- Nov 25, 2009
I currently have two coolermaster 120mm fans in my coolermaster elite 330 case. One is the standard fan, the second mounted at the front sucking air in over the hard disks is a Cooler Master TLF-S12-EB 120mm Quad LED Silent Case Fan. It has an air flow rating of 42.734 CFM and an air pressure rating of 1.557 mmH2O.
I have given up on overclocking my phenom 965, as soon as I boost the speed, it gets too hot, even though idle temp is at 30c.
So next idea is to replace these two case fans with better ones, but how much of a difference would a higher rated fan be?
For instance if I swapped for two Coolermaster BladeMaster 120mm fans with an air flow rating of 76.8 CFM and an air pressure rating of 3.90 mm H2O.
