Hi Overclockers!
I seem to have some issues with my build, the fps im getting is not as expected, I am aware that i have little to no ram here, however im am never using it all.
At the moment im playing a lot of league of legends and this system should be more than enough for it to run on max settings, i however seem to get some mad fps drops when we start teamfighting(a lot of particles and things to process), and id like to know how i can make it a fluent game all the way through? The average fps is 150, but during teamfights, it drops to 15/30 fps. lagging.
So, here is my setup so far.
i5 4670k 3.4ghz OC to 3.9
4gb 1600 mhz Corsair xms ram, running at 1600 not 1333
60GB Kingston ssd 6gb/s
Msi z87 GD65 Gaming motherboard
Msi GTX 760 Twin frozr 2GB OC
Coolermaster Seidon water cooling, swapped original fan out with a high performance 12cm viper 83 cfm fan
People suspect me of having bad internet, i have 200mb fiber
So system stays under 60 degrees celcius at all times, even during hot load.
Used Occt for cpu testing, cpu never rose above 80 degrees at stress test, for 30 minutes.
My own suspicion is that my cpu is bottlenecking the information, but the i5 is not a weak processor. so please, enlighten me!
If images from cpuz is needed, i will post later.
Thanks for reading
Thanks for reading
