hi there.
just joined, first post.
i've been reading online for hours and hours, trying to get a good grasp on my first OC.
when running cpuid HWMonitor and Core Temp on the default build, i found i was already getting nothing cooler than 60C when idle, so i started to scratch my head and wonder.
i did some mild OCing from the bios and booted back into windows to find that now my temps were between 90 and 100C (!!!)
then i remembered how, when cleaning and changing some hardware in the tower i'd removed the heatsink, which hadn't gone well (tbh), and i also hadn't reapplied any thermal compound.
so i did some more research then went out today and got a Nano Diamond compound with >3.8 W/m-K conductivity, applied it, and re-seated the cpu.
i booted into bios, changed the settings back to default, and watched the HW monitor (still in BIOS) climb from 50C to 67C within less than two minutes of booting.
so, with fully knowledge that i haven't divulged any other specs, i'm simply wondering: how inaccurate is "inaccurate" when threads mention the thermal sensors being not so trustworthy? also, how do i know if i've re-seated the heatsink correctly? i realise there are several kinds of heatsinks, but i don't believe any of them, when installed correctly, should be able to be lifted out with a gentle tug (which mine always could, hence the original removal).
anyone care to take a stab at this?
or do you need more info first?
i have been searching, both in here and in general on google, but, well, even searching the term "temperature" in OC.com doesn't yield any pertinent results that seemed to address this (amateur) issue.
i could dig more, but i've been reading all day so i thought i'd start a thread.
thanks!
thanks!
