- Nov 22, 2011
- PA
Hello all! My first post after joining.
Just wanted to say happy to be a part of this website.
First off wanted to share my new build I'm using right now, and hear thoughts on it.
AMD 1100AMD Phenom II X6 1100T Black Edition Thuban 3.3GHz
G.SKILL Sniper Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1866 (PC3 14900)
ASUS Sabertooth 990FX AM3+ AMD 990FX
SAPPHIRE FleX 100312FLEX Radeon HD 6950 2GB 256-bit
Intel 320 Series SSDSA2CW120G3K5 2.5" 120GB SATA II MLC Internal Solid State Drive (SSD)
OCZ ModXStream Pro 700W Modular High Performance psu
ZALMAN CNPS9900 NT 120mm 2 Ball CPU Cooler (green led)
Cooler master Storm Enforcer Mid tower case
LG BR-RW optical drive
I went with this set up because my first plan was to get a bulldozer. However, I chickened out last minute (because of some of the reviews). I plan to get the 8170 fx when it comes out. So I got the 1100t until that drops. Which brings me to my 2nd question, The ram I acquired is pc3 14900, this was intended for the bulldozer. I was wondering since I had the 990fx mobo if I could still get this speed out of my ram (its running manually at 1600)even though I am running the 1100t? Also, the timings that are manually set in my BIOS are 11 11 11 28. The timings listed with the RAM was 9 10 9 28. Can I manually put that in while running at 1600 or are they only good if I'm running at 1866? I am a little new to all this. So any info would be terrific. Thank you in advance!
Also I would like to know a little about timings for my RAM.
