I used to use the program Rain to make sure my K6-2 wasn't getting too hot... I haven't used the program in a while... is it advisable to use this program when overclocking or does it negate the effects of o/c'ing the processor?
It only helps your temps while your CPU is at idle speeds under full load it does not work and it is not ment too at full load. Its best if you only run Rain on a Intel system as to many AMD users have problems with it, if you want to run software to help out with idle temps try www.tweakfiles.com and try another program.
