Hi this is my first mod ever that wasn't buy x part and just slap it in and call it a mod. The mods are pretty minor but have bigger plans for it soon.
Sorry about quality of pics taken on my HTC Evo 3D (5mp)
Mods so far:
1.Painted white tubes
2.Painted crossfire bridge
3.Painted video card cover and added a black pinstripe
4.Added a NZXT 120mm white fan rear exhaust
OutSide
InSide
will be redoing the white tubes
I plan on
1.Painting the front fan white fins with black bracket and removing leds
2. Adding sound activated blue led strips for each audio channel and a always on UV light
3.Cutting the front mesh for better air flow (200mm)
4.Sleeving the sata, PCI-E,8 pin and 24 pin in a white high mesh
5. This is kinda out there for my current lack of skills but cutting most of the top mesh out building a bracket to hold the rad so I can set up a push system
Any thought or suggestions and tips are most wecome
System Specs
AMD FX 6300 @4.5 1.425
HIS AMD HD 7770 Crossfire
ASrock 990FX Extreme 3
G.SKILL Ripjaws 8GB (2 x 4GB) 1333 7-7-7-21 1.5v
XFX PRO 750 xxx
ThermalTake Water 2.0 Extreme
Mushkin Enhanced Chronos 120GB SATA III
WD Green 1Tb 5400
WD Blue 640Gb 7200
Corsair 600T Case
Mods so far:
OutSide
InSide
I plan on
System Specs
XFX PRO 750 xxx
WD Green 1Tb 5400
WD Blue 640Gb 7200
Corsair 600T Case
