Ehh, I'll look into it. Even a slight bump in the BIOS can greatly improve rigs. However, there is a risk into OCing, so I'm afraid of that.
If you OC, is it covered by warranty?
In three years I've never seen a CPU or board die from a mild OC. Only people who don't follow basic guidelines for voltage and temperature end up with dead equipment from OC'ing.
Do you have a Phenom II, if so what is the vcore on load and idle (with CnQ, stock clocks)? Mine is 1.056v idle and 1.344v load but I've seen some people get sub 1v idle... I guess this has to do with the motherboard and power supply?
The rig I was talking about is a 940BE on an M3A32-MVP board with 2x1 Gb Corsair DDR2-800 CL4 RAM.
Currently running 3525 (235x15) @ 1.36 vCore, NB 2350 @ 1.225v - 42°C on SETI using a TRUE & medium Panaflo.
CnQ doesn't run stock clocks at idle - it down-clocks the CPU and drops the vCore to save power.
I haven't run CnQ since July 2006. I crunch SETI and our Team's unofficial motto is "
No Off Switch!". I was running 1.15 vCore at SETI load at the stock 3.0 GHz speed for just under 48 hours with the northbridge OC'ed to 2.0 GHz instead of the stock 1.8 GHz. SETI load is typically as much as, or maybe a
very small hair under, P95 (load temps run about 0.5°C lower). It's a lot tougher to crunch 48 hours worth of
valid work units than run P95 for 24 hours - and I get credit for crunching, P95 just heats up the room.
BTW - The rig did pass a 3 hour P95 test (manually stopped) just before I started crunching ...
