Procedure Implementing Password Policies using Overlay
penLDAP with ppolicy
Overlays are dynamically configurable modules that provide additional functionality to OpenLDAP. The ppolicy overlay provides some useful functionalities for enforcing a password policy for the domain.
Requirement was the following
Account*should*be locked out after 5 failed authentication attempts.
Password expiration on 90 days
Minimum*password*length of 8
All our desktop's were authenticating the OpenLDAP server(example.in) which was setup on a CentOS box.*We were able to*achieve*the 99999 days password expiration using the default*shadowAccount*objectClass as given below.
Code:
# test, People, example.in
dn: uid=test,ou=People,dc=example,dc=in
uid: test
cn: test
objectClass: account
objectClass: posixAccount
objectClass: top
objectClass: shadowAccount
userPassword:: e2NyeXB0fSQxJEMzOxxxxxxxxxx
shadowLastChange: 15140
shadowMax: 99999
shadowWarning: 7
loginShell: /bin/bash
uidNumber: 1000
gidNumber: 1000
homeDirectory: /home/test
But we couldn't find any way to implement the*password*expirartion and password*length*polcies using the default OpenLDAP*configuration. So I started my*experiment's*with ppolicy overlays.*The ppolicy overlays provides enhanced password management capabilities that are applied to non-rootdn bind attempts in OpenLDAP.
Installation
The password policy(ppolicy) and other overlays are included in the package*openldap-servers-overlays for Redhat/Centos servers. So we nee first install this package assuming openldap server and*dependencies*are already installed..
Code:
yum install*openldap-servers-overlays
The ppolicy module file should get installed at*/usr/lib64/openldap/ppolicy.la and schema file at /etc/openldap/schema/ppolicy.schema**on a 64 bit CentOS/Redhat server. The module file should be in*/usr/lib/openldap directory on an x86 server.
Server Configuartion
We need to*configure*the ppolicy overlays now. Add the following lines to*/etc/openldap/slapd.conf*in the respective sections.
Code:
include /etc/openldap/schema/ppolicy.schema
modulepath /usr/lib64/openldap
moduleload ppolicy.la
This is assuming that ppolicy overlay files are in respective locations. The ACL's*should be set such that*clients*bind to OpenLDAP server by self-authentication. We should not allow anonymous or rootdn binds to the server. The default*configuration*is to allow anonymous binds to server. So I added ACL as given below in the ACL section of*slapd.conf.
Code:
#ACL
access to attrs=userPassword
by self =xw
by anonymous auth
by * none
access to *
by self write
by * read
Next we need to add default password policy we are going to enforce on the domain. Add the following after the DB section in slapd.conf.
Code:
overlay ppolicy
ppolicy_default "cn=default,ou=policies,dc=example,dc=in"
ppolicy_use_lockout
This should complete the*configuration*of slapd.conf . You should be able to restart the LDAP server without any issues now.
Importing the password policy
Create a LDIF file with following content.
Code:
cat password-policy.ldif
dn: ou=policies,dc=example,dc=in
ou: policies
objectClass: top
objectClass: organizationalUnit
# default, policies, example.com
dn: cn=default,ou=policies,dc=example,dc=in
objectClass: top
objectClass: device
objectClass: pwdPolicy
cn: default
pwdAttribute: userPassword
pwdMaxAge: 7776002
pwdExpireWarning: 432000
pwdInHistory: 3
pwdCheckQuality: 1
pwdMinLength: 8
pwdMaxFailure: 5
pwdLockout: TRUE
pwdLockoutDuration: 900
pwdGraceAuthNLimit: 0
pwdFailureCountInterval: 0
pwdMustChange: TRUE
pwdAllowUserChange: TRUE
pwdSafeModify: FALSE
This sets the following policies
password expiration at 90 days
password lockout on 5 failures and lockout duration of 15 mintues
minimum*password*length of 8
3 earlier password in history
To import the policy run the following command.
Code:
ldapadd *-D "cn=Manager,dc=example,dc=in" -W -x *-f*password-policy.ldif
This ldapadd command should add to policy on authentication as LDAP*administrator.*We should be able to see the newly imported policy now when we do a ldapsearch.
Code:
ldapsearch *-x -D "cn=Manager,dc=example,dc=in" -W -b "dc=example,dc=in"
This completes the server*configuration.*
Client Side Configuration
On the LDAP clients in my case desktops we need make the following change in LDAP client*configuration*file*/etc/ldap.conf*assuming the*client*was*configured*to authenticate to our LDAP server before. Uncomment the pam_lookup_policy line which should be already there in*/etc/ldap.conf
Yes !! Now the password policy should be enforced for all non-rootdn authentication attempt
