Finally got my water cooling all inside the new case! 56k Warning!
These are pics of my old setup, as you can see the rad is on the top.
This case is just way too crowded!
My new rig is a CM stacker case with all components inside.
I got a lot of great ideas from you guys so thanks. First off I decided to make a fiberglass shroud. It turned out decent but I did learn a few things to try for next time. I also switched to a bonneville heatercore (with A/C) as it is not as wide as the one I had originally. The cut out area on the side of the case is where I had to cut it to fit the first heatercore.
For fans I went with a couple of 24v Sanyo Denki's, they move quite a bit of air and are nearly silent at 12v. My loop is using tap water with a mixture of antifreeze and dye from a hilighter marker.
I also switched from 5/8"OD to 3/4"OD 1/2" tubing, it looks nicer and handles tight bends a heck of alot better than the 5/8" stuff. I cut a window in the side panel but it's not done yet. I've still got to cut out the opening for a 120mm fan. I'm pleased with the results so far, my temps are a little bit higher do to the warm weather but idle is 32ºc and load is 42ºc.
I'll update this thread once I finish the window mod.
Edit: I also have not installed my backup HD yet, still considering placement of cables and wires.
