Has anyone had a problem where the GPU is working just fine (splendid actually) under power but on idle its giving out "coil whine"? I put quotes because it isnt really a coil whine, it sounds more like some PWM high frequency switch, almost like a hard drive head. The rest of the pc is super quiet, this sound is also pretty quiet but it is uneven and irritating.
It has something to do with power, that much is clear but in all honesty i cant say if its GPU or PSU related, i tried listening with a straw and it seems like its coming from GPU. Old 1080Ti didnt have any issues like this and i believe it drew more power in all regards (low and high), PSU wasnt touched with the upgrade, same cables, same routing. PSU is also single rail Strider+ 850W so it definitely has enough power.
The sound happens almost constantly on idle but it is changing tone, as i said like a higher pitched hdd head when its changing lanes a lot (some sound higher pitched, some sound more muffled). I tried following whats going on in AB plots but got nothing consistent. With a small load the sound seems to still be there but almost cannot be heard, it really needs total silence and concentration and at that level im not sure if im really hearing it or is it just stuck in my head.
I found a way to reproduce it tho, at its highest volume and to make it constant so im not crazy.
Since i play everything in windowed mode on a 55" tv, when desktop is idle the sound is there and when i launch a game the sound stops completely (clear change) and then it is kinda back once the game starts but very very low (as described above). While the application is running it will stay as such with very minor oscilation and basically any sound from the game or music will cover it completely (fans wont tho, since all are super quiet). Now, when the game is running and i pick up the game window to move it the game will freeze while the window is being moved and the sound will go bonkers, being as loud and as constant as it gets. As soon as i release the window, the sound goes silent.
Has anyone had anything similar?
EDIT: Oh, forgot to mention, i do a bit of night crypto mining, to pay off the scalping prices of GPU. When the GPU is mining (theres load on it, in W more than with a low powered game) the sound is still present same as on idle. ETH mining basically only uses memory so this makes me think the problem is in the chip power delivery, not the memory power delivery.
