- Jan 15, 2004
no the rads in there are copper and the heatercore may or may not have a brass tank (the one with a/c does not have brass it has copper on the bonny core), however brass and copper won't corrode much.
Reservoir:
Pros:
1) Faster/easier bleeding
2) can look good
Cons:
1) expensive
2) can break
T-line:
Pros:
1) CHEAP!
2) Can't break
3) small
Cons:
1) Harder to bleed/takes longer
2) Doesn't look as good
Reservoir:
Pros:
2) can look good
Cons:
1) expensive
2) can break
T-line:
Pros:
1) CHEAP!
2) Can't break
3) small
Cons:
