- Jun 7, 2011
One of my boards has been delivered inside a package which was contaminated with thermal paste by the manufacturer. The board itself seems clean but package was dirty at 2 spots (white grease). Nonethless i was cleaning all the sinks and other stuff which can possibly be touched with a weak vinegar acid.
Of course i tried not to touch it but there can still be invisible traces, although the board usualy isnt touched with bare fingers (if so, hands are cleaned after). Package will be thrown away but thats not a matter since i dont usualy store packages of MBs. Its only needed for RMA (so they generally are thrown away in a few years).
Now i dont know how safe it is to the skin. Because when i used the NH-C12P paste i saw a warning message "do not touch it with your skin" or something like that. I got in mind "that must be kinda strong chemicals or metals, else there wont be such a warning". So the safety level of thermal paste is very questionable.
Reality is i dont know whats exactly inside, so i cant tell how safe it is.
But the only possible ingridients i do worry is "beryllium oxide" its a very harmful ceramic compound and even in very small doses able to be hazardous to the body, even the skin itself is not safe! But thats the only ingridient i truly feel that it is to dangerous to use, or even to store inside someones home in any condition. Its considered same level of poison such as mercury (both is T+ according to EU), and that one is considered one of the most dangerous metals.
The other possible ingridients i do consider safe to the body (skin), as long as any kind of visible traces has been cleaned from the skin immediately.
So i simply dont know the current condition and how safe it really is, and i wish do know. The golden answer to the holy question simply is, do they still use beryllium oxyde, even by knowing its high potential to be harmful (compared to any other ingridients its significantly more dangerous). Compared to Pb (lead) beryllium oxyde is still way more dangerous because lead is not toxic to the skin, it may only harm when ingested. Although nowadays most boards are lead free, but its not the most dangerous material used in computer manufacturing.
I could send the stuff to the labor for chemical analysis, but thats pricy for some infos a manufacturer is able to hand out for free.
