im talking about systems with a very large amount of heat output 1200+watts(not a measurement of heat), even though this applies to smaller systems too
ok, so....
* a good loop has temp varience of 1-3' C throughout the whole loop AND at its warmest is between 5-10' C above ambient. a great loop at its warmest is between 2-5' C above ambient. we know our components run WAY hotter than 10' C above ambient.... so let's say i have 120.8 and 140.4 blowing a ton of warm air into the room. unless you're really lucky and it's a dry 65' F year around where youre at, it's not always the best idea to open a window(thinking in terms of summer now).
seems like no matter what, after the heat is removed from the loop, the heat is dealt with using an AC unit to cool the house.
central air uses WHO-KNOWS-how-much enery depending on the size of the house or apt. so rather than trying to keep the air in the room cool by cooling the whole house, why not just do something like this
window ac unit leads into a box vai large hosing, and out the other end of the box(of course the hosing is not connected inside the box)... the hosing eventually leads back to the intake of the ac unit(as long as that air is still cooler than the air outside) or just back outside. i can have my loop run into the box, have a fanless radiator in the box, and have my loop run back out of the box. this does this same thing for pretty cheap and keeps heat, mostly, from being introduced to your room. the ac unit can be as big or small as you need
i dont mean to walk in circles here,,,,,, but why does this not only seem practical, but nessecary
please dont say "hook the ac to your case"... unless im wrong here too. A: watercooling is way more efficient at cooling your components..........B: if the ac is in your case, when you turn the ac off, and warm air moves back into your case over the cool parts, youre going to end up with condensation
just so you guys know... when i say box, i mean mini fridge
