- May 29, 2001
- Columbus, OH
Howdy all
I'm thinking of modding my case by putting that sweet acrylic window on the side panel like everyone else does ...
only the problem is, there's a duct hole on it already .. urghh ... and I use it to blow direct outside air into the cpu HSF, and it works so well, dropping my cpu temp couple degrees down.
so I want both
.. acrylic window with a duct hole
... one question, can I cut the window like I do the case? (using dremel)
so I want both
