Just been looking around at some local retailers. The model I want to buy is not available and I don't want to buy the higher priced ones. There's one data point I'd really like but it is too obscure for mainstream reviews. Even though many are happy to use Prime95 for max power, it seems no one uses (or understands) the built in benchmark. Can I request a Prime95 throughput benchmark? Set min/max FFT size to 128k, test HT off, rest can be default, reduce the duration to minimum of 5 seconds if desired as it doesn't really make a difference with adequate cooling. Observe running clock during the benchmark, optionally reported power. Bench output is the maximum iter/s (usually n workers, n cores at this FFT size).
