- Jul 7, 2001
- Greenwich,CT,USA
The Citroen
Newbie_Doo said:Do you have a solution to his problem? Can you help with his troubles with the game pad, or offer advice as to whether a wheel/pedal combo will work? Can you help with his display issues?
Pretty pictures are nice, but they don't help with his problem.
Newbie_Doo said:If YOU look above, the thread originator asked you to stop posting pictures and remove the ones you posted. If you don't know how to, I will be happy to do it for you.
Yes I used the Developement Patch but all it did was cause more problems. I would get thrown to the desktop after playing for 15mnts. or so. All it really did was to make the wing mirrors work with the bonus of instabilityFerrariF50 said:Also Did you download the game patch? You did know their was one out right? You can find it at www.easports.com It's a Development patch... Fixed alot of issue with Video cards like the Geforce.. Also it adds Forcefeedback and Backfireing sounds...And some more stuff.. It's about 10.3 Mb.
sonny said:Yes I used the Developement Patch but all it did was cause more problems. I would get thrown to the desktop after playing for 15mnts. or so. All it really did was to make the wing mirrors work with the bonus of instability
