Hello, I just read and searched the forum, but didnt find the answer. I want to speed the GPU/Men but cant fond any info on where this is done, i searched my bios but it doesnt show.
Most new cards have a utility that comes with the card that allows you to overclock it through the software utility. I would check your task tray for an icon associated with your video card and open the application. Then check all of the advanced options. You should find something to allow you to change both the GPU and memory frequency. Most NVIDIA based cards have this utility.
Download this and open up your display features in windows and a new overclocking option will become available. You must restart the PC before you can do any overclocking thou.
increase it a notch by notch and see if your system runs stable, run 3dmark2001se and see if there are any problems than you can again increase a notch keep doing that till you start having problems
