- Jun 15, 2011
I am looking into building an HTPC to replace my current WDTV Live (custom WDLXTV firmware). The WDTV is a good movie streamer, but it has slow navigation, and I'm a little fed up with creating moviesheets manually. I also have some annoying audio/video sync problems I can't get rid of. I want to keep my media files on my QNAP NAS.
I've been looking at different media players, but they all seem to come with a non-customizable interface, plugins and apps I don't want etc, other limitations etc. Now, I realise that building an HTPC is somewhat different than building the regular gaming PC when you're just mixing all the fastest components on the market. Fast components generate heat (bad) and empty the wallet (bad) without adding any performance.
So my needs are this:
-Fluent playback of full HD 1080p with DTS/AC3 sound
-Fluent and fast navigation
-Customizable navigation layout
-Ability to power on HTPC by remote control
-Internal remote (IR?) sensor
-Deathly quiet
-Boot directly to media player
-3D BluRay ISO (nice if possible, but not crucial)
What I don't need.
-Gaming, music, any other computer related tasks
Now, I haven't decided on an OS/software, but I'm a little tempted by running XBMC. XBMC Live or the soon to be released XBMCbuntu will probably be what I am looking for.
What I also haven't decided on, however, is whether to go with an Intel or an AMD CPU, or if I need a discrete GPU. I have been looking at both the AMD A-3500 and the Intel i3 2120T. The i3 has a TDP of 35W and the A-3500 65W. But then again, there is a question about driver support and which chip has the better graphics for movie playback.
So far, my best idea for a complete build will be:
ASUS F1A75I-Deluxe m-ITX motherboard
AMD A-3500 CPU
4GB of cheapest RAM
OCZ Agility 3 60GB SSD
Streacom FC8 fanless chassis
Streacom IR sensor (internal)
Is this overkill for my needs? Am I better off choosing a motherboard with intergrated CPU/GPU (ie. ASUS E45M1-I with the AMD E-450 CPU)? That would require at least a chassis fan to cool the heatsink, and I'm not too keen on adding any noise sources.
Does anybody have any other (and preferrably cheaper) solutions that would satisfy my needs? I'd be greatful for any tips.
-Deathly quiet
What I don't need.
AMD A-3500 CPU
4GB of cheapest RAM
