hello dear all supporters, i need help this OC. i want my cpu OC 3.2 or 3.6 ghz.
i have
GA-EP35-DS3R motherboard.
Core 2 Quad Q6600 @2.40Ghz (1066fsb)
1333Mhz Gskill CL-9 DDR3 Ram
My bios:
Advanced BIOS Features
Hard Disk Boot Priority [Press Enter]
First Boot Device [Floppy]
Second Boot Device [Hard Disk]
Third Boot Device [CDROM]
Password Check [Setup]
HDD S.M.A.R.T Capability [Disabled]
Limit CPUID Max. to 3 [Disabled]
No-Execute Memory Protect [Enabled]
CPU Enhanced Halt (C1E) [Disabled]
CPU Thermal Monitor 2(TM2) [Disabled]
CPU EIST Function [Disabled]
Virtualization Technology [Disabled]
Full Screen LOGO Show [Enabled]
Init Display First [PCI]
Integrated Peripherals
SATA RAID/ACHI Mode [Disabled]
SATA Port0-3 Native Mode [Disabled]
USB Controller [Enabled]
USB 2.0 Controller [Enabled]
USB Keyboard Support [Disabled]
USB Mouse Support [Disabled]
Legacy USB Storage detect [Enabled]
Azalia Codec [Auto]
Onboard H/W LAN [Enabled]
>SMART LAN [Press Enter]
Onboard LAN Boot ROM [Disabled]
Onboard SATA/IDE Device [Enabled]
Onboard SATA/IDE Ctrl Mode [IDE]
Onboard Serial Port 1 [3F8/IRQ4]
Onboard Parallel Port [378/IRQ7]
Parallel Port Mode [SPP]
PC Health Status
Reset Case Open Status [Disabled]
CPU Warning Temperature [Disabled]
CPU FAN Fail Warning [Disabled]
SYSTEM FAN2 Fail Warning [Disabled]
SYSTEM FAN1 Fail Warning [Disabled]
POWER FAN Fail Warning [Disabled]
CPU Smart FAN Control [Enabled]
MB Intelligent Tweaker (MIT)
Robust Graphics Booster...........: Auto
CPU Clock Ratio...................: 9 X
CPU Frequency...................: 2.40Ghz (266x9)
CPU Host Clock Control............: [Disabled]
CPU Host Frequency(Mhz)...........: 333
PCI Express Frequency (Mhz).......: Auto
C.I.A.2...........................: Disabled
Performance Enhance...............: Turbo
System Memory Multiplier (SPD)....: Auto
Memory Frequency(Mhz).............: 1066 1066
DRAM Timing Selectable (SPD)...........: Auto
***Standard Timing Control***
CAS Latency Time (tCL)............: 7 5
DRAM RAS# to CAS# (tRCD).........: 7 5
DRAM RAS# Precharge (tRP).........: 7 5
Precharge Delay (tRAS)............: 20 Auto
***Advanced Timing Control ***
ACT to ACT Delay(tRRD)............: 4 Auto
Rank Write to READ Delay...........: 4 Auto
Write To Precharge Delay...........: 8 Auto
Refresh to ACT Delay................: 86 Auto
Read To Precharge Delay............: 4 Auto
Static tREAD Value....................: 4 Auto
Static tREAD Phase Adj............: 0 Auto
***System Voltage Optimized ***
System Voltage Control [Manual]
DDR2/DDR3 OverVoltage Control [Normal]
PCI-E OverVoltage Control [Normal]
FSB OverVoltage Control [Normal]
(G)MCG OverVoltage Control [Normal]
CPU Voltage Control [Normal]
Normal CPU Vcore 1.32500V
So im changed This
CPU Frequency...................: 3.00Ghz (333x9)
CPU Host Clock Control............: [ENABLED] << 3.00 ghz here
PCI Express Frequency (Mhz).......: 100
System Memory Multiplier (SPD)....: 3.00
Memory Frequency(Mhz).............: 1066 1333
*** System Voltage NOT Optimized ***
CPU Voltage Control [Normal] << im tested. 1.4V 1.5V
F10 Y Enter... restarting cpu... and nothing changed. CPU Host Clock Control automatically [Disabed]
please help me what must i do?
i have
My bios:
Azalia Codec [Auto]
PC Health Status
So im changed This
