- Jun 20, 2003
- Fontana, CA
We'll I should have done my research but I cant enjoy watching 720p youtube vids on this thing so its going back. I cant believe I almost bought a netbook. which only has 1 atom core.
http://www.newegg.com/Product/Produ...1154091&cm_re=itx_case-_-11-154-091-_-Productya its great on power... the chipset uses more power than the cpu!!!
Im tempted to pick one up just for ****s n giggles.... but i dont have a small psu that i can use with it.
Anywhere i can get one for cheap?
We'll I put Win 7 on it and noticed that I could not get the Video driver sorted out. In the device manager it kept refreshing and had a warning sign on it. When I tested the playback I used the 720p mp4 version of HOME, a great free HD movie, using the CCCP and MPC. Since Windows 7 was having issues I'm installing XP and have read else ware that coreavc make 720p playable so I'll post back when I get that running in a hour. Also, I noticed that youtube and hulu suck because of flash. Are there any PCI GFX cards that can accelerate that type of video?
WOW! CoreAvc, best $10 ever spent. I can play 1080p .mkv files like butter and with little lag. No need for GFX acceleration with this. Thanks for suggesting that nd4spdbh2, you really saved me some time. Now I'll try Windows 7 again.
And you can download home from here via torrent or of course watch/download it from youtube. It seems that the bluray version is the only way you can get the 1080p version. Theres some site selling a download to it for $4.99.
im pretty sure core avc is multi threaded..
Also again i ask wheres a cheap place to get super small psu's like the ones you find in small itx cases?
never used coreavc, dont pay for programs that can be found for free. the psu powering my atom 330 still is the cheapy that came with the case. Ironic i know but the atom really doesnt take much power to be taxing to even this cheap psu. its rated at something like 250watts, this isnt whats in the case but worth the $24 imo
http://www.newegg.com/Product/Product.aspx?Item=N82E16817104999
i actually would like to get a pico-psu for my atom box, will free up alot of space. the psu even being small takes up alot of room inside the case.
Well I just cant get windows 7 to let me install the video driver. I might have to stay with XP on this one but as far as your PSU question goes, just look at this. Since a full atom system consumes about 45w I'm probably going to order this bundle. That 80w psu in the first link for $40 should do the trick.
EDIT.... in doing a little testing with the latest core avc which supports cuda acceleration. W/O cuda accel on my 3.4ghz e6600 (gtx 260) i use around 35% cpu playing back a 11.6Mbit 1080p video stream (gpu engine load 0%)... using Cuda Acceleration it drops cpu down to around 8-10% and gpu engine load up to ~32ish. Dunno how handy it is on lower end cuda cards but id imagine its alot more than nothing haha.
