Gigabyte z370xp sli MB / i5-8600k - Which Memory Stick is right for me
Roketteere
Hey guys I am building my wife a new rig as I have been getting the stink eye from her for having a new desktop in 5 years. I have bought the following:
Gigabyte Z370XP SLI Mboard - ATX/LGA 1151
Buying the following:
i5-8600K
I’m using her old case And already bought an EVGA 600w power supply which is currently installed on MB
I have been looking for 16GB of RAM for her and have found this:
CORSAIR Vengeance LPX 16GB (2 x 8GB) 288-Pin DDR4 SDRAM DDR4 3000 (PC4 24000) Desktop Memory Model CMK16GX4M2B3000C15W http://www.newegg.com/Product/Product.aspx?Item=20-236-039
I will be OCing CPU
Does this seem like a good choice for RAM for this MB/CPU?
Thanks
R
Roketteere
Just about any will do. That will work fine. :)
R u following me lol. J/k
Again thanks you are the freaking best. I’m definitely going to grow my build knowledge quickly here
Looks like OC those sticks with XMP will be the first step after installing
EarthDog
Gulper Nozzle Co-Owner
Buckeyes!
That's what needs to happen regardless to anything over 2666. You are not overclocking the sticks as they are rated out of the box to run that (you are overclocking the memory controller in the CPU, however). But this platform will do 4000+ so no worries there.
R
Roketteere
This is what I ended up getting after all. Still did good?
Woomack
Benching Team Leader
i5 8400 already has the same cooler in the box so or skip it or get something better ... it's still good enough and not so loud for this CPU
i5 8400 is not overclocking, I hope you know that
R
Roketteere
Yes I knew that I can’t overclock. Wife and I decided this was a good enough build for what she needs. As long as she’s happy I’m happy.
Also didn’t know it came with fan. Thank you for that. I’ll keep it as a backup.
Thanks again everyone
