- Apr 15, 2001
- Turku, Finland
In pursuit of reason for occasional crashes on 3D Mark and games I have drifted to quite desperate means. Now that summer has come and room temp is getting up to 23°-25° my cooling setup has proved to be quite insufficient. Increasing air flow through the case to maximum I can get with 2x120 mm and 2x80 mm fans, doesn't any more drop CPU temp under 38° under load (would give 35°-36° with 20° room temp). 38° happens to be the limit of stability with this CPU on 866MHz. Because another cause for crashes could be the memory I had to get CPU cooler for testing of recent VIO mod I made.
Vacuum cleaner tip was just what I was searching for!
So I took MB, PSU, HD and diskette drive out of the case and connected them on table. From my GORB I took fan away and attached vacuum cleaner (1350W) on it with cardboard adapter tube and duct tape. I looped 3D Mark 2000 for 2½ hours which is not long enough to be sure. Anyway it seems that CPU temperature can be now the culprit. I think that more airflow through heatsink is hard to get. Still CPU temp was 35°-36° (rt 25°)!
I am finally thinking of getting a better heatsink. Would drop in temperature be expected without a vacuum cleaner? Because CPU is on a slotket next to memory and PSU is almost touching slotket I don't have much room for heatsink. Any recommendations are welcome.
