- Dec 21, 2011
- Republic of Texas
Over the past year, i have been using premix liquid coolant from EK and Koolance, now i want to mix my own coolant but i don't know how and where to start, somebody please help.
Distilled water and biocide (silver killcoil or PHN Nuke). That's all that's required. So long as you don't have aluminum in your loop, you don't need corrosion inhibitors.
The instructions will tell you how to mix it. I can't remember off hand but a couple of drops is probably sufficient for most loops.
+1 to coloured tubing. Dyes tend to clog and stain your components. If you really want colour, some UV reactive tubing and UV lights will make your case shine like no tomorrow. You can also use LEDs in strategic locations for lighting in your reservoir.
I did use led light, here are my pc pic
http://www.overclockers.com/forums/picture.php?albumid=495&pictureid=2655
Thank Modz 4 Higher, that are the answer i have been asking for tho whole afternoon
this, but no Nuke. nickel platting...
killcoil or silver tubing will do.
