- Dec 19, 2012
There's something that makes me thing that's not the socket temp Blaylock. More likely the NB or even VRM both of which can get well over 100°c or might also be a non sensor like some other boards have. With that low voltage and a package temp of 53°c , makes me think of a cheap/stock cooler or bad mount or fans too slow. This makes it quite possible that the core temp is higher than the socket. Also if that were the socket temp the board should have either throttled itself or shut down. Right now I'm inclined to think that tmpin0 is the socket but I'll do more research.
I found it. I knew there was a user at OCN with the GD80
