- Sep 19, 2003
- Rhode Island
Hi guys, after messing with this setup and reading up some on the forum for a few days this was the best i can do with an Asus P6X58D Premium, i7 930 and Corsair Dominator TR3X6G1866C9DF * PC3-15000 6GB Kit 9-9-9-24 1.65v. H50 corsair cooling and 850watt corsair PS. The system runs rock solid at these settings and passes all the test i throw at it.
Here are all my settings in the bios, I know i'm only at 19x multi but at 21x i could only get the mem to 1531 and i was trying to get as close as I could to the specs of it. But this was as close as I could get and still boot into windows. I have tried all kinds of settings and volts but still no luck.
Was wondering if anyone can leave me with some insite in maybe trying to get the ram higher or is this fine. O and i have lowered the timings on the mem since I couldn't get the 1866 at 9-9-9-24 so i figured i could run them tighter at 8-8-8-24 at 1691, and they run fine.
Any suggestions are greatly appreciated.
JumperFree Configuration Settings
AI Overclock Tuner: Manual
CPU Ratio Setting: 19x
Intel (R) SpeedStep (TM) Tech: disabled
Intel (R) Extreme phase full power: enabled
BLCK Frequency: 210
PCIE Frequency: 100
DRAM Frequency: DDR3-1691MHz
UCLK Frequency:3384MHz
QPI Link Data Rate:auto
DRAM Timing Control:
1st Information :
CAS# Latency: 8
DRAM RAS# to CAS# Delay: 8
DRAM RAS# PRE Time: 8
DRAM RAS# ACT Time: 24
DRAM RAS# to RAS# Delay: Auto
DRAM REF Cycle Time: Auto
DRAM Write Recovery Time: Auto
DRAM Read to Precharge Time: Auto
DRAM FOUR ACT WIN Time: Auto
DRAM Back-To-Back CAS# Delay: Auto
2nd Information :
DRAM Timing Mode: Auto
DRAM Round Trip Latency on CHA: Auto
DRAM Round Trip Latency on CHB: Auto
DRAM Round Trip Latency on CHC: Auto
3rd Information :
DRAM WRITE To READ Delay (DD): Auto
DRAM WRITE To READ Delay (DR): Auto
DRAM WRITE To READ Delay (SR): Auto
DRAM READ To WRITE Delay (DD): Auto
DRAM READ To WRITE Delay (DR): Auto
DRAM READ To WRITE Delay (SR): Auto
DRAM READ To READ Delay (DD): Auto
DRAM READ To READ Delay (DR): Auto
DRAM READ To READ Delay (SR): Auto
DRAM WRITE To WRITE Delay (DD): Auto
DRAM WRITE To WRITE Delay (DR): Auto
DRAM WRITE To WRITE Delay (SR): Auto
CPU Voltage: 1.30000
CPU PLL Voltage: 1.88
QPI/DRAM Core Voltage: 1.3000
IOH Voltage: Auto
IOH PCIE Voltage: Auto
ICH Voltage: Auto
ICH PCIE Voltage: Auto
DRAM Bus Voltage: 1.64
DRAM DATA REF Voltage on CHA: Auto
DRAM DATA REF Voltage on CHB: Auto
DRAM DATA REF Voltage on CHC: Auto
Load Line Calibration: Enabled
CPU Differential Amplitude: 800mV
CPU Clock Skew: Auto
CPU Spread Spectrum: Disabled
IOH Clock Skew : Auto
PCIE Spread Spectrum: Disabled
Advance CPU Settings
C1E Suppport: Disabled
Hardware Prefetcher: Enabled
Adjacent Cache Line Prefetch: Enabled
Intel® Virtualization Tech: Disabled
CPU TM Function: Disabled
Execute Disable Bit: Disabled
Intel (R) HT Techology: Enabled
Active Processor Cores: All
A20M: Disabled
Intel (R) SpeedStep (TM) Tech: Enabled
Intel (R) C-STATE Tech: Disabled
BLCK Frequency: 210
PCIE Frequency: 100
1st Information :
CAS# Latency: 8
2nd Information :
3rd Information :
IOH Voltage: Auto
ICH Voltage: Auto
A20M: Disabled
