Sounds like you might have a stubborn CPU, or a less than stellar sample from the 4690K lineup. Much like my previous 4690K.
1. You're going to need more than 1.8v on the CPU Input voltage to keep the system stable, pretty much guaranteed. Probably 1.85V should do it. It defaults to 1.9V for whatever they called the in-BIOS auto-overclocking.
2. If this is anything like my 4690K, I'd try 1.25V for the Core Voltage and see if that's stable (assuming you're still trying to get it stable that is...) (it's what mine took to be stable at 4.3GHz).
3. LLC is a good thing to have on, it tends to make things easier and make the Core Voltage more stable and predictable.
4. Basically ignore what Organik said about using Offset voltage, it tends to apply more voltage than necessary in my experience in order to stabilize an overclock (and thus cause an unnecessary increase in heat output). It's the easier/lazier way of overclocking, but it's not necessarily more efficient.
5. Actually, ignore what Organik said about adjusting the Base Clock (BCLK/BCLCK) as well. Most people can't get anywhere near 120MHz on this platform anyway, and the system tends to get unstable if you go much past say 104-105MHz on the LGA1150 platform (and LGA1155, for that matter). I wouldn't even bother adjusting that up at this point, as you're just going for a more basic overclock and that'll just throw more variables in and likely cause confusion.
6. On the bright side, from what I can see from one of your pictures it looks like you have an L4 Malaysia chip which means this should be a better overclocking candidate than the X5 Vietnam chip I have (X5's don't tend to perform well and/or need more voltage from my research, L3 and L4 CPU's from Malaysia and Costa Rica tend to do better).
My settings from my 4690K:
Batch number: X527A991
stock (100MHz x 35): 1.15v (voltage set to auto/default) (55-56°C max load temp)
4.2GHz (100MHz x 42): 1.179v (1.18v) (62°C max load temp)-ASRock Z97 Extreme6
4.3GHz (100MHz x 43): 1.247v (1.25v) (68°C max load temp)-ASRock Z97 Extreme6
4.4GHz (100MHz x 44: 1.29v) (1.29v) (77°C max load temp in Real Temp, 80°C in HWMonitor)-Asus Z97-A USB 3.1 -four hours Prime95 stable
