- Oct 4, 2007
Hey there... I have two basic questions to ask here; I have a Coolermaster CM 690 case and I plan on using those two water cooling ports on the back in the near future (Preferably when I upgrade to a good dual or quad core) and since the two port holes are made for external cooling, I'd like to know what are some good external water cooling kits out there? Or rather, could I be safe with normal internal water cooling parts just sitting on my desk? This is the desk space including my monitor and such;
Save for cleaning it up I should have plenty of room...
The second question goes, if there aren't any good external kits, does it look like I have enough room for an internal? Here is a screen from inside my case:
Note that soon I'll upgrade to a 8800 so it's going to get a little cramped in there... but for now I'm keeping my wires all out since I'm still doing some small upgrades and not ready to close it up :b but now I just need suggestions if it's a good idea to go out and buy some external kit (However I'm going to get a better waterblock then what they'd offer) or just build my own and try to fit it all in.
