000 out of 250000 steps (70%)
18:27:51:WU04:FS01:0x17:Completed 1325000 out of 2500000 steps (53%)
18:28:03:WU02:FS02:0xa4:Completed 177500 out of 250000 steps (71%)
18:29:24:WU02:FS02:0xa4:Completed 180000 out of 250000 steps (72%)
18:29:48:WU00:FS00:0x17:Completed 1475000 out of 2500000 steps (59%)
18:30:43:WU02:FS02:0xa4:Completed 182500 out of 250000 steps (73%)
18:32:03:WU02:FS02:0xa4:Completed 185000 out of 250000 steps (74%)
18:33:24:WU02:FS02:0xa4:Completed 187500 out of 250000 steps (75%)
18:34:46:WU02:FS02:0xa4:Completed 190000 out of 250000 steps (76%)
18:36:07:WU02:FS02:0xa4:Completed 192500 out of 250000 steps (77%)
18:37:28:WU02:FS02:0xa4:Completed 195000 out of 250000 steps (78%)
18:38:49:WU02:FS02:0xa4:Completed 197500 out of 250000 steps (79%)
18:40:09:WU02:FS02:0xa4:Completed 200000 out of 250000 steps (80%)
18:41:30:WU02:FS02:0xa4:Completed 202500 out of 250000 steps (81%)
18:42:51:WU02:FS02:0xa4:Completed 205000 out of 250000 steps (82%)
18:44:12:WU02:FS02:0xa4:Completed 207500 out of 250000 steps (83%)
18:45:02:WU04:FS01:0x17:Completed 1350000 out of 2500000 steps (54%)
18:45:32:WU02:FS02:0xa4:Completed 210000 out of 250000 steps (84%)
18:45:53:WU00:FS00:0x17:Completed 1500000 out of 2500000 steps (60%)
18:46:54:WU02:FS02:0xa4:Completed 212500 out of 250000 steps (85%)
18:48:16:WU02:FS02:0xa4:Completed 215000 out of 250000 steps (86%)
18:49:37:WU02:FS02:0xa4:Completed 217500 out of 250000 steps (87%)
18:50:58:WU02:FS02:0xa4:Completed 220000 out of 250000 steps (88%)
18:52:19:WU02:FS02:0xa4:Completed 222500 out of 250000 steps (89%)
18:53:40:WU02:FS02:0xa4:Completed 225000 out of 250000 steps (90%)
18:55:01:WU02:FS02:0xa4:Completed 227500 out of 250000 steps (91%)
18:56:23:WU02:FS02:0xa4:Completed 230000 out of 250000 steps (92%)
18:57:44:WU02:FS02:0xa4:Completed 232500 out of 250000 steps (93%)
18:59:06:WU02:FS02:0xa4:Completed 235000 out of 250000 steps (94%)
19:00:26:WU02:FS02:0xa4:Completed 237500 out of 250000 steps (95%)
19:01:47:WU02:FS02:0xa4:Completed 240000 out of 250000 steps (96%)
19:02:12:WU00:FS00:0x17:Completed 1525000 out of 2500000 steps (61%)
19:02:36:WU04:FS01:0x17:Completed 1375000 out of 2500000 steps (55%)
19:03:09:WU02:FS02:0xa4:Completed 242500 out of 250000 steps (97%)
19:04:30:WU02:FS02:0xa4:Completed 245000 out of 250000 steps (98%)
19:04:31:WU01:FS02:Connecting to assign3.stanford.edu:8080
19:04:31:WU01:FS02:News: Welcome to Folding@Home
19:04:31:WU01:FS02:Assigned to work server 128.143.231.202
19:04:31:WU01:FS02:Requesting new work unit for slot 02: RUNNING cpu:7 from 128.143.231.202
19:04:31:WU01:FS02:Connecting to 128.143.231.202:8080
19:04:33:WU01:FS02
19:04:35:WU01:FS02
19:04:35:WU01:FS02:Received Unit: id:01 state
19:05:52:WU02:FS02:0xa4:Completed 247500 out of 250000 steps (99%)
19:07:14:WU02:FS02:0xa4:Completed 250000 out of 250000 steps (100%)
19:07:24:WU02:FS02:0xa4:
19:07:24:WU02:FS02:0xa4:Finished Work Unit:
19:07:24:WU02:FS02:0xa4:- Reading up to 1567212 from \"02/wudata_01.trr\": Read 1567212
19:07:24:WU02:FS02:0xa4:trr file hash check passed.
19:07:24:WU02:FS02:0xa4:- Reading up to 1758580 from \"02/wudata_01.xtc\": Read 1758580
19:07:24:WU02:FS02:0xa4:xtc file hash check passed.
19:07:24:WU02:FS02:0xa4:edr file hash check passed.
19:07:24:WU02:FS02:0xa4:logfile size: 27019
19:07:24:WU02:FS02:0xa4:Leaving Run
19:07:26:WU02:FS02:0xa4:- Writing 3362239 bytes of core data to disk...
19:07:27:WU02:FS02:0xa4
19:07:27:WU02:FS02:0xa4: ... Done.
19:07:27:WU02:FS02:FahCore returned: FINISHED_UNIT (100 = 0x64)
19:07:27:WU02:FS02:Sending unit results: id:02 state:SEND error:NO_ERROR project:8702 run:42 clone:55 gen:3 core:0xa4 unit:0x000000036652edb351c6a5149b882353
19:07:27:WU02:FS02:Uploading 3.09MiB to 171.67.108.35
19:07:27:WU02:FS02:Connecting to 171.67.108.35:8080
19:07:27:WU01:FS02:Starting
19:07:27:WU01:FS02:Running FahCore: \"C:\\Program Files (x86)\\FAHClient/FAHCoreWrapper.exe\" C:/Users/Brad/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/Core_a3.fah/FahCore_a3.exe -dir 01 -suffix 01 -version 703 -lifeline 2208 -checkpoint 15 -np 7
19:07:27:WU01:FS02:Started FahCore on PID 8968
19:07:27:WU01:FS02:Core PID:6984
19:07:27:WU01:FS02:FahCore 0xa3 started
19:07:27:WU01:FS02:0xa3:
19:07:27:WU01:FS02:0xa3:*------------------------------*
19:07:27:WU01:FS02:0xa3:Folding@Home Gromacs SMP Core
19:07:27:WU01:FS02:0xa3:Version 2.27 (Dec. 15, 2010)
19:07:27:WU01:FS02:0xa3:- Looking at optimizations...
19:07:27:WU01:FS02:0xa3:- Created dyn
19:07:27:WU01:FS02:0xa3:- Files status OK
19:07:27:WU01:FS02:0xa3:- Expanded 3847686 -> 4382420 (decompressed 113.8 percent)
19:07:27:WU01:FS02:0xa3:Called DecompressByteArray: compressed_data_size=3847686 data_size=4382420, decompressed_data_size=4382420 diff=0
19:07:27:WU01:FS02:0xa3:- Digital signature verified
19:07:27:WU01:FS02:0xa3:Assembly optimizations on if available.
19:07:27:WU01:FS02:0xa3:Entering M.D.
19:07:33:WU02:FS02:Upload 20.20%
19:07:33:WU01:FS02:0xa3:Mapping NT from 7 to 7
19:07:34:WU01:FS02:0xa3:Completed 0 out of 500000 steps (0%)
19:07:39:WU02:FS02:Upload 38.38%
19:07:45:WU02:FS02:Upload 54.54%
19:07:51:WU02:FS02:Upload 70.70%
19:07:57:WU02:FS02:Upload 88.88%
19:08:02:WU02:FS02:Upload complete
19:08:02:WU02:FS02:Server responded WORK_ACK (400)
19:08:02:WU02:FS02:Final credit estimate, 1547.00 points
19:08:02:WU02:FS02:Cleaning up
19:17:12:WU01:FS02:0xa3:Completed 5000 out of 500000 steps (1%)
19:18:11:WU00:FS00:0x17:Completed 1550000 out of 2500000 steps (62%)
19:19:50:WU04:FS01:0x17:Completed 1400000 out of 2500000 steps (56%)
19:26:52:WU01:FS02:0xa3:Completed 10000 out of 500000 steps (2%)
19:34:34:WU00:FS00:0x17:Completed 1575000 out of 2500000 steps (63%)
19:36:27:WU01:FS02:0xa3:Completed 15000 out of 500000 steps (3%)
19:37:20:WU04:FS01:0x17:Completed 1425000 out of 2500000 steps (57%)
19:46:03:WU01:FS02:0xa3:Completed 20000 out of 500000 steps (4%)
19:50:34:WU00:FS00:0x17:Completed 1600000 out of 2500000 steps (64%)
19:54:32:WU04:FS01:0x17:Completed 1450000 out of 2500000 steps (58%)
19:55:41:WU01:FS02:0xa3:Completed 25000 out of 500000 steps (5%)
20:05:16:WU01:FS02:0xa3:Completed 30000 out of 500000 steps (6%)
20:06:58:WU00:FS00:0x17:Completed 1625000 out of 2500000 steps (65%)
20:12:03:WU04:FS01:0x17:Completed 1475000 out of 2500000 steps (59%)
20:14:52:WU01:FS02:0xa3:Completed 35000 out of 500000 steps (7%)
20:22:59:WU00:FS00:0x17:Completed 1650000 out of 2500000 steps (66%)
20:24:27:WU01:FS02:0xa3:Completed 40000 out of 500000 steps (8%)
20:29:16:WU04:FS01:0x17:Completed 1500000 out of 2500000 steps (60%)
20:34:01:WU01:FS02:0xa3:Completed 45000 out of 500000 steps (9%)
20:39:21:WU00:FS00:0x17:Completed 1675000 out of 2500000 steps (67%)
20:43:38:WU01:FS02:0xa3:Completed 50000 out of 500000 steps (10%)
20:46:49:WU04:FS01:0x17:Completed 1525000 out of 2500000 steps (61%)
20:53:06:WU01:FS02:0xa3:Completed 55000 out of 500000 steps (11%)
20:55:19:WU00:FS00:0x17:Completed 1700000 out of 2500000 steps (68%)
21:02:41:WU01:FS02:0xa3:Completed 60000 out of 500000 steps (12%)
21:04:05:WU04:FS01:0x17:Completed 1550000 out of 2500000 steps (62%)
21:11:44:WU00:FS00:0x17:Completed 1725000 out of 2500000 steps (69%)
21:12:15:WU01:FS02:0xa3:Completed 65000 out of 500000 steps (13%)
21:21:41:WU04:FS01:0x17:Completed 1575000 out of 2500000 steps (63%)
21:21:48:WU01:FS02:0xa3:Completed 70000 out of 500000 steps (14%)
21:27:43:WU00:FS00:0x17:Completed 1750000 out of 2500000 steps (70%)
21:31:25:WU01:FS02:0xa3:Completed 75000 out of 500000 steps (15%)
21:38:57:WU04:FS01:0x17:Completed 1600000 out of 2500000 steps (64%)
21:41:00:WU01:FS02:0xa3:Completed 80000 out of 500000 steps (16%)
21:44:06:WU00:FS00:0x17:Completed 1775000 out of 2500000 steps (71%)
21:50:38:WU01:FS02:0xa3:Completed 85000 out of 500000 steps (17%)
21:56:28:WU04:FS01:0x17:Completed 1625000 out of 2500000 steps (65%)
22:00:07:WU00:FS00:0x17:Completed 1800000 out of 2500000 steps (72%)
22:00:12:WU01:FS02:0xa3:Completed 90000 out of 500000 steps (18%)
22:09:47:WU01:FS02:0xa3:Completed 95000 out of 500000 steps (19%)
22:13:43:WU04:FS01:0x17:Completed 1650000 out of 2500000 steps (66%)
22:16:31:WU00:FS00:0x17:Completed 1825000 out of 2500000 steps (73%)
22:19:24:WU01:FS02:0xa3:Completed 100000 out of 500000 steps (20%)
22:28:55:WU01:FS02:0xa3:Completed 105000 out of 500000 steps (21%)
22:31:15:WU04:FS01:0x17:Completed 1675000 out of 2500000 steps (67%)
22:32:32:WU00:FS00:0x17:Completed 1850000 out of 2500000 steps (74%)
22:38:35:WU01:FS02:0xa3:Completed 110000 out of 500000 steps (22%)
22:48:12:WU01:FS02:0xa3:Completed 115000 out of 500000 steps (23%)
22:48:28:WU04:FS01:0x17:Completed 1700000 out of 2500000 steps (68%)
22:48:54:WU00:FS00:0x17:Completed 1875000 out of 2500000 steps (75%)
22:57:45:WU01:FS02:0xa3:Completed 120000 out of 500000 steps (24%)
23:04:53:WU00:FS00:0x17:Completed 1900000 out of 2500000 steps (76%)
23:06:02:WU04:FS01:0x17:Completed 1725000 out of 2500000 steps (69%)
23:07:22:WU01:FS02:0xa3:Completed 125000 out of 500000 steps (25%)
23:17:00:WU01:FS02:0xa3:Completed 130000 out of 500000 steps (26%)
23:21:12:WU00:FS00:0x17:Completed 1925000 out of 2500000 steps (77%)
23:23:15:WU04:FS01:0x17:Completed 1750000 out of 2500000 steps (70%)
23:26:33:WU01:FS02:0xa3:Completed 135000 out of 500000 steps (27%)
23:36:09:WU01:FS02:0xa3:Completed 140000 out of 500000 steps (28%)
23:37:17:WU00:FS00:0x17:Completed 1950000 out of 2500000 steps (78%)
23:40:52:WU04:FS01:0x17:Completed 1775000 out of 2500000 steps (71%)
23:45:41:WU01:FS02:0xa3:Completed 145000 out of 500000 steps (29%)
23:53:39:WU00:FS00:0x17:Completed 1975000 out of 2500000 steps (79%)
23:55:12:WU01:FS02:0xa3:Completed 150000 out of 500000 steps (30%)
23:58:08:WU04:FS01:0x17:Completed 1800000 out of 2500000 steps (72%)
00:04:48:WU01:FS02:0xa3:Completed 155000 out of 500000 steps (31%)
00:09:44:WU00:FS00:0x17:Completed 2000000 out of 2500000 steps (80%)
00:14:27:WU01:FS02:0xa3:Completed 160000 out of 500000 steps (32%)
00:15:48:WU04:FS01:0x17:Completed 1825000 out of 2500000 steps (73%)
00:24:08:WU01:FS02:0xa3:Completed 165000 out of 500000 steps (33%)
00:26:05:WU00:FS00:0x17:Completed 2025000 out of 2500000 steps (81%)
00:33:04:WU04:FS01:0x17:Completed 1850000 out of 2500000 steps (74%)
00:33:45:WU01:FS02:0xa3:Completed 170000 out of 500000 steps (34%)
00:42:11:WU00:FS00:0x17:Completed 2050000 out of 2500000 steps (82%)
00:43:03:WU01:FS02:0xa3:Completed 175000 out of 500000 steps (35%)
00:50:49:WU04:FS01:0x17:Completed 1875000 out of 2500000 steps (75%)
00:52:17:WU01:FS02:0xa3:Completed 180000 out of 500000 steps (36%)
00:58:29:WU00:FS00:0x17:Completed 2075000 out of 2500000 steps (83%)
01:01:33:WU01:FS02:0xa3:Completed 185000 out of 500000 steps (37%)
01:08:09:WU04:FS01:0x17:Completed 1900000 out of 2500000 steps (76%)
01:10:49:WU01:FS02:0xa3:Completed 190000 out of 500000 steps (38%)
01:14:34:WU00:FS00:0x17:Completed 2100000 out of 2500000 steps (84%)
01:20:05:WU01:FS02:0xa3:Completed 195000 out of 500000 steps (39%)
01:25:51:WU04:FS01:0x17:Completed 1925000 out of 2500000 steps (77%)
01:29:26:WU01:FS02:0xa3:Completed 200000 out of 500000 steps (40%)
01:30:52:WU00:FS00:0x17:Completed 2125000 out of 2500000 steps (85%)
01:39:12:WU01:FS02:0xa3:Completed 205000 out of 500000 steps (41%)
01:43:10:WU04:FS01:0x17:Completed 1950000 out of 2500000 steps (78%)
01:46:55:WU00:FS00:0x17:Completed 2150000 out of 2500000 steps (86%)
01:49:06:WU01:FS02:0xa3:Completed 210000 out of 500000 steps (42%)
01:58:57:WU01:FS02:0xa3:Completed 215000 out of 500000 steps (43%)
02:00:58:WU04:FS01:0x17:Completed 1975000 out of 2500000 steps (79%)
02:03:18:WU00:FS00:0x17:Completed 2175000 out of 2500000 steps (87%)
02:09:00:WU01:FS02:0xa3:Completed 220000 out of 500000 steps (44%)
02:18:21:WU04:FS01:0x17:Completed 2000000 out of 2500000 steps (80%)
02:19:08:WU01:FS02:0xa3:Completed 225000 out of 500000 steps (45%)
02:19:26:WU00:FS00:0x17:Completed 2200000 out of 2500000 steps (88%)
******************************* Date: 2013-06-25 *******************************
02:29:17:WU01:FS02:0xa3:Completed 230000 out of 500000 steps (46%)
02:35:46:WU00:FS00:0x17:Completed 2225000 out of 2500000 steps (89%)
02:36:12:WU04:FS01:0x17:Completed 2025000 out of 2500000 steps (81%)
02:39:33:WU01:FS02:0xa3:Completed 235000 out of 500000 steps (47%)
02:49:07:WU01:FS02:0xa3:Completed 240000 out of 500000 steps (48%)
02:51:47:WU00:FS00:0x17:Completed 2250000 out of 2500000 steps (90%)
02:53:31:WU04:FS01:0x17:Completed 2050000 out of 2500000 steps (82%)
02:58:32:WU01:FS02:0xa3:Completed 245000 out of 500000 steps (49%)
03:07:54:WU01:FS02:0xa3:Completed 250000 out of 500000 steps (50%)
03:08:09:WU00:FS00:0x17:Completed 2275000 out of 2500000 steps (91%)
03:11:00:WU04:FS01:0x17:Completed 2075000 out of 2500000 steps (83%)
03:17:15:WU01:FS02:0xa3:Completed 255000 out of 500000 steps (51%)
03:24:08:WU00:FS00:0x17:Completed 2300000 out of 2500000 steps (92%)
03:26:41:WU01:FS02:0xa3:Completed 260000 out of 500000 steps (52%)
03:28:11:WU04:FS01:0x17:Completed 2100000 out of 2500000 steps (84%)
03:36:09:WU01:FS02:0xa3:Completed 265000 out of 500000 steps (53%)
03:40:31:WU00:FS00:0x17:Completed 2325000 out of 2500000 steps (93%)
03:45:36:WU01:FS02:0xa3:Completed 270000 out of 500000 steps (54%)
03:45:44:WU04:FS01:0x17:Completed 2125000 out of 2500000 steps (85%)
03:54:59:WU01:FS02:0xa3:Completed 275000 out of 500000 steps (55%)
03:56:30:WU00:FS00:0x17:Completed 2350000 out of 2500000 steps (94%)
04:02:57:WU04:FS01:0x17:Completed 2150000 out of 2500000 steps (86%)
04:04:26:WU01:FS02:0xa3:Completed 280000 out of 500000 steps (56%)
04:12:53:WU00:FS00:0x17:Completed 2375000 out of 2500000 steps (95%)
04:14:00:WU01:FS02:0xa3:Completed 285000 out of 500000 steps (57%)
04:20:29:WU04:FS01:0x17:Completed 2175000 out of 2500000 steps (87%)
04:23:22:WU01:FS02:0xa3:Completed 290000 out of 500000 steps (58%)
04:28:53:WU00:FS00:0x17:Completed 2400000 out of 2500000 steps (96%)
04:32:49:WU01:FS02:0xa3:Completed 295000 out of 500000 steps (59%)
04:37:43:WU04:FS01:0x17:Completed 2200000 out of 2500000 steps (88%)
04:42:15:WU01:FS02:0xa3:Completed 300000 out of 500000 steps (60%)
04:45:17:WU00:FS00:0x17:Completed 2425000 out of 2500000 steps (97%)
04:52:00:WU01:FS02:0xa3:Completed 305000 out of 500000 steps (61%)
04:55:17:WU04:FS01:0x17:Completed 2225000 out of 2500000 steps (89%)
