Thanks for the help. I have a long way to go here still. I just didn’t want to load up all the software and debug etc to find I needed to reformat because I installed the Hard Drive SATA II config all wrong. I also just downloaded 3D Mark 06 and will run that. I have to start somewhere as I know my CPU is not really set the way it should be, nor do I know at the moment what to set it too? I will read up and figure it out, but I want to do benchmarking as I go along to monitor progress. I never used all these utilityies before, so it’s a learning cure. Memtest, 3dmark06, I seen a lot of postings with CPU-Z results, hav no idea what that is, but I will google that also. I will do follow up postings,,,by the way, (perhaps this needs another post?) I have a :
EVGA GeForce 8800GTS (G92) 512MB 256bit GDDR3 PCI Express 2.0 HDCP & SLI Ready Video Card Retail 512-P3-N841-AR
e-GeForce 8800GTS 512MB
Part Number 512-P3-N841-AR
Core Clock Speed 670MHz
Stream Processors 128
Memory Clock Speed 1940MHz
Memory Bandwidth 62.1GB/sec
Shader Clock Speed 1674MHz
Bus PCI-E
Interface DVI-I, DVI-I, HDTV-7
Bios settings are unclear:
Robust Graphics Booster (Auto, Fast, Turbo) ????
And this one really puzzles me:
PCI Express Frequency (MHZ) Adjustable range = 90 Mhz to 150 MHz. The auto setting defaults the setting to 100 MHZ (Which is what it is set to now)
The core clock on my GPU is 670 MHZ, Shader Clock speed = 1674 MHz
What am I missing here? The PCI Express Frequency (MHZ) maxes out at 150?
Thanks for the info, just so you know, that config for idling the cpu is disabled in the bios. I have below my CPU-Z validation, which thanks to you, I never knew I could display that. I also am new to using all these utilitys. I was also thrown back on your HD Tach results, then I realized you were running Raid. I also posted my results for this test, I am only running a single SATA II 500 GIG Western Digital. Tell me what you think of the results. Thanks
http://valid.x86-secret.com/show_oc.php?id=291552
yeah ,, I turned the CPU settings in the bios off because I read something in CPU-Z Faqs about disabling then because the CPU speed will not show up as intended (something of that nature), So I disabled them. As far as HD Tach goes, I had nothing running when I benchmarked. I have just been reading up on the benefits of loading up the SATA drive using the AHCI config as it facilitates "Native Command Queuing" and my drive supports that feature.
I plan on starting from scratch again this weekend, the only conflicting info I am reading is as to whether or not I need to install the driver in F6 mode while installing the new OS? Reading till my head explodes, it is not clear,
then it seems to matter whether or not you install the SATA drive on the Intel ICH9R South Bridge SATA controller, or Gigabytes SATA Controller???? which offers better performance,, I have not yet determined.
On another note, I also wanted to test my 4 gig of memory, so I downloaded Memtest,,, that SUCKED! When I ran it , it prompted me and told me I had to run 4 tests simultaneously @ 1028 values each. That thing ran over an hour and never finished anyway, I shut er down. Is there better freeware to test memory? Thanks,,, wheres the Tylenol?
P.S. I originally posted my questions in many forums I visit. this is the only forum so far that has not only responded, but offfered great assistance. Thanks to all that contribute!
