- Jun 16, 2001
This may have been a deciding factor, considering the performance loss isn't enough to warrant spending the extra money for an Intel system. He really didn't spend that much on the "core" components (except the RAM seems a bit pricey to me?)
Well it might have been the deciding factor if he had actually gone for the cheaper components like the TF570SLI, and the 5200+. The system purchased really offers no savings over an Intel system that after overclocking would dominate performance wise.
For $175 you get an E6550 and a Biostar TP35D2 for $85 AR, and it would actually be $25 cheaper than the AMD setup chosen. That combo should hit 3.5 at least and will be significantly faster than the X2.
Of course we're talking a difference of maybe 20-30% ultimately, and if the OP knowingly sacrificed that performance to buy AMD, then thats his choice. I think he will be very happy with that system, it should be a pretty solid gaming platform for some time to come.
Yikes, I didn't see that ram....$200 for 2GB of ram is ridiculous when you can get 2GB of Ballistix for $60 which will OC almost as well as anything out there. Honestly I would order the Ballistix and send back the Patriots even though you have to swallow the 15% restocking fee.
