I'm newish to memory overclocking. I just wanted someone with more experience than I to take a look at my current settings and confirm they are safe. I don't want to melt anything
These settings showed no errors with 86 mem test. I tried loosening the timings but had no post and I'm unsure exactly what each does exactly so I'm unfamiliar with how to adjust them individually. (Tried 17 17 37, booted but crashed). I assume (hopefully) I haven't done anything crazy with the voltage but if there is room for adjustment there, or anywhere, any advice is greatly appreciated.
If 3466 is all it can get, I'm ok with it. I just don't like missing out on potential performance if I can get it.
Thank you!
Memory label states:
*G.Skill F4-3200C16D-16GVKB
*DDR4 3200MHz 8gb x 2
*CL 16-18-18-38 1.35v
Current settings are:
3466MHz
cas latency 16
ras to cas delay 18
ras act time 38
dram voltage 1.3860
vccio voltage 1.15
sys agent voltage 1.15
Thank you!
3466MHz
cas latency 16
ras to cas delay 18
ras act time 38
dram voltage 1.3860
vccio voltage 1.15
