I thought XMBC was a WMC replacement?
Anyway, I've seen an explanation of how XMBC can play BDs, but it's a pain to get working.
I CAN verify a shortcut appears in WMC, but I haven't ever opened it yet.
I'll have a look at WIN-REMOTE, thanks. My current app is Unified Remote, which seems to have similar functionality, if not as much eye candy.
I wanted to chime in on what I use for my HTPC. With a possible interesting option at the end.
Granted it looks like you've invested in a remote already, but this may seem VERY interesting to you.
I bought a cheap 7" Levono tablet.Then installed WIN - REMOTE on both the PC and the tablet. I find this to be a great solution for a remote HTPC control. It handles WMC and XMBC, besides other media apps and your browser of choice, whatever that may be. (I remote control my torrent client, since I seed Overclockix.) Plus the befit of being able to use the tablet for other things as well. It's just nice to have a multifunction device. Or play Angry Birds if I am bored.
Since I'm a cord cutter. I don't have cable TV DVR. Though if I did. I could download an app for my provider, to set up the DRV with that. Though I do use is the tablet as a TV guide. Since OTA is harder to get easy listings.
I suggest looking at the Galaxy Tab 2. With the built in IR blaster and Peel software. I think it would be of interest to you.
Alternatively, can you have TWO cable modems hooked up in the same house? If so, I could just buy a cheap cable modem off of ebay and stick it down with the HTPC. It would unfortunately not be on the same network, but I could live with that trade-off.
You may be onto something, as my confidence in that kind of work is near zero. I called a local electrician and they'd charge time & material. Labor would be $100 for the first hour, pro-rated at that rate every additional hour. Based on what I told them, the estimate is 1-2 hours, plus cable. While it's not cheap, it's probably better (and cheaper) in the long run than me screwing something up.If your confidence and/or handyman skills are low. You could outsource the basics to an electrician. He/she will be very familiar with what to do, for your local codes. It would be far cheaper in the long run, against a new modem subscription. Plus the professional will have all the tools needed to do the job.
You could get all the infrastructure lines you need dropped. Having the work done beforehand. If you need to upgrade to a newer tech later on. You would not have the same issue now. As the hard part is done. Since once the drops are in place. It is super easy to go sideways, adding more lines as you see fit.
MoCA sounds interesting; wonder whether that interfere with my incoming cable signal at all? Of course, having to buy all the MoCA equipment would end up being more expensive than having the electrician come drop the cable.Considered MoCA? If you have existing CATV outlets both at the HTPC and also near the switch.
Another possible alternative is powerline which *might* work if you are going floor-to-floor right above one another. Just be sure you can return them because they'll either get adequate speeds or they'll suck, depending on your home's wiring age and whether you need to cross phases of your circuit box.
The good thing about either is that whatever speeds you get, they are virtually 100% stable with MoCA or powerline. So if it's enough speed for HD content, it's always enough.
