Hi,
I'm planning on purchasing a new System, and would appreciate any comments and /or suggestions on what I've put together. This system is mainly for general use, but I want something that will last at least 5 years and is very responsive... (I also want to 'tinker' CPU overclocking). I know the graphics card is low end, but I have to include one in the build, and this is the least expensive. I plan on using the on-board GPU and can always upgrade later if needed... but I don't ever seen a need for more than 1 mid-range card.
Here's the system I configured at AVADIRECT.COM ($897 w/delivery)...
# APEX, Vortex 3620 Black Mid-Tower Case, ATX, No PSU
# CORSAIR, TX650 V2 Power Supply 650W, 80 PLUS® Bronze, 24-pin ATX12V v2.31 EPS12V 2.92, 2x 8/6-pin PCIe
# GIGABYTE, GA-Z68A-D3H-B3, LGA1155, Intel® Z68, DDR3-2133 32GB /4, PCIe x16 SLI CF /2, SATA 3Gb/s RAID 5 /2, 6Gb/s /2, VGA+DVI+HDMI, USB 3.0 /2, HDA, GbLAN, ATX, Retail
# INTEL, Core™ i5-2500K Quad-Core 3.3GHz, HD Graphics 3000, LGA1155, 6MB L3 Cache, 32nm, 95W, EM64T EIST TB VT-x XD, Retail
# MUSHKIN, 4GB (2 x 2GB) Enhanced Silverline PC3-12800 DDR3 1600MHz CL9 (9-9-9-24) 1.5V SDRAM DIMM, Non-ECC
# GIGABYTE, GV-N84STC-512I Rev2.0, GeForce® 8400 GS 450MHz, 512MB GDDR3 1800MHz, PCIe x16, DVI+HDMI+VGA, Full-height/Low-profile, Retail
# SAMSUNG, 1TB SpinPoint F3, SATA 3 Gb/s, 7200-RPM, 32MB Cache, Retail
# RAID, RAID 1 (mirroring), min 2 hard drives required
# MICROSOFT, Windows 7 Home Premium 64-bit Edition, OEM
I can save an additional $20 by going with the following RAM instead of MUSHKIN... is it worth the savings?....
KINGSTON 4GB ValueRAM PC3-10600 DDR3 1333MHz CL9 (9-9-9) 1.5V SDRAM DIMM, Non-ECC
Thanks,
Tom
Hi,
Thanks,
Tom
