Something like..1011 dollars total. I got moniter, mouse, software, keyboard, perhiperals, etc covered. What do you think of that? First comp im gunna be putting together. Correct things you see wrong as fit.
Case/Power –
Foxconn CasEdge Case with 400W Power Supply (Blue&Black), Model "TH202" -RETAIL
Model# Diabolic TH202 BLUE
Item # N82E16811153007
Specifications:
Case Type: Mid-Tower
Color: Blue& Black
Material: Steel & Plastic
Drive Bays: 4x5.25", 2x3.5", 4x3.5"(Internal)
Expansion Slots: 7
Front Ports: 4x USB2.0, 1x1394, Audio Ports
Power Supply: 400w
Cooling System: 1x120mm Fan
Motherboard Compatibility: MicroATX/ATX
Dimensions: 19"x18"x17" (DxWxH)
Special Features: Tooless removable/installation of M/B tray; Side Panel Window
$69Dollars
Motherboard –
EPoX "EP-4PDA3I" i865PE Chipset Motherboard for Intel Socket 478 CPU -RETAIL
Model# EP-4PDA3I
Item # N82E16813123217
Specifications:
Supported CPU: Intel Pentium 4(HT)/Celeron Processors(Prescott Ready)
Chipset: Intel 865PE + ICH5
FSB: 800/533/400MHz
RAM: 4x DIMM for Dual-Channel DDR400/333/266 Max 4GB
IDE: 2x ATA 100 up to 4 Devices
Slots: 1x AGP 8X/4X (1.5V), 5x PCI
Ports: 2xPS/2, 2xCOM, 1xLPT, 1xLAN, 8xUSB2.0 (Rear 4), SPDIF Out, Audio Ports
Onboard Audio: Realtek ALC650 6-Channel Codec
Onboard LAN: Realtek 8100B 10/100Mbps Fast Ethernet
Onboard SATA: 2x Serial ATA
Form Factor: ATX
$79 Dollars
Processor –
Intel Pentium 4/ 3.0E GHz 800MHz FSB, 1MB L2 Cache, Hyper Threading Technology
Model# BX80546PG3000E
Item # N82E16819116171
Specifications:
Model: Intel Pentium 4 w/ Hyper Threading
Core: Prescott
Operating Frequency: 3.0GHz
FSB: 800MHz
Intel Pentium 4/ 3.0E GHz 800MHz FSB, 1MB L2 Cache, Hyper Threading Technology - Retail
Specifications:
Core: Prescott
FSB: 800MHz
Cache: L1/12K+16K; L2/1MB
Voltage: 1.25V - 1.525V
Process: 0.09Micron
Socket: Socket 478
Multimedia Instruction: MMX, SSE, SSE2, SSE3
Warranty: 3-year MFG
$199 Dollars
Hard drive - SAMSUNG 160GB 7200RPM IDE Hard Drive, Model SP1604N, OEM Drive Only
$89 Dollars
Video Card -
ASUS nVIDIA GeForce 6800 Video Card, 256MB DDR3, 256-Bit, TV-Out/DVI, 8X AGP, Model"V9999 Gamer Edition/TD/256M" -RETAIL
Model# V9999 GE/TD/256M
Item # N82E16814121172
Specifications:
Chipset/Core Speed: nVIDIA GeForce 6800/350MHz
Memory/Effective Speed: 256MB DDR3/1000MHz
BUS: AGP 4X/8X
Ports: VGA out (15 Pin D-Sub) + TV-Out (S-Video/Composite) + DVI
Support 3D API: DirectX 9, OpenGL 1.5
Max Resolution@32bit Color: 2048X1536
Cable/Accessories: S-Video Cable, DVI to VGA adaptor, Manual, Driver CD, Games, Free Web cam
$412 Dollars
CD Drives –
SONY Beige 52x32x52 IDE Internal CD-RW Drive, Model CRX230ED, OEM
Model# CRX230ED
Item # N82E16827106822
Specifications:
Write Speed: 52X CD-R, 32X CD-RW
Read Speed: 52X CD-ROM
Interface: ATAPI / E-IDE
Buffer: 2MB
OS Support: Windows XP/ 2000/ Me/ 98SE
Features: PowerBurn Conformed, VAS Vibration Reduction
Packaging: OEM (W/ CD Maker software)
$28 Dollars (Bottom – WRITE DRIVE)
Samsung Black 52X32X52X16 DVD/CD-RW Combo Drive, Model TS-H492A/WBGH, OEM
Model# TS-H492A/WBGH
Item # N82E16827151051
Specifications:
Read Speed: 52X CD-ROM, 16X DVD-ROM
Buffer: 2MB
OS Support: Windows XP/2000/Me/98SE
Features: Not specified
Packaging: OEM
$37 Dollars (Top – READ DRIVE)
Memory
OCZ Performance Series 184-Pin 512MB DDR PC-3200 Rev 3
Model# OCZ400512R3
Item # N82E16820146898
Specifications:
Manufacturer: OCZ
Speed: DDR400 (PC3200)
Type: 184-Pin DDR SDRAM
Error Checking: Non-ECC
Registered/Unbuffered: Unbuffered
Cas Latency: 2.5-3-3-6 on AMD systems and 2-3-3-6 on the Intel systems
Support Voltage: 2.6V
Bandwidth: 3.2GB/s
Organization: 64M x 64-Bit
Warranty: Lifetime
$98 Dollars
SO what do you guys think?
Case/Power –
Specifications:
Color: Blue& Black
Expansion Slots: 7
Power Supply: 400w
$69Dollars
Motherboard –
Model# EP-4PDA3I
Specifications:
FSB: 800/533/400MHz
Form Factor: ATX
$79 Dollars
Processor –
Specifications:
Core: Prescott
FSB: 800MHz
Specifications:
Core: Prescott
FSB: 800MHz
Process: 0.09Micron
Socket: Socket 478
$199 Dollars
$89 Dollars
Video Card -
Specifications:
BUS: AGP 4X/8X
$412 Dollars
CD Drives –
Model# CRX230ED
Specifications:
Buffer: 2MB
Specifications:
Buffer: 2MB
Packaging: OEM
Memory
Model# OCZ400512R3
Specifications:
Manufacturer: OCZ
Bandwidth: 3.2GB/s
Warranty: Lifetime
$98 Dollars
