- Apr 3, 2002
- Bloomington, IN
- Thread Starter
- #21
Updated (and improved) experiment
Hi, Everybody!
I just refined the tests. I had originally intended to use a multimeter to test the signal by turning the fan to each of 4 positions and measuring, but because the fan requires a minimal "threshhold" speed to give a reading that is faster than my multimeter can measure a voltage, I had to settle for these cruder tests.
Here's a cut 'n' paste of the results: (where bolded, there is text from another conversation, to which this was a reply)
Well, I refined the test a little bit, and the results are a little clearer. Also, there was one more result that I forgot to mention:
The fan needed to attain a sort of "threshold" speed before the LED's would flash with the RPM data. Before that, the fans would remain constantly on or off, depending upon the setup.
In the new setup, the "GND" LED indicates when the fan sensor wire is at ground, and the "+" LED indicates when the fan sensor wire is at a positive voltage.
Here's the test circuit for experiments 1 - 3:
(thank goodness for the breadboard -- easy rigging!)
Experiment 1:
fan +3V connected,
fan GND connected:
fan stalled: GND LED lit, bright
+ LED unlit
low speed: GND LED flashes (quickly) with fan signal, bright
+ LED unlit
Experiment 2:
Fan +3V disconnected,
fan GND connected:
fan stalled: GND LED unlit
+ LED unlit
low speed: GND LED flahses (more easily seen), bright
+ LED unlit
Experiment 3:
Fan +3V connected
fan GND disconnected:
+ LED lit, very dim
low speed: GND LED unlit
+ LED flashes, very dim
Here's the diagram for the last tests:
Experiment 4:
Rewired to supply fan +9V, common ground
(See the second circuit diagram.)
connected +9V to fan, then disconnected
+9V with GND connected and observed LED
as fan slowed to a stop.
fan at 9V speed: GND LED lit, bright,
flashes too fast to observe
+ LED unlit
fan slowing down: GND LED continues to flash
at lower speed, bright, until
fan is too slow to sustain signal
+ LED unlit
Experiment 4a:
Manual 50% PWM duty cycle, 1 second on,
1 second off:
GND LED flashes bright and is sustained during
entire cycle,
+ LED unlit
Test 3 confirms that the rpm monitoring signal occurs independent of the +ve fan voltage.
Absolutely. The tests seem to indicate a NC - GND
cycle. Furthermore, the strange results I got with the + LED in experiment 3 gave only a weak signal at best. I think it's a minor effect that won't be seen in most of our configurations. On the other hand, perhaps that weak signal would be sufficient for the motherboard to detect in a PWM scheme that modulates the GND current to the fan.
This gets me thinking about PWM and rpm monitiring, it should work if the -ve lead of the fan stays negative.
I think you're right. So long as the fan retains sufficient speed, the signal appears to come through just fine.
Unfortunately most of the PWM regulate the -ve lead of the fan
I looked at yours (and others). They do all seem to regulate the GND lead of the fan. If anybody has a PWM circuit that regulates the +V, that would be terrific!
This is pretty neat -- I think we're on to something here!
Anyone aware of any PWM that regulate the +ve fan lead (use a PnP or P channel mosfet to do the switching)
I'll keep my eyes peeled. At the end of the day, I'll probably use a potentiometer - NPN circuit for the low speed, but I'm certainly keeping an open mind to PWM, especially now that we have evidence that it would continue to supply a fan RPM signal!
-- Paul
Hi, Everybody!
Experiment 1:
fan +3V connected,
fan GND connected:
+ LED unlit
+ LED unlit
Experiment 2:
fan GND connected:
+ LED unlit
+ LED unlit
Experiment 3:
Fan +3V connected
+ LED lit, very dim
Experiment 4:
+ LED unlit
+ LED unlit
Experiment 4a:
1 second off:
entire cycle,
+ LED unlit
-- Paul
