W wingman99 Member Joined Dec 10, 2003 Aug 6, 2011 #1 I have a thermalright TRUE black. I am wondering if it will fit the board im posting will the screws or plate hit the heat sink or caps also VRM? GIGABYTE GA-Z68A-D3-B3
Archer0915 "The Expert" Joined Nov 3, 2008 Aug 6, 2011 #2 The boards are designed with min/max specs. 1155 is 1155 as far as the HSF manufactures are concerned. If it will fit 1155 it should fit your board.
OP W wingman99 Member Joined Dec 10, 2003 Aug 6, 2011 Thread Starter #3 It just fit my board i have now the hold down screw just fits between chokes and i'm worried it will hit the new board VRM choke. I have the 1156 mount kit just want to order the rest of the component and have no problems.
