- Oct 22, 2008
- Boise, ID
So, I ended up switching from AMD to Intel after 13 years of AMD. I picked up an i7 920 (D0), and an Intel DX58SO.
First of all some questions for ones who know:
1. I have read not to increase your i7 920 over 1.25v, why? My Phenom 9950 was at 1.47v for 3-4 months and no issues.
2. I cannot find anywhere what a safe "Uncore" voltage is. Currently mine is at 1.30v
3. I also read not to surpass 1.65v on the DRAM, but mine is at 1.66 (XMP Profile 1600mhz)
4. Is having the "Turbo Boost" option enabled a bad idea when overclocking?
I have one issue that concerns me:
After overclocking I ran 3dmark06. During the graphics tests, the playback acts as if it skips every few seconds; even at 80fps or more. It plays smooth, but skips ahead like 10 frames every few seconds. I have the Sapphire Radeon HD4870 512mb card. This was all at 4ghz (200*20.) I thought it was my OC, so I turned it down to 3.6ghz and it still did it, but at a more frequent rate. I went down to 3.0ghz and it did it even more frequent. Here is a pic of my settings:
My cpu is at 1.275v in the BIOS but CPU-Z says 1.23v - I have never had it give me the same voltage for a few years now. The system runs stable, prime95 is fine, 3dmark all the way through, super pi and wprime all kosher. I am just concerned about my voltages. Heat isn't an issue - 63c is max load on prime95 (large ffts)
The excitement is that I tuned it to 4ghz on my second try. First was BSOD at 1.25v - upped it to 1.275 and no problems yet.
Thanks for everyone who helps!
Tubesock
Tubesock
