Instructions
Instructions
It is very easy to update your Award MB bios file with the new HPT bios using the cbrom dos program - the newest version of cbrom is 215
1. Just load cbrom215.exe, mb award bios file, new hpt bios file on a floppy
2. Insert bootable floppy and boot to dos a prompt
3. type cbrom215.exe bd7_92.bin /d (bd7_92.bin is mb bios file name)
4. this will display info about files contained in your bios - look at the two files listed under pci a & b - under one of those you will see the HPT 231 or 232 bios file listed
5. Then type cbrom215.exe bd7_92.bin / pci release
It will prompt you as to relase a or b - select the one which contained the HPT 231 or 232 bios - it will confirm that file was released
6. Then type cbrom215.exe bd7-92.bin /pci bios372s.233 (bios372s.233 this is the new HPT 2.33 bios - can also flash to 2.32 if you have or want that HPT bios file) will confirm the new hpt bios was added
7. then type cbrom215.exe bd7-92.bin /d - this will again show all files in your bios just confirm that the new HPT bios is in pci a or b whichever you removed the old one from
Just load the new HPT drivers prior to flashing to your new bios
thats it - very easy
Get the cbrom215 program here -
http://www.stormpages.com/crazyape/cbrom.html
thanks steven , original post :
http://forum.oc-forums.com/vb/showthread.php?s=&threadid=104239&highlight=cbrom
