How loud? Is there any way to quiet them down? If not, which video card would you suggest, keep in mind that I would like to keep it under $200.
The thing that causes fan noise is power draw.
Power being used creates heat, that heat has to be removed, and that has to be done with a heatsink.
The reference is loud because of the small heatsink area, causing higher fan speeds.
Two ways to get rid of this:
- Buy a GPU with a lower power draw.
- Buy a GPU with a non-reference heatsink.
Best option is both, as it becomes near silent instead of just becoming quieter.
I, personally, like EVGA's ACX cooler.
Also, by the time you're buying, the GTX 760 might be in your price range
(it would stomp both the 660 and 750Ti for gaming, and with the ACX cooler will be darn quiet)
As was pointed out earlier, its almost a waste to plan a PC build 3 months ahead of time.
The market simply changes too quickly.
