Ok, I hope I am putting this in the right forum, if not I apologize...
I am somewhat of a newb @ overclocking, and I would really like some help from someone that knows what they are doing.
My rig:
MB: Gigabyte GA EP45-UD3L
CPU: q9550 (2.83)
CPU Cooler: Zalman CNPS7500 LED (with the speed control switch)
PSU: PC-Power 750W
RAM: 8 gigs (4x2gig) corsair "dominator" 1066 DDRII w/ heatsink/+fans
GPU: HIS 4870 (i know I know, I shoulda gone Nvidia but lets not go there!)
Case: antec 900 (tons of fans including a big one on top blowing out)
HDD: standard WD SATA 320 gig
OS: x64 Vista Pro.
Ok, hopefully that is enough information for starters.
I have fooled around a bit in BIOS, and managed to raise the FSB to 400 instead of 333, set the RAM freq. to the 2.66D (i think) which made it say 1066/1066 which I think is what it should be...
I did nothing to voltages or mch strap or any of that stuff as it confuses me.
Those changes put the cpu @ 3.4 ghz and it seems very stable. I let prime95 run for a few hours, and then checked temps and the hottest core was barely breaking 60C. Idle speeds appear to be in the low-mid 30's C.
I suppose there is probably more that I can do. I don't want to go nuts since I have no watercooling, but I would like to fully maximize the potential of my system, and I am not sure what if anything I should be changing re: voltages, nor if I have the RAM stuff set properly. Should it be 1:1 what ever that means?
I would be eternally grateful if someone with experience with this board could help me...tell me exactly what should be set to what in the intelligent tweaker. I suppose I can probably go higher than this 3.4 but I'm unsure of what changes need to be made to the voltages, mch, etc.
Please help!
Again, sorry if this is in the wrong section, I did not see a place specifically for OC questions, so I figured cooling was the right area...
Thanks in advance for any help I receive here!
p.s. I know to google board+cpu etc etc. I've read and read, and tried things for hours on end. I am just struggling with this stuff...a lot of it confuses me. I am hoping I can find someone w/ a similar rig that would be kind enough to just tell me what to set things at...
My rig:
CPU: q9550 (2.83)
PSU: PC-Power 750W
OS: x64 Vista Pro.
Please help!
