- Sep 29, 2001
- Budapest, Hungary
Hi, I got a 30-cap ("EE-layout") 3.0C specifically for overclocking. The default voltage is the lowest 1.475 V, so I thought it would go to at least 3.7 Ghz on air (as others report with such processors). But no. The CPU is Prime95-stable at the default voltage at 3.5 Ghz, but wouldn't go higher no matter what I do. Even at 3.6 Ghz, it rarely loads Windows. I have replaced my RAM (now have Geil DDR500 running at 1:1 way below spec) and increased the voltage up to 1.550, but no go. Using Abit IC7 with the latest BIOS. AGP/PCI speeds are of course locked at spec.
I don't think that the CPU temp is the problem; if it's Prime-stable at 3.5 Ghz, it should at least load Windows at 3.6...
Any ideas? Thanks.
Any ideas? Thanks.
