I'm installing my first mobo/cpu on my own.
I have two questions and need some help:
First, the ATX 12V power connector from my PSU won't fit in the appropriate connector on the mobo. The long 20-pin connector works fine, but the smaller 4-pin connector is "backwards". What I mean is that, two of the pins on the connectors are "contoured" rather than a perfect square, but the ones that are contoured don't line up. Basically the way they're shaped right now requires me to put a contoured peg in a square hole, and a square peg in a contoured hole.... that's a problem. Help with that? Is the 4pin connector required? on my old Asus A7N8X it wasn't, but the documentation for this mobo says that it is required, but the plug won't frickin fit!
Second,
Obviously the wires for the front panel buttons go to their respective buttons and LEDs (power switch reset switch, hdd LED and power LED). My question is, which is the positive and which is the negative. Each one has a colored wire (whether it is orange, green, yellow, blue, whatever) and a white wire. Is the colored wire the + wire and the white one the - wire? I'm assuming that's the way it is, but I don't want to hook things up backwards and fry my mobo/cpu.
TIA
Second,
TIA
