- Mar 10, 2011
Hi guys.
I'm looking for a good cooler to keep my CPU with good temps while I do some bench, this will not be 24/7 so, stability 24/7 isn't important. The rig components are this:
1- ASUS Maximus IV Gene-Z/GEN3
2- i7-2600k
3- Corsair Vengeance 2x4GB or Crucial Ballistix Tracer 2x2GB both 1600MHz. I have both, so, compatibility isn't a problem
4- NO case
In my country I can find the Hyper 212+, Cooler Master V6GT (which I think is good enough), Thermaltake Frio, MC V8, CM V10 and maybe the Noctua NH-D14 if I have lucky.
What do you think is the best option price/performance for that rig? I know than the NH-D14 is the best of those options, but if the V6GT can keep with good temps the CPU @ ~5GHz-5.2GHz while I do some 3D bench I'd be happy and get the V6GT.
Thanks for the help
2- i7-2600k
4- NO case
Thanks for the help
