Senater_Cache said:
impressive, any one with the older version D4 chart on hand please post for comparison.
This was my take on the D4's performance. Note that my pump has 3/4" fittings so it is more free flowing than the 1/2" models towards the right end of the graph. The peak pressure will not change because of this. The larger fittings have the most effect when the pump is working against no pumping resistance.
My curve was not obtained using proper equipment so it'll be out to some extent. It's an extrapolation of about 5 data points, being peak pumping head (for which I am 100% confident that is accurate to +/- 0.02m), peak flow rate, which I am confident to within +/- 1LPM, and the intermediate data points which I am confident to within +/- 1LPM and +/- 0.3mH2O.
I contacted the lead Laing engineer at the time and forwarded my graph and confirmed with him at the time over the phone that my graph was indeed accurate to within about 5%, in his opinion, to the results that they were seeing with the unmuffled pumps, so this gives me greater confidence in my results.
I have two pumps here, the second pump did push less pressure, being around 3.7mH2O, and this value matched more closely with what the Laing engineer observed himself in their testing, with him remarking that there will always be some variance between pumps.
