- Oct 29, 2011
- Schenectady, NY
So im having a ****ty problem with my computer right now. I dont know whats going on and im at the point where im cleaning out my water cooling system and just about to fire it back up to see if it worked.
First off, when I boot up it starts to boot up but then it the screen shuts off as if its not recognizing the video card. the thing is that i can see it starting to boot up on the screen but then it shuts off when i get to the log in page for windows. It will some time go down before I even get there but mostly im able to get to that part.
another thing it does is that the video card fan will start spinning out of control and then thats when it goes down. after that ill turn it off and try to boot up and theres nothing on the screen. Ive removed the video card and reinserted it but the problem persists.
another thing is that my dram is only showing 8 gigs when it has 12 gigs in it. Ive tested each one in each slot in different configs and all sticks are working and all slots are working but Im still only getting 8 gigs in the bios and when i check windows under usable memory.
lastly, I have 3 120mm fans on my rad which are spinning slowly until i crank up the knobs on the fan controller. Ive checked each fan in all slots and it does the same problem persists on each fan. The top fan will spin slowly and i have to crank it almost to max for it to run fast enough to push air but it always pushes it way to fast and is super loud. its like theres no in between.
Im mentioning everything because im wondering if there is any correlation to these problems. Ill list what im using at the bottom so you can know my setup and if youre able to offer any insight, suggestions, advice, help, or ANYTHING then I would be forever grateful.
Asus sabertooth x58 mobo
I7 950 bloomfield
EVGA GTX 580
Gskill ripjaws 3x4gig sticks
corsair gs800 power supply
Sunbeam RHK-BA Rheobus fan controller
crucial m4 128 gig ssd (os)
WD cavier black 1tb hd
swiftech apogee XT water block
swiftech 3.120 rad
corsair d4 water pump
I think thats about it.
any help will be appreciated guy. Thanks
I7 950 bloomfield
EVGA GTX 580
swiftech 3.120 rad
