Usually after 4ghz, there's a heavy vcore required unless chip is very good. Some people say 1.35 vcore is fine, but if she's not stable, probably drop bclk lower or drop multi.
Here's the thing about bclk vs multi. Because ram is tied to bclk and ram multiplier doesn't go low enough, you may not be able to go too much bclk, because in turn it'll drive ram too much frequency....they're tied together. Lowest multi in p6t is 6x, which at 210multi will make ram 1260. I don't see that much of a problem though because is ram even being 1066 can take it with looser timings, but if you have 1333 ram sticks and don't want to undercloxk them, here's what happens:
Next ram multi is 8x, which makes ram go 210x8=1680!! Some 1333 ram can take it, but others will need very loose timings to run it. And another thing, if uncore(integrated memory controller) isn't very good, it will need bigger QPI/DRAM(vtt) voltage bumps. Most people I've read can run 1600 ram though.
Don't forget, uncoee has to be minimum 2x multi of ram, so if ram is 1333, uncore will be 2666...it can go higher than 2x, but not lower.
Another thing with higher bclk is, your QPI link speed, even being at lowest multi will make it still very high and in some cases may not work reliably. My board for example can't stay stable even 196 bclk and 200 won't even boot. Yours looks better because it in boots, but I guess this is where guide is correct about checking max bclk you can run. In your case if you're pusshing it beyond 200, probably good idea to see if it's even stable. In this case, like I mentioned, guide is excellent advice. They say drop everything multis to lowest and see if she's stable.
Now if you don't feel like doing that extra work and want to "jump over that", you have high miltis to play around with. You can replicate similar could frequency by cranking CPU multi and dropping bclk and see if she's good now.
210bclk x21 =4400 MHz cpu
169bclk x26 =4396 fairly similar, which you could try and if it doesn't work then it's definitely too high court frequency because 169 bclk *anyone* can run
