fx-6300 cpu-nb voltage
Chuy
Las Vegas
What is considered the max safe cpu-nb voltage? I had it at 2200MHz @1.1308v stable, 1 hour prime95 and a couple hours gaming,
if I pushed it to 2400MHz it would fail prime95 fairly quick. My goal is to raise the cpu-nb frequency to 2600MHz or as close a I'm able to get it. At the moment I have the cpu-nb set at 2400MHz @ 1.1391v testing on prime as I type this. After reading some old post I saw RGone state he ran his cpu-nb @ 1.2825v but I wasn't able to tell what cpu he had. I'm also sure his cooling/mobo is way better then what I have.http://www.overclockers.com/forums/showthread.php/730550-Vishera-and-NB
C
Chuy
Las Vegas
I think I have partially found some of the answers to my question.
cpu-nb 2400MHz @ 1.1391v stable at the moment. (only stress tested for short amount of time)
cpu-nb 2600MHz @ 1.1391v fail prime95
cpu-nb 2600MHz @ 1.1419v did not boot, got a black screen had to use jumper on mobo.
cpu-nb of 2400MHz might be all this chip/mobo can handle. Is there a recommended voltage limit? Are there any other setting that can be adjusted to try to get system stable with a cpu-nb of 2400MHz stable?
C
Chuy
Las Vegas
Do you think it just needed more juice to help keep stable? Im guessing that chart is for all FX processors?
Thank you
Johan45
Yes and yes, start at ~ 1.25v should get you to 24-2600 any way
C
Chuy
Las Vegas
I wasn't able to get the cpu-nb at 2600MHz even at 1.45v. It would fail to boot sometimes and I would have to use the cmos jumper on the motherboard. I was hesitant to run over 1.45v, while at that voltage it did make a significant difference to temps too.
Johan45
Some chips just don't have the parts. Try lowering to 2400 . If it's a no go then you're pretty much done.
